[Mapbender-commits] r3407 - branches/astroidex_25/http/tools
    svn_mapbender at osgeo.org
    Tue Jan  6 14:07:00 EST 2009
Author: astrid_emde
Date: 2009-01-06 14:07:00 -0500 (Tue, 06 Jan 2009)
New Revision: 3407
Added:
   branches/astroidex_25/http/tools/mapFiler.php
I changed some parts of the mapFiler to let it work with UMN MapServer 5.x
changes in Version 0.2
        I called ther version 0.2
	multiplicate MAXSIZE with factor
	division SYMBOLSCALE by factor
	multiplicate WIDTH with factor
	division MINSCALEDENOM and MAXSCALEDENOM by factor
Added: branches/astroidex_25/http/tools/mapFiler.php
--- branches/astroidex_25/http/tools/mapFiler.php	                        (rev 0)
+++ branches/astroidex_25/http/tools/mapFiler.php	2009-01-06 19:07:00 UTC (rev 3407)
@@ -0,0 +1,162 @@
+<html>
+  <head>
+    <title>MapFiler Version 0.2 for UMN MapServer 5.x</title>
+    <style></style>
+  <script type='text/javascript' >
+  function validate(){
+  	/*eventuell den Inhalt (Pfad) noch aufbereiten?
+	* Slash und Backslash -> win, linux usw.
+	document.form1.location.type = 'text';
+	document.form1.myLocation.value = document.form1.location.value;
+	document.form1.submit();
+  </script>
+  </head>
+  <body>
+  <form name='form1' action='<?php $PHP_SELF ?>' method='POST'>
+	<b>MapFiler Version 0.2 for UMN MapServer 5.x </b>
+	<br><br>changes in Version 0.2
+	<li>multiplicate MAXSIZE with factor</li>
+	<li>division SYMBOLSCALE by factor</li>
+	<li>multiplicate WIDTH with factor</li>
+	<li>division MINSCALEDENOM and MAXSCALEDENOM by factor  </li>
+	<br>
+  <table>
+	<tr>
+		<td>Location:</td>
+		<td>
+			<input type='file' name='location' >
+			<input type='hidden' name='myLocation'>
+		</td>
+	</tr>
+	<tr>
+		<td>all files with the same extension:</td>
+		<td>
+		<input type='checkbox' name='dir'>
+		</td>
+	</tr>
+	<tr>
+		<td>Factor:</td>
+		<td><input type='text' name='factor' value='4'></td>
+	</tr>
+	<tr>
+		<td><input type='button' value="let's go" onclick='validate()'></td>
+		<td></td>
+	</tr>
+  </table>
+  <?php
+import_request_variables('PG');
+/*********PARAMS***************/
+$countSymbolsFiles = 0;
+$arraySymbolsFiles;
+function modify($myDir, $myFile){
+	global $factor;
+	$myContent = fopen($myDir."/".$myFile, "r") or die("Datei " . $myDir . " / ". $myFile ." konnte nicht zum Lesen geöffnet werden!");
+	$myNewContent = fopen($myDir."/".str_replace(".","_".$factor.".",$myFile), "w") or die("Datei " . $myDir . " / ". str_replace(".","_".$factor.".",$myFile) ." konnte nicht zum Schreiben geöffnet werden!");
+	fputs($myNewContent, "#Modified by MapbenderTools" . "Date: ". date("d.m.Y") . "Factor: ". $factor . "\n\n");
+	//fputs($myNewContent, "#Date: ". date("d.m.Y") . "Factor: ". $factor . "\n\n");
+	//fputs($myNewContent, "#Factor: ". $factor . "\n\n");
+	while(!feof($myContent)){
+		$myLine = fgets($myContent, 1024);
+		if(preg_match("/\bSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+			if(count($matches) <= 2){
+				fputs($myNewContent, str_replace($matches[1], multiplicate($matches[1]), $myLine));
+		else if(preg_match("/(.*OFFSET)\s*(\d+.?\d*)(\s*)(\d+.?\d*)(\s*)/i",$myLine,$matches)){
+			$myNewOFFSET=$matches[1] . " " .multiplicate($matches[2]) . " " . multiplicate($matches[4]).$matches[5];
+			fputs($myNewContent,$myNewOFFSET);
+		else if(preg_match("/\bMAXSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+		else if(preg_match("/\bMINSIZE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+		else if(preg_match("/\bWIDTH\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+			//fputs($myNewContent, "# ". $myLine);
+		else if(preg_match("/\bSYMBOLSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+				fputs($myNewContent, str_replace($matches[1], division($matches[1]), $myLine));
+		else if(preg_match("/\bMINSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+		else if(preg_match("/\bMAXSCALE\s*(\d+.?\d*)\s*/i",$myLine,$matches)){
+		else if(preg_match("/\bSYMBOLSET\s*(.*)/i",$myLine,$matches)){ //noch nicht fertig
+			$arraySymbolFiles[$countSymbolsFiles] = str_replace("\"","",$matches[1]);
+			$countSymbolsFiles++;
+			fputs($myNewContent, $myLine);
+		#catch all
+		else{
+	fclose($myContent);
+	fclose($myNewContent);
+function multiplicate($x){
+	global $factor;
+	$x = floatval($x) * $factor;
+	return $x;
+function division($x){
+	global $factor;
+	$x = floatval($x) / $factor;
+	return $x;
+ if(isset($myLocation) && $myLocation != ""){
+	# what is to do...
+	$myFile = basename($myLocation);
+	$myDir = dirname($myLocation);
+	$suffix = strstr($myFile, ".");
+	if(!isset($dir)){
+		modify($myDir, $myFile);
+		echo "modified: " . $myDir . "/" . $myFile. "<br />";
+	else{
+		if($verz = opendir($myDir)){
+			while ($myFile = readdir ($verz)) {
+				if($myFile != ".." && $myFile != "." && is_file($myDir."/".$myFile) && strstr($myFile, $suffix)){
+			closedir($verz);
+  </form>
+  </body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
