[Mapbender-commits] r3399 - in trunk/mapbender: http/javascripts
	http/php lib resources/db/update
    svn_mapbender at osgeo.org
    Fri Jan  2 10:27:22 EST 2009
Author: nimix
Date: 2009-01-02 10:27:22 -0500 (Fri, 02 Jan 2009)
New Revision: 3399
   trunk/mapbender/http/javascripts/mod_zoomCoords.php
   trunk/mapbender/http/php/mod_zoomCoords.php
   trunk/mapbender/lib/basic.js
   trunk/mapbender/resources/db/update/update_2.6.sql
http://trac.osgeo.org/mapbender/ticket/360
Modified: trunk/mapbender/http/javascripts/mod_zoomCoords.php
--- trunk/mapbender/http/javascripts/mod_zoomCoords.php	2009-01-02 15:25:42 UTC (rev 3398)
+++ trunk/mapbender/http/javascripts/mod_zoomCoords.php	2009-01-02 15:27:22 UTC (rev 3399)
@@ -103,5 +103,5 @@
 echo "</form>";
Modified: trunk/mapbender/http/php/mod_zoomCoords.php
--- trunk/mapbender/http/php/mod_zoomCoords.php	2009-01-02 15:25:42 UTC (rev 3398)
+++ trunk/mapbender/http/php/mod_zoomCoords.php	2009-01-02 15:27:22 UTC (rev 3399)
@@ -103,5 +103,5 @@
 echo "</form>";
Modified: trunk/mapbender/lib/basic.js
--- trunk/mapbender/lib/basic.js	2009-01-02 15:25:42 UTC (rev 3398)
+++ trunk/mapbender/lib/basic.js	2009-01-02 15:27:22 UTC (rev 3399)
@@ -37,6 +37,7 @@
 function mb_showHighlight(frameName,x,y){
    var pos = makeRealWorld2mapPos(frameName,x, y);
+//TODO frame des Mapobjekts frameName nehmen
    mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
    window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql	2009-01-02 15:25:42 UTC (rev 3398)
+++ trunk/mapbender/resources/db/update/update_2.6.sql	2009-01-02 15:27:22 UTC (rev 3399)
@@ -101,3 +101,6 @@
 DELETE FROM gui_element WHERE e_id = 'closePolygon';
 DELETE FROM gui_element WHERE e_id = 'rubber';
 DELETE FROM gui_element WHERE e_id = 'getArea';
+UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
More information about the Mapbender_commits
