[Mapbender-commits] r3317 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Mon Dec 15 08:27:27 EST 2008
Author: christoph
Date: 2008-12-15 08:27:27 -0500 (Mon, 15 Dec 2008)
New Revision: 3317
trunk/mapbender/http/classes/class_gml2.php
trunk/mapbender/http/classes/class_wfs_conf.php
trunk/mapbender/http/php/mod_wfs_result.php
http://trac.osgeo.org/mapbender/ticket/347
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php 2008-12-15 13:25:44 UTC (rev 3316)
+++ trunk/mapbender/http/classes/class_gml2.php 2008-12-15 13:27:27 UTC (rev 3317)
@@ -17,10 +17,10 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-require_once(dirname(__FILE__)."/../classes/class_connector.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
class gml2 {
var $geomtype_point = 'Point';
var $geomtype_polygon = 'Polygon';
@@ -35,6 +35,7 @@
var $geometry = array();
var $bbox = array();
var $doc;
+ var $geomFeaturetypeElement = null;
function gml2(){
@@ -55,7 +56,9 @@
function parseXML($data) {
+ if (func_num_args() == 2) {
+ $this->geomFeaturetypeElement = func_get_arg(1);
$this->doc = $this->removeWhiteSpace($data);
return $this->toGeoJSON();
@@ -93,7 +96,12 @@
$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
$feature = new Feature();
- $feature->parse($featureMember_dom);
+ if ($this->geomFeaturetypeElement != null) {
+ $feature->parse($featureMember_dom, $this->geomFeaturetypeElement);
+ else {
+ $feature->parse($featureMember_dom);
if (isset($feature->geometry)) {
$featureCollection->addFeature($feature);
@@ -198,7 +206,7 @@
xml_parser_free($parser);
foreach ($values as $element) {
- #$e = new mb_exception($element[tag]);
+ #$e = new mb_exception($element[tag]);
if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
$boundedBy = true;
@@ -360,10 +368,10 @@
elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
- else{
- $e = new mb_notice("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."' or no geometry existing");
- return "";
+ else{
+ $e = new mb_notice("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."' or no geometry existing");
+ return "";
$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
@@ -422,6 +430,7 @@
var $fid;
var $geometry = false;
var $properties = array();
public function __construct() {
@@ -432,50 +441,54 @@
return $nodeName;
- * Parses the feature segment of a GML and stores the geometry in the
- * $geometry variable of the class.
- * Example of a feature segment of a GML.
- * <gml:featureMember>
- * <ms:ROUTE fid="ROUTE.228168">
- * <gml:boundedBy>
- * <gml:Box srsName="EPSG:31466">
- * <gml:coordinates>2557381.0,5562371.1 2557653.7,5562526.0</gml:coordinates>
- * </gml:Box>
- * </gml:boundedBy>
- * <ms:geometry>
- * <gml:LineString>
- * 2557380.97,5562526 2557390.96,
- * 5562523.22 2557404.03,5562518.2 2557422.31,
- * 5562512 2557437.16,5562508.37 2557441.79,
- * 5562507.49 2557454.31,5562505.1 2557464.27,
- * 5562503.97 2557473.24,5562502.97 2557491.67,
- * 5562502.12 2557505.65,5562502.43 2557513.78,
- * 5562501.12 2557520.89,5562498.79 2557528.5,
- * 5562495.07 2557538.9,5562488.91 2557549.5,
- * 5562483.83 2557558.55,5562476.61 2557569.07,
- * 5562469.82 2557576.61,5562462.72 2557582.75,
- * 5562457.92 2557588.57,5562452.56 2557590.38,
- * 5562449.69 2557593.57,5562445.07 2557596.17,
- * 5562441.31 2557601.71,5562433.93 2557612.97,
- * 5562421.03 2557626,5562405.33 2557639.66,
- * 5562389.75 2557653.69,5562371.12
- * </gml:coordinates>
- * </gml:LineString>
- * </ms:geometry>
- * <code>354</code>
- * <Verkehr>0</Verkehr>
- * <rlp>t</rlp>
- * </ms:ROUTE>
- * </gml:featureMember>
- * @return void
- * @param $domNode DOMNodeObject the feature tag of the GML
- * (<gml:featureMember> in the above example)
+ * Parses the feature segment of a GML and stores the geometry in the
+ * $geometry variable of the class.
+ * Example of a feature segment of a GML.
+ * <gml:featureMember>
+ * <ms:ROUTE fid="ROUTE.228168">
+ * <gml:boundedBy>
+ * <gml:Box srsName="EPSG:31466">
+ * <gml:coordinates>2557381.0,5562371.1 2557653.7,5562526.0</gml:coordinates>
+ * </gml:Box>
+ * </gml:boundedBy>
+ * <ms:geometry>
+ * <gml:LineString>
+ * 2557380.97,5562526 2557390.96,
+ * 5562523.22 2557404.03,5562518.2 2557422.31,
+ * 5562512 2557437.16,5562508.37 2557441.79,
+ * 5562507.49 2557454.31,5562505.1 2557464.27,
+ * 5562503.97 2557473.24,5562502.97 2557491.67,
+ * 5562502.12 2557505.65,5562502.43 2557513.78,
+ * 5562501.12 2557520.89,5562498.79 2557528.5,
+ * 5562495.07 2557538.9,5562488.91 2557549.5,
+ * 5562483.83 2557558.55,5562476.61 2557569.07,
+ * 5562469.82 2557576.61,5562462.72 2557582.75,
+ * 5562457.92 2557588.57,5562452.56 2557590.38,
+ * 5562449.69 2557593.57,5562445.07 2557596.17,
+ * 5562441.31 2557601.71,5562433.93 2557612.97,
+ * 5562421.03 2557626,5562405.33 2557639.66,
+ * 5562389.75 2557653.69,5562371.12
+ * </gml:coordinates>
+ * </gml:LineString>
+ * </ms:geometry>
+ * <code>354</code>
+ * <Verkehr>0</Verkehr>
+ * <rlp>t</rlp>
+ * </ms:ROUTE>
+ * </gml:featureMember>
+ * @return void
+ * @param $domNode DOMNodeObject the feature tag of the GML
+ * (<gml:featureMember> in the above example)
public function parse($domNode) {
$currentSibling = $domNode->firstChild;
$this->fid = $currentSibling->getAttribute("fid");
@@ -490,13 +503,14 @@
$namespace = $this->sepNameSpace($name);
$ns = $namespace['ns'];
$columnName = $namespace['value'];
+ $isGeomColumn = ($this->geomFeaturetypeElement == null || $columnName == $this->geomFeaturetypeElement);
- // check if this node is a geometry node.
- // however, even if it is a property node,
- // it has a child node, the text node!
- // So we might need to do something more
- // sophisticated here...
- if ($currentSibling->hasChildNodes()){
+ // check if this node is a geometry node.
+ // however, even if it is a property node,
+ // it has a child node, the text node!
+ // So we might need to do something more
+ // sophisticated here...
+ if ($currentSibling->hasChildNodes() && $isGeomColumn){
$geomNode = $currentSibling->firstChild;
$geomType = $geomNode->nodeName;
switch ($geomType) {
@@ -523,12 +537,12 @@
case "gml:Envelope" :
$this->geometry = new GMLEnvelope();
$this->geometry->parseEnvelope($geomNode);
- default:
- $this->properties[$columnName] = $value;
- break;
+ default:
+ $this->properties[$columnName] = $value;
+ break;
- else {
+ else {
@@ -556,7 +570,7 @@
$cnt ++;
- $json = new Mapbender_JSON();
+ $json = new Mapbender_JSON();
$str .= $json->encode($prop);
$str .= "}";
@@ -948,4 +962,4 @@
return $str;
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php 2008-12-15 13:25:44 UTC (rev 3316)
+++ trunk/mapbender/http/classes/class_wfs_conf.php 2008-12-15 13:27:27 UTC (rev 3317)
@@ -49,7 +49,7 @@
// parameter is a number
if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
- $idArray = array(intval($idOrIdArray));
+ $idOrIdArray = array(intval($idOrIdArray));
// parameter is an array of numbers
@@ -69,7 +69,7 @@
$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
- return $this->getWfsConfFromDB($idArray);
+ return $this->getWfsConfFromDbByArray($idArray);
// parameter is invalid
else {
@@ -108,6 +108,16 @@
return $rowArray;
+ public static function getGeomColumnNameByConfId ($confId) {
+ $elArray = self::getWfsConfElementFromDb($confId);
+ foreach ($elArray as $element) {
+ if ($element["f_geom"] == "1") {
+ return $element["element_name"];
+ return null;
* Gets the database content of a WFS conf element given by a WFS conf ID.
Modified: trunk/mapbender/http/php/mod_wfs_result.php
--- trunk/mapbender/http/php/mod_wfs_result.php 2008-12-15 13:25:44 UTC (rev 3316)
+++ trunk/mapbender/http/php/mod_wfs_result.php 2008-12-15 13:27:27 UTC (rev 3317)
@@ -21,6 +21,7 @@
require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
require_once(dirname(__FILE__) . "/../classes/class_connector.php");
require_once(dirname(__FILE__) . "/../classes/class_gml2.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
$filter = stripslashes($_REQUEST["filter"]);
$url = stripslashes($_REQUEST["url"]);
@@ -88,8 +89,10 @@
$data = $connection->file;
if (!$data) die('{}');
+$geomColumn = WfsConf::getGeomColumnNameByConfId($db_wfs_conf_id);
$wfsResult = new gml2 ();
-$geoJson = $wfsResult->parseXML($data);
+$geoJson = $wfsResult->parseXML($data, $geomColumn);
header('Content-type: text/html');
echo $geoJson;
More information about the Mapbender_commits
