[Mapbender-commits] r3103 - branches/noframes/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 3 08:08:24 EDT 2008
Author: nimix
Date: 2008-10-03 08:08:23 -0400 (Fri, 03 Oct 2008)
New Revision: 3103
   branches/noframes/http/javascripts/map_obj.js
   branches/noframes/http/javascripts/mod_box1.js
   branches/noframes/http/javascripts/mod_pan.php
   branches/noframes/http/javascripts/mod_selArea1.php
make mod_box1.js and mod_selArea1.php noframe compartible
Modified: branches/noframes/http/javascripts/map_obj.js
--- branches/noframes/http/javascripts/map_obj.js	2008-10-03 10:37:33 UTC (rev 3102)
+++ branches/noframes/http/javascripts/map_obj.js	2008-10-03 12:08:23 UTC (rev 3103)
@@ -75,8 +75,6 @@
 	this.epsg = wms[0].gui_wms_epsg;
 	this.extent = setExtent(this.width,this.height,this.epsg);
 	this.mapURL = [];
-	console.log(this.frameName);
-	console.log(this.elementName);
 	if(this.frameName){
 		this.domElement = window.frames[this.frameName].document.getElementById(this.elementName);
@@ -411,5 +409,27 @@
 		return this.domElement;
+	this.getMousePos = function(e){
+		if(ie){
+			if(this.frameName){
+				clickX = window.frames[fName].event.clientX;
+				clickY = window.frames[fName].event.clientY;
+			else{
+				clickX = event.clientX;
+				clickY = event.clientY;
+		else{
+			clickX = e.pageX;
+			clickY = e.pageY;
+		//remove divtag offset
+		clickX -= parseInt(this.getDomElement().style.left);
+		clickY -= parseInt(this.getDomElement().style.top);
+		return new Point(clickX, clickY);
 	eventAfterMapObjectConstruction.trigger();
\ No newline at end of file
Modified: branches/noframes/http/javascripts/mod_box1.js
--- branches/noframes/http/javascripts/mod_box1.js	2008-10-03 10:37:33 UTC (rev 3102)
+++ branches/noframes/http/javascripts/mod_box1.js	2008-10-03 12:08:23 UTC (rev 3103)
@@ -7,6 +7,7 @@
 var mb_isActive = false;
 var mb_isBF = false;
 var mb_zF = false;
+var mb_boxMapObj = null;
 var mb_offset_top = 0;
 var mb_offset_right = 0;
@@ -14,8 +15,9 @@
 var mb_offset_left = 0;
 function  mod_box_start(e){
+	mb_boxMapObj = getMapObjByName(mb_isBF);
 	mb_isActive = true;
-	mb_getMousePos(e,mb_isBF);
+	mb_boxMapObj.getMousePos(e);
 	mb_start_x = clickX;
 	mb_start_y = clickY;
 	mb_end_x = mb_start_x+1;
@@ -29,13 +31,10 @@
 function mod_box_run(e){
 	if(mb_isActive){
-		for(var i=0; i<mb_mapObj.length; i++){
-			if(mb_mapObj[i].frameName == mb_isBF){
-				var width = mb_mapObj[i].width;
-				var height = mb_mapObj[i].height;
+		var width = mb_boxMapObj.width;
+		var height = mb_boxMapObj.height;
 		if (((clickX>width) || (clickY>height) || (clickX<=0) ||(clickY<=0))){
 			isActive = false;
 			mod_box_stop(e);
@@ -60,6 +59,37 @@
 function mb_drawBox(left,top,right,bottom){
+	//Look if we have the Box elements
+	var map_el = mb_boxMapObj.getDomElement();
+	if(!map_el.ownerDocument.getElementById(mb_boxMapObj.elementName+"_l_top")){
+		//create Box Elements
+		el_top = map_el.ownerDocument.createElement("div");
+		el_top.style.position = "absolute";
+		el_top.style.top = "0px";
+		el_top.style.left = "0px";
+		el_top.style.width = "0px";
+		el_top.style.height = "0px";
+		el_top.style.overflow = "hidden";
+		el_top.style.zIndex = "10";
+		el_top.style.visibility = "hidden";
+		el_top.style.cursor = "crosshair";
+		el_top.style.backgroundColor = "#ff0000";
+		el_left = el_top.cloneNode(false);
+		el_right = el_top.cloneNode(false);
+		el_bottom = el_top.cloneNode(false);
+		el_top.id = mb_boxMapObj.elementName+"_l_top";
+		el_left.id = mb_boxMapObj.elementName+"_l_left";
+		el_right.id = mb_boxMapObj.elementName+"_l_right";
+		el_bottom.id = mb_boxMapObj.elementName+"_l_bottom";
+		map_el.appendChild(el_top);
+		map_el.appendChild(el_left);
+		map_el.appendChild(el_right);
+		map_el.appendChild(el_bottom);
 	mb_arrangeBox("l_top",left,top,right,top+2);
 	mb_arrangeBox("l_left",left,top,left+2,bottom);
 	mb_arrangeBox("l_right",right-2,top,right,bottom);
@@ -70,17 +100,20 @@
 	mb_displayElement("l_bottom");
 function mb_arrangeBox(name, left, top, right, bottom){
-	var el = window.frames[mb_isBF].document.getElementById(name).style;
+	var el = map_el.ownerDocument.getElementById(mb_boxMapObj.elementName+"_"+name).style;
 	el.height = Math.abs(bottom - top);
 	el.width = Math.abs(right - left);
 	el.top = top + "px";
 	el.left = left + "px";
 function mb_displayElement(name){
-	window.frames[mb_isBF].document.getElementById(name).style.visibility = "visible";
+	var el = map_el.ownerDocument.getElementById(mb_boxMapObj.elementName+"_"+name).style.visibility = "visible";
 function mb_hideElement(name) {
-	window.frames[mb_isBF].document.getElementById(name).style.visibility = "hidden";
+	var el = map_el.ownerDocument.getElementById(mb_boxMapObj.elementName+"_"+name).style.visibility = "hidden";
 function evalExtent(){
 	if(mb_start_x>mb_end_x){
Modified: branches/noframes/http/javascripts/mod_pan.php
--- branches/noframes/http/javascripts/mod_pan.php	2008-10-03 10:37:33 UTC (rev 3102)
+++ branches/noframes/http/javascripts/mod_pan.php	2008-10-03 12:08:23 UTC (rev 3103)
@@ -63,8 +63,6 @@
 	mb_panActive = true;
 	mb_getMousePos(e,mod_pan_target);
 	var el = mod_pan_MapObj.getDomElement();
-	mb_element_x = parseInt(el.style.left);
-	mb_element_y = parseInt(el.style.top);
 	mb_start_x=clickX;
 	mb_start_y=clickY;
 	mb_end_x = clickX;
Modified: branches/noframes/http/javascripts/mod_selArea1.php
--- branches/noframes/http/javascripts/mod_selArea1.php	2008-10-03 10:37:33 UTC (rev 3102)
+++ branches/noframes/http/javascripts/mod_selArea1.php	2008-10-03 12:08:23 UTC (rev 3103)
@@ -22,7 +22,7 @@
 var mod_selArea_elName = "selArea1";
 var mod_selArea_frameName = "";
 var mod_selArea_target = "<?php echo $e_target[0]; ?>";
+var mos_selArea_MapObj = null;
 var mod_selArea_img_on = new Image();
 mod_selArea_img_on.src = "<?php  echo preg_replace("/_off/","_on",$e_src);  ?>";
 var mod_selArea_img_off = new Image();
@@ -31,6 +31,7 @@
 mod_selArea_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
 function init_selArea1(ind){
+	mod_selArea_MapObj = getMapObjByName(mod_selArea_target);
 	mb_button[ind] = document.getElementById(mod_selArea_elName);
 	mb_button[ind].img_over = mod_selArea_img_over.src;
 	mb_button[ind].img_on = mod_selArea_img_on.src;
@@ -42,19 +43,15 @@
 	mb_button[ind].stop = new Function ("mod_selArea_disable()");
 function mod_selArea_click(){
-	if(mod_pan_target)
-		var el = window.frames[mod_pan_target].document;
-	else
-		var el = document.getElementById("mapDiv");	el.onmouseover = mod_selArea_init;
+	var el = mod_selArea_MapObj.getDomElement();
+	el.onmouseover = mod_selArea_init;
 	el.onmousedown = mod_box_start;
 	el.onmouseup = mod_selArea_get;
 	el.onmousemove = mod_box_run;
 function mod_selArea_disable(){
-	else
-		var el = document.getElementById("mapDiv");	el.onmousedown = null;
+	el.onmousedown = null;
 	el.onmouseup = null;
 	el.onmousemove = null;
More information about the Mapbender_commits mailing list
