[Mapbender-commits] r1691 - in trunk/mapbender/http: html
javascripts
svn_mapbender at osgeo.org
Wed Sep 26 09:39:38 EDT 2007
Author: nimix
Date: 2007-09-26 09:39:38 -0400 (Wed, 26 Sep 2007)
New Revision: 1691
trunk/mapbender/http/html/mod_treefolder2.php
trunk/mapbender/http/javascripts/jsTree.js
Sublayer and reverse support for Treefolder2
Modified: trunk/mapbender/http/html/mod_treefolder2.php
--- trunk/mapbender/http/html/mod_treefolder2.php 2007-09-26 13:38:29 UTC (rev 1690)
+++ trunk/mapbender/http/html/mod_treefolder2.php 2007-09-26 13:39:38 UTC (rev 1691)
@@ -58,6 +58,8 @@
var jst_display_root = false;
var defaultTarget = 'examplemain';
var lock=false;
+var lock_update=false;
+var lock_check=false;
var selectedMap=-1;
var selectedWMS=-1;
var selectedLayer=-1;
@@ -74,6 +76,7 @@
function _foo(){}
// some defaults
+try{if (reverse){}}catch(e){reverse = 'false';}
try{if (switchwms){}}catch(e){switchwms = 'true';}
try{if (ficheckbox){}}catch(e){ficheckbox = 'false';}
try{if (metadatalink){}}catch(e){metadatalink = 'false';}
@@ -81,6 +84,7 @@
try{if (showstatus){}}catch(e){showstatus = 'false';}
try{if (alerterror){}}catch(e){alerterror = 'false';}
try{if (openfolder){}}catch(e){openfolder = 'false';}
+try{if (handlesublayer){}}catch(e){handlesublayer = 'false';}
try{if (menu){}}catch(e){menu = '';}
//menu elements
@@ -121,19 +125,19 @@
if(selectedLayer==0)
setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_name, '#999999');
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
else if(scale > parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
else
else{
setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_name, '');
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
selectedMap=i;
@@ -152,19 +156,19 @@
if(iii==0)
setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '#999999');
else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name, '#999999');
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '#999999');
else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
if(iii==0)
else
else{
if(iii==0)
setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id, '');
else
- setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_name, '');
+ setNodeColor(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '');
@@ -254,6 +258,8 @@
+//parent.mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
function init_mapcheck(){
if(!init)return;
errors = 0;
@@ -271,11 +277,14 @@
function handleSelectedLayer(mapObj,wms_id,layername,type,status){
- var mywms = new Array();
- mywms[0] = wms_id;
- var mylayername = new Array();
- mylayername[0] = layername;
- parent.handleSelectedLayer_array(mapObj, mywms, mylayername, type, status);
+ if(lock_update||lock_check)return;
+ var ind = parent.getMapObjIndexByName(mapObj);
+ for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ if(parent.mb_mapObj[ind].wms[i].wms_id == wms_id){
+ parent.mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+ break;
function zoomToLayer(j,k,l){
@@ -326,7 +335,7 @@
if (parent.mb_mapObj[mapObj_id].wms[wms_id].gui_wms_visible > 0) {
var divId = 'div_'+wms_id;
wmsImage = parent.mapframe1.document.getElementById(divId);
- if (wmsImage != null && !isNaN(opacity) && opacity != 100) {
+ if (wmsImage != null && !isNaN(opacity)) {
wmsImage.style.opacity = (opacity / 100);
wmsImage.style.MozOpacity = (opacity / 100);
wmsImage.style.KhtmlOpacity = (opacity / 100);
@@ -348,7 +357,7 @@
//---end------------- opacity --------------------
function move_up(j,k,l){
- if(!j&&!k&&!l){
+ if(isNaN(j)&&isNaN(k)&&isNaN(l)){
j=selectedMap;
k=selectedWMS;
l=selectedLayer;
@@ -357,95 +366,62 @@
alert("You have to select the WMS you want to move up!")
return;
- if(l!=0){
- if(l==1){
- alert("The Layer you selected is already on top of the WMS");
- return;
- var my = parent.mb_mapObj[j];
- var upperLayers = my.wms[k].objLayer[l-1];
- my.wms[k].objLayer[l-1] = my.wms[k].objLayer[l];
- my.wms[k].objLayer[l] = upperLayers;
- //Reload the mapframe by calling zoom function with factor one
- treeState = getState();
- parent.zoom(my.frameName, true, 1.0);
- parent.mb_execloadWmsSubFunctions();
- select(j, k, l-1);
- selectNode(arrNodes[0][0]+"|"+my.wms[k].wms_id+"|"+my.wms[k].objLayer[l-1].layer_name);
+ var lid=parent.mb_mapObj[j].wms[k].objLayer[l].layer_id;
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
+ alert("Illegal move operation");
return;
- var previousWMS=-1;
- for(var i=k-1;i>=0;i--)
- if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1){
- previousWMS=i;
- break;
+ treeState = getState();
+ parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
+ parent.mb_execloadWmsSubFunctions();
+ //find layer and select
+ for(k=0;k<parent.mb_mapObj[j].wms.length;k++){
+ for(l=0;l<parent.mb_mapObj[j].wms[k].objLayer.length;l++){
+ if(parent.mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
+ select(j,k,l);
+ if(l!=0)
+ selectNode(String(lid));
+ else
+ selectNode(String(parent.mb_mapObj[j].wms[k].wms_id));
- if(previousWMS==-1){
- alert("The selected WMS is already on top!")
- return;
- if (parent.mb_swapWmsByIndex(j, previousWMS, k) == true){
- parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
- select(j, previousWMS, 0);
- selectNode(arrNodes[0][0]+"|"+parent.mb_mapObj[j].wms[previousWMS].wms_id);
function move_down(j,k,l){
- if(!j&&!k&&!l){
j=selectedMap;
k=selectedWMS;
l=selectedLayer;
if(j==-1||k==-1||l==-1){
alert("You have to select the WMS you want to move down!")
return;
- if(l!=0){
- if(selectedLayer==my.wms[k].objLayer.length-1){
- alert("The Layer you selected is already on bottom of the WMS");
- return;
- var nextLayers = my.wms[k].objLayer[l+1];
- my.wms[k].objLayer[l+1] = my.wms[k].objLayer[l];
- my.wms[k].objLayer[l] = nextLayers;
- select(j, k, l+1);
- selectNode(arrNodes[0][0]+"|"+my.wms[k].wms_id+"|"+my.wms[k].objLayer[l+1].layer_name);
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
return;
- var nextWMS=-1;
- for(var i=k+1;i<parent.mb_mapObj[j].wms.length;i++){
- nextWMS=i;
- break;
+ select(j,k,l);
+ if(l!=0)
+ else
- if(nextWMS==-1){
- alert("The selected WMS is already on bottom!")
- return;
- if (parent.mb_swapWmsByIndex(j, k, nextWMS) == true){
- select(j, nextWMS, 0);
- selectNode(arrNodes[0][0]+"|"+parent.mb_mapObj[j].wms[nextWMS].wms_id);
function remove_wms(j,k,l){
- if(!j&&!k&&!l){
j=selectedMap;
k=selectedWMS;
l=selectedLayer;
@@ -474,37 +450,55 @@
function updateParent(path){
- if(lock)return;
- lock=true;
+ if(lock_check)return;
+ var reset_lock=!lock_update;
+ lock_update=true;
var state=getChildrenCheckState(path, 0);
//enableCheckbox(path, (state!=-1)); //3rd state
checkNode(path, 0, (state==1));
- if(state==0 && showstatus=='true'){
-/* var arrPath = path.split(jst_delimiter[0])
- var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
- for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++)
- if(parent.mb_mapObj[ind].wms[wms].wms_id==arrPath[arrPath.length-1])
- break;
-*/ setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
-// state[wms]=-1;
- lock=false;
+ if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
+ setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
+ if(reset_lock)
+ lock_update=false;
function handleSelectedWMS(path){
- if(lock)return;
- lock=true;
+ if(lock_update)return;
+ var t = path.split("|");
+ var reset_lock=!lock_check;
+ var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
+ var layername = parent.mb_mapObj[ind].wms[parent.getWMSIndexById(mod_treeGDE_map,t[t.length-1])].objLayer[0].layer_name;
var bChk = IsChecked(path, 0);
- enableCheckbox(path, 0, true);
+ handleSelectedLayer(mod_treeGDE_map,t[t.length-1],layername,"visible",bChk?"1":"0");
+ lock_check=true;
checkChildren(path, 0, bChk);
if(ficheckbox)checkChildren(path, 1, bChk);
if(bChk==false && showstatus=='true')
- lock=false;
+ if(reset_lock)
+ lock_check=false;
+ parent.mb_restateLayers(mod_treeGDE_map,t[t.length-1]);
+ parent.setSingleMapRequest(mod_treeGDE_map,t[t.length-1]);
+function handleSelection(path){
+ lock_check=true;
+ var bChk = IsChecked(path, 0);
+// enableCheckbox(path, 0, true);
+ checkChildren(path, 0, bChk);
+ if(reset_lock){
+ lock_check=false;
+ parent.mb_restateLayers(mod_treeGDE_map,t[1]);
+ parent.setSingleMapRequest(mod_treeGDE_map,t[1]);
function initArray(){
var parentObj = "";
var controls="";
@@ -517,27 +511,49 @@
var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
var c_menu="[";
- if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
- if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
+ if(reverse=="true"){
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
// if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
if(menu.indexOf("opacity_up")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
if(menu.indexOf("opacity_down")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
c_menu+="]";
- if(switchwms=='true') {
- addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,"javascript:select("+i+","+ii+","+iii+");",,,,eval(c_menu),'<INPUT type="checkbox" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />',[i,ii,iii]]],false,false);
- else {
- addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,"javascript:select("+i+","+ii+","+iii+");",,,,eval(c_menu),,[i,ii,iii]]],false,false);
+ controls=null;
+ if(switchwms=='true')controls='<INPUT type="checkbox" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
+ if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\'../php/mod_layerMetadata.php?id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
+ addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
parentObj = arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id;
- if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == "0"){
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"||parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
+ var parentLayer = "";
+ var j = iii;
+ while(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
+ //find parent
+ for(var jj=0; jj < parent.mb_mapObj[i].wms[ii].objLayer.length; jj++){
+ if(parent.mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
+ j=jj;
+ break;
+ parentLayer = "|" + parent.mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
var c_menu="[";
- if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
- if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
// if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
@@ -545,10 +561,10 @@
c_menu+="]";
- controls='<input type="checkbox" '+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);updateParent('"+parentObj+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
- if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)\" />";
+ controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"');updateParent('"+parentObj+parentLayer+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
+ if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);checkChildren('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1, this.checked?1:0)\" />";
- addNode(parentObj, [temp.layer_name,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,(c_menu!='[]'?'menu.png':null),,eval(c_menu),controls,[i,ii,iii]]],false,false);
+ addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
Modified: trunk/mapbender/http/javascripts/jsTree.js
--- trunk/mapbender/http/javascripts/jsTree.js 2007-09-26 13:38:29 UTC (rev 1690)
+++ trunk/mapbender/http/javascripts/jsTree.js 2007-09-26 13:39:38 UTC (rev 1691)
@@ -187,6 +187,11 @@
eval(ps)[d].push(new Array())
eval(ps)[d][2].push(nd)
break;
+ case "u":
+ if(!eval(ps)[d][2])
+ eval(ps)[d].push(new Array())
+ eval(ps)[d][2].unshift(nd)
+ break;
return true
@@ -201,8 +206,8 @@
return false
-function addNode(path, nd, sel, refresh){
- if(_editDataNode("a", path, nd)){
+function addNode(path, nd, sel, refresh, begining){
+ if(_editDataNode((begining?"u":"a"), path, nd)){
if(refresh){
rebuildNode(path, true)
rebuildNode(path)
@@ -242,16 +247,22 @@
function setState(data){
jst_state_paths = data.split(jst_delimiter[1])
for(var p in jst_state_paths){
- var tr = getDomNode(jst_state_paths[p])
- if(tr){
- var f1 = tr.firstChild
- if(f1){
- var f2 = f1.firstChild
- if(!isExpanded(tr) && f2)
- if(f2.onclick)
- f2.onclick()
+ var path="";
+ var pathElements = jst_state_paths[p].split(jst_delimiter[0]);
+ for(i in pathElements){
+ path += pathElements[i];
+ var tr = getDomNode(path)
+ if(tr){
+ var f1 = tr.firstChild
+ if(f1){
+ var f2 = f1.firstChild
+ if(!isExpanded(tr) && f2)
+ if(f2.onclick)
+ f2.onclick()
+ path+=jst_delimiter[0];
@@ -395,7 +406,7 @@
var plus;
if(!nd)return false;
- if(!childExists(nd))nd.firstChild.firstChild.onclick();
+ if(!childExists(nd))return false;
var tBody = nd.nextSibling.childNodes[1].firstChild.firstChild;
if(!tBody)return false;
for(var i = 0;i < tBody.childNodes.length; i++){
@@ -405,8 +416,7 @@
var cb = tBody.childNodes[i].childNodes[1].childNodes[ctrlNr+plus];
if(cb && cb.nodeName=="INPUT"&&!cb.disabled){
cb.checked = bChk;
- if(cb.onclick){cb.onclick();}
-//TODO DataNode anpassen
+ if(cb.onclick){cb.onclick();}
return true;
@@ -588,16 +598,20 @@
return
}else{
- ctlImg.src = jst_image_folder + "/" + (tr.nextSibling ? "" : "last_") + "expanded.png"
+ ctlImg.src = jst_image_folder + "/" + (tr.nextSibling ? "" : "last_") + "closed.png"
if(eval(strData.substr(0, strData.length-3)+"[1][3]"))
fldImg.src = jst_image_folder + "/" + eval(strData.substr(0, strData.length-3)+"[1][3]");
else
- fldImg.src = jst_image_folder + "/expanded_folder.png";
+ fldImg.src = jst_image_folder + "/closed_folder.png";
var newTr = tr.parentNode.insertRow((tr.rowIndex?tr.rowIndex:0) + 1)
+ if(ctlImg.id != "rootFolder"){
+ newTr.style.display = "none";
newTr.appendChild(document.createElement('td'))
@@ -605,7 +619,20 @@
newTr.firstChild.setAttribute("background", jst_image_folder + "/branch.png", "false")
newTr.childNodes[1].innerHTML = renderChildren(strData)
+ var nodes = eval(strData)
+ var ndWithChildren = 0;
+ for(var n in nodes){
+ var n0 = nodes[n]
+ var n1 = n0[2]
+ if(n1){
+ renderNode(strData + "[" + n + "][2]" ,newTr.childNodes[1].firstChild.firstChild.childNodes[parseInt(n)+ndWithChildren].firstChild.firstChild);
+ ndWithChildren++;
jst_loaded = true
More information about the Mapbender_commits
