[Mapbender-commits] r2270 - in branches/nimix_dev/http: javascripts
php
svn_mapbender at osgeo.org
Wed Mar 19 10:48:52 EDT 2008
Author: nimix
Date: 2008-03-19 10:48:52 -0400 (Wed, 19 Mar 2008)
New Revision: 2270
Added:
branches/nimix_dev/http/php/mod_setTimeout_server.php
branches/nimix_dev/http/javascripts/mod_setTimeout.php
enhance setTimeout by sessionrefresh
Modified: branches/nimix_dev/http/javascripts/mod_setTimeout.php
--- branches/nimix_dev/http/javascripts/mod_setTimeout.php 2008-03-19 12:34:50 UTC (rev 2269)
+++ branches/nimix_dev/http/javascripts/mod_setTimeout.php 2008-03-19 14:48:52 UTC (rev 2270)
@@ -23,72 +23,79 @@
-try{
- if (mod_timeout_text){}
-catch(e){
- mod_timeout_text = "Your session may not be valid anymore!";
- //mod_timeout_text = "Bitte beachten Sie, dass Ihre Session abgelaufen sein kann!";
+try{if (mod_timeout_text){}}
+catch(e){mod_timeout_text = "Your session may not be valid anymore!";}
-try{
- if (mod_timeout_ttl){}
-catch(e){
- mod_timeout_ttl = '15';
+try{if (mod_timeout_ttl){}}
+catch(e){mod_timeout_ttl = '15';}
* alert: a confirm - window to reload the application when timeout is reached
-* logout: request mod_logout after timeout
+* logout: request mod_logout after timeout
+* refresh: send a refresh to preserve the session
-try{
- if (mod_timeout_action){}
-catch(e){
- mod_timeout_action = 'alert';
+try{if (mod_timeout_action){}}
+catch(e){mod_timeout_action = 'alert';}
/*version 2.0.0*/
mod_timeout_cnt = false;
+eventAfterMapRequest.register(mod_setTimeout_set);
+eventInit.register(mod_setTimeout_interval);
+//mb_registerSubFunctions("mod_setTimeout_set()"); // maprequest
+//mb_registerInitFunctions("mod_setTimeout_interval()");
-mb_registerSubFunctions("mod_setTimeout_set()"); // maprequest
-mb_registerInitFunctions("mod_setTimeout_interval()");
function mod_setTimeout_interval(){
- var aktiv = window.setInterval("mod_setTimeout_check()",60000);
- mod_setTimeout_set();
- mod_setTimeout_check();
+ var aktiv = window.setInterval("mod_setTimeout_check()",60000);
+ mod_setTimeout_set();
-function mod_setTimeout_set(){
- mod_timeout_cnt = parseInt(mod_timeout_ttl);
+function mod_setTimeout_set(){
+ if(mod_timeout_ttl==='session')
+ mod_timeout_cnt = 180;
+ else
+ mod_timeout_cnt = parseInt(mod_timeout_ttl, 10);
+ //refresh session
+ mb_ajax_json("../php/mod_setTimeout_server.php?<?php echo $urlParameters;?>", {}, function (json, status) {
+ if(mod_timeout_ttl==='session'){
+ mod_timeout_cnt = parseInt(json, 10);
+ mod_setTimeout_check();
function mod_setTimeout_check(){
+ var str = "<span style='font-family: Arial, Helvetica, sans-serif;font-size:10px;'>";
+ str += "Logout in ";
+ if(mod_timeout_cnt >= 0){
+ str += mod_timeout_cnt;
+ else {
+ str += "0";
- var str = "<span style='font-family: Arial, Helvetica, sans-serif;font-size:10px;'>";
- str += "Logout in ";
- if(mod_timeout_cnt >= 0){
- str += mod_timeout_cnt;
- else { str += "0"; }
- str += " min";
- str += "</span>";
- writeTag("", "timeout", str );
- if(mod_timeout_cnt == 0 && mod_timeout_action == 'alert'){
- var go = confirm(mod_timeout_text);
- if(go == true){
- // document.location.href = "./login.php";
- if(mod_timeout_cnt == 0 && mod_timeout_action == 'logout'){ document.location.href = "../php/mod_logout.php";}
- mod_timeout_cnt--;
+ str += " min";
+ str += "</span>";
+ writeTag("", "timeout", str );
+ if(mod_timeout_cnt == 0 && mod_timeout_action == 'alert'){
+ var go = confirm(mod_timeout_text);
+ if(go == true){
+ // document.location.href = "./login.php";
+ if(mod_timeout_cnt == 0 && mod_timeout_action == 'logout'){
+ document.location.href = "../php/mod_logout.php";
+ if(mod_timeout_cnt == 1 && mod_timeout_action == 'refresh'){
+ mod_timeout_cnt--;
Added: branches/nimix_dev/http/php/mod_setTimeout_server.php
--- branches/nimix_dev/http/php/mod_setTimeout_server.php (rev 0)
+++ branches/nimix_dev/http/php/mod_setTimeout_server.php 2008-03-19 14:48:52 UTC (rev 2270)
@@ -0,0 +1,24 @@
+<?php
+# $Id:$
+# maintained by http://www.mapbender.org/index.php/User:Astrid Emde
+# http://www.mapbender.org/index.php/mod_setTimeout.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+echo session_cache_expire();
\ No newline at end of file
More information about the Mapbender_commits
