[Mapbender-commits] r1690 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 26 09:38:29 EDT 2007
Author: nimix
Date: 2007-09-26 09:38:29 -0400 (Wed, 26 Sep 2007)
New Revision: 1690
   trunk/mapbender/http/javascripts/map.js
   trunk/mapbender/http/javascripts/map_obj.js
a lot of prototype function for redesign
Modified: trunk/mapbender/http/javascripts/map.js
--- trunk/mapbender/http/javascripts/map.js	2007-09-26 09:49:10 UTC (rev 1689)
+++ trunk/mapbender/http/javascripts/map.js	2007-09-26 13:38:29 UTC (rev 1690)
@@ -215,26 +215,305 @@
    this.epsg = wms[0].gui_wms_epsg;
    this.extent = setExtent(this.width,this.height,this.epsg);
    this.mapURL = [];
+	 * get the width of the mapObj
+	 * @member mb_mapObj_const
+	 * @return width of the mapObj
+	 * @type integer
+	this.getWidth = function(){
+		return parseInt(this.width);
+	 * set the width of the mapObj
+	 * @param {integer} widht the width of the mapObj
+	this.setWidth = function(width){
+		this.width = parseInt(width);
+	 * get the height of the mapObj
+	 * @type integer
+	this.getHeight = function(){
+		return parseInt(this.height);
+	 * set the height of the mapObj
+	 * @param {integer} height the height of the mapObj
+	this.setHeight = function(height){
+		this.height = parseInt(height);
+	 * get the extent of the mapObj
+	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+	 * @type string
+	this.getExtent = function(){
+		return this.extent;
+	 * get the extent as minx, maxx, miny, maxy
+	 * @return extent and additional informations of the mapObj
+	 * @type Object
+	this.getExtentInfos = function(){
+		var c = this.getExtent().split(",");
+		var ext = new Extent(c[0],c[1],c[2],c[3]);
+		return ext;
+	 * converts the extent of the mapobject so that the maximum	extent will be displayed
+	this.calculateExtent = function(ext){
+		var relation_px_x = this.getWidth() / this.getHeight();
+		var relation_px_y = this.getHeight() / this.getWidth();
+		var relation_bbox_x = ext.extentx / ext.extenty;
+		if(relation_bbox_x <= relation_px_x){
+			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+		if(relation_bbox_x > relation_px_x){
+			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+	 * zoom the map with a zoomfactor and optional to x,y coords
+	 * @param {boolean} in_ in = true, out = false
+	 * @param {float} factor the zoomfactor 1 equals 100%
+	 * @param {float} x center to x-position
+	 * @param {float} y center to y-position
+	 this.zoom = function(in_, factor, x, y){
+		factor = parseFloat(factor);
+		if (!in_) {
+			factor = 1 / factor;
+		var extent = this.getExtentInfos();
+		var distx = extent.maxx - extent.minx;
+		var disty =  extent.maxy - extent.miny;
+		if(x && y){
+			var centerx = parseFloat(x);
+			var centery = parseFloat(y);
+		else{
+			var centerx = extent.minx + distx/2;
+			var centery = extent.miny + disty/2;
+		var new_distx = distx / factor;
+		var new_disty = disty / factor;
+		var minx = centerx - new_distx / 2;
+		var miny = centery - new_disty / 2;
+		var maxx = centerx + new_distx / 2;
+		var maxy = centery + new_disty / 2;
+		this.setExtent(minx,miny,maxx,maxy);
+		//Todo:
+		//setMapRequest!
+	 * set the extent of the wms
+	 this.setExtent = function(minx,miny,maxx,maxy){
+	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
+	 * get the srs of the mapObj
+	 * @return srs as epsg:number
+	 * @type string
+	this.getSRS = function(){
+		return this.epsg;
+	 * get all mapRequests
+	 * @return array of mapRequests of this map object
+	 * @type string[]
+	this.getMapRequests = function(){
+		var allRequests = [];
+		//loop through all wms to get the mapRequests
+		for(var i=0; i<this.wms.length; i++){
+			var currentRequest = this.wms[i].getMapRequest(this);
+			if(currentRequest){
+				allRequests.push(currentRequest);
+		if(allRequests.length > 0){
+			return allRequests;
+		return false;
+	 * get all MapRequests
+	 * @return array of all mapRequests of this map-object
+	 * @type string[]
+		//loop through all wms to get the MapRequests
+		return false;
+	 * get all featureInfoRequests
+	 * @param float x the x-value of the click position in pixel
+	 * @param float y the y-value of the click position in pixel
+	 * @return array of all featureInfoRequests of this map object
+	 * @type string[]
+	this.getFeatureInfoRequests = function(clickPoint){
+		//loop through all wms to get the FeatureInfoRequests
+			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+		return false;
+	 * calculation of the mapscale
+	 * @return scale
+	 * @type integer
+	this.getScale = function(){
+		var scale;
+		var bbox = this.extent.split(",");
+		var xtenty;
+		if(this.epsg=="EPSG:4326"){
+			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
+			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
+			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
+			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
+			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
+			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
+			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
+			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
+		}else{
+			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
+			scale = (xtenty / this.height) * (mb_resolution * 100);
+		return Math.round(scale);
+	 * move a wms or layer
+	 * @param int wms_id id of wms to move
+	 * @param int layer_id id of layer to move
+	 * @return true of successful
+	 * @type boolean
+	this.move = function(wms_id, layer_id, moveUp){
+		var i,j;
+		for(i=0;i<this.wms.length;i++){
+			if(wms_id==this.wms[i].wms_id)
+				break;
+		//check if only one wms is affected?
+		if(layer_id&&layer_id!=this.wms[i].objLayer[0].layer_id)
+			return this.wms[i].moveLayer(layer_id, moveUp);
+		//else swap wms
+		j = i + (moveUp?-1:1);
+		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length))
+			return false;
+		upper = this.wms[i];
+		this.wms[i] = this.wms[j];
+		this.wms[j] = upper;
+		var upperLayers = this.layers[i];
+		var upperStyles = this.styles[i];
+		var upperQuerylayers = this.querylayers[i];
+		this.layers[i] = this.layers[j];
+		this.styles[i] = this.styles[j];
+		this.querylayers[i] = this.querylayers[j];
+		this.layers[j] = upperLayers;
+		this.styles[j] = upperStyles;
+		this.querylayers[j] = upperQuerylayers;
+		return true;
    for(var i=0; i<mb_MapObjectSubFunctions.length; i++){
       eval(mb_MapObjectSubFunctions[i]);
+ * get the conjunction character of an URL
+ * @param {String} onlineresource
+ * @return the character & or ?
+ * @type String
 function mb_getConjunctionCharacter(onlineresource){
+	var conChar;
 	if(onlineresource.indexOf("?") > -1){
 		if(onlineresource.charAt(onlineresource.length-1) == "?"){
-			nextvalue = "";
+			conChar = "";
 		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
-			nextvalue = "";
+			conChar = "";
 		}else{
-			nextvalue = "&";
+			conChar = "&";
 	if(onlineresource.indexOf("?") == -1){
-		nextvalue = "?";
+		conChar = "?";
-	return nextvalue;
+	return conChar;
@@ -601,14 +880,14 @@
 			var styles = "";
 			var querylayers = "";
 			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
 					if(cnt_layers > 0){layers += ","; styles += ","; }
 					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
 					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
 					styles += "";
 					cnt_layers++;
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
 					if(cnt_querylayers > 0){querylayers += ",";}
 					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
 					cnt_querylayers++;
@@ -751,29 +1030,22 @@
        document.getElementById(elName).innerHTML = tagSource;
+ * global function to zoom a mapobject
+ * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
+ * @deprecated
 function zoom(frameName,in_, factor,x,y) {
-  var x = parseFloat(x);
-  var y = parseFloat(y);
-  var ind = getMapObjIndexByName(frameName);
-  var arrayBBox = mb_mapObj[ind].extent.split(",");
-  var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
-  var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
-  var centerx = parseFloat(arrayBBox[0]) + xtentx/2;
-  var centery = parseFloat(arrayBBox[1]) + xtenty/2;
-  var factor = parseFloat(factor);
-  if(x){
-   centerx = x;
-   centery = y;
-  if (!in_) {factor = 1 / factor;}
-  var new_xtentx = xtentx / factor;
-  var new_xtenty = xtenty / factor;
-  var minx = centerx - new_xtentx / 2;
-  var miny = centery - new_xtenty / 2;
-  var maxx = centerx + new_xtentx / 2;
-  var maxy = centery + new_xtenty / 2;
-  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
-  setMapRequest(frameName);
+	var obj = getMapObjByName(frameName);
+	if(x && y){
+		obj.zoom(in_, factor, x, y);
+	else{
+		obj.zoom(in_, factor, false, false);
+	setMapRequest(frameName);
 function mb_panMap(frameName,dir){
@@ -997,6 +1269,14 @@
+function getMapObjByName(frameName){
+	for(var i=0; i<mb_mapObj.length; i++){
+		if(mb_mapObj[i].frameName == frameName){
+			return mb_mapObj[i];
+	return false;
 function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
 	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
 		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
@@ -1069,27 +1349,37 @@
+ * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
+ * use: mb_mapObj.calculateExtent
+ * @deprecated
 function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var extenty = parseFloat(maxy) - parseFloat(miny);
-  var extentx = parseFloat(maxx) - parseFloat(minx);
-  var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
-  var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
-  var relation_bbox_x = extentx / extenty;
-  var centerx = parseFloat(minx) + (extentx/2);
-  var centery = parseFloat(miny) + (extenty/2);
-  if(relation_bbox_x <= relation_px_x){
-    minx = centerx - relation_px_x * extenty / 2;
-    maxx = centerx + relation_px_x * extenty / 2;
-  if(relation_bbox_x > relation_px_x){
-    miny = centery - relation_px_y * extentx / 2;
-    maxy = centery + relation_px_y * extentx / 2;
-  mb_mapObj[ind].extent = minx  +","+ miny +","+ maxx  +","+ maxy;
+  var map = getMapObjByName(frameName);
+  var extent = new Extent(minx,miny,maxx,maxy);
+  map.calculateExtent(extent);
+ * @class extent
+ * @param {float} minx
+ * @param {float} miny
+ * @param {float} maxx
+ * @param {float} maxy
+ * @return the extent as object
+ * @type Object
+function Extent(minx,miny,maxx,maxy){
+	this.minx = parseFloat(minx);
+	this.miny = parseFloat(miny);
+	this.maxx = parseFloat(maxx);
+	this.maxy = parseFloat(maxy);
+	this.extentx = this.maxx - this.minx;
+	this.extenty = this.maxy - this.miny;
+	this.centerx = this.minx + this.extentx/2;
+	this.centery = this.miny + this.extenty/2;
+	return this;
 function mb_showHighlight(frameName,x,y){
    var pos = makeRealWorld2mapPos(frameName,x, y);
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2007-09-26 09:49:10 UTC (rev 1689)
+++ trunk/mapbender/http/javascripts/map_obj.js	2007-09-26 13:38:29 UTC (rev 1690)
@@ -5,9 +5,27 @@
 //global variables
-var wms = new Array();
+var wms = [];
 var wms_layer_count = 0;
-//list of all wms-objects
+ * global function to add wms to the wms-object
+ * @param {String} wms_id the unique id of the wms
+ * @param {String} wms_version the version assumed from capabilities
+ * @param {String} wms_title the title of the wms
+ * @param {String} wms_abstract the abstract of the wms
+ * @param {String} wms_getmap the url for map requests
+ * @param {String} wms_getfeatureinfo the url for featureInof requests
+ * @param {String} wms_getlegendurl the url for legend requests
+ * @param {String} wms_filter a filter (deprecated)
+ * @param {String} gui_wms_mapformat the image-format in the actual gui
+ * @param {String} gui_wms_featureinfoformat the current format for featureInfos
+ * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
+ * @param {String} gui_wms_epsg the current srs
+ * @param {Integer} gui_wms_visible the visibility of this service
+ * @param {String} gui_wms_sldurl url to an actual sld
 function add_wms(
 			wms_id,
 			wms_version,
@@ -21,7 +39,8 @@
 			gui_wms_featureinfoformat,
 			gui_wms_exceptionformat,
 			gui_wms_epsg,
-			gui_wms_visible){
+			gui_wms_visible,
+			gui_wms_sldurl){
 					wms[wms.length] = new wms_const(
 					wms_id,
 					wms_version,
@@ -35,10 +54,30 @@
 					gui_wms_epsg,
-					gui_wms_visible);
-					wms_layer[wms.length - 1] = new Array();
+					parseInt(gui_wms_visible),
+					gui_wms_sldurl);
+					wms_layer[wms.length - 1] = [];
-//the wms constructor
+ * @class A class representing the wms
+ * @constructor
+ * @param {String} gui_wms_visible the visibility of this service
 function wms_const(
 			wms_id,
 			wms_version,
@@ -52,7 +91,8 @@
 			gui_wms_epsg,
-			gui_wms_visible){
+			gui_wms_visible,
+			gui_wms_sldurl){
 	if (!wms_id) {
 		var id_ok = false;
@@ -73,23 +113,357 @@
 	this.wms_getfeatureinfo = wms_getfeatureinfo;
 	this.wms_getlegendurl = wms_getlegendurl;
 	this.wms_filter = wms_filter;
-	this.data_type = new Array();
-	this.data_format = new Array();
-	this.objLayer = new Array();
+	this.data_type = [];
+	this.data_format = [];
+	this.objLayer = [];
 	this.gui_wms_mapformat = gui_wms_mapformat;
 	this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
 	this.gui_wms_exceptionformat = gui_wms_exceptionformat;
 	this.gui_wms_epsg = gui_wms_epsg;
 	this.gui_wms_visible = gui_wms_visible;
-	this.gui_epsg = new Array();
-	this.gui_minx = new Array();
-	this.gui_miny = new Array();
-	this.gui_maxx = new Array();
-	this.gui_maxy = new Array();
+	this.gui_epsg = [];
+	this.gui_minx = [];
+	this.gui_miny = [];
+	this.gui_maxx = [];
+	this.gui_maxy = [];
-// opacity version
-	this.gui_wms_mapopacity = 1;
+	// opacity version
+	this.gui_wms_mapopacity = 1;
+	// sld version
+	this.gui_wms_sldurl = gui_wms_sldurl;
+ * rephrases the mapRequest
+ * @param {Object} mapObj the mapbender mapObject of the wms
+ * @return mapRequest, i.e. onlineresource + params
+ * @type String
+wms_const.prototype.getMapRequest = function(mapObj){
+	//console.log()
+	//check visible layers first
+	var layers = this.getLayers(mapObj);
+	if(!layers){
+		return false;
+	var rq = this.wms_getmap;
+	rq += mb_getConjunctionCharacter(this.wms_getmap);
+	if(this.wms_version === "1.0.0"){
+		rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
+	else{
+		rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
+	rq += "&LAYERS=" + layers.join(",");
+	rq += "&WIDTH=" + mapObj.getWidth();
+	rq += "&HEIGHT=" + mapObj.getHeight();
+	rq += "&SRS=" + mapObj.getSRS();
+	rq += "&BBOX=" + mapObj.getExtent();
+	rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
+	rq += "&FORMAT=" + this.gui_wms_mapformat;
+	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
+	//Todo: error occurs:
+	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
+	//window.console.log("getMapRequest: " + rq);
+	return rq;
+ * rephrases the featureInfoRequest
+ * @param {Point} clickPoint map-click position {@link Point}
+ * @return featureInfoRequest, onlineresource + params
+ * @type string
+wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
+	//check layers and querylayers first
+	var querylayers = this.getQuerylayers(mapObj);
+	if(!layers || !querylayers){
+		return false;
+	var rq = this.wms_getfeatureinfo;
+	rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
+		rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
+	else{
+		rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
+	rq += "&QUERY_LAYERS=" + querylayers.join(",");
+	rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
+	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
+	rq += "&X=" + clickPoint.x;
+	rq += "&Y=" + clickPoint.y;
+	//console.log(rq);
+	return rq;
+ * get all visible layers
+ * @return array of layernames
+ * @type string[]
+wms_const.prototype.getLayers = function(mapObj){
+	//visibility of the wms
+	var wmsIsVisible = (this.gui_wms_visible > 0);
+	if(!wmsIsVisible){
+		return false;
+	visibleLayers = [];
+	for(var i=0; i< this.objLayer.length; i++){
+		if(this.objLayer[i].gui_layer_visible === 1 && ! this.objLayer[i].has_childs){
+			if(this.objLayer[i].checkScale(mapObj)){
+				//console.log("checkLayer: " + this.objLayer[i].layer_name);
+				visibleLayers.push(this.objLayer[i].layer_name);
+	if(visibleLayers.length === 0){
+		return false;
+	return visibleLayers;
+ * get the actual style of all visible layers
+ * @return commaseparated list of actual layerstyles
+ * @type string
+wms_const.prototype.getLayerstyles = function(mapObj){
+	var layerstyles = '';
+	var styles = [];
+	if(layers){
+		for(i = 0; i < layers.length; i++){
+			var style = this.getStyleByLayerName(layers[i]);
+			if(!style){
+				style = '';
+			styles.push(style)
+		return styles;
+	return false;
+ * get the style of the layer
+ * @param layername
+ * @return the stylename of the given layer
+ * @type string
+wms_const.prototype.getStyleByLayerName = function(layername){
+	return false;
+ * get all querylayers
+ * @type string[]
+wms_const.prototype.getQuerylayers = function(){
+	queryLayers = [];
+		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
+			queryLayers.push(this.objLayer[i].layer_name);
+	if(queryLayers.length === 0){
+		return false;
+	return queryLayers;
+ * get a layer Object by layer_pos
+ * @param int payer_pos layer_pos of layer you want to get
+ * @return object layer
+wms_const.prototype.getLayerByLayerPos = function(layer_pos){
+	for(var i=0;i<this.objLayer.length;i++){
+		if(this.objLayer[i].layer_pos == layer_pos)
+			return this.objLayer[i];
+	return null;
+ * get the state of sublayers from a specified layer
+ * @param int layer_id of the parent layer
+ * @param String type "visible" or "querylayer"
+ * @return int -1 if state differs else the state
+wms_const.prototype.getSublayerState = function(layer_id, type){
+	var i;
+	var state=-1,value;
+	for(i = 0; i < this.objLayer.length; i++){
+		if(this.objLayer[i].layer_id==layer_id)
+			break;
+	//go throught sublayers
+	for(var j = i+1; j < this.objLayer.length; j++){
+		if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer)
+			break;
+		if(type == "visible")
+			value = this.objLayer[j].gui_layer_visible;
+		else if(type == "querylayer")
+			value = this.objLayer[j].gui_layer_querylayer;
+		if(state == -1)
+			state = value;
+		if(state != value)
+			return -1;
+	return state;
+ * handle change of visibility / quaryability of a layer
+ * @param string layer_name of layer to handle
+ * @param string type of change ("visible" or "querylayer")
+ * @param int value of the change
+wms_const.prototype.handleLayer = function(layer_name, type, value){
+	var i;
+		if(this.objLayer[i].layer_name==layer_name)
+			break;
+	//Set visibility/queryability of Layer and Sublayers
+	for(var j = i; j < this.objLayer.length; j++){
+		if(i != j && this.objLayer[i].layer_parent == this.objLayer[j].layer_parent)
+			break;
+			this.objLayer[j].gui_layer_visible = parseInt(value);
+		else if(type=="querylayer")
+			this.objLayer[j].gui_layer_querylayer = parseInt(value);
+	//Update visibility/queryability of parent layer
+	var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
+	if(parentLayer){
+		var state = this.getSublayerState(parentLayer.layer_id, type);
+		if(state!=-1){
+				this.objLayer[j].gui_layer_visible = state;
+				this.objLayer[j].gui_layer_querylayer = state;
+ * move a layer (with his sublayers) up or down
+ * @param int layerId layer_id of layer to move
+ * @param boolean moveUp true to move up or false to move down
+ * @return boolean success
+wms_const.prototype.moveLayer = function(layerId, moveUp){
+	var iLayer=-1;
+	var i;
+	//find layer to move
+	for(i=0;i<this.objLayer.length;i++){
+		if(this.objLayer[i].layer_id==layerId){
+			iLayer=i;
+			break;
+	if(iLayer==-1)
+		return false;
+	var upperLayer = -1;
+	var lowerLayer = -1;
+	//find layer to swap position with
+	var parentLayer = this.objLayer[iLayer].layer_parent;
+	if(moveUp){
+		lowerLayer = iLayer;
+		//find previous layer on same level
+		for(i=iLayer-1;i>0;i--){
+			if(parentLayer == this.objLayer[i].layer_parent){
+				upperLayer = i;
+				break;
+		if(upperLayer == -1){
+			//alert("The Layer you selected is already on top of parent Layer/WMS");
+			return false;
+	else{
+		upperLayer = iLayer;
+		//find next layer on same level
+		for(i=iLayer+1;i<this.objLayer.length;i++){
+				lowerLayer = i;
+				break;
+		if(lowerLayer == -1){
+			//alert("The Layer you selected is already on bottom of parent Layer/WMS");
+			return false;
+	//calc number of layers to move down
+	var layersDown = lowerLayer - upperLayer;
+	//get number of layers to move up
+	for(i=lowerLayer+1; i<this.objLayer.length; i++){
+			break;
+	var layersUp = i - lowerLayer;
+	//do moving
+	var temp = [];
+	for(i=0;i<layersDown+layersUp;i++){
+		temp[temp.length]=this.objLayer[upperLayer+i];
+	for(i=0;i<layersUp;i++){
+		this.objLayer[upperLayer+i]=temp[i+layersDown];
+	for(i=0;i<layersDown;i++){
+		this.objLayer[upperLayer+layersUp+i]=temp[i];
+	return true;
 function wms_add_data_type_format(datatype,dataformat){
 	var insertDataFormat = true;
 	for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
@@ -110,16 +484,16 @@
 	wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
 function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
-	if (wms[wms.length-1].objLayer[layerCount]) {
-		wms[wms.length-1].objLayer[layerCount].layer_style[count] = new Array();
-		wms[wms.length-1].objLayer[layerCount].layer_style[count]["name"] = styleName;
-		wms[wms.length-1].objLayer[layerCount].layer_style[count]["title"] = styleTitle;
-		wms[wms.length-1].objLayer[layerCount].layer_style[count]["legendurl"] = styleLegendUrl;
-		wms[wms.length-1].objLayer[layerCount].layer_style[count]["legendurlformat"] = styleLegendUrlFormat;
+	var currentLayer = wms[wms.length-1].objLayer[layerCount];
+	if (currentLayer) {
+		currentLayer.layer_style[count] = [];
+		currentLayer.layer_style[count]["name"] = styleName;
+		currentLayer.layer_style[count]["title"] = styleTitle;
+		currentLayer.layer_style[count]["legendurl"] = styleLegendUrl;
+		currentLayer.layer_style[count]["legendurlformat"] = styleLegendUrlFormat;
+//TODO: add layerstyle handling....
 //layer
 function wms_add_layer(
 			layer_parent,
@@ -155,23 +529,27 @@
 											layer_metadataurl,
 											gui_layer_wms_id,
 											gui_layer_status,
-											gui_layer_selectable,
-											gui_layer_visible,
-											gui_layer_queryable,
-											gui_layer_querylayer,
-											gui_layer_minscale,
-											gui_layer_maxscale,
+											parseInt(gui_layer_selectable),
+											parseInt(gui_layer_visible),
+											parseInt(gui_layer_queryable),
+											parseInt(gui_layer_querylayer),
+											parseInt(gui_layer_minscale),
+											parseInt(gui_layer_maxscale),
 											gui_layer_wfs_featuretype );
+	var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent));
+	if(parentLayer)
+		parentLayer.has_childs = true;
 function layer_addEpsg(epsg,minx,miny,maxx,maxy){
-	var j=wms[wms.length-1].objLayer.length-1;
-	var k=wms[wms.length-1].objLayer[j].layer_epsg.length;
-	wms[wms.length-1].objLayer[j].layer_epsg[k]=new Array();
-	wms[wms.length-1].objLayer[j].layer_epsg[k]["epsg"]=epsg;
-	wms[wms.length-1].objLayer[j].layer_epsg[k]["minx"]=minx;
-	wms[wms.length-1].objLayer[j].layer_epsg[k]["miny"]=miny;
-	wms[wms.length-1].objLayer[j].layer_epsg[k]["maxx"]=maxx;
-	wms[wms.length-1].objLayer[j].layer_epsg[k]["maxy"]=maxy;
+	var j = wms[wms.length-1].objLayer.length-1;
+	var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
+	var currentLayer = wms[wms.length-1].objLayer[j];
+	currentLayer.layer_epsg[k]=[];
+	currentLayer.layer_epsg[k]["epsg"]=epsg;
+	currentLayer.layer_epsg[k]["minx"]=minx;
+	currentLayer.layer_epsg[k]["miny"]=miny;
+	currentLayer.layer_epsg[k]["maxx"]=maxx;
+	currentLayer.layer_epsg[k]["maxy"]=maxy;
 function wms_layer(
 			layer_parent,
@@ -204,7 +582,7 @@
 	this.layer_minscale = layer_minscale;
 	this.layer_maxscale = layer_maxscale;
 	this.layer_metadataurl = layer_metadataurl;
-	this.layer_epsg = new Array();
+	this.layer_epsg = [];
 	this.gui_layer_wms_id = gui_layer_wms_id;
 	this.gui_layer_status = gui_layer_status;
 	this.gui_layer_selectable = gui_layer_selectable;
@@ -214,6 +592,45 @@
 	this.gui_layer_minscale = gui_layer_minscale;
 	this.gui_layer_maxscale = gui_layer_maxscale;
 	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
-	this.layer_style = new Array();
+	this.gui_layer_style;
+	this.has_childs = false;
+	this.layer_style = [];
 	wms_layer_count++;
\ No newline at end of file
+ * check the scale of the layer
+ * @param Object mapObj the mapbender mapObject of the layer
+ * @return boolean if the layer is in scale or not
+ * @type boolean
+wms_layer.prototype.checkScale = function(mapObj){
+	var minScale = this.gui_layer_minscale;
+	var maxScale = this.gui_layer_maxscale;
+	var currentScale = mapObj.getScale();
+	if(minScale === 0 && maxScale === 0){
+		return true;
+	if(minScale < currentScale || maxScale > currentScale){
+		return false;
+	return true;
+ * set visibility of the layer
+ * @param boolean visible visibility on/off
+wms_layer.prototype.setVisible = function(visible){
+	this.gui_layer_visible = parseInt(visible);
+	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
+ * set queryability of the layer
+ * @param boolean queryable queryability on/off
+wms_layer.prototype.setQueryable = function(queryable){
+	this.gui_layer_querylayer = parseInt(queryable);
+	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
More information about the Mapbender_commits mailing list
