[Mapbender-commits] r3903 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Apr 21 11:11:03 EDT 2009
Author: christoph
Date: 2009-04-21 11:11:02 -0400 (Tue, 21 Apr 2009)
New Revision: 3903
trunk/mapbender/http/javascripts/map_obj.js
added
* ignoreWMS array to featureInfo request
* event afterMapRequest
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2009-04-21 10:01:35 UTC (rev 3902)
+++ trunk/mapbender/http/javascripts/map_obj.js 2009-04-21 15:11:02 UTC (rev 3903)
@@ -250,6 +250,7 @@
domElement.style.width = this.width;
domElement.style.height = this.height;
+ this.afterMapRequest = new MapbenderEvent();
* get the extent of the mapObj
@@ -628,14 +629,25 @@
* @return array of all featureInfoRequests of this map object
* @type string[]
- this.getFeatureInfoRequests = function(clickPoint){
+ this.getFeatureInfoRequests = function(clickPoint, ignoreWms){
var allRequests = [];
//loop through all wms to get the FeatureInfoRequests
for (var i = 0; i < this.wms.length; i++) {
- var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
- if (currentRequest) {
- allRequests.push(currentRequest);
+ var ignoreThisWms = false;
+ if (ignoreWms.constructor === Array) {
+ for (var j = 0; j < ignoreWms.length; j++) {
+ if (ignoreWms[j] == this.wms[i].wms_id) {
+ ignoreThisWms = true;
+ break;
+ if (!ignoreThisWms) {
+ var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+ if (currentRequest) {
+ allRequests.push(currentRequest);
if (allRequests.length > 0) {
return allRequests;
@@ -813,6 +825,7 @@
"map": this,
"myMapId": myMapId.join(",")
+ this.afterMapRequest.trigger();
var that = this;
More information about the Mapbender_commits
