[Mapbender-commits] r3406 - in trunk/mapbender: http/classes
http/include resources/db/update
svn_mapbender at osgeo.org
Mon Jan 5 06:12:07 EST 2009
Author: christoph
Date: 2009-01-05 06:12:07 -0500 (Mon, 05 Jan 2009)
New Revision: 3406
Added:
trunk/mapbender/http/include/gui1_splash.php
trunk/mapbender/http/classes/class_element.php
trunk/mapbender/resources/db/update/update_2.6.sql
http://trac.osgeo.org/mapbender/ticket/231
Modified: trunk/mapbender/http/classes/class_element.php
--- trunk/mapbender/http/classes/class_element.php 2009-01-05 10:50:52 UTC (rev 3405)
+++ trunk/mapbender/http/classes/class_element.php 2009-01-05 11:12:07 UTC (rev 3406)
@@ -45,6 +45,7 @@
var $target;
var $requires;
var $helpUrl;
+ var $isBodyAndUsesSplashScreen = false;
public function __contruct() {
@@ -126,7 +127,7 @@
private function getHtmlOpenTag () {
$openTag = "";
if ($this->id) {
// tag name
$openTag .= "<" . $this->element . " ";
@@ -184,17 +185,37 @@
$openTag .= "'>";
- if ($this->element == "body" && USE_LOAD_MESSAGE) {
- $htmlWhileLoading = "<img src='../img/indicator_wheel.gif'> " .
- "<b>Ma<font color='#0000CE'>p</font><font color='#C00000'>b</font>ender " .
- MB_VERSION_NUMBER . " " . strtolower(MB_VERSION_APPENDIX) . "</b>..." .
- "loading application '" . $this->guiId . "'";
+ if ($this->element == "body") {
+ $e_id = "body";
+ $gui_id = $this->guiId;
+ include(dirname(__FILE__)."/../include/dyn_php.php");
+ $splashScreen = "";
+ if ($use_load_message) {
+ $this->isBodyAndUsesSplashScreen = true;
+ if (isset($htmlWhileLoading) && $htmlWhileLoading != '') {
+ $splashScreen .= $htmlWhileLoading;
+ } elseif (isset($includeWhileLoading) && $includeWhileLoading != '' && file_exists(dirname(__FILE__)."/".$includeWhileLoading)) {
+ ob_start();
+ include(dirname(__FILE__)."/".$includeWhileLoading);
+ $splashScreen .= ob_get_contents();
+ ob_end_clean();
+ else {
+ $splashScreen .= "<img src='../img/indicator_wheel.gif'> " .
+ "<b>Ma<font color='#0000CE'>p</font><font color='#C00000'>b</font>ender " .
+ MB_VERSION_NUMBER . " " . strtolower(MB_VERSION_APPENDIX) . "</b>..." .
+ "loading application '" . $this->guiId . "'";
$openTag .= "<div id='loading_mapbender' " .
- "style='position:absolute;top:100;left:100'>" .
- $htmlWhileLoading . "</div>" .
+ "style='margin:0px;padding:0px;width:100%;height:100%;'>" .
+ $splashScreen . "</div>" .
"<div id='complete_mapbender' " .
"style='display:none'>";
+ unset ($e_id, $gui_id);
return $openTag;
@@ -209,7 +230,7 @@
private function getHtmlCloseTag () {
+ if ($this->element == "body" && $this->isBodyAndUsesSplashScreen) {
return "</div></body>";
if ($this->closeTag != "") {
Added: trunk/mapbender/http/include/gui1_splash.php
--- trunk/mapbender/http/include/gui1_splash.php (rev 0)
+++ trunk/mapbender/http/include/gui1_splash.php 2009-01-05 11:12:07 UTC (rev 3406)
@@ -0,0 +1,6 @@
+<?php
+echo "<img src='../img/indicator_wheel.gif'> " .
+ "loading application '" . $gui_id . "'";
Modified: trunk/mapbender/resources/db/update/update_2.6.sql
--- trunk/mapbender/resources/db/update/update_2.6.sql 2009-01-05 10:50:52 UTC (rev 3405)
+++ trunk/mapbender/resources/db/update/update_2.6.sql 2009-01-05 11:12:07 UTC (rev 3406)
@@ -104,3 +104,7 @@
UPDATE gui_element SET e_element = 'div', e_src = '', e_attributes = '', e_more_styles = 'overflow:hidden;', e_content = '', e_closetag = 'div', e_js_file = 'mod_zoomCoords.php', e_target = 'mapframe1,overview', e_requires = 'mapframe1' WHERE e_id = 'zoomCoords';
+-- a demo splash screen for gui1
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'use_load_message', 'true', '' ,'php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui1', 'body', 'includeWhileLoading', '../include/gui1_splash.php', '' ,'php_var');
More information about the Mapbender_commits
