[Mapbender-commits] r3098 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org
Thu Oct 2 11:28:13 EDT 2008
Author: nimix
Date: 2008-10-02 11:28:13 -0400 (Thu, 02 Oct 2008)
New Revision: 3098
branches/nimix_dev/http/javascripts/mod_tooltip.php
fix tooltips when first request has no result
Modified: branches/nimix_dev/http/javascripts/mod_tooltip.php
--- branches/nimix_dev/http/javascripts/mod_tooltip.php 2008-10-02 15:27:36 UTC (rev 3097)
+++ branches/nimix_dev/http/javascripts/mod_tooltip.php 2008-10-02 15:28:13 UTC (rev 3098)
@@ -63,6 +63,7 @@
var tooltipWmsRequestCount = 0;
var numberOfFinishedWfsRequests = 0;
var numberOfFinishedWmsRequests = 0;
+var visibleRequest = 0;
var TooltipMsg = {'title':"<?php echo _mb("Informations");?>"};
//buttonWfs_toDigitize_on ="0";
@@ -86,6 +87,7 @@
point = new Point(clickX,clickY);
var point_geom = new Geometry(geomType.point);
point_geom.addPoint(mapToReal(tooltipTarget,point));
+ visibleRequest = 0;
//FeatureInfo requests
urls = mb_mapObj[ind].getFeatureInfoRequests(point);
@@ -118,11 +120,16 @@
numberOfFinishedWmsRequests++;
//check if there are results
- if(js_code == "")
+ if(js_code == ""){
+ if(!isFirstResult())
+ displayResultDoc("");
return;
for(var k=0;k < no_result_text.length;k++){
if(js_code.indexOf(no_result_text[k])!==-1){
return;
@@ -146,11 +153,13 @@
var html = createDetailedWfsResultHtml(resultGeomArray);
displayResultDoc(html);
+ else if(!isFirstResult())
function isFirstResult(){
- return (numberOfFinishedWfsRequests+numberOfFinishedWmsRequests) == 1;
+ return visibleRequest == 0;
function isLastResult(){
@@ -174,6 +183,7 @@
if(isLastResult())
oDoc.close();
+ visibleRequest++;
function showBalloonFrame(html){
More information about the Mapbender_commits
