[Mapbender-commits] r4564 - in trunk/mapbender/documents/api_js: Data files/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 28 09:28:30 EDT 2009
Author: christoph
Date: 2009-08-28 09:28:30 -0400 (Fri, 28 Aug 2009)
New Revision: 4564
   trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
   trunk/mapbender/documents/api_js/Data/FileInfo.nd
   trunk/mapbender/documents/api_js/Data/IndexInfo.nd
   trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
updated_documentation
Modified: trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd
--- trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 13:24:50 UTC (rev 4563)
+++ trunk/mapbender/documents/api_js/Data/ClassHierarchy.nd	2009-08-28 13:28:30 UTC (rev 4564)
@@ -1,3 +1,3 @@
 (    repaint    >/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js ?/home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.php  doubleclickZoom    F/home/cbaudson/workspace/trunk/http/javascripts/mod_doubleclickZoom.js
-changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js
-ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  overviewToggle    E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
\ No newline at end of file
+changeEPSG    A/home/cbaudson/workspace/trunk/http/javascripts/mod_changeEPSG.js  	Mapbender    8/home/cbaudson/workspace/trunk/http/javascripts/core.php  Ajax    */home/cbaudson/workspace/trunk/lib/ajax.js  mousewheelZoom    E/home/cbaudson/workspace/trunk/http/javascripts/mod_mousewheelZoom.js  	Sandclock    @/home/cbaudson/workspace/trunk/http/javascripts/mod_sandclock.js  Notice    //home/cbaudson/workspace/trunk/lib/exception.js  Reload    =/home/cbaudson/workspace/trunk/http/javascripts/mod_reload.js  Map    :/home/cbaudson/workspace/trunk/http/javascripts/map_obj.js  Request    */home/cbaudson/workspace/trunk/lib/ajax.js  Extent    ,/home/cbaudson/workspace/trunk/lib/extent.js  Log    :/home/cbaudson/workspace/trunk/http/javascripts/mod_log.js  Warning    //home/cbaudson/workspace/trunk/lib/exception.js  Event    +/home/cbaudson/workspace/trunk/lib/event.js  AddWmsFromTree    E/home/cbaudson/workspace/trunk/http/javascripts/mod_addWMSfromTree.js
+ResizeMapsize    E/home/cbaudson/workspace/trunk/http/javascripts/mod_resize_mapsize.js  scalebar    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_scalebar.js  overviewToggle    E/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js  Notification    */home/cbaudson/workspace/trunk/lib/ajax.js  	Exception    //home/cbaudson/workspace/trunk/lib/exception.js  zoomFull    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomFull.js  ZoomIn1    ?/home/cbaudson/workspace/trunk/http/javascripts/mod_zoomIn1.php
Modified: trunk/mapbender/documents/api_js/Data/FileInfo.nd
--- trunk/mapbender/documents/api_js/Data/FileInfo.nd	2009-08-28 13:24:50 UTC (rev 4563)
+++ trunk/mapbender/documents/api_js/Data/FileInfo.nd	2009-08-28 13:28:30 UTC (rev 4564)
@@ -85,7 +85,7 @@
 /home/cbaudson/workspace/trunk/http/php/mod_createCategory.php	1246283966	0	/home/cbaudson/workspace/trunk/http/php/mod_createCategory.php
 /home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_ows_factory.php
 /home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php	1246284046	0	/home/cbaudson/workspace/trunk/http/classes/class_gml_polygon.php
-/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js	1251465851	1	overviewToggle
+/home/cbaudson/workspace/trunk/http/javascripts/mod_overviewToggle.js	1251466094	1	overviewToggle
 /home/cbaudson/workspace/trunk/http/javascripts/mod_repaint.js	1247660170	1	repaint
 /home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt	1246284045	0	/home/cbaudson/workspace/trunk/http/classes/phpmailer-1.72/ChangeLog.txt
 /home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql	1246284069	0	/home/cbaudson/workspace/trunk/resources/db/mysql/ISO-8859-1/mysql_data_2.5.sql
Modified: trunk/mapbender/documents/api_js/Data/IndexInfo.nd
--- trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 13:24:50 UTC (rev 4563)
+++ trunk/mapbender/documents/api_js/Data/IndexInfo.nd	2009-08-28 13:28:30 UTC (rev 4564)
@@ -1 +1 @@
-(    Database Index                            General            Function                     Database Table                            File                           Class                 Database Trigger                            Property
+(    General            Database Index                            Function                     File                           Database Table                            Class                 Database Trigger                            Property
Modified: trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html
--- trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html	2009-08-28 13:24:50 UTC (rev 4563)
+++ trunk/mapbender/documents/api_js/files/http/javascripts/mod_overviewToggle-js.html	2009-08-28 13:28:30 UTC (rev 4564)
@@ -19,8 +19,13 @@
 -1,-1,NULL ,NULL ,NULL ,
 'display:none;height:24px;width:35px;text-align:right;vertical-align:middle',
 '<img style=''position:absolute;top:0px;left:0px'' src=''../img/ovtoggle.png'' /><span style=''padding:3px''>></span>',
-'div','../javascripts/mod_overviewToggle.js','','overview','','');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/OverviewToggle" class=LURL target=_top>http://www.mapbender.org/OverviewToggle</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright &copy; 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license.&nbsp; <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
+'div','../javascripts/mod_overviewToggle.js','','overview','','');
+INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type) VALUES ('&lt;app_id&gt;', 'body',
+'overviewToggle_css', '../css/dialog/jquery-ui-1.7.2.custom.css',
+'' ,'file/css');</pre></blockquote><h4 class=CHeading>Help</h4><p><a href="http://www.mapbender.org/OverviewToggle" class=LURL target=_top>http://www.mapbender.org/OverviewToggle</a></p><h4 class=CHeading>Maintainer</h4><p><a href="http://www.mapbender.org/User:Christoph_Baudson" class=LURL target=_top>http://www.mapbender.org/User:Christoph_Baudson</a></p><h4 class=CHeading>License</h4><p>Copyright &copy; 2009, Open Source Geospatial Foundation This program is dual licensed under the GNU General Public License and Simplified BSD license.&nbsp; <a href="http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt" class=LURL target=_top>http://svn.osgeo.org<wbr>/mapbender<wbr>/trunk<wbr>/mapbender<wbr>/license<wbr>/license.txt</a></p></div></div></div>
 </div><!--Content-->
More information about the Mapbender_commits mailing list
