[Mapbender-commits] r2271 - branches/nimix_dev/http/html
svn_mapbender at osgeo.org
Wed Mar 19 12:29:11 EDT 2008
Author: nimix
Date: 2008-03-19 12:29:11 -0400 (Wed, 19 Mar 2008)
New Revision: 2271
branches/nimix_dev/http/html/mod_treefolder2.php
handling of quaryability
Modified: branches/nimix_dev/http/html/mod_treefolder2.php
--- branches/nimix_dev/http/html/mod_treefolder2.php 2008-03-19 14:48:52 UTC (rev 2270)
+++ branches/nimix_dev/http/html/mod_treefolder2.php 2008-03-19 16:29:11 UTC (rev 2271)
@@ -452,18 +452,19 @@
-function handleSelection(path){
+function handleSelection(path, box){
if(lock_update)return;
var reset_lock=!lock_check;
lock_check=true;
- var bChk = IsChecked(path, 0);
+ var bChk = IsChecked(path, box);
// enableCheckbox(path, 0, true);
- checkChildren(path, 0, bChk);
+ checkChildren(path, box, bChk);
if(reset_lock){
var t = path.split("|");
lock_check=false;
parent.mb_restateLayers(mod_treeGDE_map,t[1]);
- parent.setSingleMapRequest(mod_treeGDE_map,t[1]);
+ if(box==0)
+ parent.setSingleMapRequest(mod_treeGDE_map,t[1]);
@@ -531,8 +532,8 @@
if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
c_menu+="]";
- controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"');updateParent('"+parentObj+parentLayer+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
- if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);checkChildren('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1, this.checked?1:0)\" />";
+ controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);updateParent('"+parentObj+parentLayer+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
+ if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1)\" />";
if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\'../php/mod_layerMetadata.php?id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
More information about the Mapbender_commits
