[Mapbender-commits] r1731 - in branches/mapbender_sld/resources/db:
mysql postgresql
svn_mapbender at osgeo.org
Mon Oct 15 10:32:14 EDT 2007
Author: mschulz
Date: 2007-10-15 10:32:14 -0400 (Mon, 15 Oct 2007)
New Revision: 1731
branches/mapbender_sld/resources/db/mysql/mysql_schema.sql
branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql
added fkey_gui_id, changed columns fkey_layer_id, fkey_mb_user_id
Modified: branches/mapbender_sld/resources/db/mysql/mysql_schema.sql
--- branches/mapbender_sld/resources/db/mysql/mysql_schema.sql 2007-10-15 14:30:05 UTC (rev 1730)
+++ branches/mapbender_sld/resources/db/mysql/mysql_schema.sql 2007-10-15 14:32:14 UTC (rev 1731)
@@ -338,12 +338,13 @@
CREATE TABLE sld_user_layer (
- id int(11) NOT NULL auto_increment,
- mb_user_id int(11) NOT NULL default '0',
- layer_id int(11) NOT NULL default '0',
+ sld_user_layer_id int(11) NOT NULL auto_increment,
+ fkey_mb_user_id int(11) NOT NULL default '0',
+ fkey_layer_id int(11) NOT NULL default '0',
+ fkey_gui_id int(11) NOT NULL default '0',
sld_xml longtext default NULL,
use_sld int(4) default NULL,
- PRIMARY KEY (id)
+ PRIMARY KEY (sld_user_layer_id)
) TYPE=InnoDB;
Modified: branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql
--- branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql 2007-10-15 14:30:05 UTC (rev 1730)
+++ branches/mapbender_sld/resources/db/postgresql/pgsql_schema.sql 2007-10-15 14:32:14 UTC (rev 1731)
@@ -361,11 +361,12 @@
- id serial NOT NULL,
- mb_user_id integer NOT NULL,
- layer_id integer NOT NULL,
+ sld_user_layer_id serial NOT NULL,
+ fkey_mb_user_id integer NOT NULL,
+ fkey_layer_id integer NOT NULL,
+ fkey_gui_id character varying,
sld_xml text,
- use_sld smallint
+ use_sld smallint,
@@ -1094,5 +1095,5 @@
ALTER TABLE mb_log ADD CONSTRAINT pk_mb_log PRIMARY KEY (id);
-ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (id);
+ALTER TABLE sld_user_layer ADD CONSTRAINT pk_sld_user_layer PRIMARY KEY (sld_user_layer_id);
More information about the Mapbender_commits
