[Mapbender-commits] r2067 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Feb 7 07:37:20 EST 2008
Author: verenadiewald
Date: 2008-02-07 07:37:20 -0500 (Thu, 07 Feb 2008)
New Revision: 2067
trunk/mapbender/http/php/mod_wfs_edit.php
added field f_operator
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php 2008-02-07 12:30:28 UTC (rev 2066)
+++ trunk/mapbender/http/php/mod_wfs_edit.php 2008-02-07 12:37:20 UTC (rev 2067)
@@ -41,6 +41,58 @@
function validate(){
return true;
+function openwindow(Adresse) {
+ Fenster1 = window.open(Adresse, "GeoPortal Rheinland-Pfalz - Metadaten", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+ Fenster1.focus();
+function removeChildNodes(node) {
+ while (node.childNodes.length > 0) {
+ var childNode = node.firstChild;
+ node.removeChild(childNode);
+function controlOperators(checkVal,operator,valType,opValue){
+ var opSelect = document.getElementById(operator);
+ removeChildNodes(opSelect);
+ if(checkVal==true){
+ opSelect.disabled = '';
+ option1 = new Option("-----","0");
+ opSelect.options[opSelect.length] = option1;
+ if(valType=='string' || valType=='date'){
+ option2 = new Option("%...%","bothside");
+ opSelect.options[opSelect.length] = option2;
+ option3 = new Option("...%","rightside");
+ opSelect.options[opSelect.length] = option3;
+ option4 = new Option("equal","equal");
+ opSelect.options[opSelect.length] = option4;
+ else if(valType=='int' || valType=='float'){
+ option2 = new Option(">","greater_than");
+ option3 = new Option("<","less_than");
+ else{
+ option5 = new Option(">","greater_than");
+ opSelect.options[opSelect.length] = option5;
+ option6 = new Option("<","less_than");
+ opSelect.options[opSelect.length] = option6;
+ else{
+ opSelect.disabled = 'disabled';
</script>
</head>
@@ -132,14 +184,25 @@
$sql .= "'";
$sql .= ", ";
$sql .= "f_auth_varname = '".$_REQUEST["f_auth_varname".$i];
- $sql .= "',";
- $sql .= "f_show_detail = '";
+ $sql .= "'";
+ $sql .= ", ";
+ $sql .= "f_show_detail = '";
if(!empty($_REQUEST["f_show_detail".$i])){
$sql .= '1';
}else{$sql .= '0';}
- $sql .= "' WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
- $res = db_query($sql);
+ $sql .= "',";
+ $sql .= "f_operator = ";
+ if(empty($_REQUEST["f_operator".$i])){
+ $sql .= "0";
+ else{
+ $sql .= "'".$_REQUEST["f_operator".$i];
+ $sql .= "'";
+ $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
+ $res = db_query($sql);
/* end save wfs_conf properties */
@@ -221,6 +284,7 @@
echo "<td>" . toImage('edit') . "</td>";
echo "<td>" . toImage('html') . "</td>";
echo "<td>" . toImage('auth') . "</td>";
+ echo "<td>" . toImage('operator') . "</td>";
echo "</tr>";
$cnt = 0;
while($row = db_fetch_array($res)){
@@ -236,7 +300,7 @@
echo "></td>";
echo "<td><input name='f_search".$cnt."' type='checkbox'";
if($row["f_search"] == 1){ echo " checked"; }
- echo "></td>";
+ echo " onclick='controlOperators(document.forms[0].f_search".$cnt.".checked,\"f_operator".$cnt."\",\"".$row["element_type"]."\",\"".$row["f_operator"]."\");'></td>";
echo "<td><input name='f_pos".$cnt."' type='text' size='1' value='".$row["f_pos"]."'></td>";
echo "<td><input name='f_style_id".$cnt."' type='text' size='2' value='".$row["f_style_id"]."'></td>";
echo "<td><input name='f_toupper".$cnt."' type='checkbox'";
@@ -259,6 +323,54 @@
echo "></td>";
echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".stripslashes($row["f_form_element_html"])."</textarea></td>";
echo "<td><input name='f_auth_varname".$cnt."' type='text' size='8' value='".$row["f_auth_varname"]."'></td>";
+ echo "<td><select name='f_operator".$cnt."' id='f_operator".$cnt."' ";
+ if($row["f_search"] != 1){
+ echo "disabled";
+ echo "<option value='0' ";
+ if($row["f_operator"] == 0){ echo " selected"; }
+ echo ">-----</option>";
+ if($row["element_type"]=='string' || $row["element_type"]=='date'){
+ echo "<option value='bothside' ";
+ if($row["f_operator"] == 'bothside'){ echo " selected"; }
+ echo ">%...%</option>";
+ echo "<option value='rightside' ";
+ if($row["f_operator"] == 'rightside'){ echo " selected"; }
+ echo ">...%</option>";
+ echo "<option value='equal' ";
+ if($row["f_operator"] == 'equal'){ echo " selected"; }
+ echo ">equal</option>";
+ else if($row["element_type"]=='int' || $row["element_type"]=='float'){
+ echo "<option value='greater_than' ";
+ if($row["f_operator"] == 'greater_than'){ echo " selected"; }
+ echo ">></option>";
+ echo "<option value='less_than' ";
+ if($row["f_operator"] == 'less_than'){ echo " selected"; }
+ echo "><</option>";
+ else{
+ echo "</select></td>";
echo "</tr>";
$cnt++;
More information about the Mapbender_commits
