[Mapbender-commits] r3417 - in branches/2.5/http: classes
javascripts php
svn_mapbender at osgeo.org
Thu Jan 8 09:47:47 EST 2009
Author: christoph
Date: 2009-01-08 09:47:47 -0500 (Thu, 08 Jan 2009)
New Revision: 3417
Added:
branches/2.5/http/classes/class_map.php
branches/2.5/http/classes/class_wmcToXml.php
branches/2.5/http/javascripts/mod_loadwmc.js
branches/2.5/http/javascripts/mod_loadwmc_list.php
branches/2.5/http/php/mod_loadwmc_server.php
branches/2.5/http/php/mod_savewmc_server.php
branches/2.5/http/classes/class_administration.php
branches/2.5/http/classes/class_user.php
branches/2.5/http/classes/class_wmc.php
branches/2.5/http/classes/class_wms.php
branches/2.5/http/javascripts/map.js
branches/2.5/http/javascripts/mod_initWmc.php
branches/2.5/http/javascripts/mod_loadwmc.php
branches/2.5/http/javascripts/mod_savewmc.php
branches/2.5/http/php/mod_mapOV.php
http://trac.osgeo.org/mapbender/ticket/364
Modified: branches/2.5/http/classes/class_administration.php
--- branches/2.5/http/classes/class_administration.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/classes/class_administration.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -106,6 +106,54 @@
+ * Removes the namespace from a tag name
+ * @return String like "gml"
+ * @param $s String like "ogc:gml"
+ public static function sepNameSpace($s) {
+ $c = strpos($s,":");
+ if ($c > 0) {
+ return substr($s,$c+1);
+ return $s;
+ * Parses an XML with PHP XML parser, see
+ * http://de2.php.net/manual/de/book.xml.php
+ * @return Array an associative array of tags, values, attributes and types
+ * @param $someXml String The actual XML as string.
+ public static function parseXml ($someXml) {
+ $values = null;
+ $tags = null;
+ $parser = xml_parser_create(CHARSET);
+ // set parsing options
+ xml_parser_set_option($parser, XML_OPTION_CASE_FOLDING, 0);
+ xml_parser_set_option($parser, XML_OPTION_SKIP_WHITE, 1);
+ xml_parser_set_option($parser, XML_OPTION_TARGET_ENCODING, CHARSET);
+ // this is the actual parsing process
+ xml_parse_into_struct($parser, $someXml, $values, $tags);
+ // check if an error occured
+ $code = xml_get_error_code ($parser);
+ if ($code) {
+ // report error
+ $line = xml_get_current_line_number($parser);
+ $errorMessage = xml_error_string($code) . " in line " . $line;
+ $mb_exception = new mb_exception($errorMessage);
+ return false;
+ xml_parser_free($parser);
+ return $values;
* returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
@@ -633,8 +681,8 @@
* @deprecated
- function getGuisByPermission($mb_user_id,$ignorepublic){
- $e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
+ function getGuisByPermission($mb_user_id,$ignorepublic){
+ $e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
$user = new User($mb_user_id);
return $user->getApplicationsByPermission($ignorepublic);
@@ -1085,10 +1133,10 @@
* @param integer userid the user-ID of the current user
* @return integer[] the IDs of the wfs_conf-table
- function getWfsConfByPermission($userid){
+ function getWfsConfByPermission($userid){
$e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
$user = new User($userid);
return $user->getWfsConfByPermission();
\ No newline at end of file
Added: branches/2.5/http/classes/class_map.php
--- branches/2.5/http/classes/class_map.php (rev 0)
+++ branches/2.5/http/classes/class_map.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,458 @@
+<?php
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
+ * Representing a map object, identical to the JS object in javascripts/map.js
+ * @class
+class Map {
+ private $width;
+ private $height;
+ private $frameName;
+ private $elementName = "maps";
+ private $extent;
+ private $isOverview = false;
+ private $wmsArray = array();
+ * @destructor
+ * @param
+ function __destruct() {
+ * @constructor
+ * @param
+ function __construct() {
+ // getter and setter
+ * @param $value Integer
+ public function setWidth ($value) {
+ $this->width = $value;
+ * @return
+ public function getWidth () {
+ return $this->width;
+ public function setHeight ($value) {
+ $this->height = $value;
+ * @return
+ public function getHeight () {
+ return $this->height;
+ * @param $value String
+ public function setFrameName ($value) {
+ $this->frameName = $value;
+ public function setElementName ($value) {
+ $this->elementName = $value;
+ * @return String
+ public function getFrameName () {
+ return $this->frameName;
+ public function setExtent ($aMapbenderBbox) {
+ $this->extent = $aMapbenderBbox;
+ * @return Mapbender_bbox
+ public function getExtent () {
+ return $this->extent;
+ * @return String EPSG code of the map.
+ public function getEpsg () {
+ return $this->extent->epsg;
+ * @return
+ public function getWmsArray () {
+ return $this->wmsArray;
+ * @return
+ * @param $wmsArray Object
+ public function setWmsArray ($wmsArray) {
+ $this->wmsArray = $wmsArray;
+ * @return
+ public function isOverview () {
+ return $this->isOverview;
+ public function setIsOverview ($bool) {
+ $this->isOverview = $bool;
+ * @param $value Object
+ public function addWms ($value) {
+ array_push($this->wms, $value);
+ // map manipulation
+ * Appends the WMS of another map to this map.
+ * @param $anotherMap Map
+ public function append ($anotherMap) {
+ $this->wmsArray = array_merge($anotherMap->getWmsArray(), $this->wmsArray);
+ * Merges this map with another map: Copies the map settings from the
+ * other map and merges the WMS (keeping the settings of the other
+ * map if there are duplicates)
+ public function merge ($anotherMap) {
+ $this->width = $anotherMap->width;
+ $this->height = $anotherMap->height;
+ $this->frameName = $anotherMap->frameName;
+ $this->elementName = $anotherMap->elementName;
+ $this->extent = $anotherMap->extent;
+ $this->isOverview = $anotherMap->isOverview;
+ $this->wmsArray = wms::merge(array_merge($anotherMap->getWmsArray(), $this->wmsArray));
+ * Adds WMS to this map
+ * @return
+ public function appendWmsArray ($wmsArray) {
+ $this->wmsArray = array_merge($this->wmsArray, $wmsArray);
+ * Merge WMS into this map
+ * @return
+ public function mergeWmsArray ($wmsArray) {
+ $this->wmsArray = wms::merge(array_merge($this->wmsArray, $wmsArray));
+ // Instantiation
+ * @return
+ * @param $jsMapObject Object
+ public function createFromJs ($jsMapObject) {
+ $arrayBBox = explode(",", $jsMapObject->extent);
+ $minx = floatval($arrayBBox[0]);
+ $miny = floatval($arrayBBox[1]);
+ $maxx = floatval($arrayBBox[2]);
+ $maxy = floatval($arrayBBox[3]);
+ $srs = $jsMapObject->epsg;
+ $bbox = new Mapbender_bbox($minx, $miny, $maxx, $maxy, $srs);
+ $this->width = $jsMapObject->width;
+ $this->height = $jsMapObject->height;
+ $this->frameName = $jsMapObject->frameName;
+ $this->extent = $bbox;
+ if (isset($jsMapObject->isOverview) && $jsMapObject->isOverview == "1") {
+ $this->isOverview = true;
+ for ($i=0; $i < count($jsMapObject->wms); $i++){
+ $currentWms = $jsMapObject->wms[$i];
+ $wms = new wms();
+ // set WMS data
+ $wms->wms_id = $currentWms->wms_id;
+ $wms->wms_version = $currentWms->wms_version;
+ $wms->wms_title = $currentWms->wms_title;
+ $wms->wms_abstract = $currentWms->wms_abstract;
+ $wms->wms_getmap = $currentWms->wms_getmap;
+ $wms->wms_getfeatureinfo = $currentWms->wms_getfeatureinfo;
+ $wms->wms_getlegendurl = $currentWms->wms_getlegendurl;
+ $wms->wms_filter = $currentWms->wms_filter;
+ $wms->gui_epsg = $currentWms->gui_epsg;
+ $wms->gui_minx = $currentWms->gui_minx;
+ $wms->gui_miny = $currentWms->gui_miny;
+ $wms->gui_maxx = $currentWms->gui_maxx;
+ $wms->gui_maxy = $currentWms->gui_maxy;
+ $wms->gui_wms_mapformat = $currentWms->gui_wms_mapformat;
+ $wms->gui_wms_featureinfoformat = $currentWms->gui_wms_featureinfoformat;
+ $wms->gui_wms_exceptionformat = $currentWms->gui_wms_exceptionformat;
+ $wms->gui_wms_opacity = $currentWms->wms_opacity;
+ $wms->gui_wms_sldurl = $currentWms->gui_wms_sldurl;
+ $wms->gui_wms_visible = $currentWms->gui_wms_visible;
+ $wms->gui_wms_epsg = $currentWms->gui_wms_epsg;
+ $wms->data_type = $currentWms->data_type;
+ $wms->data_format = $currentWms->data_format;
+ for ($k = 0; $k < count($currentWms->objLayer); $k++){
+ // the current layer of the JSON map object
+ $currentLayer = $currentWms->objLayer[$k];
+ // add new layer to WMS
+ $pos = $currentLayer->layer_pos;
+ $parent = $currentLayer->layer_parent;
+ $wms->addLayer($pos, $parent);
+ $newLayerIndex = count($wms->objLayer) - 1;
+ // $newLayer is a short cut to the layer we just added
+ $newLayer = $wms->objLayer[$newLayerIndex];
+ // set layer data
+ $newLayer->layer_uid = $currentLayer->layer_uid;
+ $newLayer->layer_name = $currentLayer->layer_name;
+ $newLayer->layer_title = $currentLayer->layer_title;
+ $newLayer->layer_dataurl_href = $currentLayer->layer_dataurl_href;
+ $newLayer->layer_pos = $currentLayer->layer_pos;
+ $newLayer->layer_queryable = $currentLayer->layer_queryable;
+ $newLayer->layer_minscale = $currentLayer->layer_minscale;
+ $newLayer->layer_maxscale = $currentLayer->layer_maxscale;
+ $newLayer->layer_metadataurl = $currentLayer->metadataurl;
+ $newLayer->gui_layer_wms_id = $currentLayer->gui_layer_wms_id;
+// $newLayer->gui_layer_wms_id = $wms->objLayer[0]->layer_uid;
+ $newLayer->gui_layer_status = $currentLayer->gui_layer_status;
+ $newLayer->gui_layer_style = $currentLayer->gui_layer_style;
+ $newLayer->gui_layer_selectable = $currentLayer->gui_layer_selectable;
+ if ($this->isOverview) {
+ preg_match_all("/LAYERS\=([^&]*)/", $jsMapObject->mapURL[0], $resultMatrix);
+ $layerList = $resultMatrix[1][0];
+ $layerListArray = explode(",", $layerList);
+ $newLayer->gui_layer_visible = (in_array($currentLayer->layer_name, $layerListArray)) ? 1 : 0;
+ else {
+ $newLayer->gui_layer_visible = $currentLayer->gui_layer_visible;
+ $newLayer->gui_layer_queryable = $currentLayer->gui_layer_queryable;
+ $newLayer->gui_layer_querylayer = $currentLayer->gui_layer_querylayer;
+ $newLayer->gui_layer_minscale = $currentLayer->gui_layer_minscale;
+ $newLayer->gui_layer_maxscale = $currentLayer->gui_layer_maxscale;
+ $newLayer->gui_layer_wfs_featuretype = $currentLayer->gui_layer_wfs_featuretype;
+ // BEWARE THIS IS SUPER UGLY CODE
+ $newLayer->layer_epsg = array();
+ for ($z = 0; $z < count($currentLayer->layer_epsg); $z++) {
+ $newLayer->layer_epsg[$z] = array();
+ $newLayer->layer_epsg[$z]["epsg"] = $currentLayer->layer_epsg[$z]->epsg;
+ $newLayer->layer_epsg[$z]["minx"] = $currentLayer->layer_epsg[$z]->minx;
+ $newLayer->layer_epsg[$z]["miny"] = $currentLayer->layer_epsg[$z]->miny;
+ $newLayer->layer_epsg[$z]["maxx"] = $currentLayer->layer_epsg[$z]->maxx;
+ $newLayer->layer_epsg[$z]["maxy"] = $currentLayer->layer_epsg[$z]->maxy;
+ $newLayer->layer_style = array();
+ for ($z = 0; $z < count($currentLayer->layer_style); $z++) {
+ $newLayer->layer_style[$z] = array();
+ $newLayer->layer_style[$z]["name"] = $currentLayer->layer_style[$z]->name ? $currentLayer->layer_style[$z]->name : "default";
+ $newLayer->layer_style[$z]["title"] = $currentLayer->layer_style[$z]->title ? $currentLayer->layer_style[$z]->title : "default";
+ $newLayer->layer_style[$z]["legendurl"] = $currentLayer->layer_style[$z]->legendurl;
+ $newLayer->layer_style[$z]["legendurlformat"] = $currentLayer->layer_style[$z]->legendurlformat;
+ array_push($this->wmsArray, $wms);
+ return true;
+ // database functions
+ public static function selectMainMapByApplication ($appId) {
+ return map::selectByApplication($appId, "mapframe1");
+ public static function selectOverviewMapByApplication ($appId) {
+ $currentMap = map::selectByApplication($appId, "overview");
+ if ($currentMap !== null) {
+ $currentMap->setIsOverview(true);
+ return $currentMap;
+ // Output
+ * Returns an array of string, which are JS statements.
+ * @return String[]
+ public function toJavaScript ($wmsIndex) {
+ $jsCodeArray = array();
+ // initialise map object
+ if ($wmsIndex === null) {
+ $wmsIndex = "null";
+ $registerMapString = "mb_registerMapObj('" .
+ $this->frameName . "', " .
+ "'maps', " .
+ $wmsIndex . ", " .
+ $this->width . ", " .
+ $this->height . ");";
+ array_push($jsCodeArray, $registerMapString);
+// $e = new mb_notice("Map to JS: ov? " . $this->isOverview);
+ // if map is overview...
+ // ...set overview flag
+ $setOverviewFlagString = "mb_mapObj[mb_mapObj.length-1].isOverview = true;";
+ array_push($jsCodeArray, $setOverviewFlagString);
+ // set width
+ $setMapframeWidth = "document.getElementById('" . $this->frameName . "')." .
+ "style.width = " . $this->width . ";";
+ array_push($jsCodeArray, $setMapframeWidth);
+ // set height
+ $setMapframeHeight = "document.getElementById('" . $this->frameName . "')." .
+ "style.height = " . $this->height . ";";
+ array_push($jsCodeArray, $setMapframeHeight);
+ // calculate extent
+ $calcExtentString = "mb_calculateExtent('" .
+ $this->extent->min->x . ", " .
+ $this->extent->min->y . ", " .
+ $this->extent->max->x . ", " .
+ $this->extent->max->y . ");";
+ array_push($jsCodeArray, $calcExtentString);
+ return $jsCodeArray;
+ // PRIVATE FUNCTIONS
+ private static function selectByApplication ($appId, $frameName) {
+ // find the mapframe in the application elements...
+ $sql = "SELECT * FROM gui_element WHERE fkey_gui_id = $1 AND " .
+ "e_id = $2 AND e_public = 1 LIMIT 1";
+ $v = array($appId, $frameName);
+ $t = array('s', 's');
+ $res = db_prep_query($sql,$v,$t);
+ $row = db_fetch_array($res);
+ // if found...
+ if ($row) {
+ $currentMap = new Map();
+ // use settings from database
+ $currentMap->setWidth($row["e_width"]);
+ $currentMap->setHeight($row["e_height"]);
+ $currentMap->setFrameName($row["e_id"]);
+ // get the WMS
+ $wmsArray = wms::selectMyWmsByApplication($appId);
+// $e = new mb_notice("WMS in this map: " . implode(",", $wmsArray));
+ // if this is the overview, find the WMS index and
+ // reset the WMS array
+ // BEWARE, SUPER UGLY CODE AHEAD!!
+ // (BUT THERE IS NO OTHER WAY TO DO IT)
+ if (strpos($row["e_src"], "mod_mapOV.php?wms") !== false) {
+// $e = new mb_exception("guess this is the OV");
+ $pattern = "/[\.\/a-zA-Z_]*\?wms=([0-9]*)[^0-9]*/";
+ $ovIndex = preg_replace($pattern, "\$1", $row["e_src"]);
+// $e = new mb_exception("OV index: " . $ovIndex);
+ if (!$ovIndex) {
+ $ovIndex = 0;
+ $wmsArray = array($wmsArray[$ovIndex]);
+// $e = new mb_notice("WMS in this map (corrected): " . implode(",", $wmsArray));
+ else {
+// $e = new mb_exception("guess this is NOT the OV");
+ $currentMap->wmsArray = $wmsArray;
+ // EXTENT
+ $minx = $wmsArray[0]->objLayer[0]->layer_epsg[0]["minx"];
+ $miny = $wmsArray[0]->objLayer[0]->layer_epsg[0]["miny"];
+ $maxx = $wmsArray[0]->objLayer[0]->layer_epsg[0]["maxx"];
+ $maxy = $wmsArray[0]->objLayer[0]->layer_epsg[0]["maxy"];
+ $epsg = $wmsArray[0]->objLayer[0]->layer_epsg[0]["epsg"];
+ $mapExtent = new Mapbender_bbox($minx, $miny, $maxx, $maxy, $epsg);
+ $currentMap->setExtent($mapExtent);
+ else {
+ return null;
Modified: branches/2.5/http/classes/class_user.php
--- branches/2.5/http/classes/class_user.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/classes/class_user.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -38,6 +38,13 @@
+ * @return String the ID of this user
+ public function __toString () {
+ return (string) $this->id;
* Returns an array of application IDs that the user is allowed to access.
* @return Array an array of application IDs
@@ -129,5 +136,24 @@
return $ownWFSconfs;
+ * Returns all WMCs that this user owns
+ * @return integer[] an array of WMC ids; ids from table mb_user_wmc
+ public function getWmcByOwner () {
+ $sql = "SELECT wmc_id FROM mb_user_wmc ";
+ $sql .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
+ $v = array($this->id);
+ $t = array("i");
+ $res_wmc = db_prep_query($sql, $v, $t);
+ $wmcArray = array();
+ while($row = db_fetch_array($res_wmc)){
+ array_push($wmcArray, $row["wmc_id"]);
+ return $wmcArray;
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/classes/class_wmc.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -16,56 +16,87 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__) . "/../classes/class_wms.php");
require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
require_once(dirname(__FILE__) . "/../classes/class_point.php");
require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_map.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+require_once(dirname(__FILE__) . "/../classes/class_wmcToXml.php");
-function mb_utf8_encode ($str) {
- if(CHARSET!="UTF-8") return utf8_encode($str);
- return $str;
-function mb_utf8_decode ($str) {
- if(CHARSET!="UTF-8") return utf8_decode($str);
- return $str;
-function sepNameSpace($s){
- $c = strpos($s,":");
- if($c>0)return substr($s,$c+1);
- return $s;
* Implementation of a Web Map Context Document, WMC 1.1.0
+ * Use cases:
+ * Instantiation (1) create a WMC object from a WMC XML document
+ * $myWmc = new wmc();
+ * $myWmc->createFromXml($xml);
+ * If you want to create a WMC object from a WMC in the database
+ * $xml = wmc::getDocument($wmcId);
+ * Instantiation (2) create a WMC from the client side
+ * $myWmc->createFromJs($mapObject, $generalTitle, $extensionData);
+ * (creates a WMC from the JS data and then creates an object from that WMC)
+ * Output (1) (do Instantiation first) Load a WMC into client
+ * This will return an array of JS statements
+ * $myWmc->toJavaScript();
+ * Output (2) (do Instantiation first) Merge with another WMC, then load
+ * $myWmc->merge($anotherWmcXml);
class wmc {
+ * Representing the main map in a map application
+ * @var Map
+ var $mainMap;
+ * Representing an (optional) overview map in a map application
+ * @var Map
+ var $overviewMap;
+ * @var Array
+ var $generalExtensionArray = array();
+ * The XML representation of this WMC.
+ * @var String
var $xml;
+ // constants
+ var $monitoringIsOn = false;
+ var $saveWmcAsFile = false;
+ var $extensionNamespace = "mapbender";
+ var $extensionNamespaceUrl = "http://www.mapbender.org";
+ // set in constructor
var $wmc_id;
+ var $userId;
+ // set during parsing
var $wmc_version;
- var $wmc_windowWidth;
- var $wmc_windowHeight;
- var $wmc_bBox_SRS;
- var $wmc_bBox_minx;
- var $wmc_bBox_maxx;
- var $wmc_bBox_miny;
- var $wmc_bBox_maxy;
var $wmc_name;
var $wmc_title;
var $wmc_abstract;
- var $wmc_general_extension = array();
- var $wmc_logourl;
- var $wmc_logourl_format;
- var $wmc_logourl_type;
- var $wmc_logourl_width;
- var $wmc_logourl_height;
- var $wmc_descriptionurl;
- var $wmc_descriptionurl_format;
- var $wmc_descriptionurl_type;
var $wmc_keyword = array();
var $wmc_contactposition;
var $wmc_contactvoicetelephone;
@@ -79,1294 +110,995 @@
var $wmc_contactstateorprovince;
var $wmc_contactpostcode;
var $wmc_contactcountry;
- var $wmc_wms_title = array();
- var $wmc_layer_queryable = array();
- var $wmc_layer_hidden = array();
- var $wmc_wms_id = array();
- var $wmc_wms_service = array();
- var $wmc_wms_version = array();
- var $wmc_wms_layer_id = array();
- var $wmc_layer_wfs_featuretype = array();
- var $wmc_layer_id = array();
- var $wmc_layer_pos = array();
- var $wmc_layer_parent = array();
- var $wmc_layer_querylayer = array();
- var $wmc_layer_title = array();
- var $wmc_layer_name = array();
- var $wmc_layer_abstract = array();
- var $wmc_layer_srs = array();
- var $wmc_wms_serviceURL = array();
- var $wmc_layer_format_current = array();
- var $wmc_layer_dataurl = array();
- var $wmc_layer_metadataurl = array();
- var $wmc_layer_minscale = array();
- var $wmc_layer_maxscale = array();
- var $wmc_gui_layer_minscale = array();
- var $wmc_gui_layer_maxscale = array();
- var $wmc_layer_format = array();
- var $wmc_layer_style_current = array();
- var $wmc_layer_style_name = array();
- var $wmc_layer_style_title = array();
- var $wmc_layer_style_legendurl = array();
- var $wmc_layer_style_legendurl_width = array();
- var $wmc_layer_style_legendurl_height = array();
- var $wmc_layer_style_legendurl_format = array();
- var $wmc_layer_style_legendurl_type = array();
- var $wmc_layer_style_sld_url = array();
- var $wmc_layer_style_sld_type = array();
- var $wmc_layer_style_sld_title = array();
- var $wmc_wms_count = 0;
- var $data_type = array();
- var $data_format = array();
- var $objLayer = array();
- var $gui_wms_mapformat;
- var $gui_wms_featureinfoformat;
- var $gui_wms_exceptionformat;
- var $gui_wms_epsg;
- var $default_epsg = 0;
- var $monitoringIsOn = false;
-function wmc() {
+ var $wmc_logourl;
+ var $wmc_logourl_format;
+ var $wmc_logourl_type;
+ var $wmc_logourl_width;
+ var $wmc_logourl_height;
+ var $wmc_descriptionurl;
+ var $wmc_descriptionurl_format;
+ var $wmc_descriptionurl_type;
- * Saves the current WMC in the log folder.
- * @return string the filename of the WMC document.
-function saveAsFile() {
- $filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
- $logfile = "../../log/" . $filename;
+ public function __construct () {
+ $this->userId = $_SESSION["mb_user_id"];
+ $this->wmc_id = time();
- if($h = fopen($logfile,"a")){
- $content = $this->xml;
- if(!fwrite($h,$content)){
- $e = new mb_exception("class_wmc.php: failed to write wmc.");
+ // INSTANTIATION
+ * Parses the XML string and instantiates the WMC object.
+ * @param $xml String
+ public function createFromXml ($xml) {
+ return $this->createObjFromWMC_xml($xml);
+ * Loads a WMC from the database.
+ * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
+ function createFromDb($wmcId){
+ $this->monitoringIsOn = true;
+ $doc = wmc::getDocument($wmcId);
+ if ($doc === false) {
return false;
- fclose($h);
+ $this->createObjFromWMC_xml($doc);
+ return true;
- return $filename;
- * @return string the title of the WMC.
-function getTitle() {
- return $this->wmc_title;
+ public function createFromApplication ($appId) {
+ // get the map objects "overview" and "mapframe1"
+ $this->mainMap = map::selectMainMapByApplication($appId);
+ $this->overviewMap = map::selectOverviewMapByApplication($appId);
+ $this->createXml();
+ $this->saveAsFile();
- * @return Integer the number of (unique?) WMS contained in this WMC.
-function getNumberOfWms () {
- return $this->wmc_wms_count;
- * Creates a WMC object from a JS map object {@see map.js}
- * @param object $mapObject a map object
- * @param integer $user_id the ID of the current user
- * @param string $generalTitle the desired title of the WMC
- * @param object $extensionData data exclusive to Mapbender, which will be
- * mapped into the extension part of the WMC
-function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
- $this->wmc_id = $user_id . '_' . time();
+ * Creates a WMC object from a JS map object {@see map_obj.js}
+ * @param object $mapObject a map object
+ * @param integer $user_id the ID of the current user
+ * @param string $generalTitle the desired title of the WMC
+ * @param object $extensionData data exclusive to Mapbender, which will be
+ * mapped into the extension part of the WMC
+ public function createFromJs($mapObject, $generalTitle, $extensionData) {
- $generalWidth = $mapObject->width;
- $generalHeight = $mapObject->height;
- $generalBboxSrs = $mapObject->epsg;
- $arrayBBox = explode(",", $mapObject->extent);
- $generalBboxMinx = floatval($arrayBBox[0]);
- $generalBboxMiny = floatval($arrayBBox[1]);
- $generalBboxMaxx = floatval($arrayBBox[2]);
- $generalBboxMaxy = floatval($arrayBBox[3]);
- $generalName = "Mapbender WMC"; // TO do : insert proper data
- $generalKeywords = array("Mapbender", "WMC"); // TO do : insert proper data
- $generalAbstract = ""; // TO do : insert proper data
- $generalLogoUrl = ""; // TO do : insert proper data
- $generalLogoUrlWidth = ""; // TO do : insert proper data
- $generalLogoUrlHeight = ""; // TO do : insert proper data
- $generalLogoUrlFormat = ""; // TO do : insert proper data
- $generalDescriptionUrl = ""; // TO do : insert proper data
- $generalContactPerson = "";
- $generalContactOrganization = "";
- $generalContactPosition = "";
- $generalContactAddressType = "";
- $generalContactAddress = "";
- $generalContactCity = "";
- $generalContactStateOrProvince = "";
- $generalContactPostCode = "";
- $generalContactCountry = "";
- $generalContactVoiceTelephone = "";
- $generalContactFacsimileTelephone = "";
- $generalContactElectronicMailAddress = "";
- $extension_namespace = "mapbender";
- // LayerList variables
- $layerHidden = "";
- $layerQueryable = "";
- $layerAbstract = "";
- $layerName = "";
- $layerSrs = "";
- $layerDataUrl = "";
- $layerMetadataUrl = "";
- $layerFormat = "";
- $layerFormat_current = "";
- $layerStyle_current = "";
- $layerStyle_name = "";
- $layerStyle_title = "";
- $layerStyle_legendURL = "";
- $layerStyle_legendURL_width = "";
- $layerStyle_legendURL_height = "";
- $layerStyle_legendURL_format = "";
- // generate XML
- $doc = new DOMDocument("1.0", CHARSET);
- $doc->preserveWhiteSpace = false;
- // ViewContext
- $e_view_context = $doc->createElementNS("http://www.opengis.net/context", "ViewContext");
- $e_view_context->setAttribute("version", "1.0.0");
- $e_view_context->setAttribute("id", $this->wmc_id);
- $e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_view_context->setAttribute("xmlns:mapbender", "http://www.mapbender.org");
- $e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
- $e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
- // General
- $e_general = $doc->createElement("General");
- $e_window = $doc->createElement("Window");
- if (!empty($generalWidth) && !empty($generalHeight)) {
- $e_window->setAttribute("width", $generalWidth);
- $e_window->setAttribute("height", $generalHeight);
+ if (count($mapObject) > 2) {
+ $e = new mb_exception("Save WMC only works for two concurrent map frames (overview plus main) at the moment.");
+ // set extension data
+ $this->generalExtensionArray = $extensionData;
+ // set title
+ $this->wmc_title = $generalTitle;
+ // create the map objects
+ for ($i = 0; $i < count($mapObject); $i++) {
+ $currentMap->createFromJs($mapObject[$i]);
+ if (isset($mapObject[$i]->isOverview)) {
+ $this->overviewMap = $currentMap;
- $e_general->appendChild($e_window);
- $e_bbox = $doc->createElement("BoundingBox");
- $e_bbox->setAttribute("SRS", $generalBboxSrs);
- $e_bbox->setAttribute("minx", $generalBboxMinx);
- $e_bbox->setAttribute("miny", $generalBboxMiny);
- $e_bbox->setAttribute("maxx", $generalBboxMaxx);
- $e_bbox->setAttribute("maxy", $generalBboxMaxy);
- $e_general->appendChild($e_bbox);
- $e_name = $doc->createElement("Name", $generalName);
- $e_general->appendChild($e_name);
- $e_title = $doc->createElement("Title", $generalTitle);
- $e_general->appendChild($e_title);
- $e_keyword_list = $doc->createElement("KeywordList");
- for ($i=0; $i < count($generalKeywords); $i++) {
- $e_keyword = $doc->createElement("Keyword", $generalKeywords[$i]);
- $e_keyword_list->appendChild($e_keyword);
+ else {
+ $this->mainMap = $currentMap;
- $e_general->appendChild($e_keyword_list);
- if ($generalAbstract){
- $e_abstract = $doc->createElement("Abstract", $generalAbstract);
- $e_general->appendChild($e_abstract);
- if ($generalLogoUrlWidth && $generalLogoUrlHeight && $generalLogoUrlFormat && $generalLogoUrl){
- $e_logo_url = $doc->createElement("LogoURL");
- $e_logo_url->setAttribute("width", $generalLogoUrlWidth);
- $e_logo_url->setAttribute("height", $generalLogoUrlHeight);
- $e_logo_url->setAttribute("format", $generalLogoUrlFormat);
- $e_logo_url_or = $doc->createElement("OnlineResource");
- $e_logo_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_logo_url_or->setAttribute("xlink:type", "simple");
- $e_logo_url_or->setAttribute("xlink:href", $generalLogoUrl);
- $e_logo_url->appendChild($e_logo_url_or);
+ // create XML
+ return true;
- $e_general->appendChild($e_logo_url);
- if ($generalDescriptionUrl){
- $e_description_url = $doc->createElement("DescriptionURL");
- $e_description_url_or = $doc->createElement("OnlineResource");
- $e_description_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_description_url_or->setAttribute("xlink:type", "simple");
- $e_description_url_or->setAttribute("xlink:href", $generalDescriptionUrl);
- $e_description_url->appendChild($e_description_url_or);
- $e_general->appendChild($e_description_url);
+ // DATABASE FUNCTIONS
+ * Stores this WMC in the database. The WMC has to be instantiated first, see above.
+ * @return mixed[] an assoc array with attributes "success" (boolean) and "message" (String).
+ public function insert () {
+ $result = array();
+ if ($this->userId && $this->xml && $this->wmc_title) {
+ $sql = "INSERT INTO mb_user_wmc VALUES ($1, $2, $3, $4, $5)";
+ $v = array($this->wmc_id, $this->userId, $this->xml, $this->wmc_title, time());
+ $t = array("s", "i", "s", "s", "s");
- if ($generalContactElectronicMailAddress || $generalContactOrganization ||
- $generalContactPerson || $generalContactPosition || $generalContactAddressType ||
- $generalContactAddress || $generalContactCity || $generalContactStateOrProvince ||
- $generalContactPostCode || $generalContactCountry || $generalContactVoiceTelephone ||
- $generalContactFacsimileTelephone || $generalContactElectronicMailAddress) {
- $e_contact = $doc->createElement("ContactInformation");
- if ($generalContactPerson || $generalContactOrganization){
- $e_contact_person_primary = $doc->createElement("ContactPersonPrimary");
- if ($generalContactPerson){
- $e_contact_person = $doc->createElement("ContactPerson", $generalContactPerson);
- $e_contact_person_primary->appendChild($e_contact_person);
- if ($generalContactOrganization){
- $e_contact_organization = $doc->createElement("ContactOrganization", $generalContactOrganization);
- $e_contact_person_primary->appendChild($e_contact_organization);
- $e_contact->appendChild($e_contact_person_primary);
- if ($generalContactPosition){
- $e_contact_position = $doc->createElement("ContactPosition", $generalContactPosition);
- $e_contact->appendChild($e_contact_position);
- if ($generalContactAddressType || $generalContactAddress ||
- $generalContactCity || $generalContactStateOrProvince ||
- $generalContactPostCode || $generalContactCountry) {
- $e_contact_address = $doc->createElement("ContactAddress");
- if ($generalContactAddressType){
- $e_address_type = $doc->createElement("AddressType", $generalContactAddressType);
- $e_contact_address->appendChild($e_address_type);
- if ($generalContactAddress){
- $e_address = $doc->createElement("Address", $generalContactAddress);
- $e_contact_address->appendChild($e_address);
- if ($generalContactCity){
- $e_city = $doc->createElement("City", $generalContactCity);
- $e_contact_address->appendChild($e_city);
- if ($generalContactStateOrProvince){
- $e_state = $doc->createElement("StateOrProvince", $generalContactStateOrProvince);
- $e_contact_address->appendChild($e_state);
- if ($generalContactPostCode){
- $e_postcode = $doc->createElement("PostCode", $generalContactPostCode);
- $e_contact_address->appendChild($e_postcode);
- if ($generalContactCountry){
- $e_country = $doc->createElement("Country", $generalContactCountry);
- $e_contact_address->appendChild($e_country);
- $e_contact->appendChild($e_contact_address);
- if ($generalContactVoiceTelephone){
- $e_voice_telephone = $doc->createElement("ContactVoiceTelephone", $generalContactVoiceTelephone);
- $e_contact->appendChild($e_voice_telephone);
- if ($generalContactFacsimileTelephone){
- $e_facsimile_telephone = $doc->createElement("ContactFacsimileTelephone", $generalContactFacsimileTelephone);
- $e_contact->appendChild($e_facsimile_telephone);
- if ($generalContactElectronicMailAddress){
- $e_email = $doc->createElement("ContactElectronicMailAddress", $generalContactElectronicMailAddress);
- $e_contact->appendChild($e_email);
- $e_general->appendChild($e_contact);
+ $res = db_prep_query($sql, $v, $t);
+ if (db_error()) {
+ $errMsg = "Error while saving WMC document '" . $this->wmc_title . "': " . db_error();
+ $result["success"] = false;
+ $result["message"] = $errMsg;
+ $e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg);
- if (count($extensionData) > 0) {
- //$e = new mb_exception("writing wmc...");
- $e_extensionGeneral = $doc->createElement("Extension");
- foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
- $e_currentExtensionTag = $doc->createElement($extension_namespace.":".$keyExtensionData, $valueExtensionData);
- $e_extensionGeneral->appendChild($e_currentExtensionTag);
- $e_general->appendChild($e_extensionGeneral);
+ else {
+ $result["success"] = true;
+ $msg = "WMC document '" . $this->wmc_title . "' has been saved.";
+ $result["message"] = $msg;
+ $e = new mb_notice("mod_insertWMCIntoDB: WMC '" . $this->wmc_title . "' saved successfully.");
- $e_view_context->appendChild($e_general);
+ else {
+ $errMsg = "missing parameters (user_id: ".$this->userId.", title: " . $this->wmc_title . ")";
+ $e = new mb_exception("mod_insertWMCIntoDB: " . $errMsg .")");
+ return $result;
+ * deletes a {@link http://www.mapbender.org/index.php/WMC WMC}
+ * entry specified by wmc_id and user_id
+ * @param integer the user_id
+ * @param string the wmc_id
+ * @return boolean Did the query run successful?
+ public static function delete ($wmcId, $userId) {
+ if (!isset($userId) || $userId === null) {
+ $userId = $_SESSION["mb_user_id"];
+ $sql = "DELETE FROM mb_user_wmc ";
+ $sql .= "WHERE fkey_user_id = $1 AND wmc_id = $2";
+ $v = array($userId, $wmcId);
+ $t = array('i', 's');
+ if ($res) {
+ return true;
+ return false;
+ * Returns a WMC document
+ * @return String|boolean The document if it exists; else false
+ * @param $id String the WMC id
+ public static function getDocument ($id) {
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 AND fkey_user_id = $2";
+ $v = array($id, $_SESSION["mb_user_id"]);
+ $t = array('s', 'i');
+ if ($row) {
+ return $row["wmc"];
+ return false;
+ // GETTER FUNCTIONS
- // LayerList
- $e_layer_list = $doc->createElement("LayerList");
+ * @return string the title of the WMC.
+ public function getTitle() {
+ return $this->wmc_title;
+ // OUTPUT FUNCTIONS
- for ($i=0; $i < count($mapObject->wms); $i++){
- $wmsId = $mapObject->wms[$i]->wms_id;
- $wms_epsg = array();
- $wms_epsg[0] = $mapObject->epsg;
- if ($mapObject->wms[$i]->gui_wms_epsg != $mapObject->epsg){
- $wms_epsg[1] = $mapObject->wms[$i]->gui_wms_epsg;
+ * Wrapper function, returns XML at the moment
+ * @return String
+ public function __toString() {
+ return $this->toXml();
+ * Returns the XML document if available
+ * @return String The XML document; if unavailable, null is returned.
+ public function toXml () {
+ if (!$this->xml) {
+ return $this->xml;
+ * Returns an array of JavaScript statements
+ public function toJavaScript () {
+ // counts how often a layer has been loaded
+ if ($this->monitoringIsOn) {
+ $monitor = new Layer_load_count();
+ for ($i = 0; $i < count($this->wmc_layer_id); $i++) {
+ $monitor->increment($this->wmc_layer_id[$i]);
- for ($q = 0; $q < count($mapObject->wms[$i]->gui_epsg); $q++){
- $isInArray = false;
- for ($r=0 ; $r < count($wms_epsg); $r++){
- if ($wms_epsg[$r] == $mapObject->wms[$i]->gui_epsg[$q]){
- $isInArray = true;
- if ($isInArray == false){
- array_push($wms_epsg, $mapObject->wms[$i]->gui_epsg[$q]);
- for ($j = 0; $j < count($mapObject->wms[$i]->objLayer); $j++){
- if ($mapObject->wms[$i]->objLayer[$j]->layer_parent != ''){
- if ($mapObject->wms[$i]->objLayer[$j]->gui_layer_visible == "1"){
- $layerHidden = 0;
- else{
- $layerHidden = 1;
- $layerQueryable = $mapObject->wms[$i]->objLayer[$j]->layer_queryable;
- $layerQuerylayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
- $layerId = $mapObject->wms[$i]->objLayer[$j]->layer_uid;
- $layerName = $mapObject->wms[$i]->objLayer[$j]->layer_name;
- $layerTitle = $mapObject->wms[$i]->objLayer[$j]->layer_title;
- $layerAbstract = $mapObject->wms[$i]->wms_abstract; //To Do: insert actual abstract
- $layerDataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_dataurl_href;
- $layerMetadataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_metadataurl;
- $layerMinscale = $mapObject->wms[$i]->objLayer[$j]->layer_minscale;
- $layerMaxscale = $mapObject->wms[$i]->objLayer[$j]->layer_maxscale;
- $guiLayerMinscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_minscale;
- $guiLayerMaxscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_maxscale;
- $wmsVersion = $mapObject->wms[$i]->wms_version;
- $wmsTitle = $mapObject->wms[$i]->wms_title;
- $wmsLayerId = $mapObject->wms[$i]->objLayer[0]->layer_uid;
- $wmsOnlineResource = $mapObject->wms[$i]->wms_getmap;
- $layerPos = $mapObject->wms[$i]->objLayer[$j]->layer_pos;
- $layerParent = $mapObject->wms[$i]->objLayer[$j]->layer_parent;
- $queryLayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
- $wfsFeatureType = $mapObject->wms[$i]->objLayer[$j]->gui_layer_wfs_featuretype;
- $e_layer = $doc->createElement("Layer");
- $e_layer->setAttribute("queryable", $layerQueryable);
- $e_layer->setAttribute("hidden", $layerHidden);
+ // will contain the JS code to create the maps
+ // representing the state stored in this WMC
+ $wmcJsArray = array();
- $e_service = $doc->createElement("Server");
- $e_service->setAttribute("service", "OGC:WMS");
- $e_service->setAttribute("version", $wmsVersion);
- $e_service->setAttribute("title", $wmsTitle);
+ // set general extension data
+ if (count($this->generalExtensionArray) > 0) {
+ $json = new Mapbender_JSON();
+ array_push($wmcJsArray, "restoredWmcExtensionData = " . $json->encode($this->generalExtensionArray) . ";");
- $e_service_or = $doc->createElement("OnlineResource");
- $e_service_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_service_or->setAttribute("xlink:type", "simple");
- $e_service_or->setAttribute("xlink:href", $wmsOnlineResource);
- $e_service->appendChild($e_service_or);
- $e_layer->appendChild($e_service);
- $e_layer_name = $doc->createElement("Name", $layerName);
- $e_layer->appendChild($e_layer_name);
- $e_layer_title = $doc->createElement("Title", $layerTitle);
- $e_layer->appendChild($e_layer_title);
- if ($layerAbstract){
- $e_layer_abstract = $doc->createElement("Abstract", $layerAbstract);
- $e_layer->appendChild($e_layer_abstract);
- $e_layer_srs = $doc->createElement("SRS", implode(" ", $wms_epsg));
- if ($layerDataUrl){
- $e_layer_data_url = $doc->createElement("DataURL");
- $e_layer_data_url_or = $doc->createElement("OnlineResource");
- $e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_layer_data_url_or->setAttribute("xlink:type", "simple");
- $e_layer_data_url_or->setAttribute("xlink:href", $layerDataUrl);
- $e_layer_data_url->appendChild($e_layer_data_url_or);
- $e_layer->appendChild($e_layer_data_url);
- if ($layerMetadataUrl){
- $e_layer_metadata_url = $doc->createElement("MetadataURL");
- $e_layer_metadata_url_or = $doc->createElement("OnlineResource");
- $e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_layer_metadata_url_or->setAttribute("xlink:type", "simple");
- $e_layer_metadata_url_or->setAttribute("xlink:href", $layerMetadataUrl);
- $e_layer_metadata_url->appendChild($e_layer_metadata_url_or);
- $e_layer->appendChild($e_layer_metadata_url);
- $e_extension = $doc->createElement("Extension");
- $e_scalehint = $doc->createElement($extension_namespace.":ScaleHint");
- $e_scalehint->setAttribute("min", $layerMinscale);
- $e_scalehint->setAttribute("max", $layerMaxscale);
- $e_extension->appendChild($e_scalehint);
- $e_gui_scalehint = $doc->createElement($extension_namespace.":guiScaleHint");
- $e_gui_scalehint->setAttribute("min", $guiLayerMinscale);
- $e_gui_scalehint->setAttribute("max", $guiLayerMaxscale);
- $e_extension->appendChild($e_gui_scalehint);
- $e_layer_id = $doc->createElement($extension_namespace.":layer_id", $layerId);
- $e_extension->appendChild($e_layer_id);
- $e_wms_layer_id = $doc->createElement($extension_namespace.":wms_layer_id", $wmsLayerId);
- $e_extension->appendChild($e_wms_layer_id);
- $e_layer_pos = $doc->createElement($extension_namespace.":layer_pos", $layerPos);
- $e_extension->appendChild($e_layer_pos);
- $e_layer_parent = $doc->createElement($extension_namespace.":layer_parent", $layerParent);
- $e_extension->appendChild($e_layer_parent);
- $e_wms_id = $doc->createElement($extension_namespace.":wms_id", $wmsId);
- $e_extension->appendChild($e_wms_id);
- $e_querylayer = $doc->createElement($extension_namespace.":querylayer", $layerQuerylayer);
- $e_extension->appendChild($e_querylayer);
- if ($wfsFeatureType) {
- $e_wfsFeatureType = $doc->createElement($extension_namespace.":wfsFeatureType", $wfsFeatureType);
- $e_extension->appendChild($e_wfsFeatureType);
+ // reset WMS data
+ array_push($wmcJsArray, "wms = [];");
+ array_push($wmcJsArray, "wms_layer_count = 0;");
- $e_layer->appendChild($e_extension);
- //layerFormat
- $e_layer_format = $doc->createElement("FormatList");
- $data_format_current = false;
- for ($k = 0; $k < count($mapObject->wms[$i]->data_format); $k++){
- if ($mapObject->wms[$i]->data_type[$k] == "map") {
- $layerFormat = $mapObject->wms[$i]->data_format[$k];
- $e_format = $doc->createElement("Format", $layerFormat);
- if ($data_format_current == false && (
- ($mapObject->wms[$i]->data_format[$k] == $mapObject->wms[$i]->gui_wms_mapformat) ||
- ($k == (count($mapObject->wms[$i]->data_format)-1))
- $e_format->setAttribute("current", "1");
- $data_format_current = true;
- $e_layer_format->appendChild($e_format);
- $e_layer->appendChild($e_layer_format);
- // LayerStyle
- $e_layer_stylelist = $doc->createElement("StyleList");
- for ($k = 0; $k < count($mapObject->wms[$i]->objLayer[$j]->layer_style); $k++){
- if ($k == 0){
- $layerStyle_current = 1; // To do: insert proper data
- else{
- $layerStyle_current = 0; // To do: insert proper data
- $e_layer_style = $doc->createElement("Style");
- $layerStyleSLD = "";
- if ($layerStyleSLD){
- $layerStyleSLDUrl = ""; // To Do: Insert Proper Data
- $e_layer_style_or = $doc->createElement("OnlineResource");
- $e_layer_style_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_layer_style_or->setAttribute("xlink:type", "simple");
- $e_layer_style_or->setAttribute("xlink:href", $layerStyleSLDUrl);
- $e_layer_style->appendChild($e_layer_style_or);
- else{
- //TODO: determine correct layer style entries
- $layerStyle_name = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->name;
- $layerStyle_title = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->title;
- $layerStyle_legendUrl = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->legendurl;
- $layerStyle_legendUrl_width = ""; // To Do: add proper data
- $layerStyle_legendUrl_height = ""; // To Do: add proper data
- $layerStyle_legendUrl_format = ""; // To Do: add proper data
- if ($layerStyle_current == 1){
- $e_layer_style->setAttribute("current", "1");
- $e_layer_style_name = $doc->createElement("Name", $layerStyle_name);
- $e_layer_style->appendChild($e_layer_style_name);
- $e_layer_style_title = $doc->createElement("Title", $layerStyle_title);
- $e_layer_style->appendChild($e_layer_style_title);
- $e_layer_style_legendurl = $doc->createElement("LegendUrl");
- $e_layer_style_legendurl->setAttribute("width", $layerStyle_legendUrl_width);
- $e_layer_style_legendurl->setAttribute("height", $layerStyle_legendUrl_height);
- $e_layer_style_legendurl->setAttribute("format", $layerStyle_legendUrl_format);
- $e_layer_style_legendurl_or = $doc->createElement("OnlineResource");
- $e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
- $e_layer_style_legendurl_or->setAttribute("xlink:href", $layerStyle_legendUrl);
- $e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
- $e_layer_style->appendChild($e_layer_style_legendurl);
- $e_layer_stylelist->appendChild($e_layer_style);
- $e_layer->appendChild($e_layer_stylelist);
- $e_layer_list->appendChild($e_layer);
+ // add WMS for main map frame
+ $wmsArray = $this->mainMap->getWmsArray();
+ // find the WMS in the main map which is equal to the WMS
+ // in the overview map
+ $overviewWmsIndex = null;
+ $ovWmsArray = array();
+ if ($this->overviewMap !== null) {
+ $ovWmsArray = $this->overviewMap->getWmsArray();
+ $overviewWmsIndex = 0;
+ for ($i = 0; $i < count($ovWmsArray); $i++) {
+ for ($j = 0; $j < count($wmsArray); $j++) {
+ if ($ovWmsArray[$i]->equals($wmsArray[$j])) {
+ $overviewWmsIndex = $j;
+ break;
- $e_view_context->appendChild($e_layer_list);
- $doc->appendChild($e_view_context);
- $this->xml = $doc->saveXML();
- // for debugging: saving WMC as file
- // (comment when no longer needed)
- $filename = $this->saveAsFile();
- if ($filename) {
- $e = new mb_notice("class_wmc: saving WMC as file " . $filename);
- * Loads a WMC from the database.
- * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
-function createObjFromWMC_id($wmc_id){
- global $DBSERVER,$DB,$OWNER,$PW;
- $con = db_connect($DBSERVER,$OWNER,$PW);
- db_select_db(DB, $con);
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
- $v = array($wmc_id);
- $t = array("s");
- $res = db_prep_query($sql, $v, $t);
- $wmc = db_fetch_row($res);
- $this->createObjFromWMC_xml($wmc[0]);
- $this->monitoringIsOn = true;
- * Loads a WMC from an actual WMC XML document.
- * @param string $data the data from the XML file
-function createObjFromWMC_xml($data){
-# $data = str_replace("&", "&", $data);
- // store xml
- $this->xml = $data;
+ // for all wms...
+ for ($i = 0; $i < count($wmsArray); $i++) {
+ // ..use settings from ov if available
+ if ($overviewWmsIndex !== null && $this->overviewMap !== null &&
+ $overviewWmsIndex == $i && count($ovWmsArray) > $i) {
+ array_push($wmcJsArray, $ovWmsArray[$i]->createJsObjFromWMS_());
+ else {
+ // ..otherwise use data from mapframe1
+ array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
- if ($filename) {
+ // delete existing map objects...
+ array_push($wmcJsArray, "mb_mapObj = [];");
+ // .. and add the overview map (if exists) and set map request
+ $wmcJsArray = array_merge($wmcJsArray, $this->overviewMap->toJavaScript($overviewWmsIndex));
+ // .. and add main map ..
+ $wmcJsArray = array_merge($wmcJsArray, $this->mainMap->toJavaScript(null));
- $values = NULL;
- $tags = NULL;
- $parser = xml_parser_create(CHARSET);
- xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
- xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
- xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
- xml_parse_into_struct($parser,$data,$values,$tags);
- $code = xml_get_error_code ($parser);
- if ($code) {
- $line = xml_get_current_line_number($parser);
- $mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
- return false;
+ // set visibility of main map WMS (may be different from overview)
+ for ($i = 0; $i < count($wmsArray[$overviewWmsIndex]->objLayer); $i++) {
+ $visStr = "mb_mapObj[1].wms[" .$overviewWmsIndex . "].handleLayer(" .
+ "'" . $wmsArray[$overviewWmsIndex]->objLayer[$i]->layer_name . "', " .
+ "'visible', " .
+ ($wmsArray[$overviewWmsIndex]->objLayer[$i]->gui_layer_visible ? 1 : 0) . ");";
+ array_push($wmcJsArray, $visStr);
+ array_push($wmcJsArray, "mb_mapObj[1].restateLayers(" . $wmsArray[$overviewWmsIndex]->wms_id . ");");
+ // .. request the map
+ array_push($wmcJsArray, "setMapRequest('" . $this->mainMap->getFrameName() . "');");
+ array_push($wmcJsArray, "setMapRequest('" . $this->overviewMap->getFrameName() . "');");
+ array_push($wmcJsArray, "eventAfterLoadWMS.trigger();");
+ return $wmcJsArray;
- xml_parser_free($parser);
- $section = NULL;
- $format = NULL;
- $cnt_format = 0;
- $parent = array();
- $myParent = array();
- $cnt_layer = -1;
- $request = NULL;
- $layer_style = array();
- $extension = false;
- $general = false;
- $layerlist = false;
- $layer = false;
- $formatlist = false;
- $dataurl = false;
- $metadataurl = false;
- $stylelist = false;
- $cnt_style = -1;
- foreach ($values as $element) {
- $verbose .= ".";
- if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
- $this->wmc_id = $element[attributes]["id"];
- $this->wmc_version = $element[attributes]["version"];
+ // manipulation
+ * Merges this WMC with another WMC.
+ * The settings of the other WMC overwrite the settings of this WMC.
+ * @return void
+ * @param $xml2 Object
+ public function merge ($xml2) {
+ $someWmc = new wmc();
+ $someWmc->createFromXml($xml2);
+ $this->mainMap->merge($someWmc->mainMap);
+ if (isset($this->overviewMap) && isset($someWmc->overviewMap)) {
+ $this->overviewMap->merge($someWmc->overviewMap);
- if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
- $general = true;
+ * Appends the layers of another WMC to this WMC.
+ * @return void
+ public function append ($xml2) {
+ $this->mainMap->append($someWmc->mainMap);
+ // There is only one WMS in the overview map; merge, not append
- if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
- $layerlist = true;
- if ($general) {
- if(strtoupper($element[tag]) == "WINDOW"){
- $this->wmc_windowWidth = $element[attributes]["width"];
- $this->wmc_windowHeight = $element[attributes]["height"];
+ * Adds a WMS to this WMC
+ * @return
+ return $this->mainMap->appendWmsArray($wmsArray);
+ * Merges a WMS into this WMC
+ * @return
+ $this->mainMap->mergeWmsArray($wmsArray);
+// private functions
+ * Loads a WMC from an actual WMC XML document.
+ * Uses WMS class.
+ * @param string $data the data from the XML file
+ private function createObjFromWMC_xml($data){
+ // store xml
+ $this->xml = $data;
+ $values = administration::parseXml($data);
+ // Local variables that indicate which section of the WMC
+ // is currently parsed.
+ $extension = false; $general = false; $layerlist = false;
+ $layer = false; $formatlist = false; $dataurl = false;
+ $metadataurl = false; $stylelist = false;
+ // reset WMC data
+ $this->mainMap = new Map();
+ $this->overviewMap = null;
+ $this->generalExtensionArray = array();
+ $layerlistArray = array();
+ $layerlistArray["main"] = array();
+ $layerlistArray["overview"] = array();
+ foreach ($values as $element) {
+ $tag = strtoupper(administration::sepNameSpace($element[tag]));
+ $tagLowerCase = administration::sepNameSpace($element[tag]);
+ $type = $element[type];
+ $attributes = $element[attributes];
+ $value = mb_utf8_decode(html_entity_decode($element[value])); // TODO: not sure if utf decoding is necessary
+ if ($tag == "VIEWCONTEXT" && $type == "open") {
+ $this->wmc_id = $attributes["id"];
+ $this->wmc_version = $attributes["version"];
+ if ($tag == "GENERAL" && $type == "open") {
+ $general = true;
+ if ($tag == "LAYERLIST" && $type == "open") {
+ $layerlist = true;
+ if ($general) {
+ if ($tag == "WINDOW") {
+ $this->mainMap->setWidth($attributes["width"]);
+ $this->mainMap->setHeight($attributes["height"]);
- if(strtoupper($element[tag]) == "BOUNDINGBOX"){
- $this->wmc_bBox_SRS = $element[attributes]["SRS"];
- $this->wmc_bBox_minx = $element[attributes]["minx"];
- $this->wmc_bBox_miny = $element[attributes]["miny"];
- $this->wmc_bBox_maxx = $element[attributes]["maxx"];
- $this->wmc_bBox_maxy = $element[attributes]["maxy"];
+ if ($tag == "BOUNDINGBOX") {
+ $bbox = new Mapbender_bbox($attributes["minx"], $attributes["miny"], $attributes["maxx"], $attributes["maxy"], $attributes["SRS"]);
+ $this->mainMap->setExtent($bbox);
- if(strtoupper($element[tag]) == "NAME"){
- $this->wmc_name = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "NAME") {
+ $this->wmc_name = $value;
- if(strtoupper($element[tag]) == "TITLE"){
- $this->wmc_title = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "TITLE") {
+ $this->wmc_title = $value;
- if(strtoupper($element[tag]) == "ABSTRACT"){
- $this->wmc_abstract = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "ABSTRACT") {
+ $this->wmc_abstract = $value;
- if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
- $contactinformation = true;
+ if ($tag == "CONTACTINFORMATION" && $type == "open") {
+ $contactinformation = true;
if ($contactinformation) {
- if(strtoupper($element[tag]) == "CONTACTPOSITION"){
- $this->wmc_contactposition = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "CONTACTPOSITION") {
+ $this->wmc_contactposition = $value;
- if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
- $this->wmc_contactvoicetelephone = $element[value];
+ if ($tag == "CONTACTVOICETELEPHONE") {
+ $this->wmc_contactvoicetelephone = $value;
- if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
- $this->wmc_contactfacsimiletelephone = $element[value];
+ if ($tag == "CONTACTFACSIMILETELEPHONE") {
+ $this->wmc_contactfacsimiletelephone = $value;
- if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
- $this->wmc_contactemail = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "CONTACTELECTRONICMAILADDRESS") {
+ $this->wmc_contactemail = $value;
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
- $contactpersonprimary = true;
+ if ($tag == "CONTACTPERSONPRIMARY" && $type == "open") {
+ $contactpersonprimary = true;
if ($contactpersonprimary) {
- if(strtoupper($element[tag]) == "CONTACTPERSON"){
- $this->wmc_contactperson = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "CONTACTPERSON") {
+ $this->wmc_contactperson = $value;
- if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
- $this->wmc_contactorganization = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "CONTACTORGANIZATION") {
+ $this->wmc_contactorganization = $value;;
- if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
- $contactpersonprimary = false;
+ if ($tag == "CONTACTPERSONPRIMARY" && $type == "close") {
+ $contactpersonprimary = false;
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
- $contactaddress = true;
+ if ($tag == "CONTACTADDRESS" && $type == "open") {
+ $contactaddress = true;
if ($contactaddress) {
- if(strtoupper($element[tag]) == "ADDRESSTYPE"){
- $this->wmc_contactaddresstype = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "ADDRESSTYPE") {
+ $this->wmc_contactaddresstype = $value;
- if(strtoupper($element[tag]) == "ADDRESS"){
- $this->wmc_contactaddress = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "ADDRESS") {
+ $this->wmc_contactaddress = $value;
- if(strtoupper($element[tag]) == "CITY"){
- $this->wmc_contactcity = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "CITY") {
+ $this->wmc_contactcity = $value;
- if(strtoupper($element[tag]) == "STATEORPROVINCE"){
- $this->wmc_contactstateorprovince = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "STATEORPROVINCE") {
+ $this->wmc_contactstateorprovince = $value;
- if(strtoupper($element[tag]) == "POSTCODE"){
- $this->wmc_contactpostcode = $element[value];
+ if ($tag == "POSTCODE"){
+ $this->wmc_contactpostcode = $value;
- if(strtoupper($element[tag]) == "COUNTRY"){
- $this->wmc_contactcountry = mb_utf8_decode(html_entity_decode($element[value]));
+ if ($tag == "COUNTRY") {
+ $this->wmc_contactcountry = $value;
- if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
- $contactaddress = false;
+ if ($tag == "CONTACTADDRESS" && $type == "close") {
+ $contactaddress = false;
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
+ if ($tag == "LOGOURL" && $type == "open") {
$logourl = true;
- $this->wmc_logourl_width = $element[attributes]["width"];
- $this->wmc_logourl_height = $element[attributes]["height"];
- $this->wmc_logourl_format = $element[attributes]["format"];
+ $this->wmc_logourl_width = $attributes["width"];
+ $this->wmc_logourl_height = $attributes["height"];
+ $this->wmc_logourl_format = $attributes["format"];
if ($logourl) {
- if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
- $logourl = false;
+ if ($tag == "LOGOURL" && $type == "close") {
+ $logourl = false;
- if(strtoupper($element[tag]) == "ONLINERESOURCE"){
- $this->wmc_logourl_type = $element[attributes]["xlink:type"];
- $this->wmc_logourl = $element[attributes]["xlink:href"];
+ if ($tag == "ONLINERESOURCE") {
+ $this->wmc_logourl_type = $attributes["xlink:type"];
+ $this->wmc_logourl = $attributes["xlink:href"];
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
+ if ($tag == "DESCRIPTIONURL" && $type == "open") {
$descriptionurl = true;
- $this->wmc_descriptionurl_format = $element[attributes]["format"];
+ $this->wmc_descriptionurl_format = $attributes["format"];
if ($descriptionurl) {
- if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
- $descriptionurl = false;
+ if ($tag == "DESCRIPTIONURL" && $type == "close"){
+ $descriptionurl = false;
- $this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
- $this->wmc_descriptionurl = $element[attributes]["xlink:href"];
+ $this->wmc_descriptionurl_type = $attributes["xlink:type"];
+ $this->wmc_descriptionurl = $attributes["xlink:href"];
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
- $keywordlist = true;
+ if ($tag == "KEYWORDLIST" && $type == "open") {
+ $keywordlist = true;
if ($keywordlist) {
- if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
- $keywordlist = false;
- $cnt_keyword = -1;
+ if ($tag == "KEYWORDLIST" && $type == "close") {
+ $keywordlist = false;
+ $cnt_keyword = -1;
- if(strtoupper($element[tag]) == "KEYWORD"){
+ if ($tag == "KEYWORD") {
$cnt_keyword++;
- $this->wmc_keyword[$cnt_keyword] = mb_utf8_decode(html_entity_decode($element[value]));
+ $this->wmc_keyword[$cnt_keyword] = $value;
- if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "close"){
+ if ($tag == "EXTENSION" && $type == "close") {
$generalExtension = false;
+ // After the general extension tag is closed,
+ // we have all necessary information to CREATE
+ // the map objects that are contained in this
+ // WMC.
+ $this->setMapData();
if ($generalExtension) {
- $this->wmc_general_extension[sepNameSpace($element[tag])] = $element[value];
-// $e = new mb_exception("WMC: " . $element[tag] . ": " . $element[value]);
+ $this->generalExtensionArray[$tag] = $value;
- if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "open"){
+ if ($tag == "EXTENSION" && $type == "open") {
$generalExtension = true;
- if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
+ if ($tag == "GENERAL" && $type == "close") {
$general = false;
- if ($layerlist) {
- if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
+ if ($layerlist) {
+ if ($tag == "LAYERLIST" && $type == "close") {
$layerlist = false;
- if(strtoupper($element[tag]) == "LAYER" && $element[type] == "open"){
- $cnt_layer++;
- $this->wmc_layer_queryable[$cnt_layer] = $element[attributes]["queryable"];
- $this->wmc_layer_hidden[$cnt_layer] = $element[attributes]["hidden"];
- $layer = true;
- $cnt_epsg = 0;
+ if ($tag == "LAYER" && $type == "open") {
+ // The associative array currentLayer holds all
+ // data of the currently processed layer.
+ // The data will be set in the classes' WMS
+ // object when the layer tag is closed.
+ $currentLayer = array();
+ $currentLayer["queryable"] = $attributes["queryable"];
+ if ($attributes["hidden"] == "1") {
+ $currentLayer["visible"] = 0;
+ else {
+ $currentLayer["visible"] = 1;
+ $currentLayer["format"] = array();
+ $currentLayer["style"] = array();
+ $layer = true;
if ($layer) {
- if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
- $layer = false;
- if ($formatlist) {
- if(strtoupper($element[tag]) == "FORMAT"){
- $cnt_format++;
- $this->wmc_layer_format_current[$cnt_layer][$cnt_format] = $element[attributes]["current"];
- $this->wmc_layer_format[$cnt_layer][$cnt_format] = $element[value];
+ if ($tag == "LAYER" && $type == "close") {
+ // After a layer tag is closed,
+ // a layer object and append it to the WMS object
+ if ($currentLayer["extension"]["ISOVERVIEWLAYER"] == "1") {
+ array_push($layerlistArray["overview"], $currentLayer);
+ else {
+ array_push($layerlistArray["main"], $currentLayer);
+ $layer = false;
+ if ($formatlist) {
+ if ($tag == "FORMAT") {
+ array_push($currentLayer["format"], array("current" => $attributes["current"], "name" => $value));
+ if ($attributes["current"] == "1") {
+ $currentLayer["formatIndex"] = count($currentLayer["format"]) - 1;
- if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "close"){
+ if ($tag == "FORMATLIST" && $type == "close") {
elseif ($metadataurl) {
- $this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
- if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
+ $currentLayer["metadataurl"] = $attributes["xlink:href"];
+ if ($tag == "METADATAURL" && $type == "close") {
elseif ($dataurl) {
- $this->wmc_layer_dataurl[$cnt_layer] = $element[attributes]["xlink:href"];
+ $currentLayer["dataurl"] = $attributes["xlink:href"];
+ if ($tag == "DATAURL" && $type == "close") {
+ $dataurl = false;
- if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
- $dataurl = false;
elseif ($stylelist) {
- if(strtoupper($element[tag]) == "STYLE" && $element[type] == "open"){
- $cnt_style++;
- $style = true;
- $this->wmc_layer_style_current[$cnt_layer][$cnt_style] = $element[attributes]["current"];
- if ($style) {
- if(strtoupper($element[tag]) == "STYLE" && $element[type] == "close"){
- $style = false;
- if(strtoupper($element[tag]) == "SLD" && $element[type] == "open"){
- $sld = true;
- if ($sld) {
- if(strtoupper($element[tag]) == "SLD" && $element[type] == "close"){
- $sld = false;
- $this->wmc_layer_style_sld_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
- $this->wmc_layer_style_sld_url[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
- $this->wmc_layer_style_sld_title[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
- else {
- $this->wmc_layer_style_name[$cnt_layer][$cnt_style] = mb_utf8_decode(html_entity_decode($element[value]));
- $this->wmc_layer_style_title[$cnt_layer][$cnt_style] = $element[value];
- if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "open"){
+ if ($style) {
+ $index = count($currentLayer["style"]) - 1;
+ if ($tag == "STYLE" && $type == "close") {
+ $style = false;
+ if ($tag == "SLD" && $type == "open") {
+ $sld = true;
+ if ($sld) {
+ if ($tag == "SLD" && $type == "close") {
+ $sld = false;
+ $currentLayer["style"][$index]["sld_type"] = $attributes["xlink:type"];
+ $currentLayer["style"][$index]["sld_url"] = $attributes["xlink:href"];
+ $currentLayer["style"][$index]["sld_title"] = $value;
+ else {
+ if ($tag == "NAME"){
+ $currentLayer["style"][$index]["name"] = $value ? $value : "default";
+ $currentLayer["style"][$index]["title"] = $value ? $value : "default";
+ if ($legendurl) {
+ if ($tag == "LEGENDURL" && $type == "close") {
+ $legendurl = false;
+ $currentLayer["style"][$index]["legendurl_type"] = $attributes["xlink:type"];
+ $currentLayer["style"][$index]["legendurl"] = $attributes["xlink:href"];
+ if ($tag == "LEGENDURL" && $type == "open") {
$legendurl = true;
- $this->wmc_layer_style_legendurl_width[$cnt_layer][$cnt_style] = $element[attributes]["width"];
- $this->wmc_layer_style_legendurl_height[$cnt_layer][$cnt_style] = $element[attributes]["height"];
- $this->wmc_layer_style_legendurl_format[$cnt_layer][$cnt_style] = $element[attributes]["format"];
- if ($legendurl) {
- if(strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
- $legendurl = false;
- $this->wmc_layer_style_legendurl_type[$cnt_layer][$cnt_style] = $element[attributes]["xlink:type"];
- $this->wmc_layer_style_legendurl[$cnt_layer][$cnt_style] = $element[attributes]["xlink:href"];
- if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "close"){
- else {
- if(strtoupper($element[tag]) == "SERVER" && $element[type] == "open"){
- $server = true;
- $this->wmc_wms_service[$cnt_layer] = $element[attributes]["service"];
- $this->wmc_wms_version[$cnt_layer] = $element[attributes]["version"];
- $this->wmc_wms_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[attributes]["title"]));
- if ($server) {
- if(strtoupper($element[tag]) == "SERVER" && $element[type] == "close"){
- $server = false;
- $this->wmc_wms_serviceURL[$cnt_layer] = $element[attributes]["xlink:href"];
- $this->wmc_layer_name[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
- $this->wmc_layer_title[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
- $this->wmc_layer_abstract[$cnt_layer] = mb_utf8_decode(html_entity_decode($element[value]));
- if(strtoupper($element[tag]) == "SRS"){
- $epsgArray = explode(" ", $element[value]);
- for ($c = 0 ; $c < count($epsgArray) ; $c ++) {
- $this->wmc_layer_srs[$cnt_layer][$cnt_epsg] = $epsgArray[$c];
- $cnt_epsg++;
- if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "open") {
- $extension = true;
- if (strtoupper($element[tag]) == "EXTENSION" && $element[type] == "close") {
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "SCALEHINT"){
- $this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
- $this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "GUISCALEHINT"){
- $this->wmc_gui_layer_minscale[$cnt_layer] = $element[attributes]["min"];
- $this->wmc_gui_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_ID"){
- $this->wmc_layer_id[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_LAYER_ID"){
- $this->wmc_wms_layer_id[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_POS"){
- $this->wmc_layer_pos[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_PARENT"){
- $this->wmc_layer_parent[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "QUERYLAYER"){
- $this->wmc_layer_querylayer[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
- $this->wmc_wms_id[$cnt_layer] = $element[value];
- if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WFSFEATURETYPE"){
- $this->wmc_layer_wfs_featuretype[$cnt_layer] = $element[value];
- if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
- $metadataurl = true;
- if(strtoupper($element[tag]) == "DATAURL" && $element[type] == "open"){
- $dataurl = true;
- if(strtoupper($element[tag]) == "FORMATLIST" && $element[type] == "open"){
- $formatlist = true;
- $cnt_format = -1;
- if(strtoupper($element[tag]) == "STYLELIST" && $element[type] == "open"){
- $stylelist = true;
- $cnt_style = -1;
+ $currentLayer["style"][$index]["legendurl_width"] = $attributes["width"];
+ $currentLayer["style"][$index]["legendurl_height"] = $attributes["height"];
+ $currentLayer["style"][$index]["legendurl_format"] = $attributes["format"];
+ if ($tag == "STYLE" && $type == "open") {
+ $style = true;
+ array_push($currentLayer["style"], array("current" => $attributes["current"]));
+ $currentLayer["styleIndex"] = count($currentLayer["style"]) - 1;
+ if ($tag == "STYLELIST" && $type == "close") {
+ $stylelist = false;
+ else {
+ if ($tag == "SERVER" && $type == "open") {
+ $server = true;
+ $currentLayer["service"] = $attributes["service"];
+ $currentLayer["version"] = $attributes["version"];
+ $currentLayer["wms_title"] = $attributes["title"];
+ if ($server) {
+ if ($tag == "SERVER" && $type == "close") {
+ $server = false;
+ $currentLayer["url"] = $attributes["xlink:href"];
+ $currentLayer["name"] = $value;
+ $currentLayer["title"] = $value;
+ $currentLayer["abstract"] = $value;
+ if ($tag == "SRS") {
+ $currentLayer["epsg"] = explode(" ", $value);
+ if ($extension == true){
+ if ($value !== "") {
+ if (isset($currentLayer["extension"][$tag])) {
+ if (!is_array($currentLayer["extension"][$tag])) {
+ $firstValue = $currentLayer["extension"][$tag];
+ $currentLayer["extension"][$tag] = array();
+ array_push($currentLayer["extension"][$tag], $firstValue);
+ array_push($currentLayer["extension"][$tag], $value);
+ else {
+ $currentLayer["extension"][$tag] = $value;
+ $currentLayer["extension"] = array();
+ $extension = true;
+ if ($tag == "METADATAURL" && $type == "open") {
+ $metadataurl = true;
+ if ($tag == "DATAURL" && $type == "open") {
+ $dataurl = true;
+ if ($tag == "FORMATLIST" && $type == "open") {
+ $formatlist = true;
+ if ($tag == "STYLELIST" && $type == "open") {
+ $stylelist = true;
+ // set WMS data
+ $layerlistCompleteArray = array_merge($layerlistArray["main"], $layerlistArray["overview"]);
+ for ($i = 0; $i < count($layerlistCompleteArray); $i++) {
+ $this->setLayerData($layerlistCompleteArray[$i]);
return true;
- //return $verbose;
- * Creates JS code manipulating the map and wms objects,
- * by this displaying the WMC
+ * Saves the current WMC in the log folder.
- * @param string $target the link to the map object, f.e. "parent." or "window.opener."
- * @param string $mapObj the name of the map object, f.e. "mapframe1"
- * @param string $action "load", "merge" or "append"
- * @return string the JS code
+ * @return string the filename of the WMC document.
- function createJsObjFromWMC($target, $mapObj, $action){
- * counts how often a layer has been loaded
- if ($this->monitoringIsOn) {
- $monitor = new Layer_load_count();
- for ($i = 0; $i < count($this->wmc_layer_id); $i++) {
- $monitor->increment($this->wmc_layer_id[$i]);
+ private function saveAsFile() {
+ if ($this->saveWmcAsFile) {
+ $filename = "wmc_" . date("Y_m_d_H_i_s") . ".xml";
+ $logfile = "../tmp/" . $filename;
+ if($h = fopen($logfile,"a")){
+ $content = $this->xml;
+ if(!fwrite($h,$content)){
+ $e = new mb_exception("class_wmc.php: failed to write wmc.");
+ return false;
+ fclose($h);
+ $e = new mb_notice("class_wmc: saving WMC as file " . $filename . "; You can turn this behaviour off in class_wmc.php");
+ return $filename;
- $wmc_string = "";
- $validActions = array("load", "merge", "append");
- if (!in_array($action, $validActions)) {
- $wmc_string .= "alert('invalid action: ".$action."');";
+ return null;
+ * Called during WMC parsing; sets the data of a single layer.
+ * @return
+ * @param $currentLayer Array an associative array with layer data
+ private function setLayerData ($currentLayer) {
+ $currentMap = $this->mainMap;
+ $currentMapIsOverview = false;
+ $currentMap = $this->overviewMap;
+ $currentMapIsOverview = true;
- else {
- // general extension
- if (count($this->wmc_general_extension) > 0) {
- $json = new Mapbender_JSON();
- $wmc_string .= $target . "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";\n";
+ $wmsArray = $currentMap->getWmsArray();
+ // check if current layer belongs to an existing WMS.
+ // If yes, store the index of this WMS in $wmsIndex.
+ // If not, set the value to null.
+ $wmsIndex = null;
+ // find last WMS with the same online resource
+ for ($i = count($wmsArray) - 1; $i >= 0; $i--) {
+ if (isset($currentLayer["url"]) &&
+ $currentLayer["url"] == $wmsArray[$i]->wms_getmap) {
+ $wmsIndex = $i;
+ break;
+ // Even if this WMS has been found before it could still
+ // be a duplicate! We would have to create a new WMS and
+ // not append this layer to that WMS.
+ // For the overview layer we never add a new wms.
+ // check if this layer is an overview layer. If yes, skip this layer.
+ if ($wmsIndex !== null && !$currentMapIsOverview) {
+ // check if this WMS has a layer equal to the current layer.
+ // If yes, this is a new WMS. If not, append this layer
+ // to the existing WMS.
+ $matchingWmsLayerArray = $this->wmsArray[$wmsIndex]->objLayer;
- $wmc_string .= "var index = " . $target . "getMapObjIndexByName('" . $mapObj . "');\n";
- if ($action == "load") {
- // delete all previous wms
- $wmc_string .= "while(" . $target . "mb_mapObj[index].wms.length > 0){" . $target . "mb_mapObjremoveWMS(index,0);}";
- $wmc_string .= $target . "deleteWmsObject();\n";
+ for ($i = 0; $i < count($matchingWmsLayerArray); $i++) {
+ if ($matchingWmsLayerArray[$i]->layer_name == $currentLayer["name"]) {
+ // by re-setting the index to null, a new WMS will be
+ // added below.
+ $wmsIndex = null;
+ break;
- if ($action == "merge") {
- $wmc_string .= "var wms_exists = false;\n"; // true if this wms exists in the mapObj
- $wmc_string .= "var current_wms_index = null;\n"; // if wms_exists: index of the wms in the map obj; else: null
- $wmc_string .= "var layer_exists = false;\n"; // true if this layer exists in an existing wms of the mapObj
- $wmc_string .= "var current_layer_index = null;\n"; // if layer_exists: index of the layer of the wms in the mapObj; else: null
- $new_wms = "";
- $cnt_wms = -1;
- $added_wms = array();
+ // if yes, create a new WMS ...
+ if ($wmsIndex === null) {
+ $wmsIndex = 0;
+ $wms = new wms();
+ // set WMS data
+ $wms->wms_id = $currentLayer["extension"]["WMS_ID"]; // TO DO: how about WMS without ID?
+ $wms->wms_version = $currentLayer["version"];
+ $wms->wms_title = $currentLayer["wms_title"];
+ $wms->wms_abstract = $currentLayer["abstract"];
+ $wms->wms_getmap = $currentLayer["url"];
+ $wms->wms_getfeatureinfo = $currentLayer["url"]; // TODO : Add correct data
- // for all layers in wmc, find individual wms...
- for ($i = 0; $i < count($this->wmc_layer_title); $i++) {
- $current_wms = $this->wmc_wms_serviceURL[$i];
- // ...this is something like 'for every wms'
- if (!in_array($current_wms , $added_wms)) {
- $layerlist = "";
- $querylayerlist = "";
- $srs_array = array();
- $wmc_string .= "wms_exists = false;\n";
- $wmc_string .= "current_wms_index = null;\n";
- $wmc_string .= "for (var m=0; m < " . $target . "mb_mapObj[index].wms.length; m++) {\n";
- $wmc_string .= "\tif ('" . $this->wmc_wms_serviceURL[$i] . "' == " . $target . "mb_mapObj[index].wms[m].wms_getmap) {\n";
- $wmc_string .= "\t\twms_exists = true;\n";
- $wmc_string .= "\t\tcurrent_wms_index = m;\n";
- $wmc_string .= "\t}\n";
- $wmc_string .= "}\n";
- $wmc_string .= "if (!wms_exists) {\n";
- $mywms = new wms();
- if(!$this->wmc_layer_title[$i] || $this->wmc_layer_title[$i] == ""){
- echo "alert('Error: no valid capabilities-document !!');\n";
- die; exit;
+ $styleIndex = $currentLayer["styleIndex"];
+ $wms->wms_getlegendurl = $currentLayer["style"][$styleIndex]["legendurl"];
- for($j=0;$j<count($this->wmc_layer_format[$i]);$j++){
- if ($this->wmc_layer_format_current[$i][$j] == 1) {
- $wms_data_format = $this->wmc_layer_format[$i][$j];
- // add wms
- $wmc_string .= "\t" . $target . "add_wms('".
- $this->wmc_wms_id[$i]."','".
- $this->wmc_wms_version[$i] ."','".
- $this->wmc_wms_title[$i] ."','".
- $this->wmc_layer_abstract[$i] ."','".
- $this->wmc_wms_serviceURL[$i] ."','" .
- $this->wmc_layer_style_legendurl[$i][0] ."','','".
- $wms_data_format ."','text/html','application/vnd.ogc.se_xml','".
- $this->wmc_bBox_SRS ."','1','100','');\n";
- $added_wms[count($added_wms)] = $current_wms;
- $cnt_wms++;
- $cnt_layers = 0;
- $cnt_query_layers = 0;
- // add epsg
- $wmc_string .= $target . "wms_addSRS('".
- $this->wmc_bBox_SRS ."','".
- $this->wmc_bBox_minx ."','".
- $this->wmc_bBox_miny ."','".
- $this->wmc_bBox_maxx ."','".
- $this->wmc_bBox_maxy ."','".
- "');\n";
+ $wms->wms_filter = ""; // TODO : Add correct data
- // for each layer...
- for ($ii = 0; $ii < count($this->wmc_layer_title); $ii++) {
- $layer_wms = $this->wmc_wms_serviceURL[$ii];
- // ... of this wms
- if ($current_wms == $layer_wms) {
- // add format (FIXME: is this working?)
- $z = count($this->wmc_layer_format[$ii]);
- for($j=0;$j<$z;$j++){
- $wmc_string .= $target . "wms_add_data_type_format('map','". $this->wmc_layer_format[$ii][$j] ."');\n";
- if ($cnt_layers == 0) {
- $wmc_string .= "if (!wms_exists) {\n\t";
- // add parent layer
- $wmc_string .= $target . "wms_add_layer('','".
- $this->wmc_wms_layer_id[$i]."','','".
- $this->wmc_wms_title[$i] ."','','0','0','0','0','','".
- $this->wmc_wms_id[$i]."','1','', '1','1','0','0','0','0','');\n";
- $cnt_layers++;
- $wmc_string .= "if (wms_exists) {\n";
- // check if this layer already exists in this wms
- $wmc_string .= "\tlayer_exists = false;\n";
- $wmc_string .= "\tcurrent_layer_index = null;\n";
- $wmc_string .= "\tfor (var m=0; m < " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer.length; m++) {\n";
- $wmc_string .= "\t\tif ('" . $this->wmc_layer_name[$ii] . "' == " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[m].layer_name) {\n";
- $wmc_string .= "\t\t\tlayer_exists = true;\n";
- $wmc_string .= "\t\t\tcurrent_layer_index = m;\n";
- $wmc_string .= "\t\t}\n";
+ $formatIndex = $currentLayer["formatIndex"];
+ $wms->gui_wms_mapformat = $currentLayer["format"][$formatIndex]["name"];
- if ($this->wmc_layer_querylayer[$ii]!="") {
- $querylayer_yn = $this->wmc_layer_querylayer[$ii];
- else {
- $querylayer_yn = $this->wmc_layer_queryable[$ii];
- $wmc_string .= "\tif (layer_exists) {\n";
- // check if the visibility or the queryability are different to the existing layer
- $wmc_string .= "\t\tif (" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible != '" . intval(!$this->wmc_layer_hidden[$ii]) . "'";
- $wmc_string .= " || " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer != '" . $querylayer_yn . "') {\n";
- // if yes, update the visibility and queryability
- $wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible = " . intval(!$this->wmc_layer_hidden[$ii]) . ";\n";
- $wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer = " . $querylayer_yn . ";\n";
- $wmc_string .= "\telse {\n";
+ $wms->gui_wms_featureinfoformat = "text/html"; // TODO : Add correct data
+ $wms->gui_wms_exceptionformat = "application/vnd.ogc.se_xml"; // TODO : Add correct data
+ $wms->gui_wms_epsg = $this->mainMap->getEpsg();
+ $wms->gui_wms_visible = 1; // TODO : Add correct data
+ $wms->gui_wms_opacity = 100; // TODO : Add correct data
+ $wms->gui_wms_sldurl = $currentLayer["style"][$styleIndex]["sld_url"];
- // add layer
- $wmc_string .= "\t" . $target . "wms_add_layer('".
- ($this->wmc_layer_parent[$ii]!=""?$this->wmc_layer_parent[$ii]:"0") . "','".
- $this->wmc_layer_id[$ii] . "','".
- $this->wmc_layer_name[$ii] . "','".
- $this->wmc_layer_title[$ii] ."','".
- $this->wmc_layer_dataurl[$ii] . "','".
- ($this->wmc_layer_pos[$ii]!=""?$this->wmc_layer_pos[$ii]:intval($cnt_layers)) ."','".
- $this->wmc_layer_queryable[$ii] ."','".
- $this->wmc_layer_minscale[$ii] ."','".
- $this->wmc_layer_maxscale[$ii] ."','".
- $this->wmc_layer_metadataurl[$ii] ."','".
- $this->wmc_wms_id[$i] ."','1','', '1','".
- intval(!$this->wmc_layer_hidden[$ii]) ."','".
- ($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii]) ."','".
- ($this->wmc_gui_layer_minscale[$ii]!=""?$this->wmc_gui_layer_minscale[$ii]:$this->wmc_layer_minscale[$ii]) ."','".
- ($this->wmc_gui_layer_maxscale[$ii]!=""?$this->wmc_gui_layer_maxscale[$ii]:$this->wmc_layer_maxscale[$ii]) ."','".
- $this->wmc_layer_wfs_featuretype[$ii] . "');\n";
- // if layer is queryable, add it to querylayerlist
- if (($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii])) {
- $cnt_query_layers++;
- if (!in_array($this->wmc_layer_name[$ii], explode(",",$querylayerlist))) {
- if ($querylayerlist == "") {$querylayerlist = $this->wmc_layer_name[$ii];} else {$querylayerlist .= "," . $this->wmc_layer_name[$ii];}
- // if layer is visible, add it to layerlist
- if (intval(!$this->wmc_layer_hidden[$ii]) && !in_array($this->wmc_layer_name[$ii], explode(",",$layerlist))) {
- if ($layerlist == "") {$layerlist = $this->wmc_layer_name[$ii];} else {$layerlist .= "," . $this->wmc_layer_name[$ii];}
- // add layer style (FIXME: is this working?)
- for($j=0; $j<count($this->wmc_layer_style_name[$ii]);$j++){
- $wmc_string .= $target . "wms_addLayerStyle('".$this->wmc_layer_style_name[$ii][$j] ."','".$this->wmc_layer_style_title[$ii][$j] ."','".$j."','".$cnt_layers."', '" . $this->wmc_layer_style_legendurl[$ii][$j] . "', '" . $this->wmc_layer_style_legendurl_format[$ii][$j] . "');\n";
- // add wms to mapObj with all layers and querylayers
- $wmc_string .= $target. "mb_mapObjaddWMSwithLayers('" . $mapObj . "', '" . $layerlist . "', '" . $querylayerlist . "');\n";
- $wmc_string .= "else {\n";
- $wmc_string .= $target. "mb_mapObj[index].layers[current_wms_index] = \"" . $layerlist . "\";\n";
- $wmc_string .= $target. "mb_mapObj[index].querylayers[current_wms_index] = \"" . $querylayerlist . "\";\n";
+ $wms->gui_epsg = $currentLayer["epsg"];
+ // set data formats
+ for ($i = 0; $i < count($currentLayer["format"]); $i++) {
+ array_push($wms->data_type, "map");
+ array_push($wms->data_format, $currentLayer["format"][$i]["name"]);
- $wmc_string .= "var old_mapObj = ".$target."cloneObject(".$target."mb_mapObj);\n";
- $wmc_string .= $target . "deleteMapObj();\n";
- $wmc_string .= "for (var i=0; i<old_mapObj.length; i++) {\n";
- $wmc_string .= "\tif (old_mapObj[i].frameName != 'overview') {\n";
- $wmc_string .= "\t\t" . $target . "mb_registerMapObj(old_mapObj[i].frameName, old_mapObj[i].elementName, null, " . $this->wmc_windowWidth . ", " . $this->wmc_windowHeight . ");\n";
- $wmc_string .= "\t\t" . $target . "document.getElementById(old_mapObj[i].frameName).style.width = " . $this->wmc_windowWidth . ";\n";
- $wmc_string .= "\t\t" . $target . "document.getElementById(old_mapObj[i].frameName).style.height = " . $this->wmc_windowHeight . ";\n";
- $wmc_string .= "\t\tvar found = false;\n";
- $wmc_string .= "\t\tfor (var j=0; j < " . $target . "wms.length && found == false; j++) {\n";
- $wmc_string .= "\t\t\tif (" . $target . "wms[j].wms_getmap == old_mapObj[i].wms[0].wms_getmap) {\n";
- $wmc_string .= "\t\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, j, old_mapObj[i].width, old_mapObj[i].width);\n";
- $wmc_string .= "\t\t\t\tfound = true;\n";
- $wmc_string .= "\t\t\t}\n";
- $wmc_string .= "\t\tif (!found) {\n";
- $wmc_string .= "\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, 0, old_mapObj[i].width, old_mapObj[i].width);\n";
- $ov_bbox = array();
- // compute the union of the overview and the mapframe bbox for the new overview bbox
- if ($this->wmc_general_extension["ov_minx"] && $this->wmc_general_extension["ov_miny"] &&
- $this->wmc_general_extension["ov_maxx"] && $this->wmc_general_extension["ov_maxy"]) {
- // box for overview
- $ov_min = new Mapbender_point($this->wmc_general_extension["ov_minx"], $this->wmc_general_extension["ov_miny"], $this->wmc_bBox_SRS);
- $ov_max = new Mapbender_point($this->wmc_general_extension["ov_maxx"], $this->wmc_general_extension["ov_maxy"], $this->wmc_bBox_SRS);
- $ov_box = new Mapbender_bbox($ov_min, $ov_max, $this->wmc_bBox_SRS);
- // box for mapframe
- $mf_min = new Mapbender_point($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_SRS);
- $mf_max = new Mapbender_point($this->wmc_bBox_maxx, $this->wmc_bBox_maxy, $this->wmc_bBox_SRS);
- $mf_box = new Mapbender_bbox($mf_min, $mf_max, $this->wmc_bBox_SRS);
- $unionBox = Mapbender_bbox::union(array($ov_box, $mf_box));
- array_push($ov_bbox, $unionBox->min->x);
- array_push($ov_bbox, $unionBox->min->y);
- array_push($ov_bbox, $unionBox->max->x);
- array_push($ov_bbox, $unionBox->max->y);
- else {
- $sql = "SELECT minx, miny, maxx, maxy FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = $2 LIMIT 1";
- $v = array($this->wmc_layer_id[0], $this->wmc_bBox_SRS);
- $t = array('i', 's');
- $row = db_fetch_array($res);
- if ($row["minx"] && $row["miny"] && $row["maxx"] && $row["maxy"]) {
- $ov_bbox = array($row["minx"],$row["miny"],$row["maxx"],$row["maxy"]);
+ // set root layer
+ $wms->addLayer(0, "");
+ $wms->objLayer[0]->layer_uid = $currentLayer["extension"]["WMS_LAYER_ID"];
+ $wms->objLayer[0]->layer_name = $currentLayer["extension"]["WMS_NAME"];
+ $wms->objLayer[0]->layer_title = $currentLayer["wms_title"];
+ $wms->objLayer[0]->layer_pos = 0;
+ $wms->objLayer[0]->layer_queryable = 0;
+ $wms->objLayer[0]->layer_minscale = 0;
+ $wms->objLayer[0]->layer_maxscale = 0;
+ $wms->objLayer[0]->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
+ $wms->objLayer[0]->gui_layer_status = 1;
+ $wms->objLayer[0]->gui_layer_selectable = 1;
+ $wms->objLayer[0]->gui_layer_visible = 1;
+ $wms->objLayer[0]->gui_layer_queryable = 0;
+ $wms->objLayer[0]->gui_layer_querylayer = 0;
+ $wms->objLayer[0]->gui_layer_minscale = 0;
+ $wms->objLayer[0]->gui_layer_maxscale = 0;
+ // layer epsg
+ if ($currentLayer["extension"]["EPSG"]) {
+ $layerEpsgArray = array();
+ $layerMinXArray = array();
+ $layerMinYArray = array();
+ $layerMaxXArray = array();
+ $layerMaxYArray = array();
+ if (!is_array($currentLayer["extension"]["EPSG"])) {
+ $layerEpsgArray[0] = $currentLayer["extension"]["EPSG"];
+ $layerMinXArray[0] = $currentLayer["extension"]["MINX"];
+ $layerMinYArray[0] = $currentLayer["extension"]["MINY"];
+ $layerMaxXArray[0] = $currentLayer["extension"]["MAXX"];
+ $layerMaxYArray[0] = $currentLayer["extension"]["MAXY"];
- else if ($this->wmc_layer_id[0] && $this->wmc_bBox_SRS){
- $ov_bbox = array($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_maxx, $this->wmc_bBox_maxy);
else {
- $ov_bbox = array(2412139.175257732, 5365000, 2767860.824742268, 5700000);
+ $layerEpsgArray = $currentLayer["extension"]["EPSG"];
+ $layerMinXArray = $currentLayer["extension"]["MINX"];
+ $layerMinYArray = $currentLayer["extension"]["MINY"];
+ $layerMaxXArray = $currentLayer["extension"]["MAXX"];
+ $layerMaxYArray = $currentLayer["extension"]["MAXY"];
+ for ($i=0; $i < count($layerEpsgArray); $i++) {
+ $currentLayerEpsg = array();
+ $currentLayerEpsg["epsg"] = $layerEpsgArray[$i];
+ $currentLayerEpsg["minx"] = floatval($layerMinXArray[$i]);
+ $currentLayerEpsg["miny"] = floatval($layerMinYArray[$i]);
+ $currentLayerEpsg["maxx"] = floatval($layerMaxXArray[$i]);
+ $currentLayerEpsg["maxy"] = floatval($layerMaxYArray[$i]);
+ array_push($wms->objLayer[0]->layer_epsg, $currentLayerEpsg);
+ // add WMS
+ array_push($wmsArray, $wms);
+ // the index of the WMS we just added
+ $wmsIndex = count($wmsArray) - 1;
+ // add layer to existing WMS ...
+ $currentWms = $wmsArray[$wmsIndex];
+ $currentWms->newLayer($currentLayer, null);
+ $currentMap->setWmsArray($wmsArray);
+ return true;
+ * Called during WMC parsing; sets the maps within a WMC.
+ * @return
+ private function setMapData () {
+ if ($this->generalExtensionArray["OV_WIDTH"] &&
+ $this->generalExtensionArray["OV_HEIGHT"] &&
+ $this->generalExtensionArray["OV_FRAMENAME"] &&
+ $this->generalExtensionArray["OV_MINX"] &&
+ $this->generalExtensionArray["OV_MINY"] &&
+ $this->generalExtensionArray["OV_MAXX"] &&
+ $this->generalExtensionArray["OV_MAXY"] &&
+ $this->generalExtensionArray["OV_SRS"]) {
- $wmc_string .= "\t\t".$target."mb_calculateExtent(old_mapObj[i].frameName, ";
- $wmc_string .= $this->wmc_bBox_minx .",".$this->wmc_bBox_miny .",";
- $wmc_string .= $this->wmc_bBox_maxx .",".$this->wmc_bBox_maxy.");\n";
- $wmc_string .= $ov_bbox[0] .",".$ov_bbox[1] .",";
- $wmc_string .= $ov_bbox[2] .",".$ov_bbox[3] .");\n";
- $wmc_string .= "\t". $target . "setMapRequest(old_mapObj[i].frameName);\n";
- $wmc_string .= $target . "mb_execloadWmsSubFunctions();\n";
+ $this->overviewMap = new Map();
+ $this->overviewMap->setWidth($this->generalExtensionArray["OV_WIDTH"]);
+ $this->overviewMap->setHeight($this->generalExtensionArray["OV_HEIGHT"]);
+ $this->overviewMap->setFrameName($this->generalExtensionArray["OV_FRAMENAME"]);
+ $this->overviewMap->setIsOverview(true);
+ $bbox = new Mapbender_bbox($this->generalExtensionArray["OV_MINX"], $this->generalExtensionArray["OV_MINY"], $this->generalExtensionArray["OV_MAXX"], $this->generalExtensionArray["OV_MAXY"], $this->generalExtensionArray["OV_SRS"]);
+ $this->overviewMap->setExtent($bbox);
-// $e = new mb_exception("js code: " . $wmc_string);
- return $wmc_string;
+ if ($this->generalExtensionArray["MAIN_FRAMENAME"]) {
+ $this->mainMap->setFrameName($this->generalExtensionArray["MAIN_FRAMENAME"]);
+ else {
+ $this->mainMap->setFrameName("mapframe1");
+ return true;
+ * Creates a WMC document (XML) from the current object
+ * @return String XML
+ private function createXml() {
+ $wmcToXml = new WmcToXml($this);
+ $this->xml = $wmcToXml->getXml();
-// end class
+ * @deprecated
+function mb_utf8_encode ($str) {
+// if(CHARSET=="UTF-8") return utf8_encode($str);
+ return $str;
+ * @deprecated
+function mb_utf8_decode ($str) {
+// if(CHARSET=="UTF-8") return utf8_decode($str);
+ return $str;
Added: branches/2.5/http/classes/class_wmcToXml.php
--- branches/2.5/http/classes/class_wmcToXml.php (rev 0)
+++ branches/2.5/http/classes/class_wmcToXml.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,560 @@
+<?php
+# $Id: class_wmc.php 2466 2008-05-20 08:55:03Z christoph $
+# http://www.mapbender.org/index.php/class_wmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ * The XML representation of a WMC object.
+ * Usage:
+ * $wmcToXml = new WmcToXml($wmc);
+ * $xml = $wmcToXml->getXml();
+class WmcToXml {
+ private $wmc = null;
+ private $doc;
+ private $xml = "";
+ * Constructor. Computes the XML of the WMC object given as parameter.
+ * @param $someWmc wmc
+ public function __construct ($someWmc) {
+ $this->wmc = $someWmc;
+ $this->toXml();
+ // public functions
+ public function getXml () {
+ // private functions
+ private function toXml () {
+ // add main map and overview (if exists) to $mapArray
+ $mapArray = array($this->wmc->mainMap);
+ if ($this->wmc->overviewMap !== null) {
+ array_push($mapArray, $this->wmc->overviewMap);
+ // generate XML
+ $this->doc = new DOMDocument("1.0", CHARSET);
+ $this->doc->preserveWhiteSpace = false;
+ // ViewContext
+ $e_view_context = $this->doc->createElementNS("http://www.opengis.net/context", "ViewContext");
+ $e_view_context->setAttribute("version", "1.1.0");
+ $e_view_context->setAttribute("id", $this->wmc->wmc_id);
+ $e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_view_context->setAttribute("xmlns:" . $this->wmc->extensionNamespace, $this->wmc->extensionNamespaceUrl);
+ $e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+ $e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
+ // General
+ $e_general = $this->createGeneralNode();
+ if ($e_general !== null) {
+ $e_view_context->appendChild($e_general);
+ // Layerlist
+ $e_layer_list = $this->doc->createElement("LayerList");
+ while (count($mapArray) > 0) {
+ $currentMap = array_pop($mapArray);
+ $currentWmsArray = $currentMap->getWmsArray();
+ for ($i = 0; $i < count($currentWmsArray); $i++) {
+ $currentWms = $currentWmsArray[$i];
+ for ($j = 0; $j < count($currentWms->objLayer); $j++) {
+ $currentLayer = $currentWms->objLayer[$j];
+ $layerNode = $this->createLayerNode($currentMap, $currentWms, $currentLayer);
+ if ($layerNode !== null) {
+ $e_layer_list->appendChild($layerNode);
+ $e_view_context->appendChild($e_layer_list);
+ $this->doc->appendChild($e_view_context);
+ $this->xml = $this->doc->saveXML();
+ private function createGeneralNode () {
+ $extensionData = array();
+ $ovExtent = $this->wmc->overviewMap->getExtent();
+ $extensionData["ov_minx"] = $ovExtent->min->x;
+ $extensionData["ov_miny"] = $ovExtent->min->y;
+ $extensionData["ov_maxx"] = $ovExtent->max->x;
+ $extensionData["ov_maxy"] = $ovExtent->max->y;
+ $extensionData["ov_srs"] = $ovExtent->epsg;
+ $extensionData["ov_framename"] = $this->wmc->overviewMap->getFrameName();
+ $extensionData["ov_width"] = $this->wmc->overviewMap->getWidth();
+ $extensionData["ov_height"] = $this->wmc->overviewMap->getHeight();
+ if ($this->wmc->mainMap !== null) {
+ $extensionData["main_framename"] = $this->wmc->mainMap->getFrameName();
+ // General
+ $e_general = $this->doc->createElement("General");
+ // Window
+ $e_window = $this->doc->createElement("Window");
+ if ($this->wmc->mainMap->getWidth() && $this->wmc->mainMap->getHeight()) {
+ $e_window->setAttribute("width", $this->wmc->mainMap->getWidth());
+ $e_window->setAttribute("height", $this->wmc->mainMap->getHeight());
+ $e_general->appendChild($e_window);
+ // BoundingBox
+ $mainExtent = $this->wmc->mainMap->getExtent();
+ $e_bbox = $this->doc->createElement("BoundingBox");
+ $e_bbox->setAttribute("SRS", $mainExtent->epsg);
+ $e_bbox->setAttribute("minx", $mainExtent->min->x);
+ $e_bbox->setAttribute("miny", $mainExtent->min->y);
+ $e_bbox->setAttribute("maxx", $mainExtent->max->x);
+ $e_bbox->setAttribute("maxy", $mainExtent->max->y);
+ $e_general->appendChild($e_bbox);
+ // Name
+ $e_name = $this->doc->createElement("Name", $this->wmc->wmc_name);
+ $e_general->appendChild($e_name);
+ // Title
+ $e_title = $this->doc->createElement("Title", $this->wmc->wmc_title);
+ $e_general->appendChild($e_title);
+ // Keywords
+ $e_keyword_list = $this->doc->createElement("KeywordList");
+ for ($i=0; $i < count($this->wmc->wmc_keyword); $i++) {
+ $e_keyword = $this->doc->createElement("Keyword", $this->wmc->wmc_keyword[$i]);
+ $e_keyword_list->appendChild($e_keyword);
+ $e_general->appendChild($e_keyword_list);
+ // Abstract
+ if ($this->wmc->wmc_abstract) {
+ $e_abstract = $this->doc->createElement("Abstract", $this->wmc->wmc_abstract);
+ $e_general->appendChild($e_abstract);
+ // Logo URL
+ if ($this->wmc->wmc_logourl_width && $this->wmc->wmc_logourl_height &&
+ $this->wmc->wmc_logourl_format && $this->wmc->wmc_logourl){
+ $e_logo_url = $this->doc->createElement("LogoURL");
+ $e_logo_url->setAttribute("width", $this->wmc->wmc_logourl_width);
+ $e_logo_url->setAttribute("height", $this->wmc->wmc_logourl_height);
+ $e_logo_url->setAttribute("format", $this->wmc->wmc_logourl_format);
+ $e_logo_url_or = $this->doc->createElement("OnlineResource");
+ $e_logo_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_logo_url_or->setAttribute("xlink:type", "simple");
+ $e_logo_url_or->setAttribute("xlink:href", $this->wmc->wmc_logourl);
+ $e_logo_url->appendChild($e_logo_url_or);
+ $e_general->appendChild($e_logo_url);
+ // Description URL
+ if ($this->wmc->wmc_descriptionurl){
+ $e_description_url = $this->doc->createElement("DescriptionURL");
+ $e_description_url_or = $this->doc->createElement("OnlineResource");
+ $e_description_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_description_url_or->setAttribute("xlink:type", "simple");
+ $e_description_url_or->setAttribute("xlink:href", $this->wmc->wmc_descriptionurl);
+ $e_description_url->appendChild($e_description_url_or);
+ $e_general->appendChild($e_description_url);
+ // Contact information
+ $e_contact = $this->createContactInformationNode();
+ if ($e_contact !== null) {
+ $e_general->appendChild($e_contact);
+ // Extension data
+ if (count($extensionData) > 0) {
+ $e_extensionGeneral = $this->doc->createElement("Extension");
+ foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
+ $e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$keyExtensionData, $valueExtensionData);
+ $e_extensionGeneral->appendChild($e_currentExtensionTag);
+ $e_general->appendChild($e_extensionGeneral);
+ return $e_general;
+ private function createLayerNode ($currentMap, $currentWms, $currentLayer) {
+ if ($currentLayer->layer_parent != '') {
+ // Layer
+ $e_layer = $this->doc->createElement("Layer");
+ $e_layer->setAttribute("queryable", $currentLayer->layer_queryable);
+ $e_layer->setAttribute("hidden", ($currentLayer->gui_layer_visible ? 0 : 1));
+ // Server
+ $e_service = $this->doc->createElement("Server");
+ $e_service->setAttribute("service", "OGC:WMS");
+ $e_service->setAttribute("version", $currentWms->wms_version);
+ $e_service->setAttribute("title", $currentWms->wms_title);
+ // Online resource
+ $e_service_or = $this->doc->createElement("OnlineResource");
+ $e_service_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_service_or->setAttribute("xlink:type", "simple");
+ $e_service_or->setAttribute("xlink:href", $currentWms->wms_getmap);
+ $e_service->appendChild($e_service_or);
+ $e_layer->appendChild($e_service);
+ // Name
+ $e_layer_name = $this->doc->createElement("Name", $currentLayer->layer_name);
+ $e_layer->appendChild($e_layer_name);
+ // Title
+ $e_layer_title = $this->doc->createElement("Title", $currentLayer->layer_title);
+ $e_layer->appendChild($e_layer_title);
+ // Abstract
+ if ($currentWms->wms_abstract){
+ $e_layer_abstract = $this->doc->createElement("Abstract", $currentWms->wms_abstract);
+ $e_layer->appendChild($e_layer_abstract);
+ // SRS
+ $srsNode = $this->createSrsNode($currentMap, $currentWms);
+ if ($srsNode !== null) {
+ $e_layer->appendChild($srsNode);
+ // Data URL
+ if ($currentLayer->layer_dataurl_href){
+ $e_layer_data_url = $this->doc->createElement("DataURL");
+ $e_layer_data_url_or = $this->doc->createElement("OnlineResource");
+ $e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_layer_data_url_or->setAttribute("xlink:type", "simple");
+ $e_layer_data_url_or->setAttribute("xlink:href", $currentLayer->layer_dataurl_href);
+ $e_layer_data_url->appendChild($e_layer_data_url_or);
+ $e_layer->appendChild($e_layer_data_url);
+ // Metadata URL
+ if ($currentLayer->layer_metadataurl){
+ $e_layer_metadata_url = $this->doc->createElement("MetadataURL");
+ // Metadata URL online resource
+ $e_layer_metadata_url_or = $this->doc->createElement("OnlineResource");
+ $e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_layer_metadata_url_or->setAttribute("xlink:type", "simple");
+ $e_layer_metadata_url_or->setAttribute("xlink:href", $currentLayer->layer_metadataurl);
+ $e_layer_metadata_url->appendChild($e_layer_metadata_url_or);
+ $e_layer->appendChild($e_layer_metadata_url);
+ // Layer format
+ $formatListNode = $this->createLayerFormatListNode($currentWms);
+ if ($formatListNode !== null) {
+ $e_layer->appendChild($formatListNode);
+ // Layer style
+ $layerStyleListNode = $this->createLayerStyleNode($currentWms, $currentLayer);
+ if ($layerStyleListNode !== null) {
+ $e_layer->appendChild($layerStyleListNode);
+ // Extension
+ $extensionNode = $this->createLayerExtensionNode($currentMap, $currentWms, $currentLayer);
+ if ($extensionNode !== null) {
+ $e_layer->appendChild($extensionNode);
+ return $e_layer;
+ return null;
+ private function createSrsNode ($currentMap, $currentWms) {
+ $wms_epsg = array();
+ $wms_epsg[0] = $currentMap->getEpsg();
+ if ($currentWms->gui_wms_epsg != $currentMap->getEpsg()) {
+ $wms_epsg[1] = $currentWms->gui_wms_epsg;
+ for ($j = 0; $j < count($currentWms->gui_epsg); $j++) {
+ if (!in_array($currentWms->gui_epsg[$j], $wms_epsg)){
+ array_push($wms_epsg, $currentWms->gui_epsg[$j]);
+ $e_layer_srs = $this->doc->createElement("SRS", implode(" ", $wms_epsg));
+ return $e_layer_srs;
+ private function createLayerFormatListNode ($currentWms) {
+ $e_layer_format = $this->doc->createElement("FormatList");
+ $data_format_current = false;
+ for ($k = 0; $k < count($currentWms->data_format); $k++){
+ if ($currentWms->data_type[$k] == "map") {
+ $layerFormat = $currentWms->data_format[$k];
+ $e_format = $this->doc->createElement("Format", $layerFormat);
+ if ($data_format_current === false && (
+ $currentWms->data_format[$k] == $currentWms->gui_wms_mapformat ||
+ $k == (count($currentWms->data_format)-1)
+ $e_format->setAttribute("current", "1");
+ $data_format_current = true;
+ $e_layer_format->appendChild($e_format);
+ return $e_layer_format;
+ private function createLayerExtensionNode ($currentMap, $currentWms, $currentLayer) {
+ $layerExtensionData = array();
+ $layerExtensionData["wms_name"] = $currentWms->objLayer[0]->layer_name;
+ $layerExtensionData["minscale"] = $currentLayer->layer_minscale;
+ $layerExtensionData["maxscale"] = $currentLayer->layer_maxscale;
+ $layerExtensionData["gui_minscale"] = $currentLayer->gui_layer_minscale;
+ $layerExtensionData["gui_maxscale"] = $currentLayer->gui_layer_maxscale;
+ $layerExtensionData["layer_id"] = $currentLayer->layer_uid;
+ $layerExtensionData["wms_layer_id"] = $currentWms->objLayer[0]->layer_uid;
+ $layerExtensionData["layer_pos"] = $currentLayer->layer_pos;
+ $layerExtensionData["layer_parent"] = $currentLayer->layer_parent;
+ $layerExtensionData["wms_id"] = $currentLayer->gui_layer_wms_id;
+ $layerExtensionData["querylayer"] = $currentLayer->gui_layer_querylayer;
+ $layerExtensionData["gui_selectable"] = $currentLayer->gui_layer_selectable;
+ $layerExtensionData["gui_queryable"] = $currentLayer->gui_layer_queryable;
+ $layerExtensionData["gui_status"] = $currentLayer->gui_layer_status;
+ $layerExtensionData["layer_epsg"] = $currentLayer->layer_epsg;
+ if ($currentMap->isOverview()) {
+ $layerExtensionData["isOverviewLayer"] = 1;
+ if ($currentLayer->gui_layer_wfs_featuretype) {
+ $layerExtensionData["wfsFeatureType"] = $currentLayer->gui_layer_wfs_featuretype;
+ if (count($layerExtensionData) > 0) {
+ $e_extension = $this->doc->createElement("Extension");
+ foreach ($layerExtensionData as $keyExtensionData => $valueExtensionData) {
+ $e_currentExtensionTag = $this->addExtension($keyExtensionData, $valueExtensionData);
+ $e_extension->appendChild($e_currentExtensionTag);
+ return $e_extension;
+ return null;
+ private function addExtension ($key, $value) {
+ if (is_array($value)) {
+ if (is_numeric($key)) {
+ $key = "data" . $key;
+ $e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key);
+ foreach ($value as $childKey => $childValue) {
+ $newNode = $this->addExtension($childKey, $childValue);
+ $e_currentExtensionTag->appendChild($newNode);
+ else {
+ $e_currentExtensionTag = $this->doc->createElement($this->wmc->extensionNamespace.":".$key, $value);
+ return $e_currentExtensionTag;
+ private function createLayerStyleNode ($currentWms, $currentLayer) {
+ $e_layer_stylelist = $this->doc->createElement("StyleList");
+ for ($k = 0; $k < count($currentLayer->layer_style); $k++) {
+ $currentStyle = $currentLayer->layer_style[$k];
+ $layerStyle_current = 0;
+ if ($k === 0){
+ $layerStyle_current = 1; // To do: insert proper data
+ $e_layer_style = $this->doc->createElement("Style");
+ $layerStyleSLD = "";
+ if ($layerStyleSLD) {
+ $e_layer_style_or = $this->doc->createElement("OnlineResource");
+ $e_layer_style_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_layer_style_or->setAttribute("xlink:type", "simple");
+ $e_layer_style_or->setAttribute("xlink:href", $currentWms->gui_wms_sldurl);
+ $e_layer_style->appendChild($e_layer_style_or);
+ else{
+ if ($layerStyle_current == 1){
+ $e_layer_style->setAttribute("current", "1");
+ $e_layer_style_name = $this->doc->createElement("Name", $currentStyle["name"]);
+ $e_layer_style->appendChild($e_layer_style_name);
+ $e_layer_style_title = $this->doc->createElement("Title", $currentStyle["title"]);
+ $e_layer_style->appendChild($e_layer_style_title);
+ $e_layer_style_legendurl = $this->doc->createElement("LegendUrl");
+ //TODO: determine correct layer style entries
+ $layerStyle_legendUrl_width = ""; // To Do: add proper data
+ $layerStyle_legendUrl_height = ""; // To Do: add proper data
+ $layerStyle_legendUrl_format = ""; // To Do: add proper data
+ $e_layer_style_legendurl->setAttribute("width", $layerStyle_legendUrl_width);
+ $e_layer_style_legendurl->setAttribute("height", $layerStyle_legendUrl_height);
+ $e_layer_style_legendurl->setAttribute("format", $layerStyle_legendUrl_format);
+ $e_layer_style_legendurl_or = $this->doc->createElement("OnlineResource");
+ $e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
+ $e_layer_style_legendurl_or->setAttribute("xlink:href", $currentStyle["legendurl"]);
+ $e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
+ $e_layer_style->appendChild($e_layer_style_legendurl);
+ $e_layer_stylelist->appendChild($e_layer_style);
+ return $e_layer_stylelist;
+ * @return
+ private function createContactInformationNode () {
+ if ($this->wmc->wmc_contactemail || $this->wmc->wmc_contactorganization ||
+ $this->wmc->wmc_contactperson || $this->wmc->wmc_contactposition ||
+ $this->wmc->wmc_contactaddresstype || $this->wmc->wmc_contactaddress ||
+ $this->wmc->wmc_contactcity || $this->wmc->wmc_contactstateorprovince ||
+ $this->wmc->wmc_contactpostcode || $this->wmc->wmc_contactcountry ||
+ $this->wmc->wmc_contactvoicetelephone || $this->wmc->wmc_contactfacsimiletelephone) {
+ $e_contact = $this->doc->createElement("ContactInformation");
+ $e_contact_person_primary = $this->wmc->createContactPersonPrimaryNode();
+ if ($e_contact_person_primary !== null) {
+ $e_contact->appendChild($e_contact_person_primary);
+ if ($this->wmc->wmc_contactposition){
+ $e_contact_position = $this->doc->createElement("ContactPosition", $this->wmc->wmc_contactposition);
+ $e_contact->appendChild($e_contact_position);
+ if ($this->wmc->wmc_contactaddresstype || $this->wmc->wmc_contactaddress ||
+ $this->wmc->wmc_contactpostcode || $this->wmc->wmc_contactcountry) {
+ $e_contact_address = $this->doc->createElement("ContactAddress");
+ if ($this->wmc->wmc_contactaddresstype){
+ $e_address_type = $this->doc->createElement("AddressType", $this->wmc->wmc_contactaddresstype);
+ $e_contact_address->appendChild($e_address_type);
+ if ($this->wmc->wmc_contactaddress){
+ $e_address = $this->doc->createElement("Address", $this->wmc->wmc_contactaddress);
+ $e_contact_address->appendChild($e_address);
+ if ($this->wmc->wmc_contactcity){
+ $e_city = $this->doc->createElement("City", $this->wmc->wmc_contactcity);
+ $e_contact_address->appendChild($e_city);
+ if ($this->wmc->wmc_contactstateorprovince){
+ $e_state = $this->doc->createElement("StateOrProvince", $this->wmc->wmc_contactstateorprovince);
+ $e_contact_address->appendChild($e_state);
+ if ($this->wmc->wmc_contactpostcode){
+ $e_postcode = $this->doc->createElement("PostCode", $this->wmc->wmc_contactpostcode);
+ $e_contact_address->appendChild($e_postcode);
+ if ($this->wmc->wmc_contactcountry){
+ $e_country = $this->doc->createElement("Country", $this->wmc->wmc_contactcountry);
+ $e_contact_address->appendChild($e_country);
+ $e_contact->appendChild($e_contact_address);
+ if ($this->wmc->wmc_contactvoicetelephone){
+ $e_voice_telephone = $this->doc->createElement("ContactVoiceTelephone", $this->wmc->wmc_contactvoicetelephone);
+ $e_contact->appendChild($e_voice_telephone);
+ if ($this->wmc->wmc_contactfacsimiletelephone){
+ $e_facsimile_telephone = $this->doc->createElement("ContactFacsimileTelephone", $this->wmc->wmc_contactfacsimiletelephone);
+ $e_contact->appendChild($e_facsimile_telephone);
+ if ($this->wmc->wmc_contactemail){
+ $e_email = $this->doc->createElement("ContactElectronicMailAddress", $this->wmc->wmc_contactemail);
+ $e_contact->appendChild($e_email);
+ return $e_contact;
+ return null;
+ private function createContactPersonPrimaryNode () {
+ if ($this->wmc->wmc_contactperson || $this->wmc->wmc_contactorganization){
+ $e_contact_person_primary = $this->doc->createElement("ContactPersonPrimary");
+ if ($this->wmc->wmc_contactperson){
+ $e_contact_person = $this->doc->createElement("ContactPerson", $this->wmc->wmc_contactperson);
+ $e_contact_person_primary->appendChild($e_contact_person);
+ if ($this->wmc->wmc_contactorganization){
+ $e_contact_organization = $this->doc->createElement("ContactOrganization", $this->wmc->wmc_contactorganization);
+ $e_contact_person_primary->appendChild($e_contact_organization);
+ return $e_contact_person_primary;
+ return null;
Modified: branches/2.5/http/classes/class_wms.php
--- branches/2.5/http/classes/class_wms.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/classes/class_wms.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/class_wms
-# Copyright (C) 2002 CCGIS
@@ -19,6 +19,7 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_user.php");
require_once(dirname(__FILE__)."/class_administration.php");
class wms {
@@ -34,7 +35,7 @@
var $wms_getfeatureinfo;
var $wms_getlegendurl;
var $wms_upload_url;
var $fees;
var $accessconstraints;
var $contactperson;
@@ -48,28 +49,28 @@
var $contactvoicetelephone;
var $contactfacsimiletelephone;
var $contactelectronicmailaddress;
var $wms_keyword = array();
- var $data_type = array();
+ var $data_type = array();
var $data_format = array();
- var $objLayer = array();
+ var $objLayer = array();
var $wms_supportsld;
var $wms_userlayer;
var $wms_userstyle;
var $wms_remotewfs;
var $gui_wms_mapformat;
var $gui_wms_featureinfoformat;
var $gui_wms_exceptionformat;
var $gui_wms_epsg;
var $gui_wms_sldurl;
var $default_epsg = 0;
var $overwrite = true;
function wms() {
public static function getConjunctionCharacter ($url) {
if (mb_strpos($url, "?") !== false) {
@@ -89,11 +90,151 @@
return "";
+ function createOlObjFromWMS($base){
+ if(!$this->wms_title || $this->wms_title == ""){
+ echo "alert('Error: no valid capabilities-document !!');";
+ die; exit;
+ // wms_title and abstract have previously been urlencoded
+ // this solution may not yet be the ultimate one
+ $add_wms_string = "var wms_".$this->wms_id." = new OpenLayers.Layer.WMS.Untiled(" .
+ "'" . addslashes($this->wms_title) . "'," .
+ "'" . $this->wms_getmap ."'," ."{layers:'";
+ for($i=1;$i<count($this->objLayer);$i++){
+ $add_wms_string .= addslashes($this->objLayer[$i]->layer_name);
+ if($i!=count($this->objLayer)-1)
+ $add_wms_string .= ",";
+ $add_wms_string .= "', transparent: 'true'";
+ $add_wms_string .= ",format: '".$this->gui_wms_mapformat."'});\n";
+ if($base)
+ $add_wms_string .= "wms_".$this->wms_id.".isBaseLayer=true;\n";
+ $add_wms_string .= "wms_".$this->wms_id.".setVisibility(".($this->gui_wms_visible=="1"?"true":"false").");\n";
+ $add_wms_string .= "ol_map.addLayer(wms_".$this->wms_id.");\n";
+ echo $add_wms_string;
+ * Compares this WMS to another WMS.
+ * @return boolean false, if
+ * - the capabilities URLs don't match
+ * - the layer count is different
+ * - the layer names are different
+ * @param $anotherWms wms this is just another WMS object
+ public function equals ($anotherWms) {
+ // If the getMap URLs are not equal, the WMS are not equal.
+ if ($this->wms_getmap != $anotherWms->wms_getmap) {
+// $e = new mb_notice($this . " != " . $anotherWms . " (getMap URL)");
+ return false;
+ // If the layer count is different, the WMS are not equal.
+ if (count($this->objLayer) != count($anotherWms->objLayer)) {
+// $e = new mb_notice($this . " != " . $anotherWms . " (layer count: " . count($this->objLayer) . ":" . count($anotherWms->objLayer). ")");
+ return false;
+ // If the layer names are different, the WMS are not equal.
+ for ($i = 0; $i < count($this->objLayer); $i++) {
+ $name1 = $this->objLayer[$i]->layer_name;
+ $name2 = $anotherWms->objLayer[$i]->layer_name;
+ if ($name1 != $name2) {
+// $e = new mb_notice($this . " != " . $anotherWms . " (layer names, " . $name1 . " vs. " . $name2 . ")");
+ return false;
+// $e = new mb_notice($this . " == " . $anotherWms);
+ return true;
+ * The other WMS must be the same as this WMS, but with different
+ * application settings. These application settings are copied,
+ * the local settings are overwritten.
+ * @return boolean true if the settings could be copied; false
+ * when an error occured.
+ * @param $anotherWms wms The same WMS with possibly other settings
+ public function copyConfiguration ($anotherWms) {
+ if (!$this->equals($anotherWms)) {
+ $e = new mb_exception("class_wms.php: copyConfiguration(): parameters cannot be copied, it's a different WMS.");
+ return false;
+ $myCurrentLayer = $this->objLayer[$i];
+ $theirCurrentLayer = $anotherWms->objLayer[$i];
+ $myCurrentLayer->gui_layer_selectable = $theirCurrentLayer->gui_layer_selectable;
+ $myCurrentLayer->gui_layer_visible = $theirCurrentLayer->gui_layer_visible;
+ $myCurrentLayer->gui_layer_queryable = $theirCurrentLayer->gui_layer_queryable;
+ $myCurrentLayer->gui_layer_querylayer = $theirCurrentLayer->gui_layer_querylayer;
+ $myCurrentLayer->gui_layer_style = $theirCurrentLayer->gui_layer_style;
+ * Removes duplicate WMS from an array of WMS. To find duplicates,
+ * two WMS are compared via equals().
+ * @return wms[]
+ * @param $wmsArray wms[]
+ public static function merge ($wmsArray) {
+ $e = new mb_notice("before: " . implode(", ", $wmsArray));
+ if (!is_array($wmsArray)) {
+ $e = new mb_exception("class_wms.php: merge(): parameter is NOT an array.");
+ return array();
+ if (count($wmsArray) == 0) {
+ $e = new mb_exception("class_wms.php: merge(): parameter is an EMPTY array.");
+ return array();
+ $newWmsArray = array();
+ while (count($wmsArray) > 0) {
+ $currentWms = array_pop($wmsArray);
+ $isNewWms = true;
+ if (get_class($currentWms) != "wms") {
+ $e = new mb_exception("class_wms.php: merge(): current WMS is not a WMS object, but a " . get_class($currentWms));
+ else {
+ for ($i = 0; $i < count($newWmsArray) && $isNewWms; $i++) {
+ if ($currentWms->equals($newWmsArray[$i])) {
+ $isNewWms = false;
+ if ($isNewWms) {
+// $e = new mb_notice("adding WMS " . $currentWms);
+ array_push($newWmsArray, $currentWms);
+ // reversal of the array, because the elements were popped
+ // from another array before.
+// $e = new mb_notice("after: " . implode(", ", array_reverse($newWmsArray)));
+ return array_reverse($newWmsArray);
+ public function __toString () {
+ return $this->wms_title;
function createObjFromXML($url){
$x = new connector($url);
$data = $x->file;
if(!$data){
$this->wms_status = false;
return false;
@@ -101,13 +242,13 @@
else {
$this->wms_status = true;
$values = null;
$tags = null;
$admin = new administration();
$this->wms_getcapabilities_doc = $data;
$this->wms_upload_url = $url;
$this->wms_id = "";
$parser = xml_parser_create("");
xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
@@ -117,22 +258,22 @@
$code = xml_get_error_code($parser);
if ($code) {
- $line = xml_get_current_line_number($parser);
+ $line = xml_get_current_line_number($parser);
$mb_exception = new mb_exception(xml_error_string($code) . " in line " . $line);
xml_parser_free($parser);
$section = null;
$format = null;
$cnt_format = 0;
$parent = array();
$myParent = array();
$cnt_layer = -1;
- $request = null;
+ $request = null;
$layer_style = array();
$cnt_styles = -1;
foreach ($values as $element) {
if(mb_strtoupper($element[tag]) == "WMT_MS_CAPABILITIES" && $element[type] == "open"){
$this->wms_version = $element[attributes][version];
@@ -185,7 +326,7 @@
if(mb_strtolower($element[tag]) == "keyword" && $section != 'layer'){
$this->wms_keyword[count($this->wms_keyword)] = $element[value];
/*map section*/
if($this->wms_version == "1.0.0"){
if(mb_strtoupper($element[tag]) == "MAP" && $element[type] == "open"){
@@ -340,7 +481,7 @@
/*legend section*/
else{
if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "open"){
@@ -357,17 +498,17 @@
if(mb_strtoupper($element[tag]) == "GETLEGENDGRAPHIC" && $element[type] == "close"){
$section = "";
- /* sld section */
+ /* sld section */
if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
$this->wms_supportsld = $element[attributes]["SupportSLD"];
$this->wms_userlayer = $element[attributes]["UserLayer"];
$this->wms_userstyle = $element[attributes]["UserStyle"];
$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
- /*layer section*/
+ /*layer section*/
if(mb_strtoupper($element[tag]) == "LAYER"){
$section = "layer";
if ($element[type] == "open") {
@@ -379,7 +520,7 @@
$this->objLayer[$cnt_layer]->layer_queryable = $element[attributes][queryable];
if ($element[type] == "close") {
/* attribution */
@@ -423,7 +564,7 @@
if(mb_strtoupper($element[tag]) == "LEGENDURL" && $element[type] == "close"){
$legendurl = false;
/* end of styles */
if($section == "layer"){
@@ -447,8 +588,8 @@
if(mb_strtoupper($element[tag]) == "DATAURL" && $element[type] == "close"){
$dataurl = false;
if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
@@ -457,13 +598,13 @@
if(mb_strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
$metadataurl = false;
if(mb_strtoupper($element[tag]) == "SRS"){
$this->objLayer[$cnt_layer]->wms_srs1 = $element[value];
// unique srs only, see http://www.mapbender.org/index.php/Arrays_with_unique_entries
- $this->wms_srs = array_keys(array_flip(explode(" ", $this->objLayer[0]->wms_srs1)));
+ $this->wms_srs = array_keys(array_flip(explode(" ", $this->objLayer[0]->wms_srs1)));
if(mb_strtoupper($element[tag]) == "LATLONBOUNDINGBOX"){
$cnt_epsg++;
$this->objLayer[$cnt_layer]->layer_epsg[$cnt_epsg]["epsg"] = "EPSG:4326";
@@ -485,12 +626,12 @@
if(mb_strtoupper($element[tag]) == "SCALEHINT"){
- if($element[attributes][max]>1000) $max = 0; else $max = $element[attributes][max];
- if($element[attributes][min]>1000) $min = 0; else $min = $element[attributes][min];
+ if($element[attributes][max]>1000) $max = 0; else $max = $element[attributes][max];
+ if($element[attributes][min]>1000) $min = 0; else $min = $element[attributes][min];
$this->objLayer[$cnt_layer]->layer_minscale = round(($min * 2004.3976484406788493955738891127));
$this->objLayer[$cnt_layer]->layer_maxscale = round(($max * 2004.3976484406788493955738891127));
else {
continue;
@@ -498,13 +639,13 @@
if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
$this->optimizeWMS();
+ $e = new mb_exception("class_wms: createObjFromXML: WMS " . $url . " could not be loaded.");
return false;
else{
+ $e = new mb_notice("class_wms: createObjFromXML: WMS " . $url . " has been loaded successfully.");
return true;
@@ -554,7 +695,7 @@
for($i=0;$i<count($this->objLayer);$i++){
if(count($this->objLayer[$i]->layer_epsg) == 0 && count($this->objLayer[0]->layer_epsg) > 0){
- $this->objLayer[$i]->layer_epsg = $this->objLayer[0]->layer_epsg;
+ $this->objLayer[$i]->layer_epsg = $this->objLayer[0]->layer_epsg;
if(!is_int($this->objLayer[$i]->layer_parent)){
$this->objLayer[$i]->layer_abstract = $this->wms_abstract;
@@ -563,7 +704,7 @@
if($this->objLayer[$i]->layer_name == ""){
- $this->objLayer[$i]->layer_name = "";
+ $this->objLayer[$i]->layer_name = $this->objLayer[$i]->layer_title;
if($this->objLayer[$i]->layer_minscale == ""){
$this->objLayer[$i]->layer_minscale = 0;
@@ -585,11 +726,11 @@
if(mb_strtolower($this->data_type[$i]) == 'featureinfo' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($featureinfo_default)){
$this->gui_wms_featureinfoformat = mb_strtolower($featureinfo_default);
$featureinfo_default_ok = true;
if(mb_strtolower($this->data_type[$i]) == 'exception' && mb_strtolower($this->data_format[$i]) == mb_strtolower($exception_default)){
$this->gui_wms_exceptionformat = mb_strtolower($exception_default);
$exception_default_ok = true;
if($map_default_ok == false){
for($i=0;$i<count($this->data_format);$i++){
@@ -606,7 +747,7 @@
if(mb_strtolower($this->data_type[$i]) == "exception" ){$this->gui_wms_exceptionformat = $this->data_format[$i]; break;}
if(count($this->objLayer[0]->layer_epsg)>1){
$this->gui_wms_epsg = $this->objLayer[0]->layer_epsg[$this->default_epsg][epsg];
@@ -625,7 +766,7 @@
for($i=0; $i<count($this->objLayer); $i++){
$this->objLayer[$i]->layer_pos=$i;
/* fill sld variables when empty */
if($this->wms_supportsld == ""){
$this->wms_supportsld = 0;
@@ -640,7 +781,7 @@
$this->wms_remotewfs = 0;
function displayWMS(){
echo "<br>id: " . $this->wms_id . " <br>";
echo "version: " . $this->wms_version . " <br>";
@@ -651,13 +792,13 @@
echo "featureinforequest: " . $this->wms_getfeatureinfo . " <br>";
echo "gui_wms_mapformat: " . $this->gui_wms_mapformat . " <br>";
echo "gui_wms_featureinfoformat: " . $this->gui_wms_featureinfoformat . " <br>";
- echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
+ echo "gui_wms_exceptionformat: " . $this->gui_wms_exceptionformat . " <br>";
echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
- echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
+ echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
echo "gui_wms_opacity: " . $this->gui_wms_opacity . " <br>";
echo "support_sld: " . $this->wms_supportsld . " <br>";
for($i=0; $i<count($this->data_type);$i++){
echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
@@ -684,8 +825,8 @@
echo "<hr>";
echo "<hr>";
- function addLayer($id,$parent){
+ function addLayer($id,$parent){
$this->objLayer[count($this->objLayer)] = new layer($id,$parent);
@@ -694,17 +835,104 @@
function stripEndlineAndCarriageReturn($string) {
return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
- function createJsObjFromWMS($parent=0){
+ function createJsObjFromWMS($parent=0){
+ echo $this->createJsObjFromWMS_($parent);
+ function newLayer ($currentLayer, $currentExtent) {
+ $pos = $currentLayer["extension"]["LAYER_POS"];
+ $parent = $currentLayer["extension"]["LAYER_PARENT"];
+ $this->addLayer($pos, $parent);
+ // set layer data
+ $layerIndex = count($this->objLayer) - 1;
+ $newLayer = $this->objLayer[$layerIndex];
+ $newLayer->layer_uid = $currentLayer["extension"]["LAYER_ID"];
+ $newLayer->layer_name = $currentLayer["name"];
+ $newLayer->layer_title = $currentLayer["title"];
+ $newLayer->layer_dataurl_href = $currentLayer["dataurl"];
+ $newLayer->layer_pos = $currentLayer["extension"]["LAYER_POS"];
+ $newLayer->layer_queryable = $currentLayer["queryable"];
+ $newLayer->layer_minscale = $currentLayer["extension"]["MINSCALE"];
+ $newLayer->layer_maxscale = $currentLayer["extension"]["MAXSCALE"];
+ $newLayer->layer_metadataurl = $currentLayer["metadataurl"];
+ $newLayer->gui_layer_wms_id = $currentLayer["extension"]["WMS_ID"];
+ $newLayer->gui_layer_status = $currentLayer["extension"]["GUI_STATUS"];
+ $newLayer->gui_layer_style = ""; // TODO: Add correct data
+ $newLayer->gui_layer_selectable = $currentLayer["extension"]["GUI_SELECTABLE"];
+ $newLayer->gui_layer_visible = $currentLayer["visible"];
+ $newLayer->gui_layer_queryable = $currentLayer["extension"]["GUI_QUERYABLE"];
+ $newLayer->gui_layer_querylayer = $currentLayer["extension"]["QUERYLAYER"];
+ $newLayer->gui_layer_minscale = $currentLayer["extension"]["GUI_MINSCALE"];
+ $newLayer->gui_layer_maxscale = $currentLayer["extension"]["GUI_MAXSCALE"];
+ if (isset($currentLayer["extension"]["WFSFEATURETYPE"])) {
+ $newLayer->gui_layer_wfs_featuretype = $currentLayer["extension"]["WFSFEATURETYPE"];
+ $newLayer->layer_abstract = $currentLayer["abstract"];
+ // set layer epsg
+ $newLayer->layer_epsg = array();
+ else {
+ array_push($newLayer->layer_epsg, $currentLayerEpsg);
+ // set layer style
+ for ($i = 0; $i < count($currentLayer["style"]); $i++) {
+ $layerStyleIndex = count($newLayer->gui_layer_style) - 1;
+ $newLayer->layer_style[$layerStyleIndex] = array();
+ $newLayer->layer_style[$layerStyleIndex]["name"] = $currentLayer["style"][$i]["name"];
+ $newLayer->layer_style[$layerStyleIndex]["title"] = $currentLayer["style"][$i]["title"];
+ $newLayer->layer_style[$layerStyleIndex]["legendurl"] = $currentLayer["style"][$i]["legendurl"];
+ $newLayer->layer_style[$layerStyleIndex]["legendurl_format"] = $currentLayer["style"][$i]["legendurl_type"];
+ function createJsObjFromWMS_($parent=0){
+ $str = "";
- echo "alert('Error: no valid capabilities-document !!');";
+ $str .= "alert('Error: no valid capabilities-document !!');";
die; exit;
if($parent){
- echo "parent.";
+ $str .= "parent.";
$add_wms_string = "add_wms(" .
"'" . $this->wms_id ."'," .
"'" . $this->wms_version ."'," .
@@ -722,71 +950,77 @@
"'" . $this->gui_wms_opacity ."'," .
"'" . $this->gui_wms_sldurl ."" .
- echo $add_wms_string;
+ $str .= $add_wms_string;
if($parent){
- echo "parent.";
- echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
+ $str .= "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
if($parent){
- echo "parent.";
- print ("wms_add_layer('".
- $this->objLayer[$i]->layer_parent ."','".
- $this->objLayer[$i]->layer_uid ."','".
- addslashes($this->objLayer[$i]->layer_name) . "','".
- addslashes($this->objLayer[$i]->layer_title) ."','".
- $this->objLayer[$i]->layer_dataurl_href ."','".
- $this->objLayer[$i]->layer_pos ."','".
- $this->objLayer[$i]->layer_queryable ."','".
- $this->objLayer[$i]->layer_minscale . "','".
- $this->objLayer[$i]->layer_maxscale ."','".
- $this->objLayer[$i]->layer_metadataurl ."','".
- $this->objLayer[$i]->gui_layer_wms_id ."','".
+ $str .= "wms_add_layer('".
+ $this->objLayer[$i]->layer_parent ."','".
+ $this->objLayer[$i]->layer_uid ."','".
+ addslashes($this->objLayer[$i]->layer_name) . "','".
+ addslashes($this->objLayer[$i]->layer_title) ."','".
+ $this->objLayer[$i]->layer_dataurl_href ."','".
+ $this->objLayer[$i]->layer_pos ."','".
+ $this->objLayer[$i]->layer_queryable ."','".
+ $this->objLayer[$i]->layer_minscale . "','".
+ $this->objLayer[$i]->layer_maxscale ."','".
+ $this->objLayer[$i]->layer_metadataurl ."','".
+ $this->objLayer[$i]->gui_layer_wms_id ."','".
$this->objLayer[$i]->gui_layer_status ."','".
- $this->objLayer[$i]->gui_layer_style ."','".
- $this->objLayer[$i]->gui_layer_selectable ."','".
- $this->objLayer[$i]->gui_layer_visible ."','".
- $this->objLayer[$i]->gui_layer_queryable ."','".
- $this->objLayer[$i]->gui_layer_querylayer ."','".
- $this->objLayer[$i]->gui_layer_minscale ."','".
+ $this->objLayer[$i]->gui_layer_style ."','".
+ $this->objLayer[$i]->gui_layer_selectable ."','".
+ $this->objLayer[$i]->gui_layer_visible ."','".
+ $this->objLayer[$i]->gui_layer_queryable ."','".
+ $this->objLayer[$i]->gui_layer_querylayer ."','".
+ $this->objLayer[$i]->gui_layer_minscale ."','".
$this->objLayer[$i]->gui_layer_maxscale ."','".
- $this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n");
+ $this->objLayer[$i]->gui_layer_wfs_featuretype ."');\n";
for($j=0; $j<count($this->objLayer[$i]->layer_epsg);$j++){
if($i==0){
if($parent){
- echo "parent.";
- print("wms_addSRS('".
- $this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
- $this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
- $this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
- $this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
- $this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n");
+ $str .= "wms_addSRS('".
+ $this->objLayer[$i]->layer_epsg[$j]["epsg"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["minx"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["miny"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["maxx"] ."','".
+ $this->objLayer[$i]->layer_epsg[$j]["maxy"] ."');\n";
if($parent){
- echo "parent.";
- print("layer_addEpsg('".
+ $str .= "layer_addEpsg('".
for($j=0; $j<count($this->objLayer[$i]->layer_style);$j++){
if($parent){
- echo "parent.";
- print("wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"]."', '".$this->objLayer[$i]->layer_style[$j]["title"]."', ".$j.",".$i.",'".$this->objLayer[$i]->layer_style[$j]["legendurl"]."', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n");
+ $str .= "wms_addLayerStyle('".$this->objLayer[$i]->layer_style[$j]["name"].
+ "', '".$this->objLayer[$i]->layer_style[$j]["title"].
+ "', ".$j.
+ ",".$i.
+ ",'".$this->objLayer[$i]->layer_style[$j]["legendurl"].
+ "', '".$this->objLayer[$i]->layer_style[$j]["legendformat"]."');\n";
+ return $str;
function createJsLayerObjFromWMS($parent=0, $layer_name){
echo " alert('Error: no valid capabilities-document !!');";
@@ -797,54 +1031,54 @@
- print("add_wms('".
+ print("add_wms('".
$this->wms_id ."','".
$this->wms_version ."','".
preg_replace("/'/", "", $this->wms_title) ."','".
- preg_replace("/'/", "", $this->wms_abstract) ."','".
+ preg_replace("/'/", "", $this->wms_abstract) ."','".
$this->wms_getmap ."','" .
$this->wms_getfeatureinfo ."','".
$this->wms_getlegendurl ."','".
$this->wms_filter ."','".
- $this->gui_wms_mapformat ."','".
- $this->gui_wms_featureinfoformat ."','".
- $this->gui_wms_exceptionformat . "','".
- $this->gui_wms_epsg ."','".
+ $this->gui_wms_mapformat ."','".
+ $this->gui_wms_featureinfoformat ."','".
+ $this->gui_wms_exceptionformat . "','".
+ $this->gui_wms_epsg ."','".
$this->gui_wms_visible ."','".
$this->gui_wms_opacity ."','".
$this->gui_wms_sldurl ."');\n");
if($parent){
echo "parent.";
+ echo "wms_add_data_type_format('". $this->data_type[$i] ."','". $this->data_format[$i] ."');\n";
if($this->objLayer[$i]->layer_name == $layer_name|| $this->objLayer[$i]->layer_pos == 0){
if($parent){
echo "parent.";
- $this->objLayer[$i]->layer_name . "','".
+ print ("wms_add_layer('".
+ $this->objLayer[$i]->layer_name . "','".
@@ -852,21 +1086,21 @@
if($parent){
echo "parent.";
+ print("wms_addSRS('".
if($parent){
echo "parent.";
+ print("layer_addEpsg('".
@@ -875,15 +1109,15 @@
* writeObjInDB
- * this function exports the information from the xml to the mapbender database
+ * this function exports the information from the xml to the mapbender database
function writeObjInDB($gui_id){
global $con;
@@ -891,7 +1125,7 @@
$this->checkObj();
db_begin();
# TABLE wms
$sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, ";
$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
@@ -912,25 +1146,25 @@
if(!$res){
db_rollback();
$myWMS = db_insert_id($con,'wms', 'wms_id');
# TABLE layer and gui_layer
$this->insertLayer($i,$myWMS,$gui_id);
$this->insertGuiLayer($i,$myWMS,$gui_id);
#TABLE wms_srs
- $this->insertSRS($myWMS);
- # TABLE wms_format
- $this->insertFormat($myWMS);
+ $this->insertSRS($myWMS);
+ # TABLE wms_format
+ $this->insertFormat($myWMS);
# TABLE gui_wms
$sql ="SELECT MAX(gui_wms_position) AS pos FROM gui_wms WHERE fkey_gui_id = $1";
$v = array($gui_id);
$t = array('s');
@@ -938,7 +1172,7 @@
if(db_result($res, 0,"pos") > -1){
$position = db_result($res, 0,"pos") + 1;
} else{ $position = 0; }
$sql ="INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, ";
$sql .= "gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg)";
$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7)";
@@ -948,10 +1182,10 @@
$t = array('s','i','i','s','s','s','s');
$res = db_prep_query($sql,$v,$t);
if(!$res){
- db_rollback();
+ db_rollback();
db_commit();
#Changes JW
$this->wms_id = $myWMS;
@@ -977,19 +1211,19 @@
$t = array('i','i','s','s','s','i','i','i','s','s','s');
if(!$res){
- db_rollback();
+ db_rollback();
else {
- # save the id of each layer: set param2 true
+ # save the id of each layer: set param2 true
$this->objLayer[$i]->db_id = db_insert_id($con, 'layer','layer_id');
$this->insertLayerEPSG($i);
# TABLE layer_style for each layer
$this->insertLayerStyle($i);
# insert Keywords
- $this->insertLayerKeyword($i);
+ $this->insertLayerKeyword($i);
function updateLayer($i,$myWMS){
@@ -998,14 +1232,14 @@
$t = array('i','s');
if($row = db_fetch_array($res)){
- $l_id = $row['layer_id'];
+ $l_id = $row['layer_id'];
else{
db_rollback();
$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name);
- return;
+ return;
$sql = "UPDATE layer SET ";
$sql .= "layer_pos = $1, ";
$sql .= "layer_parent = $2, ";
@@ -1017,7 +1251,7 @@
$sql .= "layer_metadataurl = $8, ";
$sql .= "layer_abstract = $9 ";
$sql .= "WHERE layer_id = $10";
if($this->objLayer[$i]->layer_id != null){
$tmpPos = $this->objLayer[$i]->layer_id;
@@ -1031,7 +1265,7 @@
$this->objLayer[$i]->layer_title,
$this->objLayer[$i]->layer_queryable,$this->objLayer[$i]->layer_minscale,
$this->objLayer[$i]->layer_maxscale,$this->objLayer[$i]->layer_dataurl_href,
- $this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract, $l_id
+ $this->objLayer[$i]->layer_metadataurl,$this->objLayer[$i]->layer_abstract, $l_id
$t = array('i','s','s','i','i','i','s','s','s','i');
@@ -1040,20 +1274,20 @@
$sql .= "layer_title = $1, ";
$sql .= "layer_abstract = $2 ";
$sql .= "WHERE layer_id = $3";
$v = array($this->objLayer[$i]->layer_title,$this->objLayer[$i]->layer_abstract, $l_id);
$t = array('s','s','i');
if(!$res){
- db_rollback();
+ db_rollback();
else {
$this->objLayer[$i]->db_id = $l_id;
if($this->overwrite == true){
@@ -1063,7 +1297,7 @@
function insertGuiLayer($i,$myWMS,$gui_id){
# table gui_layer
$sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, ";
$sql .= "gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, ";
$sql .= "gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale, gui_layer_priority, gui_layer_style) ";
@@ -1080,12 +1314,12 @@
#$e = new mb_exception("name des insert styles und fkey_layer_id: ".$layer_style_name." --- ".$this->objLayer[$i]->db_id);
if(!$res){
- db_rollback();
+ db_rollback();
function appendGuiLayer($i,$myWMS,$gui_id){
# table gui_layer
@@ -1101,19 +1335,19 @@
$t = array('s','i','i','i','i','i','i','i','i','i','i','s');
if(!$res){
- db_rollback();
+ db_rollback();
function insertSRS($myWMS){
for($i=0; $i<count($this->wms_srs);$i++){
- $sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) values($1,$2)";
+ $sql ="INSERT INTO wms_srs (fkey_wms_id, wms_srs) values($1,$2)";
$v = array($myWMS,mb_strtoupper($this->wms_srs[$i]));
- $t = array('i','s');
+ $t = array('i','s');
if(!$res){
- db_rollback();
+ db_rollback();
function insertFormat($myWMS){
@@ -1123,9 +1357,9 @@
$t = array('i','s','s');
if(!$res){
- db_rollback();
+ db_rollback();
function insertLayerEPSG($i){
$sql = "DELETE FROM layer_epsg WHERE fkey_layer_id = $1";
@@ -1138,11 +1372,11 @@
$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_epsg[$j][epsg],
$this->objLayer[$i]->layer_epsg[$j][minx],$this->objLayer[$i]->layer_epsg[$j][miny],
$this->objLayer[$i]->layer_epsg[$j][maxx],$this->objLayer[$i]->layer_epsg[$j][maxy]
$t = array('i','s','d','d','d','d');
if(!$res){
- db_rollback();
+ db_rollback();
@@ -1156,12 +1390,12 @@
$sql .= "VALUES($1,$2,$3,$4,$5)";
$v = array($this->objLayer[$i]->db_id,$this->objLayer[$i]->layer_style[$j]["name"],
$this->objLayer[$i]->layer_style[$j]["title"],$this->objLayer[$i]->layer_style[$j]["legendurl"],
- $this->objLayer[$i]->layer_style[$j]["legendurlformat"]
+ $this->objLayer[$i]->layer_style[$j]["legendurlformat"]
$t = array('i','s','s','s','s');
if(!$res){
- db_rollback();
+ db_rollback();
@@ -1171,13 +1405,13 @@
$v = array($this->objLayer[$i]->db_id);
$t = array('i');
// var_dump($this);
$k = $this->objLayer[$i]->layer_keyword;
// var_dump($k);
for($j=0; $j<count($k); $j++){
$keyword_id = "";
while ($keyword_id == "") {
$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
$v = array($k[$j]);
@@ -1186,7 +1420,7 @@
//print_r($row);
if ($row) {
- $keyword_id = $row["keyword_id"];
+ $keyword_id = $row["keyword_id"];
else {
$sql_insertKeyword = "INSERT INTO keyword (keyword)";
@@ -1195,7 +1429,7 @@
$t1 = array('s');
$res_insertKeyword = db_prep_query($sql_insertKeyword,$v1,$t1);
if(!$res_insertKeyword){
- db_rollback();
+ db_rollback();
@@ -1214,7 +1448,7 @@
$t1 = array('i','i');
$res1 = db_prep_query($sql1,$v1,$t1);
if(!$res1){
- db_rollback();
+ db_rollback();
@@ -1222,7 +1456,7 @@
function updateObjInDB($myWMS){
db_begin();
$sql = "UPDATE wms SET ";
$sql .= "wms_version = $1 ,";
$sql .= "wms_getcapabilities = $2 ,";
@@ -1238,18 +1472,18 @@
$sql .= "wms_userstyle = $12, ";
$sql .= "wms_remotewfs = $13 ";
$sql .= " WHERE wms_id = $14";
$v = array($this->wms_version,$this->wms_getcapabilities,
$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
if(!$res){
- db_rollback();
+ db_rollback();
$sql .= "wms_title = $1 ,";
@@ -1268,7 +1502,7 @@
$sql .= "contactfacsimiletelephone = $14, ";
$sql .= "contactelectronicmailaddress = $15 ";
$sql .= " WHERE wms_id = $16";
$v = array($this->wms_title,$this->wms_abstract,$this->fees,$this->accessconstraints,
$this->contactperson,$this->contactposition,$this->contactorganization,$this->address,
$this->city,$this->stateorprovince,$this->postcode,$this->country,$this->contactvoicetelephone,
@@ -1276,33 +1510,33 @@
$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i');
if(!$res){
- db_rollback();
+ db_rollback();
# delete and refill srs and formats
$sql = "DELETE FROM wms_srs WHERE fkey_wms_id = $1 ";
$v = array($myWMS);
$t = array('i');
if(!$res){
- db_rollback();
+ db_rollback();
$sql = "DELETE FROM wms_format WHERE fkey_wms_id = $1 ";
$v = array($myWMS);
$t = array('i');
if(!$res){
- db_rollback();
+ db_rollback();
# update gui_wms
$this->update_gui_wms($myWMS);
- # update TABLE layer
+ # update TABLE layer
# delete all layer which are outdated
$v = array($myWMS);
$t = array('i');
@@ -1312,16 +1546,16 @@
if($i>0){$sql .= ',';}
$sql .= "$".$c;
array_push($v,$this->objLayer[$i]->layer_name);
- array_push($t,'s');
+ array_push($t,'s');
$c++;
$sql .= ")";
if(!$res){
- db_rollback();
+ db_rollback();
# update or insert?
$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1";
$v = array($myWMS);
@@ -1331,7 +1565,7 @@
while($row = db_fetch_array($res)){
array_push($exLayer,$row["layer_name"]);
$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1";
$v = array($myWMS);
$t = array('i');
@@ -1340,7 +1574,7 @@
array_push($exGui,$row["fkey_gui_id"]);
if(in_array($this->objLayer[$i]->layer_name,$exLayer)){
//echo "<br>update: ".$this->objLayer[$i]->layer_name;
@@ -1358,7 +1592,7 @@
db_commit();
- return;
+ return;
function updateGuiLayer($i,$myWMS,$gui_id){
$sql = "SELECT layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_name = $2";
@@ -1366,18 +1600,18 @@
else{
db_rollback();
$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name. " in gui: ".$gui_id);
- return;
+ return;
$sql = "SELECT * FROM gui_layer WHERE fkey_layer_id = $1 and fkey_gui_id = $2";
$v = array($l_id,$gui_id);
- $res = db_prep_query($sql,$v,$t);
+ $res = db_prep_query($sql,$v,$t);
if($this->objLayer[$i]->layer_queryable == 0){
$sql1 = "UPDATE gui_layer set gui_layer_queryable = 0, gui_layer_querylayer = 0 ";
@@ -1386,7 +1620,7 @@
$res1 = db_prep_query($sql1,$v,$t);
if(!$res1){
db_rollback();
@@ -1397,7 +1631,7 @@
if(!$res1){
db_rollback();
@@ -1418,7 +1652,7 @@
if(!$res1){db_rollback();
function update_gui_wms($myWMS){
@@ -1428,14 +1662,14 @@
$t = array('i');
$cnt = 0;
- while($row = db_fetch_array($res)){
+ while($row = db_fetch_array($res)){
unset($mySubmit);
$myGUI[$cnt] = $row["fkey_gui_id"];
$sql = "UPDATE gui_wms SET ";
$v = array();
$t = array();
- $paramCount = 0;
+ $paramCount = 0;
for($i=0; $i<count($this->data_type); $i++){
# gui_wms_mapformat
@@ -1474,7 +1708,7 @@
array_push($t, "s");
$mySubmit = true;
# gui_wms_epsg
for($j=0; $j<count($this->objLayer[0]->layer_epsg);$j++){
if($this->objLayer[0]->layer_epsg[$j][epsg] == mb_strtoupper($row["gui_wms_epsg"])){
@@ -1501,24 +1735,24 @@
if($mySubmit){
if(!$res){
- db_rollback();
+ db_rollback();
echo "<pre>".$sql."</pre><br> <br><p>";
- echo db_error();
+ echo db_error();
echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
$e = new mb_exception("class_wms.php: transaction: Transaction aborted, rollback.");
$cnt++;
function getVersion() {
return $this->wms_version;
function getCapabilities() {
return $this->wms_getcapabilities;
function getCapabilitiesDoc() {
return $this->wms_getcapabilities_doc;
@@ -1526,18 +1760,18 @@
* creatObjfromDB
function createObjFromDB($gui_id,$wms_id){
$sql = "Select * from gui_wms where fkey_wms_id = $1 AND fkey_gui_id = $2";
$v = array($wms_id,$gui_id);
$count=0;
#$res_count=db_num_rows($res);
$this->gui_wms_mapformat=$row["gui_wms_mapformat"];
$this->gui_wms_featureinfoformat=$row["gui_wms_featureinfoformat"];
@@ -1546,7 +1780,7 @@
$this->gui_wms_visible = $row["gui_wms_visible"];
$this->gui_wms_opacity = $row["gui_wms_opacity"];
$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
$sql = "Select * from wms where wms_id = $1 ";
$v = array($wms_id);
$t = array('i');
@@ -1571,7 +1805,7 @@
$this->wms_getcapabilities = $row2["wms_getcapabilities"];
$this->wms_getfeatureinfo = $row2["wms_getfeatureinfo"];
$this->wms_getlegendurl = $row2["wms_getlegendurl"];
// TO DO: Capabilities document needs to
// be encoded to the original encoding
// if different from the database encoding
@@ -1581,24 +1815,24 @@
$this->wms_userlayer = $row2["wms_userlayer"];
$this->wms_userstyle = $row2["wms_userstyle"];
$this->wms_remotewfs = $row2["wms_remotewfs"];
$count_wms++;
### formats
$sql = "SELECT * FROM wms_format WHERE fkey_wms_id = $1 ";
- $t = array('i');
+ $t = array('i');
$res_wms = db_prep_query($sql,$v,$t);
- $count_format=0;
- while($row3 = db_fetch_array($res_wms)){
+ $count_format=0;
+ while($row3 = db_fetch_array($res_wms)){
$this->data_type[$count_format] = $row3["data_type"];
$this->data_format[$count_format] = $row3["data_format"];
$count_format++;
$count++;
#layer
$sql = "Select * from gui_layer where gui_layer_wms_id = $1 AND fkey_gui_id = $2 ";
$sql .= " AND gui_layer_status = 1 ORDER BY gui_layer_priority;";
@@ -1606,9 +1840,9 @@
$count=0;
- $layer_id = $row["fkey_layer_id"];
+ $layer_id = $row["fkey_layer_id"];
$sql = "Select * from layer where layer_id = $1";
$v = array($layer_id);
$t = array('i');
@@ -1619,10 +1853,10 @@
$layer_cnt=count($this->objLayer)-1;
$this->objLayer[$layer_cnt]->layer_uid = $layer_id;
$this->objLayer[$layer_cnt]->layer_name =$row2["layer_name"];
- $this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
+ $this->objLayer[$layer_cnt]->layer_title =$row2["layer_title"];
$this->objLayer[$layer_cnt]->layer_dataurl_href =$row2["layer_dataurl"];
$this->objLayer[$layer_cnt]->layer_metadataurl =$row2["layer_metadataurl"];
- $this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
+ $this->objLayer[$layer_cnt]->layer_pos =$row2["layer_pos"];
$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_pos"];
$this->objLayer[$layer_cnt]->layer_queryable =$row2["layer_queryable"];
$this->objLayer[$layer_cnt]->layer_minscale =$row2["layer_minscale"];
@@ -1639,12 +1873,12 @@
$this->objLayer[$layer_cnt]->gui_layer_maxscale = $row["gui_layer_maxscale"];
$this->objLayer[$layer_cnt]->gui_layer_style = $row["gui_layer_style"];
$this->objLayer[$layer_cnt]->gui_layer_wfs_featuretype = $row["gui_layer_wfs_featuretype"];
$sql = "Select * from layer_epsg where fkey_layer_id = $1 ORDER BY fkey_layer_id";
$t = array('i');
$res_layer_epsg = db_prep_query($sql,$v,$t);
$count_layer_epsg=0;
while($row2 = db_fetch_array($res_layer_epsg)){
$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["epsg"]=$row2["epsg"];
@@ -1654,7 +1888,7 @@
$this->objLayer[$layer_cnt]->layer_epsg[$count_layer_epsg]["maxy"]=$row2["maxy"];
$count_layer_epsg++;
### handle styles
$sql = "SELECT * FROM layer_style WHERE fkey_layer_id = $1 ";
@@ -1684,7 +1918,7 @@
/** end createObjfromDB **/
* creatObjfromDBNoGui
@@ -1839,14 +2073,14 @@
* function checkObjExistsInDB()
* this function checks wether the onlineresource already exists in the database.
function checkObjExistsInDB(){
$sql = "Select * from wms where wms_getcapabilities = $1";
$v = array($this->wms_getcapabilities);
$t = array('s');
- $res_count= db_num_rows($res);
+ $res_count= db_num_rows($res);
$wms_id=0;
if($res_count>0){
$count=0;
@@ -1857,7 +2091,7 @@
return $wms_id;
function displayDBInformation(){
echo $this->wms_getcapabilities;
$sql="Select * from wms where wms_getcapabilities = $1";
@@ -1878,15 +2112,15 @@
$count++;
echo "----<br> wms_id: ".$wms_id."<br>";
$sql = "Select * from gui_wms where fkey_wms_id = $1";
$t = array('i');
echo "sql: ".$sql." <br>---------<br>";
echo "result count: ".$res_count." <br>---------<br>";
$count=0;
echo "gui_wms_featureinfoformat: " . $row["gui_wms_featureinfoformat"]." <br>";
@@ -1894,7 +2128,7 @@
echo "gui_wms_epsg: " . $row["gui_wms_epsg"]. " <br>";
$count++;
#db_close($connect);
@@ -1902,12 +2136,47 @@
if($this->wms_getcapabilities == '' || $this->wms_getmap == '' ){
echo "<br>Missing parameters: <br>";
$this->displayWMS();
- echo "<br> Data not commited<br>";
+ print_r($this);
+ echo "<br> Data not committed<br>";
die();
+ * Selects all WMS of the current user from the database.
+ * Then it creates the corresponding WMS object and returns
+ * these objects as an array.
+ * @return wms[]
+ * @param $appId String
+ public static function selectMyWmsByApplication ($appId) {
+ // check if user is permitted to access the application
+ $currentUser = new User($_SESSION["mb_user_id"]);
+ $appArray = $currentUser->getApplicationsByPermission(false);
+ if (!in_array($appId, $appArray)) {
+ $e = new mb_warning("class_wms.php: selectMyWmsByApplication(): User '" . $currentUser . "' is not allowed to acces application '" . $appId . "'.");
+ return array();
+ // get WMS of this application
+ $sql = "SELECT fkey_wms_id FROM gui_wms WHERE " .
+ "fkey_gui_id = $1 ORDER BY gui_wms_position";
+ $v = array($appId);
+ $t = array('s');
+ // instantiate PHP objects and store in array
+ $wmsArray = array();
+ while ($row = db_fetch_array($res)) {
+ $currentWms = new wms();
+ $currentWms->createObjFromDB($appId, $row["fkey_wms_id"]);
+ array_push($wmsArray, $currentWms);
+ return $wmsArray;
-class layer extends wms {
+class layer extends wms {
var $layer_id;
var $layer_parent;
var $layer_name;
@@ -1916,25 +2185,31 @@
var $layer_pos;
var $layer_queryable;
var $layer_minscale;
- var $layer_maxscale;
+ var $layer_maxscale;
var $layer_dataurl_href;
var $layer_metadataurl;
var $layer_keyword = array();
var $layer_epsg = array();
var $layer_style = array();
var $gui_layer_wms_id;
var $gui_layer_status = 1;
var $gui_layer_selectable = 1;
var $gui_layer_visible = 0;
var $gui_layer_queryable = 0;
var $gui_layer_querylayer = 0;
- var $gui_layer_style = NULL;
+ var $gui_layer_style = NULL;
function layer($id,$parent){
$this->layer_id = $id;
- $this->layer_parent = $parent;
- //var_dump($this);
+ $this->layer_parent = $parent;
+ //var_dump($this);
+ $e = new mb_exception("TITLE: " . $this->layer_title);
+ return $this->layer_title;
Modified: branches/2.5/http/javascripts/map.js
--- branches/2.5/http/javascripts/map.js 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/javascripts/map.js 2009-01-08 14:47:47 UTC (rev 3417)
@@ -465,6 +465,45 @@
return true;
+ * Sets the list of layers, styles and querylayers for a specified WMS
+ this.restateLayers = function(wms_id){
+ for (var i = 0; i < this.wms.length; i++) {
+ if (this.wms[i].wms_id == wms_id) {
+ var currentWms = this.wms[i];
+ var cnt_layers = 0;
+ var cnt_querylayers = 0;
+ var layers = "";
+ var styles = "";
+ var querylayers = "";
+ for (var ii = 0; ii < currentWms.objLayer.length; ii++) {
+ var currentLayer = currentWms.objLayer[ii];
+ if (currentLayer.gui_layer_visible == 1 && !currentLayer.has_childs) {
+ if (cnt_layers > 0) {
+ layers += ",";
+ styles += ",";
+ layers += currentLayer.layer_name;
+ styles += "";
+ cnt_layers++;
+ if (currentLayer.gui_layer_querylayer == 1 && !currentLayer.has_childs) {
+ if (cnt_querylayers > 0) {
+ querylayers += ",";
+ querylayers += currentLayer.layer_name;
+ cnt_querylayers++;
+ this.layers[i] = layers;
+ this.querylayers[i] = querylayers;
+ this.styles[i] = styles;
+// this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
eventAfterMapObjectConstruction.trigger();
Modified: branches/2.5/http/javascripts/mod_initWmc.php
--- branches/2.5/http/javascripts/mod_initWmc.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/javascripts/mod_initWmc.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -61,43 +61,36 @@
//WMC
if (isset($wmc_id)) {
- if ($adm->getWmcById($wmc_id) != false) {
+ $myInitWmc = new wmc();
+ $success = $myInitWmc->createFromDb($wmc_id);
+ if ($success) {
- $valid_wmcs = $adm->getWmcByOwner($user);
- if (in_array($wmc_id, $valid_wmcs)) {
- echo "var wmc_id = false;";
- echo "wmc_id = '".$wmc_id."';";
- $wmc = new wmc();
- $wmc->createObjFromWMC_id($wmc_id);
- $js_wmc .= $wmc->createJsObjFromWMC("", $e_target[0], $action);
+ $js_wmc = implode("", $myInitWmc->toJavaScript());
+ new mb_exception("WMC JS: " . $js_wmc);
+ if (!empty($x) && !empty($y) && !empty($icon)) {
- if (!empty($x) && !empty($y) && !empty($icon)) {
- $js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
+ $js_kml .= "var myPoint = realToMap('".$e_target[0]."', new Point(".$x.",".$y."));\n";
- // 7 is half the width of pin.png
- $js_kml .= "myPoint.x -= 7;";
- // 20 is the height of pin.png
- $js_kml .= "myPoint.y -= 20;";
+ // 7 is half the width of pin.png
+ $js_kml .= "myPoint.x -= 7;";
+ // 20 is the height of pin.png
+ $js_kml .= "myPoint.y -= 20;";
- $js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
- $js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
- $js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
- if ($url) {
- $js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
- $js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
- $js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
- $js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
- $js_kml .= "meeting_img.style.position = 'absolute';";
- $js_kml .= "meeting_img.style.top = myPoint.y;";
- $js_kml .= "meeting_img.style.left = myPoint.x;";
- $js_kml .= "mb_registerPanSubElement('meeting_logo');";
+ $js_kml .= "var meetingPointLogoStyle = {'position':'absolute', 'top':0, 'left':0, 'z-index':100, 'font-size':'10px'};\n";
+ $js_kml .= "meetingPointLogoTag = new DivTag('meeting_logo', '".$e_target[0]."', meetingPointLogoStyle);\n";
+ $js_img .= "<img id='meeting_img' border='0' src='".$icon."' title='".$alt."'>";
+ if ($url) {
+ $js_img = "<a href='".$url."' target='_blank'>" . $js_img . "</a>";
+ $js_kml .= "var meetingPointLogoText = \"" . $js_img . "\";\n";
+ $js_kml .= "meetingPointLogoTag.write(meetingPointLogoText);\n";
+ $js_kml .= "var meeting_img = window.frames['".$e_target[0]."'].document.getElementById('meeting_img');";
+ $js_kml .= "meeting_img.style.position = 'absolute';";
+ $js_kml .= "meeting_img.style.top = myPoint.y;";
+ $js_kml .= "meeting_img.style.left = myPoint.x;";
+ $js_kml .= "mb_registerPanSubElement('meeting_logo');";
- else {
- $js_error .= "alert('".$adm->getUserNameByUserId($user)." is not allowed to access WMC ".$wmc_id.". Default GUI will be loaded instead.');";
else {
$js_error .= "alert('WMC id ".$wmc_id." is not valid. Default GUI will be loaded instead.');";
@@ -111,7 +104,6 @@
echo "function addFlag() {";
echo $js_kml;
-echo $js_error;
echo "}";
Added: branches/2.5/http/javascripts/mod_loadwmc.js
--- branches/2.5/http/javascripts/mod_loadwmc.js (rev 0)
+++ branches/2.5/http/javascripts/mod_loadwmc.js 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,284 @@
+// checks if element var loadFromSession exists
+try {
+ if (loadFromSession) {
+catch(e) {
+ loadFromSession = 0;
+if (loadFromSession) {
+ // function load_wmc_session() is generated by mod_loadwmc.php
+ mb_registerInitFunctions('load_wmc_session()');
+var wmcPopup = null;
+var wmcDisplayPopup = null;
+var serverSideFileName = "../php/mod_loadwmc_server.php";
+function mod_importWmc(id){
+ alert(id);
+ * is called when the load WMC button is pressed
+function mod_loadwmc(){
+ var initialHtml = "<div>" +
+ "<h2 style='font-family: Arial, Helvetica, sans-serif; color: #808080;'><font align='left' color='#000000'>load WMC from list</font></h2>" +
+ "<table id='loadwmc_list' width='90%' style='font-family: Arial, Helvetica, sans-serif;font-size : 12px;color: #808080;' border='1' cellpadding='3' rules='rows'>" +
+ "<tr style='background-color:#F0F0F0;' width='80px'>" +
+ "<td><b>WMC name</b></td>" +
+ "<td><b>last update</b></td>" +
+ "<td colspan=5></td>" +
+ "</tr>" +
+ "</table>" +
+ "</div>";
+ // creates a new pop up (if it doesn't already exist)
+ // the pop up allows you to load, append, merge,
+ // display and delete WMC documents
+ if (wmcPopup === null) {
+ wmcPopup = new mb_popup({
+ title:"Load WMC",
+ width:500,
+ height:600,
+ top:100,
+ left:100,
+ html:initialHtml
+ // display the pop up
+ if (!wmcPopup.isVisible()) {
+ wmcPopup.setHtml(initialHtml);
+ wmcPopup.show();
+ // get WMC data from server
+ var queryObj = {command:"getWmc"};
+ $.post(serverSideFileName, {queryObj:$.toJSON(queryObj)}, function(json, status) {
+ var loadWmcDataError = false;
+ if (json && status == "success") {
+ loadWmcDataError = displayWmcList(json, status);
+ if (loadWmcDataError) {
+ alert("An error has occured. WMC list could not be loaded.");
+ * Displays available WMC documents
+function displayWmcList (json, status) {
+ var wmcObj = eval("(" + json + ")");
+ // for each wmc, add a row to the table
+ for (var i=0; i < wmcObj.wmc.length; i++) {
+ (function () {
+ var currentId = wmcObj.wmc[i].id;
+ var $tr = $("<tr onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'></tr>").appendTo($("#loadwmc_list"));
+ $tr.hide();
+ var $td;
+ $tr.append($("<td>" + wmcObj.wmc[i].title + "</td>"));
+ $tr.append($("<td>" + wmcObj.wmc[i].timestamp + "</td>"));
+ // Load WMC
+ $loadWmc = $("<img src='../img/button_gray/wmc_load.png' title='load this WMC'>");
+ $loadWmc.click(function() {
+ var queryObj = {command:"loadWmc", parameters:{id:currentId}};
+ $.post(serverSideFileName, {queryObj: $.toJSON(queryObj)}, function (json, status) {
+ var loadWmcError = false;
+ var resultObj = eval("(" + json + ")");
+ try {
+ if (resultObj.javascript && typeof(resultObj.javascript) == "object") {
+ for (var j=0; j < resultObj.javascript.length; j++) {
+// console.log("Statement: %s", resultObj.javascript[j]);
+ eval(resultObj.javascript[j]);
+ catch (e) {
+ alert(e);
+ loadWmcError = true;
+ if (loadWmcError) {
+ alert("An error has occured while loading this WMC.");
+ else {
+ // close the Pop up
+ if (wmcDisplayPopup !== null && wmcDisplayPopup.isVisible()) {
+ wmcDisplayPopup.hide();
+ wmcPopup.hide();
+ alert("WMC has been loaded successfully.");
+ $td = $("<td></td>").append($loadWmc);
+ $tr.append($td);
+ // Merge WMC
+ $mergeWmc = $("<img src='../img/button_gray/wmc_merge.png' title='merge WMC'>");
+ $mergeWmc.click(function() {
+ var extensionDataString = null;
+ if (currentWmcExtensionData !== null) {
+ extensionDataString = currentWmcExtensionData;
+ var queryObj = {
+ command:"mergeWmc",
+ parameters:{
+ id:currentId,
+ extensionData:extensionDataString,
+ mapObject:mb_mapObj,
+ generalTitle:"currentState"
+ try {
+ catch (e) {
+ alert(e);
+ else {
+ wmcPopup.hide();
+ $td = $("<td></td>").append($mergeWmc);
+ $tr.append($td);
+ // Append WMC
+ $appendWmc = $("<img src='../img/button_gray/wmc_append.png' title='append WMC'>");
+ $appendWmc.click(function() {
+ var queryObj = {
+ command:"appendWmc",
+ parameters:{
+ id:currentId,
+ try {
+ catch (e) {
+ alert(e);
+ else {
+ wmcPopup.hide();
+ $td = $("<td></td>").append($appendWmc);
+ $tr.append($td);
+ // Display WMC
+ $displayWmc = $("<img src='../img/button_gray/wmc_xml.png' title='display WMC XML'>");
+ $displayWmc.click(function() {
+ // create Popup
+ if (wmcDisplayPopup === null) {
+ wmcDisplayPopup = new mb_popup({
+ title:"WMC Document",
+ width:600,
+ height:500,
+ top:100,
+ left:300,
+ url:"../javascripts/mod_displayWmc.php?wmc_id=" + currentId
+ // set correct URL
+ if (wmcDisplayPopup.isVisible()) {
+ wmcDisplayPopup.setUrl("../javascripts/mod_displayWmc.php?wmc_id=" + currentId);
+ wmcDisplayPopup.show();
+ $td = $("<td></td>").append($displayWmc);
+ $tr.append($td);
+ $deleteWmc = $("<img src='../img/button_gray/del.png' title='delete this WMC'>");
+ $deleteWmc.click(function() {
+ var queryObj = {command:"deleteWmc", parameters:{id:currentId}};
+ var deleteWmcError = false;
+ try {
+ if (resultObj.success) {
+ $tr.remove();
+ catch (e) {
+ deleteWmcError = true;
+ if (deleteWmcError) {
+ alert("An error has occured while deleting this WMC.");
+ $td = $("<td></td>").append($deleteWmc);
+ $tr.append($td);
+ $tr.fadeIn("slow");
Modified: branches/2.5/http/javascripts/mod_loadwmc.php
--- branches/2.5/http/javascripts/mod_loadwmc.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/javascripts/mod_loadwmc.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -22,77 +22,77 @@
include(dirname(__FILE__) . "/../include/dyn_js.php");
-echo "mod_loadwmc_target = '".$e_target[0]."';";
+function createJs ($mergeWms) {
+ $jsString = "";
+ $wmc = new wmc();
+ if (!isset($_SESSION['mb_wmc'])) {
+ $e = new mb_notice("wmc not set, generating from app: " . $_SESSION["mb_user_gui"]);
+ $wmc->createFromApplication($_SESSION["mb_user_gui"]);
+ $_SESSION["mb_wmc"] = $wmc->toXml();
+// $e = new mb_exception("initial WMC: " . $_SESSION["mb_wmc"]);
-// this may be added at a later stage
-if ($new_wmc == 1) {
- include(dirname(__FILE__) . "/../generate_defaultWmc.php");
- $startup = true;
- $e = new mb_notice("loadwmc: new wmc");
-else {
- $startup = false;
- $e = new mb_notice("loadwmc: old wmc");
-if ($gui_changed == 0) {
- if ($_REQUEST['portal_services']) {
- $e = new mb_notice("loadwmc: merging layers");
- include(dirname(__FILE__) . "/../merge_layers.php");
- if ($_SESSION['GML']) {
- $e = new mb_notice("loadwmc: merging bbox");
- include(dirname(__FILE__) . "/../merge_bbox.php");
-function load_wmc_session() {
- <?php
- if (isset($_SESSION['mb_wmc'])) {
- $wmc = new wmc();
- if ($wmc->createObjFromWMC_xml($_SESSION['mb_wmc'])) {
- $js = "";
- if ($_SESSION['layer_preview']) {
-// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: layer preview');";
- $js = $wmc->createJsObjFromWMC("", $e_target, "load");
+ if (isset($_SESSION['mb_wmc'])) {
+ $e = new mb_exception("merging with WMC.");
+ if ($wmc->createFromXml($_SESSION['mb_wmc'])) {
+ if ($mergeWms) {
+ for ($i = 0; $i < count($_SESSION["wms"]); $i++) {
+ $currentWms->createObjFromXML($_SESSION["wms"][$i]);
- else if ($startup == true) {
-// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load new wmc');";
- $js = $wmc->createJsObjFromWMC("", $e_target, "merge");
- $startup = false;
- else {
-// echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: load old wmc');";
- echo $js;
+ $wmc->mergeWmsArray($wmsArray);
+ $_SESSION["command"] = "";
+ $_SESSION["wms"] = array();
- else {
- echo "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
+ $javaScriptArray = array();
+ $javaScriptArray = $wmc->toJavaScript();
+ $jsString .= implode("", $javaScriptArray);
else {
- echo "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
+ $jsString .= "var e = new Mb_notice('mod_loadwmc: load_wmc_session: error parsing wmc');";
+ else {
+ $e = new mb_notice("not merging WMC");
+ $jsString .= "var e = new Mb_warning('mod_loadwmc: load_wmc_session: no wmc set!');";
+ return $jsString;
-try {if (loadFromSession) {}}catch(e) {loadFromSession = 0;}
+// Creates the function load_wmc_session.
+// This function loads a WMC from the session, if the element var
+// "loadFromSession" is set to true.
+function load_wmc_session() {
+<?php
+if ($_SESSION["command"] && $_SESSION["command"] == "ADDWMS") {
+ $e = new mb_notice("merging with WMS in Session...");
+ echo createJs(true);
+else {
+ $e = new mb_notice("NOT merging with WMS in Session...");
+ echo createJs(false);
-if (loadFromSession) {
- mb_registerInitFunctions('load_wmc_session()');
+<?php
+if ($e_src) {
+ sprintf("var mod_loadwmc_img = new Image();
+ mod_loadwmc_img.src = '%s'", $e_src);
-var mod_loadwmc_img = new Image(); mod_loadwmc_img.src = "<?php echo $e_src; ?>";
-//var mod_loadwmc_img_over = new Image(); mod_loadwmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-function mod_importWmc(id){
- alert(id);
-function mod_loadwmc(obj){
- windowWmc = window.open("../php/mb_listWMCs.php?<?php echo SID;?>","displayWmc","width=500, height=600, scrollbars=yes, dependent=yes");
-function mod_loadwmc_init(obj){
- //document.getElementById("loadwmc").src = mod_zoom1_img_over.src;
\ No newline at end of file
+// Creates a pop up with a dialogue to load, view or delete WMC documents
+include("mod_loadwmc.js");
Added: branches/2.5/http/javascripts/mod_loadwmc_list.php
--- branches/2.5/http/javascripts/mod_loadwmc_list.php (rev 0)
+++ branches/2.5/http/javascripts/mod_loadwmc_list.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,3 @@
+<?php
+ echo "fisch";
Modified: branches/2.5/http/javascripts/mod_savewmc.php
--- branches/2.5/http/javascripts/mod_savewmc.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/javascripts/mod_savewmc.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -24,7 +24,9 @@
function setOnUnload() {
if (ie) {
- document.getElementsByTagName('body')[0].onunload = function() {var x = new Function ("", "mod_savewmc_session()"); x(); };
+ document.getElementsByTagName('body')[0].onunload = function() {
+ var x = new Function ("", "mod_savewmc_session()"); x();
else {
document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
@@ -34,11 +36,18 @@
try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
if (saveInSession == 1) {
- mb_registerInitFunctions('setOnUnload()');
+ eventAfterMapRequest.register(function () {
+ mod_savewmc_session();
+// mb_registerInitFunctions('setOnUnload()');
-var mod_savewmc_img = new Image();
-mod_savewmc_img.src = "<?php echo $e_src; ?>";
+<?php
+if ($e_src) {
+ sprintf("var mod_savewmc_img = new Image();
+ mod_savewmc_img.src = '%s';", $e_src);
//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
function mod_savewmc_session(){
@@ -62,7 +71,12 @@
if (storeInSession) {
- $.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
+ $.ajaxSetup({async:false});
- $.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":storeInSession, "generalTitle":generalTitle, "extensionData":extensionDataString, "mapObject":$.toJSON(mb_mapObj[ind])}, callbackFunction);
+ $.post("../php/mod_savewmc_server.php", {
+ "saveInSession":storeInSession,
+ "generalTitle":generalTitle,
+ "extensionData":extensionDataString,
+ "mapObject":$.toJSON(mb_mapObj)
+ }, callbackFunction);
Added: branches/2.5/http/php/mod_loadwmc_server.php
--- branches/2.5/http/php/mod_loadwmc_server.php (rev 0)
+++ branches/2.5/http/php/mod_loadwmc_server.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,174 @@
+<?php
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+ * encodes and delivers the data
+ * @param object the un-encoded object
+function sendOutput($out){
+ global $json;
+ $output = $json->encode($out);
+ header("Content-Type: text/x-json");
+ echo $output;
+ * Get all available WMC documents from the database
+ * @return mixed[] an array of wmcs
+ * (wmc = assoc. array of "id", "title", "timestamp")
+function getWmc(){
+ global $con;
+ global $userId;
+ $wmcArray = array();
+ // get WMC ids
+ $currentUser = new User($userId);
+ $wmcIdArray = $currentUser->getWmcByOwner();
+ // get WMC data
+ $v = array();
+ $t = array();
+ $wmcIdList = "";
+ for ($i = 0; $i < count($wmcIdArray); $i++) {
+ if ($i > 0) {
+ $wmcIdList .= ",";
+ $wmcIdList .= "$".($i+1);
+ array_push($v, $wmcIdArray[$i]);
+ array_push($t, 's');
+ $sql = "SELECT DISTINCT wmc_id, wmc_title, wmc_timestamp " .
+ "FROM mb_user_wmc WHERE wmc_id IN (" . $wmcIdList . ") " .
+ "ORDER BY wmc_timestamp DESC";
+ $res = db_prep_query($sql, $v, $t);
+ $currentResult = array();
+ $currentResult["id"] = $row["wmc_id"];
+ $currentResult["title"] = $row["wmc_title"];
+ $currentResult["timestamp"] = date("M d Y H:i:s", $row["wmc_timestamp"]);
+ array_push($wmcArray, $currentResult);
+ return $wmcArray;
+$json = new Mapbender_JSON();
+$queryObj = $json->decode(stripslashes($_REQUEST['queryObj']));
+$resultObj = array();
+$e = new mb_exception("command: " . $queryObj->command);
+$wmc = new wmc();
+$userId = $_SESSION[mb_user_id];
+switch($queryObj->command){
+ // gets available WMCs
+ case 'getWmc':
+ $resultObj["wmc"] = getWmc();
+ break;
+ // gets XML document of a WMC
+ case 'getWmcDocument':
+ $wmcId = $queryObj->parameters->id;
+ $doc = $wmc->getDocument($wmcId);
+ if (!$doc) {
+ $resultObj["error"] = "The WMC document could not be found.";
+ else {
+ $resultObj["wmc"] = array("document" => $doc);
+ break;
+ // deletes a WMC
+ case 'deleteWmc':
+ if ($wmc->delete($wmcId)) {
+ $resultObj["success"] = "WMC has been deleted from the database.";
+ else {
+ $resultObj["error"] = "WMC could not be deleted.";
+ break;
+ // loads a WMC (returns array of JS code)
+ case 'loadWmc':
+ $wmc->createFromDb($wmcId);
+ $jsArray = $wmc->toJavaScript();
+ if ($jsArray) {
+ $resultObj["javascript"] = $jsArray;
+ else {
+ $resultObj["error"] = "WMC could not be loaded.";
+ break;
+ // merges data with WMC and loads it (returns array of JS code)
+ case 'mergeWmc':
+ $params = $queryObj->parameters;
+ // generate a WMC for the current client state
+ $currentWmc = new wmc();
+ $currentWmc->createFromJs($params->mapObject, $params->generalTitle, $params->extensionData);
+ // get the desired WMC from the database
+ $wmcXml = wmc::getDocument($wmcId);
+ // merge the two WMCs
+ $currentWmc->merge($wmcXml);
+ // load the merged WMC
+ $jsArray = $currentWmc->toJavaScript();
+ if (is_array($jsArray) && count($jsArray) > 0) {
+ else {
+ break;
+ // appends a WMC (returns JS code)
+ case 'appendWmc':
+ $currentWmc->append($wmcXml);
+ else {
+ $resultObj["error"] = "WMC could not be appended.";
+ break;
+ // Invalid command
+ default:
+ $resultObj["error"] = "no action specified...";
+sendOutput($resultObj);
Modified: branches/2.5/http/php/mod_mapOV.php
--- branches/2.5/http/php/mod_mapOV.php 2009-01-08 14:41:46 UTC (rev 3416)
+++ branches/2.5/http/php/mod_mapOV.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -73,7 +73,7 @@
var ind = parent.getMapObjIndexByName('overview');
var ov_extent = parent.mb_mapObj[ind].getExtentInfos();
- parent.mb_setWmcExtensionData({"ov_minx":ov_extent.minx,"ov_miny":ov_extent.miny,"ov_maxx":ov_extent.maxx,"ov_maxy":ov_extent.maxy});
+ parent.mb_mapObj[ind].isOverview = true;
function mod_ov_setHandler(e){
Added: branches/2.5/http/php/mod_savewmc_server.php
--- branches/2.5/http/php/mod_savewmc_server.php (rev 0)
+++ branches/2.5/http/php/mod_savewmc_server.php 2009-01-08 14:47:47 UTC (rev 3417)
@@ -0,0 +1,50 @@
+<?php
+#$Id: mod_insertWmcIntoDb.php 1198 2007-10-18 14:37:52Z baudson $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wmc.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+// get data from POST and SESSION
+$mapObject = $json->decode(stripslashes($_POST["mapObject"]));
+$userId = $_SESSION["mb_user_id"];
+$saveInSession = $_POST["saveInSession"];
+$generalTitle = $_POST["generalTitle"];
+$extensionData = $json->decode(stripslashes($_POST["extensionData"]));
+// create WMC object
+$wmc = new wmc();
+$wmc->createFromJs($mapObject, $generalTitle, $extensionData);
+if ($saveInSession === 1) {
+ // store XML in session
+ $_SESSION["mb_wmc"] = $wmc->xml;
+ $_SESSION["epsg"] = $mapObject->epsg;
+ $_SESSION["previous_gui"] = $_SESSION["mb_user_gui"];
+ $e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
+else {
+ // insert WMC into database
+ $result = $wmc->insert();
+ echo $result["message"];
More information about the Mapbender_commits
