[Mapbender-commits] r3104 - in branches: nimix_dev/http/html
tree_dev/http/html
svn_mapbender at osgeo.org
Fri Oct 3 08:12:10 EDT 2008
Author: nimix
Date: 2008-10-03 08:12:10 -0400 (Fri, 03 Oct 2008)
New Revision: 3104
branches/nimix_dev/http/html/mod_treefolder2.php
branches/tree_dev/http/html/mod_treefolder2.php
fix initialisation with IE
Modified: branches/nimix_dev/http/html/mod_treefolder2.php
--- branches/nimix_dev/http/html/mod_treefolder2.php 2008-10-03 12:08:23 UTC (rev 3103)
+++ branches/nimix_dev/http/html/mod_treefolder2.php 2008-10-03 12:12:10 UTC (rev 3104)
@@ -77,7 +77,7 @@
var treeState = "";
<?php
//load structure
-$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 ORDER BY lft;";
+$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 AND NOT lft = 1 ORDER BY lft;";
$v = array($_SESSION["mb_user_gui"]);
$t = array("s");
$res = db_prep_query($sql, $v, $t);
Modified: branches/tree_dev/http/html/mod_treefolder2.php
--- branches/tree_dev/http/html/mod_treefolder2.php 2008-10-03 12:08:23 UTC (rev 3103)
+++ branches/tree_dev/http/html/mod_treefolder2.php 2008-10-03 12:12:10 UTC (rev 3104)
@@ -120,7 +120,9 @@
array_multisort($nr, $str);
//output javascript vars
- echo "var arrNodesStr = \"[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];\";\n";
+ $arrNodesStr = "[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];";
+ $arrNodesStr = str_replace(array("[]", ",]"),array("","]"),$arrNodesStr);
+ echo "var arrNodesStr = \"".$arrNodesStr."\";\n";
echo "var categories = {".implode(",", $categories)."};\n";
else{
More information about the Mapbender_commits
