[Mapbender-commits] r2377 - branches/2.5/http/sld
svn_mapbender at osgeo.org
Thu Apr 10 19:07:30 EDT 2008
Author: mschulz
Date: 2008-04-10 19:07:30 -0400 (Thu, 10 Apr 2008)
New Revision: 2377
branches/2.5/http/sld/sld_function_handler.php
extracted function getusersld to new module
Modified: branches/2.5/http/sld/sld_function_handler.php
--- branches/2.5/http/sld/sld_function_handler.php 2008-04-10 23:06:36 UTC (rev 2376)
+++ branches/2.5/http/sld/sld_function_handler.php 2008-04-10 23:07:30 UTC (rev 2377)
@@ -29,14 +29,9 @@
* @author Markus Krzyzanowski
-//session_start();
include_once(dirname(__FILE__)."/sld_config.php");
include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
* This function saves the data into the database
* @param string $data the content of the sld-document to be stored inside the database
@@ -68,10 +63,10 @@
$styledlayerdescriptor->generateObjectFromPost();
saveSld($styledlayerdescriptor->generateXml());
- // the function "getusersld" is called by the mapserver to get the user's sld
+ /* the function "getusersld" is called by the mapserver to get the user's sld
else if ($_REQUEST["function"] == "getusersld")
- if ( isset($_REQUEST["layer_id"]) && isset($_REQUEST["gui_id"]) && isset($_REQUEST["user_id"]) )
+ if ( isset($_REQUEST["sld_layer_id"]) && isset($_REQUEST["sld_gui_id"]) && isset($_REQUEST["user_id"]) )
{ //Used for the preview
$con = db_connect($DBSERVER,$OWNER,$PW);
db_select_db($DB,$con);
@@ -95,7 +90,7 @@
- /*$sld_xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<StyledLayerDescriptor version=\"1.0.0\">\n";*/
+ #$sld_xml = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<StyledLayerDescriptor version=\"1.0.0\">\n";
$sld_xml = "<StyledLayerDescriptor version=\"1.0.0\" xmlns=\"http://www.opengis.net/sld\" xmlns:ogc=\"http://www.opengis.net/ogc\">\n";
foreach ($layer_names as $layer_name)
@@ -127,7 +122,7 @@
$sld_xml .= "</StyledLayerDescriptor>";
echo $sld_xml;
} //Used for mapbender integration
- else if ( isset($_REQUEST["wms_id"]) && isset($_REQUEST["gui_id"]) )
+ else if ( isset($_REQUEST["sld_wms_id"]) && isset($_REQUEST["sld_gui_id"]) )
@@ -160,7 +155,7 @@
echo $sld_xml;
// sets whether the user wishes to use a sld for this layer
else if ($_REQUEST["function"] == "usesld")
More information about the Mapbender_commits
