[Mapbender-commits] r4539 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri Aug 28 08:23:54 EDT 2009
Author: christoph
Date: 2009-08-28 08:23:53 -0400 (Fri, 28 Aug 2009)
New Revision: 4539
trunk/mapbender/http/php/mod_layerMetadata.php
now accepts WMS ID as GET parameter, not only just a layer ID
Modified: trunk/mapbender/http/php/mod_layerMetadata.php
--- trunk/mapbender/http/php/mod_layerMetadata.php 2009-08-28 12:22:15 UTC (rev 4538)
+++ trunk/mapbender/http/php/mod_layerMetadata.php 2009-08-28 12:23:53 UTC (rev 4539)
@@ -60,7 +60,17 @@
'<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">' .
'</head>'.
'<body>';
+ $wms_id = $_GET['wmsid'];
+ if ($wms_id) {
+ $sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_pos = 0";
+ $v = array($wms_id);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
+ $row = db_fetch_array($res);
+ $layer_id = $row["layer_id"];
if ($layer_id) {
$sql = "SELECT ";
$sql .= "layer.layer_id, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, ";
@@ -143,8 +153,6 @@
$layer['Metadaten'] = $row['layer_metadataurl'];
$metadataUrl = $row['layer_metadataurl'];
if ($layer['Metadaten'] && $redirectToMetadataUrl) {
header("Location: " . $layer['Metadaten']);
More information about the Mapbender_commits
