[Mapbender-commits] r2297 - branches/2.5/resources/db/update
svn_mapbender at osgeo.org
Tue Mar 25 14:23:23 EDT 2008
Author: astrid_emde
Date: 2008-03-25 14:23:23 -0400 (Tue, 25 Mar 2008)
New Revision: 2297
branches/2.5/resources/db/update/mod_switchLocale_noreload.sql
rework on the module
Modified: branches/2.5/resources/db/update/mod_switchLocale_noreload.sql
--- branches/2.5/resources/db/update/mod_switchLocale_noreload.sql 2008-03-25 17:59:25 UTC (rev 2296)
+++ branches/2.5/resources/db/update/mod_switchLocale_noreload.sql 2008-03-25 18:23:23 UTC (rev 2297)
@@ -1,6 +1,2 @@
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','iframe','../php/mod_switchLocale_noreload.php','',1,1,1,1,1,'','','iframe','','','','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en', '' ,'php_var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_frameHeight[7]', '80', '' ,'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'tabs', 'tab_ids[7]', 'switchLocale_noreload', '' ,'php_var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('gui','switchLocale_noreload',8,1,'changes the locale without reloading the client','Set language','iframe','../php/mod_switchLocale_noreload.php','frameborder=''0''',720,14,50,30,5,'','','iframe','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'switchLocale_noreload', 'languages', 'de,en,bg,gr,nl,it,es', '' ,'php_var');
More information about the Mapbender_commits
