[Mapbender-commits] r1689 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 26 05:49:10 EDT 2007
Author: christoph
Date: 2007-09-26 05:49:10 -0400 (Wed, 26 Sep 2007)
New Revision: 1689
   trunk/mapbender/http/classes/class_checkInput.php
   trunk/mapbender/http/classes/class_stripRequest.php
   trunk/mapbender/http/php/mod_getStyles.php
http://trac.osgeo.org/mapbender/ticket/103
Modified: trunk/mapbender/http/classes/class_checkInput.php
--- trunk/mapbender/http/classes/class_checkInput.php	2007-09-26 09:39:44 UTC (rev 1688)
+++ trunk/mapbender/http/classes/class_checkInput.php	2007-09-26 09:49:10 UTC (rev 1689)
@@ -38,7 +38,7 @@
 					$v[$i] = db_escape_string($v[$i]);
 				else if($t[$i] == 'i'){
-					if(preg_match("/w/",$v[$i])){
+					if(preg_match("/\w/",$v[$i])){
 						$e = new mb_exception($_SERVER['SCRIPT_FILENAME'].": Unable to parse integer in: ".$q." with: param ".$i.",".$v[i]);
 						die("wrong data type in sql:".$q);
Modified: trunk/mapbender/http/classes/class_stripRequest.php
--- trunk/mapbender/http/classes/class_stripRequest.php	2007-09-26 09:39:44 UTC (rev 1688)
+++ trunk/mapbender/http/classes/class_stripRequest.php	2007-09-26 09:49:10 UTC (rev 1689)
@@ -39,7 +39,8 @@
 			$tmp = explode("=", $patterns[$i]);
 			if(mb_strtoupper($tmp[0]) == mb_strtoupper($key)){
 				$replacement = mb_strtoupper($key) . "=" . $value;
-				$this->url = preg_replace($patterns[$i],$replacement, $this->url);
+				$currentPattern = "/" . $patterns[$i] . "/";
+				$this->url = preg_replace($currentPattern, $replacement, $this->url);
 				$exists = true;
@@ -92,7 +93,8 @@
 				$replacement = "";
 		$this->encodeGET();
@@ -127,7 +129,7 @@
 	function encodeLegGET(){
-		$this->url = preg_replace("&", "\&", $this->url);
+		$this->url = preg_replace("/&/", "\&", $this->url);
 		return $this->url;
Modified: trunk/mapbender/http/php/mod_getStyles.php
--- trunk/mapbender/http/php/mod_getStyles.php	2007-09-26 09:39:44 UTC (rev 1688)
+++ trunk/mapbender/http/php/mod_getStyles.php	2007-09-26 09:49:10 UTC (rev 1689)
@@ -126,7 +126,8 @@
 	@fclose($style_xml);
 	fclose($style_file);
 	#include(dirname(__FILE__)."/../../conf/www.conf");
-	$sql = "UPDATE wms SET wms_filter = '".preg_replace(basename($login),$style_filename,$login)."' WHERE wms_id = ". $wmsList;
+	$pattern = "/" . basename($login) . "/";
+	$sql = "UPDATE wms SET wms_filter = '".preg_replace($pattern,$style_filename,$login)."' WHERE wms_id = ". $wmsList;
 	echo $sql;
 	db_query($sql) or die("unable to change filter!");
More information about the Mapbender_commits mailing list
