[Mapbender-commits] r4537 - in trunk/mapbender/documents/api_js: Data files/http/javascripts index search
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 28 07:28:33 EDT 2009
Author: christoph
Date: 2009-08-28 07:28:33 -0400 (Fri, 28 Aug 2009)
New Revision: 4537
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
   trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html
   trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-php.html
   trunk/mapbender/documents/api_js/index/DatabaseIndexes.html
   trunk/mapbender/documents/api_js/index/DatabaseTables.html
   trunk/mapbender/documents/api_js/index/DatabaseTriggers.html
   trunk/mapbender/documents/api_js/search/ClassesSymbols.html
   trunk/mapbender/documents/api_js/search/DatabaseIndexesI.html
   trunk/mapbender/documents/api_js/search/DatabaseTablesM.html
   trunk/mapbender/documents/api_js/search/DatabaseTriggersM.html
   trunk/mapbender/documents/api_js/search/FilesS.html
   trunk/mapbender/documents/api_js/search/FilesU.html
   trunk/mapbender/documents/api_js/search/GeneralSymbols.html
   trunk/mapbender/documents/api_js/search/GeneralU.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 11:27:54 UTC (rev 4536)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 11:28:33 UTC (rev 4537)
@@ -1,3 +1,3 @@
 (    repaint    >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php  doubleclickZoom    F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js
-changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  <Application element name>    F/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.php  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
-ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
\ No newline at end of file
+changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  <Application element name>    F/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.php  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js
+ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 11:27:54 UTC (rev 4536)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 11:28:33 UTC (rev 4537)
@@ -1 +1 @@
-(    General            Database Index                            Function                     File                           Database Table                            Class                 Database Trigger                            Property
+(    Database Index                            General            Function                     Database Table                            File                           Class                 Database Trigger                            Property
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-js.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Property changes on: trunk/mapbender/documents/api_js/files/http/javascripts/mod_addWMSfromTree-php.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/index/DatabaseIndexes.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/index/DatabaseTables.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/index/DatabaseTriggers.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/ClassesSymbols.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/DatabaseIndexesI.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/DatabaseTablesM.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/DatabaseTriggersM.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/FilesS.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/FilesU.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/GeneralSymbols.html
   + text/html
Property changes on: trunk/mapbender/documents/api_js/search/GeneralU.html
   + text/html
More information about the Mapbender_commits mailing list
