[Mapbender-commits] r3400 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 5 04:43:29 EST 2009
Author: christoph
Date: 2009-01-05 04:43:29 -0500 (Mon, 05 Jan 2009)
New Revision: 3400
   trunk/mapbender/http/javascripts/map_obj.js
refactoring
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js	2009-01-02 15:27:22 UTC (rev 3399)
+++ trunk/mapbender/http/javascripts/map_obj.js	2009-01-05 09:43:29 UTC (rev 3400)
@@ -37,7 +37,8 @@
 		if(this.frameName){
 			document.getElementById(this.frameName).style.width = this.width;
-		this.domElement.style.width = this.width;
+		var domElement = this.getDomElement();
+		domElement.style.width = this.width;
@@ -51,6 +52,13 @@
 		return parseInt(this.height, 10);
+	this.getDomElement = function(){
+		if(this.frameName){
+			return window.frames[this.frameName].document.getElementById(this.elementName);
+		return document.getElementById(this.elementName);
 	 * set the height of the mapObj
@@ -62,7 +70,8 @@
 		if(this.frameName){
 			document.getElementById(this.frameName).style.height = this.height;
-		this.domElement.style.height = this.height;
@@ -167,14 +176,9 @@
 	this.calculateExtent(wmsExtent);
 	this.mapURL = [];
-	if(this.frameName){
-		this.domElement = window.frames[this.frameName].document.getElementById(this.elementName);
-	else{
-		this.domElement = document.getElementById(this.elementName);
+	domElement.style.height = this.height;
@@ -857,10 +861,6 @@
 		return true;
-	this.getDomElement = function(){
-		return this.domElement;
 	this.getMousePos = function(e){
 		if(ie){
 			if(this.frameName){
More information about the Mapbender_commits mailing list
