[Mapbender-commits] r4563 - in trunk/mapbender/documents/api_js:
Data files/http/javascripts
svn_mapbender at osgeo.org
Fri Aug 28 09:24:50 EDT 2009
Author: christoph
Date: 2009-08-28 09:24:50 -0400 (Fri, 28 Aug 2009)
New Revision: 4563
trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
trunk/mapbender/documents/api_js/Data/FileInfo.nd
trunk/mapbender/documents/api_js/Data/IndexInfo.nd
trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd 2009-08-28 13:22:55 UTC (rev 4562)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd 2009-08-28 13:24:50 UTC (rev 4563)
@@ -1,3 +1,3 @@
( repaint >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php doubleclickZoom F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js
-changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php Ajax */home/cbaudson/workspace/trunk/lib/ajax.js mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js Notice //home/cbaudson/workspace/trunk/lib/exception.js Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js Request */home/cbaudson/workspace/trunk/lib/ajax.js Extent ,/home/cbaudson/workspace/trunk/lib/extent.js Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js Warning //home/cbaudson/workspace/trunk/lib/exception.js Event +/home/cbaudson/workspace/trunk/lib/event.js AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
-ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js Notification */home/cbaudson/workspace/trunk/lib/ajax.js Exception //home/cbaudson/workspace/trunk/lib/exception.js zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js ZoomIn1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
\ No newline at end of file
+changeEPSG A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js Ajax */home/cbaudson/workspace/trunk/lib/ajax.js Mapbender 8/home/cbaudson/workspace/trunk/http/javascripts/core.php mousewheelZoom E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js Sandclock @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js Reload =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js Notice //home/cbaudson/workspace/trunk/lib/exception.js Request */home/cbaudson/workspace/trunk/lib/ajax.js Map :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js Extent ,/home/cbaudson/workspace/trunk/lib/extent.js Log :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js Warning //home/cbaudson/workspace/trunk/lib/exception.js Event +/home/cbaudson/workspace/trunk/lib/event.js AddWmsFromTree E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js scalebar ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js
+ResizeMapsize E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js Notification */home/cbaudson/workspace/trunk/lib/ajax.js overviewToggle E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js zoomFull ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js Exception //home/cbaudson/workspace/trunk/lib/exception.js ZoomIn1 ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd 2009-08-28 13:22:55 UTC (rev 4562)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd 2009-08-28 13:24:50 UTC (rev 4563)
@@ -85,7 +85,7 @@
/home/cbaudson/workspace/trunk/http/php/mod_createCategory.php 1246283966 0 /home/cbaudson/workspace/trunk/http/php/mod_createCategory.php
/home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php
/home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php 1246284046 0 /home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js 1251465752 1 overviewToggle
+/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js 1251465851 1 overviewToggle
/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js 1247660170 1 repaint
/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt 1246284045 0 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql 1246284069 0 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
@@ -304,7 +304,7 @@
/home/cbaudson/workspace/trunk/tools/char_code.php 1246284046 0 /home/cbaudson/workspace/trunk/tools/char_code.php
/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js 1246458995 1 doubleclickZoom
/home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js 1246283980 0 /home/cbaudson/workspace/trunk/http/javascripts/wfsFilter.js
-/home/cbaudson/workspace/trunk/core/system.php 1251465404 0 /home/cbaudson/workspace/trunk/core/system.php
+/home/cbaudson/workspace/trunk/core/system.php 1251465834 0 /home/cbaudson/workspace/trunk/core/system.php
/home/cbaudson/workspace/trunk/http/classes/class_log.php 1246636499 0 /home/cbaudson/workspace/trunk/http/classes/class_log.php
/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js 1246636241 1 ResizeMapsize
/home/cbaudson/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js 1246283823 0 /home/cbaudson/workspace/trunk/http/extensions/i18n/ui.datepicker-ru.js
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd 2009-08-28 13:22:55 UTC (rev 4562)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd 2009-08-28 13:24:50 UTC (rev 4563)
@@ -1 +1 @@
-( General Database Index Function File Database Table Class Database Trigger Property
+( Database Index General Function Database Table File Class Database Trigger Property
Modified: trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html 2009-08-28 13:22:55 UTC (rev 4562)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html 2009-08-28 13:24:50 UTC (rev 4563)
@@ -19,7 +19,7 @@
-1,-1,NULL ,NULL ,NULL ,
'display:none;height:24px;width:35px;text-align:right;vertical-align:middle',
'<img style=''position:absolute;top:0px;left:0px'' src=''../img/ovtoggle.png'' /><span style=''padding:3px''>></span>',
-'div','../x_ingrid/mod_overviewToggle.js','','overview','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/OverviewToggle" class=LURL target=_top>http://www.mapbender.org/OverviewToggle</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+'div','../javascripts/mod_overviewToggle.js','','overview','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/OverviewToggle" class=LURL target=_top>http://www.mapbender.org/OverviewToggle</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright © 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license. <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
</div><!--Content-->
More information about the Mapbender_commits
