[Mapbender-commits] r2066 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Feb 7 07:30:28 EST 2008
Author: verenadiewald
Date: 2008-02-07 07:30:28 -0500 (Thu, 07 Feb 2008)
New Revision: 2066
trunk/mapbender/http/php/mod_wfs_conf.php
added field f_operator
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
--- trunk/mapbender/http/php/mod_wfs_conf.php 2008-02-06 20:23:53 UTC (rev 2065)
+++ trunk/mapbender/http/php/mod_wfs_conf.php 2008-02-07 12:30:28 UTC (rev 2066)
@@ -60,6 +60,54 @@
function validate(){
return true;
+function removeChildNodes(node) {
+ while (node.childNodes.length > 0) {
+ var childNode = node.firstChild;
+ node.removeChild(childNode);
+function controlOperators(checkVal,operatorField,valType){
+ var opSelect = document.getElementById(operatorField);
+ removeChildNodes(opSelect);
+ option1 = new Option("-----","0");
+ opSelect.options[opSelect.length] = option1;
+ if(checkVal==true){
+ opSelect.disabled = '';
+ if(valType=='string' || valType=='date'){
+ option2 = new Option("%...%","bothside");
+ opSelect.options[opSelect.length] = option2;
+ option3 = new Option("...%","rightside");
+ opSelect.options[opSelect.length] = option3;
+ option4 = new Option("equal","equal");
+ opSelect.options[opSelect.length] = option4;
+ else if(valType=='int' || valType=='float'){
+ option2 = new Option(">","greater_than");
+ option3 = new Option("<","less_than");
+ else{
+ option5 = new Option(">","greater_than");
+ opSelect.options[opSelect.length] = option5;
+ option6 = new Option("<","less_than");
+ opSelect.options[opSelect.length] = option6;
+ else{
+ opSelect.disabled = 'disabled';
</script>
</head>
@@ -110,7 +158,7 @@
$res = db_query($sql);
$wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
for($i=0; $i<$_REQUEST["num"]; $i++){
- $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail) VALUES(";
+ $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail,f_operator) VALUES(";
$sql .= "'".$wfsID."',";
$sql .= "'".$_REQUEST["f_id".$i]."',";
if(!empty($_REQUEST["f_search".$i])){
@@ -137,11 +185,20 @@
}else{$sql .= "'0'";}
$sql .= ", ";
$sql .= "'".$_REQUEST["f_auth_varname".$i];
- $sql .= ",";
- if(!empty($_REQUEST["f_show_detail".$i])){
+ $sql .= "'";
+ $sql .= ", ";
+ if(!empty($_REQUEST["f_show_detail".$i])){
$sql .= "'1'";
- $sql .= "); ";
+ $sql .= ", ";
+ if(empty($_REQUEST["f_operator".$i])){
+ $sql .= "0";
+ else{
+ $sql .= "'".$_REQUEST["f_operator".$i];
+ $sql .= "'";
+ $sql .= "); ";
@@ -260,6 +317,7 @@
echo "<td>" . toImage('edit') . "</td>";
echo "<td>" . toImage('html') . "</td>";
echo "<td>" . toImage('auth') . "</td>";
+ echo "<td>" . toImage('operator') . "</td>";
echo "</tr>";
for($i=0; $i<count($aWFS->elements->element_id); $i++){
@@ -267,7 +325,7 @@
echo "<td>".$aWFS->elements->element_id[$i]."<input type='hidden' name='f_id".$i."' value='".$aWFS->elements->element_id[$i]."'></td>";
echo "<td>".$aWFS->elements->element_name[$i]."<br><div style='font-size:10'>".$aWFS->elements->element_type[$i]."</div></td>";
echo "<td><input name='f_geom' type='radio' value='".$aWFS->elements->element_id[$i]."'></td>";
- echo "<td><input name='f_search".$i."' type='checkbox'></td>";
+ echo "<td><input name='f_search".$i."' type='checkbox' onclick='controlOperators(document.forms[0].f_search".$i.".checked,\"f_operator".$i."\",\"".$aWFS->elements->element_type[$i]."\");'></td>";
echo "<td><input name='f_pos".$i."' type='text' size='1' value='0'></td>";
echo "<td><input name='f_style_id".$i."' type='text' size='2' value='0'></td>";
echo "<td><input name='f_toupper".$i."' type='checkbox'></td>";
@@ -278,8 +336,11 @@
echo "<td><input name='f_respos".$i."' type='text' size='1' value='0'></td>";
echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
- echo "<td><textarea name='f_form_element_html".$i."' cols='15' rows='1' ></textarea></td>";
+ echo "<td><textarea name='f_form_element_html".$i."' cols='15' rows='1'></textarea></td>";
echo "<td><input name='f_auth_varname".$i."' type='text' size='8' value=''></td>";
+ echo "<td><select name='f_operator".$i."' id='f_operator".$i."' disabled>";
+ echo "<option value='0'>-----</option>";
+ echo "</select></td>";
echo "</tr>";
echo "</table>";
More information about the Mapbender_commits
