[Mapbender-commits] r3416 - in trunk/mapbender/http: classes
javascripts php
svn_mapbender at osgeo.org
Thu Jan 8 09:41:46 EST 2009
Author: christoph
Date: 2009-01-08 09:41:46 -0500 (Thu, 08 Jan 2009)
New Revision: 3416
trunk/mapbender/http/classes/class_map.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/classes/class_wmcToXml.php
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/javascripts/mod_initWmc.php
trunk/mapbender/http/javascripts/mod_loadwmc.js
trunk/mapbender/http/javascripts/mod_loadwmc.php
trunk/mapbender/http/javascripts/mod_savewmc.php
trunk/mapbender/http/php/mod_savewmc_server.php
WMC debugging
Modified: trunk/mapbender/http/classes/class_map.php
--- trunk/mapbender/http/classes/class_map.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/classes/class_map.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -272,11 +272,21 @@
$newLayer->layer_minscale = $currentLayer->layer_minscale;
$newLayer->layer_maxscale = $currentLayer->layer_maxscale;
$newLayer->layer_metadataurl = $currentLayer->metadataurl;
- $newLayer->gui_layer_wms_id = $wms->objLayer[0]->layer_uid;
+ $newLayer->gui_layer_wms_id = $currentLayer->gui_layer_wms_id;
+// $newLayer->gui_layer_wms_id = $wms->objLayer[0]->layer_uid;
$newLayer->gui_layer_status = $currentLayer->gui_layer_status;
$newLayer->gui_layer_style = $currentLayer->gui_layer_style;
$newLayer->gui_layer_selectable = $currentLayer->gui_layer_selectable;
- $newLayer->gui_layer_visible = $currentLayer->gui_layer_visible;
+ if ($this->isOverview) {
+ preg_match_all("/LAYERS\=([^&]*)/", $jsMapObject->mapURL[0], $resultMatrix);
+ $layerList = $resultMatrix[1][0];
+ $layerListArray = explode(",", $layerList);
+ $newLayer->gui_layer_visible = (in_array($currentLayer->layer_name, $layerListArray)) ? 1 : 0;
+ else {
+ $newLayer->gui_layer_visible = $currentLayer->gui_layer_visible;
$newLayer->gui_layer_queryable = $currentLayer->gui_layer_queryable;
$newLayer->gui_layer_querylayer = $currentLayer->gui_layer_querylayer;
$newLayer->gui_layer_minscale = $currentLayer->gui_layer_minscale;
@@ -298,8 +308,8 @@
$newLayer->layer_style = array();
for ($z = 0; $z < count($currentLayer->layer_style); $z++) {
$newLayer->layer_style[$z] = array();
- $newLayer->layer_style[$z]["name"] = $currentLayer->layer_style[$z]->name;
- $newLayer->layer_style[$z]["title"] = $currentLayer->layer_style[$z]->title;
+ $newLayer->layer_style[$z]["name"] = $currentLayer->layer_style[$z]->name ? $currentLayer->layer_style[$z]->name : "default";
+ $newLayer->layer_style[$z]["title"] = $currentLayer->layer_style[$z]->title ? $currentLayer->layer_style[$z]->title : "default";
$newLayer->layer_style[$z]["legendurl"] = $currentLayer->layer_style[$z]->legendurl;
$newLayer->layer_style[$z]["legendurlformat"] = $currentLayer->layer_style[$z]->legendurlformat;
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/classes/class_wmc.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -146,7 +146,11 @@
$this->monitoringIsOn = true;
$doc = wmc::getDocument($wmcId);
+ if ($doc === false) {
+ return false;
$this->createObjFromWMC_xml($doc);
+ return true;
public function createFromApplication ($appId) {
@@ -268,9 +272,9 @@
* @param $id String the WMC id
public static function getDocument ($id) {
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
- $v = array($id);
- $t = array('s');
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND fkey_user_id = $2";
+ $v = array($id, $_SESSION["mb_user_id"]);
+ $t = array('s', 'i');
$res = db_prep_query($sql,$v,$t);
$row = db_fetch_array($res);
if ($row) {
@@ -345,19 +349,12 @@
// add WMS for main map frame
$wmsArray = $this->mainMap->getWmsArray();
- // for all wms...
- for ($i = 0; $i < count($wmsArray); $i++) {
- // ..add wms and set properties
- array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
- // delete existing map objects...
- array_push($wmcJsArray, "mb_mapObj = [];");
- // .. and add the overview map (if exists)
+ // find the WMS in the main map which is equal to the WMS
+ // in the overview map
+ $overviewWmsIndex = null;
+ $ovWmsArray = array();
if ($this->overviewMap !== null) {
- // find the WMS in the main map which is equal to the WMS
- // in the overview map
$ovWmsArray = $this->overviewMap->getWmsArray();
$overviewWmsIndex = 0;
for ($i = 0; $i < count($ovWmsArray); $i++) {
@@ -368,14 +365,48 @@
- $wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->toJavaScript($overviewWmsIndex));
+ // for all wms...
+ for ($i = 0; $i < count($wmsArray); $i++) {
+ // ..use settings from ov if available
+ if ($overviewWmsIndex !== null && $this->overviewMap !== null &&
+ $overviewWmsIndex == $i && count($ovWmsArray) > $i) {
+ array_push($wmcJsArray, $ovWmsArray[$i]->createJsObjFromWMS_());
+ else {
+ // ..otherwise use data from mapframe1
+ array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
+ // delete existing map objects...
+ array_push($wmcJsArray, "mb_mapObj = [];");
+ // .. and add the overview map (if exists) and set map request
+ if ($this->overviewMap !== null) {
+ $wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->toJavaScript($overviewWmsIndex));
// .. and add main map ..
$wmcJsArray = array_merge($wmcJsArray, $this->mainMap->toJavaScript(null));
- // Finally, request the maps
+ // set visibility of main map WMS (may be different from overview)
+ for ($i = 0; $i < count($wmsArray[$overviewWmsIndex]->objLayer); $i++) {
+ $visStr = "mb_mapObj[1].wms[" .$overviewWmsIndex . "].handleLayer(" .
+ "'" . $wmsArray[$overviewWmsIndex]->objLayer[$i]->layer_name . "', " .
+ "'visible', " .
+ ($wmsArray[$overviewWmsIndex]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
+ array_push($wmcJsArray, $visStr);
+ array_push($wmcJsArray, "mb_mapObj[1].restateLayers(" . $wmsArray[$overviewWmsIndex]->wms_id . ");");
+ // .. request the map
array_push($wmcJsArray, "setMapRequest('" . $this->mainMap->getFrameName() . "');");
array_push($wmcJsArray, "setMapRequest('" . $this->overviewMap->getFrameName() . "');");
@@ -696,7 +727,7 @@
elseif ($stylelist) {
- if ($style) {
+ if ($style) {
$index = count($currentLayer["style"]) - 1;
if ($tag == "STYLE" && $type == "close") {
$style = false;
@@ -718,10 +749,10 @@
else {
if ($tag == "NAME"){
- $currentLayer["style"][$index]["name"] = $value;
+ $currentLayer["style"][$index]["name"] = $value ? $value : "default";
if ($tag == "TITLE") {
- $currentLayer["style"][$index]["title"] = $value;
+ $currentLayer["style"][$index]["title"] = $value ? $value : "default";
if ($legendurl) {
if ($tag == "LEGENDURL" && $type == "close") {
@@ -820,7 +851,7 @@
// set WMS data
$layerlistCompleteArray = array_merge($layerlistArray["main"], $layerlistArray["overview"]);
for ($i = 0; $i < count($layerlistCompleteArray); $i++) {
$this->setLayerData($layerlistCompleteArray[$i]);
@@ -956,7 +987,7 @@
$wms->objLayer[0]->layer_queryable = 0;
$wms->objLayer[0]->layer_minscale = 0;
$wms->objLayer[0]->layer_maxscale = 0;
- $wms->objLayer[0]->gui_layer_wms_id = $currentLayer["extension"]["WMS_LAYER_ID"];
+ $wms->objLayer[0]->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
$wms->objLayer[0]->gui_layer_status = 1;
$wms->objLayer[0]->gui_layer_selectable = 1;
$wms->objLayer[0]->gui_layer_visible = 1;
@@ -1053,8 +1084,6 @@
$wmcToXml = new WmcToXml($this);
$this->xml = $wmcToXml->getXml();
Modified: trunk/mapbender/http/classes/class_wmcToXml.php
--- trunk/mapbender/http/classes/class_wmcToXml.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/classes/class_wmcToXml.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -364,7 +364,7 @@
$layerExtensionData["wms_layer_id"] = $currentWms->objLayer[0]->layer_uid;
$layerExtensionData["layer_pos"] = $currentLayer->layer_pos;
$layerExtensionData["layer_parent"] = $currentLayer->layer_parent;
- $layerExtensionData["wms_id"] = $currentWms->wms_id;
+ $layerExtensionData["wms_id"] = $currentLayer->gui_layer_wms_id;
$layerExtensionData["querylayer"] = $currentLayer->gui_layer_querylayer;
$layerExtensionData["gui_selectable"] = $currentLayer->gui_layer_selectable;
$layerExtensionData["gui_queryable"] = $currentLayer->gui_layer_queryable;
@@ -436,10 +436,10 @@
$e_layer_style->setAttribute("current", "1");
- $e_layer_style_name = $this->doc->createElement("Name", $currentStyle->name);
+ $e_layer_style_name = $this->doc->createElement("Name", $currentStyle["name"]);
$e_layer_style->appendChild($e_layer_style_name);
- $e_layer_style_title = $this->doc->createElement("Title", $currentStyle->title);
+ $e_layer_style_title = $this->doc->createElement("Title", $currentStyle["title"]);
$e_layer_style->appendChild($e_layer_style_title);
@@ -456,7 +456,7 @@
$e_layer_style_legendurl_or = $this->doc->createElement("OnlineResource");
$e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
$e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
- $e_layer_style_legendurl_or->setAttribute("xlink:href", $currentWms->wms_getlegendurl);
+ $e_layer_style_legendurl_or->setAttribute("xlink:href", $currentStyle["legendurl"]);
$e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
$e_layer_style->appendChild($e_layer_style_legendurl);
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/classes/class_wms.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -857,7 +857,7 @@
$newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
$newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
$newLayer->layer_metadataurl = $currentLayer["metadataurl"];
- $newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_LAYER_ID"];
+ $newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
$newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
$newLayer->gui_layer_style = ""; // TODO: Add correct data
$newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
@@ -911,14 +911,13 @@
// set layer style
- for ($i = 0; $i < count($currentLayer["format"]); $i++) {
+ for ($i = 0; $i < count($currentLayer["style"]); $i++) {
$layerStyleIndex = count($newLayer->gui_layer_style) - 1;
$newLayer->layer_style[$layerStyleIndex] = array();
- $currentStyle = $newLayer->layer_style[$layerStyleIndex];
- $currentStyle["name"] = $currentLayer["style"][$i]["name"];
- $currentStyle["title"] = $currentLayer["style"][$i]["title"];
- $currentStyle["legendurl"] = $currentLayer["style"][$i]["legendurl"];
- $currentStyle["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
+ $newLayer->layer_style[$layerStyleIndex]["name"] = $currentLayer["style"][$i]["name"];
+ $newLayer->layer_style[$layerStyleIndex]["title"] = $currentLayer["style"][$i]["title"];
+ $newLayer->layer_style[$layerStyleIndex]["legendurl"] = $currentLayer["style"][$i]["legendurl"];
+ $newLayer->layer_style[$layerStyleIndex]["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
Modified: trunk/mapbender/http/javascripts/mod_initWmc.php
--- trunk/mapbender/http/javascripts/mod_initWmc.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/javascripts/mod_initWmc.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -61,43 +61,36 @@
//WMC
if (isset($wmc_id)) {
- if ($adm->getWmcById($wmc_id) != false) {
+ $myInitWmc = new wmc();
+ $success = $myInitWmc->createFromDb($wmc_id);
+ if ($success) {
- $valid_wmcs = $adm->getWmcByOwner($user);
- if (in_array($wmc_id, $valid_wmcs)) {
- echo "var wmc_id = false;";
- echo "wmc_id = '".$wmc_id."';";
- $wmc = new wmc();
- $wmc->createFromDb($wmc_id);
- $js_wmc .= $wmc->createJsObjFromWMC("", $e_target[0], $action);
+ $js_wmc = implode("", $myInitWmc->toJavaScript());
+ new mb_exception("WMC JS: " . $js_wmc);
+ if (!empty($x) && !empty($y) && !empty($icon)) {
- if (!empty($x) && !empty($y) && !empty($icon)) {
- $js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
+ $js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
- // 7 is half the width of pin.png
- $js_kml .= "myPoint.x -= 7;";
- // 20 is the height of pin.png
- $js_kml .= "myPoint.y -= 20;";
+ // 7 is half the width of pin.png
+ $js_kml .= "myPoint.x -= 7;";
+ // 20 is the height of pin.png
+ $js_kml .= "myPoint.y -= 20;";
- $js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
- $js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
- $js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
- if ($url) {
- $js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
- $js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
- $js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
- $js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
- $js_kml .= "meeting_img.style.position = 'absolute';";
- $js_kml .= "meeting_img.style.top = myPoint.y;";
- $js_kml .= "meeting_img.style.left = myPoint.x;";
- $js_kml .= "mb_registerPanSubElement('meeting_logo');";
+ $js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
+ $js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
+ $js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
+ if ($url) {
+ $js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
+ $js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
+ $js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
+ $js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
+ $js_kml .= "meeting_img.style.position = 'absolute';";
+ $js_kml .= "meeting_img.style.top = myPoint.y;";
+ $js_kml .= "meeting_img.style.left = myPoint.x;";
+ $js_kml .= "mb_registerPanSubElement('meeting_logo');";
- else {
- $js_error .= "alert('".$adm->getUserNameByUserId($user)." is not allowed to access WMC ".$wmc_id.". Default GUI will be loaded instead.');";
else {
$js_error .= "alert('WMC id ".$wmc_id." is not valid. Default GUI will be loaded instead.');";
@@ -111,7 +104,6 @@
echo "function addFlag() {";
echo $js_kml;
-echo $js_error;
echo "}";
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2009-01-08 14:41:46 UTC (rev 3416)
@@ -281,4 +281,4 @@
$tr.fadeIn("slow");
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.php
--- trunk/mapbender/http/javascripts/mod_loadwmc.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -29,11 +29,11 @@
$e = new mb_notice("wmc not set, generating from app: " . $_SESSION["mb_user_gui"]);
$wmc->createFromApplication($_SESSION["mb_user_gui"]);
$_SESSION["mb_wmc"] = $wmc->toXml();
- $e = new mb_exception("initial WMC: " . $_SESSION["mb_wmc"]);
+// $e = new mb_exception("initial WMC: " . $_SESSION["mb_wmc"]);
if (isset($_SESSION['mb_wmc'])) {
- $e = new mb_notice("merging with WMC.");
+ $e = new mb_exception("merging with WMC.");
if ($wmc->createFromXml($_SESSION['mb_wmc'])) {
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -71,7 +71,12 @@
if (storeInSession) {
- $.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
+ $.ajaxSetup({async:false});
- $.post("../php/mod_savewmc_server.php", {"saveInSession":storeInSession, "generalTitle":generalTitle, "extensionData":extensionDataString, "mapObject":$.toJSON(mb_mapObj)}, callbackFunction);
+ $.post("../php/mod_savewmc_server.php", {
+ "saveInSession":storeInSession,
+ "generalTitle":generalTitle,
+ "extensionData":extensionDataString,
+ "mapObject":$.toJSON(mb_mapObj)
+ }, callbackFunction);
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php 2009-01-08 12:44:12 UTC (rev 3415)
+++ trunk/mapbender/http/php/mod_savewmc_server.php 2009-01-08 14:41:46 UTC (rev 3416)
@@ -35,7 +35,7 @@
$wmc = new wmc();
$wmc->createFromJs($mapObject, $generalTitle, $extensionData);
-if ($saveInSession) {
+if ($saveInSession === 1) {
// store XML in session
$_SESSION["mb_wmc"] = $wmc->xml;
$_SESSION["epsg"] = $mapObject->epsg;
More information about the Mapbender_commits
