[Mapbender-commits] r3904 - in trunk/mapbender: core
http/javascripts resources/db/update
svn_mapbender at osgeo.org
Tue Apr 21 11:14:05 EDT 2009
Author: christoph
Date: 2009-04-21 11:14:04 -0400 (Tue, 21 Apr 2009)
New Revision: 3904
trunk/mapbender/core/system.php
trunk/mapbender/http/javascripts/mod_featureInfo.php
trunk/mapbender/resources/db/update/update_2.7.sql
http://trac.osgeo.org/mapbender/ticket/343
Modified: trunk/mapbender/core/system.php
--- trunk/mapbender/core/system.php 2009-04-21 15:11:02 UTC (rev 3903)
+++ trunk/mapbender/core/system.php 2009-04-21 15:14:04 UTC (rev 3904)
@@ -36,4 +36,4 @@
define("ZOOM_MOUSEWHEEL", "1.1");
-define("MODULES_NOT_RELYING_ON_GLOBALS", "back,forward,zoomIn1,zoomOut1,selArea1,pan1,copyright,dependentDiv,dragMapSize,dynamicOverview,FeatureInfoRedirect,highlightPOI,navFrame,sandclock,scaleBar,scaleSel,setBBOX,setPOI2Scale");
+define("MODULES_NOT_RELYING_ON_GLOBALS", "featureInfo1,gazetteerWFS,back,forward,zoomIn1,zoomOut1,selArea1,pan1,copyright,dependentDiv,dragMapSize,dynamicOverview,FeatureInfoRedirect,highlightPOI,navFrame,sandclock,scaleBar,scaleSel,setBBOX,setPOI2Scale");
Modified: trunk/mapbender/http/javascripts/mod_featureInfo.php
--- trunk/mapbender/http/javascripts/mod_featureInfo.php 2009-04-21 15:11:02 UTC (rev 3903)
+++ trunk/mapbender/http/javascripts/mod_featureInfo.php 2009-04-21 15:14:04 UTC (rev 3904)
@@ -21,6 +21,14 @@
include '../include/dyn_js.php';
//defaults for element vars
+try {
+ if (ignoreWms) {
+catch (e) {
+ ignoreWms = [];
if(typeof(featureInfoLayerPopup)==='undefined')
var featureInfoLayerPopup = 'false';
if(typeof(featureInfoPopupHeight)==='undefined')
@@ -28,7 +36,7 @@
if(typeof(featureInfoPopupWidth)==='undefined')
var featureInfoPopupWidth = '270';
-var mod_featureInfo_elName = "featureInfo1";
+var mod_featureInfo_elName = "<?php echo $e_id;?>";
var mod_featureInfo_frameName = "";
var mod_featureInfo_target = "<?php echo $e_target[0]; ?>";
var mod_featureInfo_mapObj = null;
@@ -37,19 +45,25 @@
var mod_featureInfo_img_off = new Image(); mod_featureInfo_img_off.src ="<?php echo $e_src; ?>";
var mod_featureInfo_img_over = new Image(); mod_featureInfo_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-function init_featureInfo1(ind){
- mod_featureInfo_mapObj = getMapObjByName(mod_featureInfo_target);
+eventInit.register(function () {
+ mb_regButton(function init_featureInfo1(ind){
+ mod_featureInfo_mapObj = getMapObjByName(mod_featureInfo_target);
- mb_button[ind] = document.getElementById(mod_featureInfo_elName);
- mb_button[ind].img_over = mod_featureInfo_img_over.src;
- mb_button[ind].img_on = mod_featureInfo_img_on.src;
- mb_button[ind].img_off = mod_featureInfo_img_off.src;
- mb_button[ind].status = 0;
- mb_button[ind].elName = mod_featureInfo_elName;
- mb_button[ind].fName = mod_featureInfo_frameName;
- mb_button[ind].go = new Function ("mod_featureInfo_click()");
- mb_button[ind].stop = new Function ("mod_featureInfo_disable()");
+ mb_button[ind] = document.getElementById(mod_featureInfo_elName);
+ mb_button[ind].img_over = mod_featureInfo_img_over.src;
+ mb_button[ind].img_on = mod_featureInfo_img_on.src;
+ mb_button[ind].img_off = mod_featureInfo_img_off.src;
+ mb_button[ind].status = 0;
+ mb_button[ind].elName = mod_featureInfo_elName;
+ mb_button[ind].fName = mod_featureInfo_frameName;
+ mb_button[ind].go = function () {
+ mod_featureInfo_click();
+ mb_button[ind].stop = function () {
+ mod_featureInfo_disable();
function mod_featureInfo_click(){
mod_featureInfo_mapObj.getDomElement().onclick = mod_featureInfo_event;
@@ -71,7 +85,7 @@
else{
- urls = mod_featureInfo_mapObj.getFeatureInfoRequests(point);
+ urls = mod_featureInfo_mapObj.getFeatureInfoRequests(point, ignoreWms);
if(urls){
for(var i=0;i<urls.length;i++){
if(featureInfoLayerPopup == 'true'){
Modified: trunk/mapbender/resources/db/update/update_2.7.sql
--- trunk/mapbender/resources/db/update/update_2.7.sql 2009-04-21 15:11:02 UTC (rev 3903)
+++ trunk/mapbender/resources/db/update/update_2.7.sql 2009-04-21 15:14:04 UTC (rev 3904)
@@ -1,6 +1,7 @@
-- remove event handlers, are now in the script
UPDATE gui_element SET e_attributes = '' WHERE e_id = 'selArea1';
UPDATE gui_element SET e_attributes = '' WHERE e_id = 'pan1';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'featureInfo1';
UPDATE gui_element SET e_content = '' WHERE e_id = 'navFrame';
More information about the Mapbender_commits
