[Mapbender-commits] r2376 - branches/2.5/http/sld
svn_mapbender at osgeo.org
Thu Apr 10 19:06:36 EDT 2008
Author: mschulz
Date: 2008-04-10 19:06:36 -0400 (Thu, 10 Apr 2008)
New Revision: 2376
branches/2.5/http/sld/sld_config.php
branches/2.5/http/sld/sld_edit_filter.php
branches/2.5/http/sld/sld_filter_parse.php
branches/2.5/http/sld/sld_main.php
branches/2.5/http/sld/sld_parse.php
added mb_validateSession urlParameters to sld related urls
Modified: branches/2.5/http/sld/sld_config.php
--- branches/2.5/http/sld/sld_config.php 2008-04-10 23:01:35 UTC (rev 2375)
+++ branches/2.5/http/sld/sld_config.php 2008-04-10 23:06:36 UTC (rev 2376)
@@ -25,14 +25,12 @@
include_once(dirname(__FILE__)."/classes/StyledLayerDescriptor.php");
-session_start();
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
include_once(dirname(__FILE__)."/sld_parse.php");
// this should come from mapbender.conf
-$SLD_MAIN = "sld_main.php?".SID;
-$SLD_FUNCTION_HANDLER = "sld_function_handler.php";
+$SLD_MAIN = "sld_main.php?".$urlParameters;
+$SLD_FUNCTION_HANDLER = "sld_function_handler.php?".$urlParameters;
$MAPBENDER_URL = "http://".$_SERVER["HTTP_HOST"].dirname($_SERVER['PHP_SELF']);
function char_encode($s){
@@ -42,15 +40,15 @@
return $s;
-if (isset($_REQUEST["wms_id"]) && isset($_REQUEST["gui_id"]))
+if (isset($_REQUEST["sld_wms_id"]) && isset($_REQUEST["sld_gui_id"]))
- $_SESSION["sld_wms_id"] = $_REQUEST["wms_id"];
- $_SESSION["sld_gui_id"] = $_REQUEST["gui_id"];
+ $_SESSION["sld_wms_id"] = $_REQUEST["sld_wms_id"];
+ $_SESSION["sld_gui_id"] = $_REQUEST["sld_gui_id"];
-if (isset($_REQUEST["layer_name"]))
+if (isset($_REQUEST["sld_layer_name"]))
- $_SESSION["sld_layer_name"] = $_REQUEST["layer_name"];
+ $_SESSION["sld_layer_name"] = $_REQUEST["sld_layer_name"];
if (isset($_SESSION["sld_wms_id"]) && isset($_SESSION["sld_layer_name"]))
Modified: branches/2.5/http/sld/sld_edit_filter.php
--- branches/2.5/http/sld/sld_edit_filter.php 2008-04-10 23:01:35 UTC (rev 2375)
+++ branches/2.5/http/sld/sld_edit_filter.php 2008-04-10 23:06:36 UTC (rev 2376)
@@ -31,7 +31,7 @@
-session_start();
+require_once(dirname(__FILE__)."/sld_config.php");
include_once(dirname(__FILE__)."/sld_filter_parse.php");
//get the neccessary variables from the request or from the session
@@ -91,22 +91,22 @@
$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new UnaryLogicOp("Not");
break;
case "PROPERTYISEQUALTO":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsEqualTo");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsEqualTo");
break;
case "PROPERTYISNOTEQUALTO":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsNotEqualTo");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsNotEqualTo");
break;
case "PROPERTYISGREATERTHAN":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsGreaterThan");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsGreaterThan");
break;
case "PROPERTYISGREATERTHANOREQUALTO":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsGreaterThanOrEqualTo");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsGreaterThanOrEqualTo");
break;
case "PROPERTYISLESSTHAN":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsLessThan");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsLessThan");
break;
case "PROPERTYISLESSTHANOREQUALTO":
- $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("ogc:PropertyIsLessThanOrEqualTo");
+ $_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new BinaryComparisonOp("PropertyIsLessThanOrEqualTo");
break;
case "PROPERTYISLIKE":
$_SESSION["sld_filter_objects"][$_REQUEST["id"]]->operations[] = new PropertyIsLike();
@@ -175,7 +175,7 @@
- header("Location: sld_edit_filter.php");
+ header("Location: sld_edit_filter.php?".$urlParameters);
exit();
else
@@ -221,7 +221,7 @@
if ($first_load != 1) echo " onLoad=\"setFilter();\"";
echo ">\n";
- echo "<form name=\"editFilter\" action=\"sld_edit_filter.php\" method=\"post\">\n";
+ echo "<form name=\"editFilter\" action=\"sld_edit_filter.php?".$urlParameters."\" method=\"post\">\n";
echo "<table cellspacing=\"0\" cellpadding=\"0\">\n";
echo "<tr align=\"center\"><td class=\"bg2 text3\">Filter bearbeiten</td></tr>\n";
Modified: branches/2.5/http/sld/sld_filter_parse.php
--- branches/2.5/http/sld/sld_filter_parse.php 2008-04-10 23:01:35 UTC (rev 2375)
+++ branches/2.5/http/sld/sld_filter_parse.php 2008-04-10 23:06:36 UTC (rev 2376)
@@ -27,7 +27,6 @@
-session_start();
Modified: branches/2.5/http/sld/sld_main.php
--- branches/2.5/http/sld/sld_main.php 2008-04-10 23:01:35 UTC (rev 2375)
+++ branches/2.5/http/sld/sld_main.php 2008-04-10 23:06:36 UTC (rev 2376)
@@ -25,33 +25,17 @@
* @package sld_main
* @author Markus Krzyzanowski
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
$classWfsConf = new wfs_conf();
-include_once(dirname(__FILE__)."/sld_config.php");
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
//read custom sld for this user&wms&layer&gui from the db instead using sld.xml
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db($DB,$con);
//Read the layer_id from the DB
-//$sql = "SELECT * FROM layer WHERE fkey_wms_id=".$_SESSION["sld_wms_id"]." AND layer_name='".$_SESSION["sld_layer_name"]."';";
-//$res = db_query($sql);
$dbutils = new DbUtils();
$layer_id = $dbutils->getLayerIdFromLayerName($_SESSION["sld_wms_id"], $_SESSION["sld_layer_name"]);
if ( $layer_id )
@@ -148,8 +132,8 @@
$sld_url = "";
$mb_sld_url = "";
//$sld_url = "http://".$_SERVER["HTTP_HOST"]."/mapbender/sld/sld_function_handler.php?function=getusersld&layer_id=".$layer_id."&user_id=".$mb_user_id."&forcesld=1";
-$sld_url = $MAPBENDER_URL."/sld_function_handler.php?function=getusersld&gui_id=".$_SESSION["sld_gui_id"]."&layer_id=".$layer_id."&user_id=".$mb_user_id."&forcesld=1";
-$mb_sld_url = $MAPBENDER_URL."/sld_function_handler.php?function=getusersld&gui_id=".$_SESSION["sld_gui_id"]."&wms_id=".$_SESSION["sld_wms_id"]."&user_id=".$mb_user_id;
+$sld_url = $MAPBENDER_URL."/sld_function_getusersld.php?function=getusersld&sld_gui_id=".$_SESSION["sld_gui_id"]."&sld_layer_id=".$layer_id."&user_id=".$mb_user_id."&forcesld=1";
+$mb_sld_url = $MAPBENDER_URL."/sld_function_getusersld.php?function=getusersld&sld_gui_id=".$_SESSION["sld_gui_id"]."&sld_wms_id=".$_SESSION["sld_wms_id"]."&user_id=".$mb_user_id;
echo "<!-- $sld_url -->";
echo "<!-- $previewMapUrl -->";
## - 2.Zeile
@@ -262,11 +246,11 @@
//echo " <form id=\"sld_editor_form\" action=\"http://".$_SERVER["HTTP_HOST"]."/mapbender/sld/".$SLD_FUNCTION_HANDLER."\" method=post >\n";
echo " <form id=\"sld_editor_form\" action=\"".$MAPBENDER_URL."/".$SLD_FUNCTION_HANDLER."\" method=post >\n";
-echo " <a href='".$SLD_FUNCTION_HANDLER."?function=getdefaultsld' onclick='if(!confirm(\"Aktuelle SLD-Definition ersetzen?\")) return false;'>\n";
+echo " <a href='".$SLD_FUNCTION_HANDLER."&function=getdefaultsld' onclick='if(!confirm(\"Aktuelle SLD-Definition ersetzen?\")) return false;'>\n";
echo " <img src='./img/script.png' border='0' alt='Standard SLD aus WMS auslesen'>\n";
echo " </a> Standard öffnen<br /><br />\n";
-echo " <input type='image' src='./img/script_save.png' border='0' alt='�nderungen an die Map senden'>\n";
+echo " <input type='image' src='./img/script_save.png' border='0' alt='Änderungen an die Map senden'>\n";
echo " SLD speichern<br>\n";
echo " <input type='hidden' name='function' value='save'>\n";
echo " <br /><a href=\"".$sld_url."\" target=_new>";
Modified: branches/2.5/http/sld/sld_parse.php
--- branches/2.5/http/sld/sld_parse.php 2008-04-10 23:01:35 UTC (rev 2375)
+++ branches/2.5/http/sld/sld_parse.php 2008-04-10 23:06:36 UTC (rev 2376)
@@ -33,7 +33,6 @@
-session_start();
More information about the Mapbender_commits
