[Mapbender-commits] r4538 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Fri Aug 28 08:22:15 EDT 2009
Author: christoph
Date: 2009-08-28 08:22:15 -0400 (Fri, 28 Aug 2009)
New Revision: 4538
trunk/mapbender/lib/class_Mapbender_session.php
http://trac.osgeo.org/mapbender/ticket/518
added methods "delete" and "exists"
Modified: trunk/mapbender/lib/class_Mapbender_session.php
--- trunk/mapbender/lib/class_Mapbender_session.php 2009-08-28 11:28:33 UTC (rev 4537)
+++ trunk/mapbender/lib/class_Mapbender_session.php 2009-08-28 12:22:15 UTC (rev 4538)
@@ -35,6 +35,17 @@
session_write_close();
+ * Unsets a session variable
+ * @param String name name of the session variable
+ public function delete ($name) {
+ $this->start();
+ unset($_SESSION[$name]);
+ new mb_notice("session.setSessionVariable.unset: " . $name);
+ session_write_close();
/* pushs the array of the session-variable
* @param String name the name of the session-variable
* @param Mixed value the new value of the session-variable
@@ -61,6 +72,22 @@
+ * checks if a session variable is set
+ * @param String name the name of the session variable
+ public function exists ($name){
+ $this->start();
+ if(isset($_SESSION[$name])){
+ return true;
+ else{
+ new mb_exception("exists(): The session variable: ".$name." is not set!'");
+ return false;
* sets a new session-id
* @param String id the new id of the session
More information about the Mapbender_commits
