[Mapbender-commits] r3318 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Dec 15 08:30:12 EST 2008
Author: christoph
Date: 2008-12-15 08:30:12 -0500 (Mon, 15 Dec 2008)
New Revision: 3318
   branches/2.5/http/classes/class_gml2.php
   branches/2.5/http/classes/class_wfs_conf.php
http://trac.osgeo.org/mapbender/ticket/347
but the bug is not fixed in 2.5.1, because mod_wfs_result doesn't yet use JSON (trunk does)
Modified: branches/2.5/http/classes/class_gml2.php
--- branches/2.5/http/classes/class_gml2.php	2008-12-15 13:27:27 UTC (rev 3317)
+++ branches/2.5/http/classes/class_gml2.php	2008-12-15 13:30:12 UTC (rev 3318)
@@ -35,6 +35,7 @@
 	var $geometry = array();
 	var $bbox = array();
 	var $doc;
+	var $geomFeaturetypeElement = null;
 	function gml2(){
@@ -55,8 +56,10 @@
 	function parseXML($data) {
-		$this->doc = $data;
+		if (func_num_args() == 2) {
+			$this->geomFeaturetypeElement = func_get_arg(1);
+		$this->doc = $this->removeWhiteSpace($data);
 		return $this->toGeoJSON();
@@ -78,6 +81,7 @@
 		$gmlDoc = new SimpleXMLElement($this->doc);
 		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$gmlDoc->registerXPathNamespace('wfs', 'http://www.opengis.net/wfs');
 		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
 		// build feature collection
@@ -92,7 +96,12 @@
 				$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
 				$feature = new Feature();
-				$feature->parse($featureMember_dom);
+				if ($this->geomFeaturetypeElement != null) {
+					$feature->parse($featureMember_dom, $this->geomFeaturetypeElement);
+				else {
+					$feature->parse($featureMember_dom);
 				if (isset($feature->geometry)) {
 					$featureCollection->addFeature($feature);
@@ -102,7 +111,7 @@
 			return $featureCollection->toGeoJSON();
 		else{
-			return "{'errorMessage':'Kein Ergebnis'}";
+			return "{}";
@@ -421,6 +430,7 @@
 	var $fid;
 	var $geometry = false;
 	var $properties = array();
 	public function __construct() {
@@ -475,6 +485,10 @@
 	 * 								(<gml:featureMember> in the above example)
 	public function parse($domNode) {
 		$currentSibling = $domNode->firstChild;
 		$this->fid = $currentSibling->getAttribute("fid");
@@ -489,13 +503,15 @@
 			$namespace = $this->sepNameSpace($name);
 			$ns = $namespace['ns'];
 			$columnName = $namespace['value'];
+			$isGeomColumn = ($this->geomFeaturetypeElement == null || $columnName == $this->geomFeaturetypeElement);
 			// check if this node is a geometry node.
 			// however, even if it is a property node,
 			// it has a child node, the text node!
 			// So we might need to do something more
 			// sophisticated here...
-			if ($currentSibling->hasChildNodes()){
+			if ($currentSibling->hasChildNodes() && $isGeomColumn){
 				$geomNode = $currentSibling->firstChild;
 					$geomType = $geomNode->nodeName;
 					switch ($geomType) {
@@ -580,7 +596,7 @@
-	private function addPoint ($x, $y) {
+	protected function addPoint ($x, $y) {
 		array_push($this->pointArray, array("x" => $x, "y" => $y));
@@ -621,7 +637,7 @@
-	private function setPoint ($x, $y) {
+	protected function setPoint ($x, $y) {
 #		echo "x: " . $x . " y: " . $y . "\n";
 		$this->point = array("x" => $x, "y" => $y);
@@ -675,7 +691,7 @@
@@ -735,8 +751,7 @@
-	private function addPoint ($x, $y, $i) {
+	protected function addPoint ($x, $y, $i) {
 		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
@@ -807,7 +822,7 @@
 		array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
@@ -841,4 +856,4 @@
 		return $str;
\ No newline at end of file
Modified: branches/2.5/http/classes/class_wfs_conf.php
--- branches/2.5/http/classes/class_wfs_conf.php	2008-12-15 13:27:27 UTC (rev 3317)
+++ branches/2.5/http/classes/class_wfs_conf.php	2008-12-15 13:30:12 UTC (rev 3318)
@@ -49,7 +49,7 @@
 			// parameter is a number
 			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
-				$idArray = array(intval($idOrIdArray));
+				$idOrIdArray = array(intval($idOrIdArray));
 			// parameter is an array of numbers
@@ -69,7 +69,7 @@
 					$idArray = array_intersect($idArray, $user->getWfsConfByPermission());
-				return $this->getWfsConfFromDB($idArray);
+				return $this->getWfsConfFromDbByArray($idArray);
 			// parameter is invalid
 			else {
More information about the Mapbender_commits mailing list
