[Mapbender-commits] r3097 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org
Thu Oct 2 11:27:36 EDT 2008
Author: nimix
Date: 2008-10-02 11:27:36 -0400 (Thu, 02 Oct 2008)
New Revision: 3097
branches/nimix_dev/http/javascripts/popup.js
implement modal state dialogues
Modified: branches/nimix_dev/http/javascripts/popup.js
--- branches/nimix_dev/http/javascripts/popup.js 2008-10-02 15:26:18 UTC (rev 3096)
+++ branches/nimix_dev/http/javascripts/popup.js 2008-10-02 15:27:36 UTC (rev 3097)
@@ -37,6 +37,7 @@
* resizeable: allow user to change the size default:true
* dragable: allow user to move the window default:true
* balloon: balloon popup from top, left (disables resizeable and dragable)
+ * modal: create modal popup default:false
* @param {String} html the "body" of the popup, can also be "url:http://foo.de" to display a website
* @param {Number} width width of the popup
@@ -115,6 +116,7 @@
mb_popup.prototype.hide = function(){
$("#"+this.id).hide();
$("#balloon_"+this.id).hide();
+ $("#modal_mouse_catcher").remove();
@@ -123,6 +125,7 @@
mb_popup.prototype.destroy = function(){
$("#"+this.id).remove();
$("#balloon_"+this.id).remove();
@@ -326,7 +329,7 @@
minTop:"document",minLeft:"document",
maxRight:false,maxBottom:false,
dragable:true,resizeable:true,balloon:false,
- style:null,destroy:true,
+ style:null,destroy:true,modal:false,
closeCallback:null
//override defaults
@@ -353,7 +356,7 @@
//set balloon arm position
if(settings.balloon){
$("#balloon_"+settings.id).attr("class", "balloon"+(pos.position>=2?"B":"T")+(pos.position%2?"R":"L"))
- .css({"z-index":(popup_top++),visibility:"visible",left:pos.bX,top:pos.bY});
+ .css({"z-index":(popup_top),visibility:"visible",left:pos.bX,top:pos.bY});
settings.left = pos.pX;
settings.top = pos.pY;
@@ -383,7 +386,7 @@
var data = {El:this,fY:settings.minTop,fX:settings.minLeft,tX:settings.maxRight,tY:settings.maxBottom,
fW:settings.minWidth,tW:settings.maxWidth,fH:settings.minHeight,tH:settings.maxHeight,
destroy:settings.destroy,opacity:settings.opacity,moveOpacity:settings.moveOpacity,close:settings.closeCallback}
//Make window Dragable
if(settings.dragable)
$(".Drag", this).bind('mousedown',data,function(event){
@@ -419,9 +422,10 @@
//closeButton
- $(".Close", this).bind('click',data, function(event){
+ this.closePopup = function(event){
if(event.data.close)
event.data.close();
if(event.data.destroy){
event.data.El.slideUp('slow', function(){$(this).remove();});
$("#balloon_"+event.data.El.attr("id")).remove();
@@ -430,8 +434,15 @@
event.data.El.slideUp('slow');
$("#balloon_"+event.data.El.attr("id")).fadeOut();
+ $(".Close", this).bind('click',data, this.closePopup);
+ //create div to make window modal
+ if(settings.modal){
+ $("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top-1)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"modal_mouse_catcher\"></div>");
+ $("#modal_mouse_catcher").bind('click',data, this.closePopup);
//raise on click
this.click(function(){this.style.zIndex=popup_top++;$("#balloon_"+this.id).css("z-index", popup_top++);});
$("#balloon_"+settings.id).click(function(){$("#"+this.id.substr(8)).css("z-index", popup_top++);this.style.zIndex=popup_top++;});
More information about the Mapbender_commits
