[Mapbender-commits] r3982 - branches/google_dev/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 2 11:29:26 EDT 2009
Author: christoph
Date: 2009-06-02 11:29:26 -0400 (Tue, 02 Jun 2009)
New Revision: 3982
Added:
   branches/google_dev/http/extensions/jquery-1.3.2.min.js
   branches/google_dev/http/extensions/jquery-ui-1.7.1.custom.min.js
   branches/google_dev/http/extensions/jquery-ui-selectable.min.js
   branches/google_dev/http/extensions/ui.core.js
   branches/google_dev/http/extensions/ui.selectable.js
Added: branches/google_dev/http/extensions/jquery-1.3.2.min.js
--- branches/google_dev/http/extensions/jquery-1.3.2.min.js	                        (rev 0)
+++ branches/google_dev/http/extensions/jquery-1.3.2.min.js	2009-06-02 15:29:26 UTC (rev 3982)
@@ -0,0 +1,19 @@
+ * jQuery JavaScript Library v1.3.2
+ * http://jquery.com/
+ * Copyright (c) 2009 John Resig
+ * Dual licensed under the MIT and GPL licenses.
+ * http://docs.jquery.com/License
+ * Date: 2009-02-19 17:34:21 -0500 (Thu, 19 Feb 2009)
+ * Revision: 6246
+(function(){var l=this,g,y=l.jQuery,p=l.$,o=l.jQuery=l.$=function(E,F){return new o.fn.init(E,F)},D=/^[^<]*(<(.|\s)+>)[^>]*$|^#([\w-]+)$/,f=/^.[^:#\[\.,]*$/;o.fn=o.prototype={init:function(E,H){E=E||document;if(E.nodeType){this[0]=E;this.length=1;this.context=E;return this}if(typeof E==="string"){var G=D.exec(E);if(G&&(G[1]||!H)){if(G[1]){E=o.clean([G[1]],H)}else{var I=document.getElementById(G[3]);if(I&&I.id!=G[3]){return o().find(E)}var F=o(I||[]);F.context=document;F.selector=E;return F}}else{return o(H).find(E)}}else{if(o.isFunction(E)){return o(document).ready(E)}}if(E.selector&&E.context){this.selector=E.selector;this.context=E.context}return this.setArray(o.isArray(E)?E:o.makeArray(E))},selector:"",jquery:"1.3.2",size:function(){return this.length},get:function(E){return E===g?Array.prototype.slice.call(this):this[E]},pushStack:function(F,H,E){var G=o(F);G.prevObject=this;G.context=this.context;if(H==="find"){G.selector=this.selector+(this.selector?" ":"")+E}else{if(H){G.selector=this.selector+"."+H+"("+E+")"}}return G},setArray:function(E){this.length=0;Array.prototype.push.apply(this,E);return this},each:function(F,E){return o.each(this,F,E)},index:function(E){return o.inArray(E&&E.jquery?E[0]:E,this)},attr:function(F,H,G){var E=F;if(typeof F==="string"){if(H===g){return this[0]&&o[G||"attr"](this[0],F)}else{E={};E[F]=H}}return this.each(function(I){for(F in E){o.attr(G?this.style:this,F,o.prop(this,E[F],G,I,F))}})},css:function(E,F){if((E=="width"||E=="height")&&parseFloat(F)<0){F=g}return this.attr(E,F,"curCSS")},text:function(F){if(typeof F!=="object"&&F!=null){return this.empty().append((this[0]&&this[0].ownerDocument||document).createTextNode(F))}var E="";o.each(F||this,function(){o.each(this.childNodes,function(){if(this.nodeType!=8){E+=this.nodeType!=1?this.nodeValue:o.fn.text([this])}})});return E},wrapAll:function(E){if(this[0]){var F=o(E,this[0].ownerDocument).clone();if(this[0].parentNode){F.insertBefore(this[0])}F.map(function(){var G=this;while(G.firstChild){G=G.firstChild}return G}).append(this)}return this},wrapInner:function(E){return this.each(function(){o(this).contents().wrapAll(E)})},wrap:function(E){return this.each(function(){o(this).wrapAll(E)})},append:function(){return this.domManip(arguments,true,function(E){if(this.nodeType==1){this.appendChild(E)}})},prepend:function(){return this.domManip(arguments,true,function(E){if(this.nodeType==1){this.insertBefore(E,this.firstChild)}})},before:function(){return this.domManip(arguments,false,function(E){this.parentNode.insertBefore(E,this)})},after:function(){return this.domManip(arguments,false,function(E){this.parentNode.insertBefore(E,this.nextSibling)})},end:function(){return this.prevObject||o([])},push:[].push,sort:[].sort,splice:[].splice,find:function(E){if(this.length===1){var F=this.pushStack([],"find",E);F.length=0;o.find(E,this[0],F);return F}else{return this.pushStack(o.unique(o.map(this,function(G){return o.find(E,G)})),"find",E)}},clone:function(G){var E=this.map(function(){if(!o.support.noCloneEvent&&!o.isXMLDoc(this)){var I=this.outerHTML;if(!I){var J=this.ownerDocument.createElement("div");J.appendChild(this.cloneNode(true));I=J.innerHTML}return o.clean([I.replace(/ jQuery\d+="(?:\d+|null)"/g,"").replace(/^\s*/,"")])[0]}else{return this.cloneNode(true)}});if(G===true){var H=this.find("*").andSelf(),F=0;E.find("*").andSelf().each(function(){if(this.nodeName!==H[F].nodeName){return}var I=o.data(H[F],"events");for(var K in I){for(var J in I[K]){o.event.add(this,K,I[K][J],I[K][J].data)}}F++})}return E},filter:function(E){return this.pushStack(o.isFunction(E)&&o.grep(this,function(G,F){return E.call(G,F)})||o.multiFilter(E,o.grep(this,function(F){return F.nodeType===1})),"filter",E)},closest:function(E){var G=o.expr.match.POS.test(E)?o(E):null,F=0;return this.map(function(){var H=this;while(H&&H.ownerDocument){if(G?G.index(H)>-1:o(H).is(E)){o.data(H,"closest",F);return H}H=H.parentNode;F++}})},not:function(E){if(typeof E==="string"){if(f.test(E)){return this.pushStack(o.multiFilter(E,this,true),"not",E)}else{E=o.multiFilter(E,this)}}var F=E.length&&E[E.length-1]!==g&&!E.nodeType;return this.filter(function(){return F?o.inArray(this,E)<0:this!=E})},add:function(E){return this.pushStack(o.unique(o.merge(this.get(),typeof E==="string"?o(E):o.makeArray(E))))},is:function(E){return !!E&&o.multiFilter(E,this).length>0},hasClass:function(E){return !!E&&this.is("."+E)},val:function(K){if(K===g){var E=this[0];if(E){if(o.nodeName(E,"option")){return(E.attributes.value||{}).specified?E.value:E.text}if(o.nodeName(E,"select")){var I=E.selectedIndex,L=[],M=E.options,H=E.type=="select-one";if(I<0){return null}for(var F=H?I:0,J=H?I+1:M.length;F<J;F++){var G=M[F];if(G.selected){K=o(G).val();if(H){return K}L.push(K)}}return L}return(E.value||"").replace(/\r/g,"")}return g}if(typeof K==="number"){K+=""}return this.each(function(){if(this.nodeType!=1){return}if(o.isArray(K)&&/radio|checkbox/.test(this.type)){this.checked=(o.inArray(this.value,K)>=0||o.inArray(this.name,K)>=0)}else{if(o.nodeName(this,"select")){var N=o.makeArray(K);o("option",this).each(function(){this.selected=(o.inArray(this.value,N)>=0||o.inArray(this.text,N)>=0)});if(!N.length){this.selectedIndex=-1}}else{this.value=K}}})},html:function(E){return E===g?(this[0]?this[0].innerHTML.replace(/ jQuery\d+="(?:\d+|null)"/g,""):null):this.empty().append(E)},replaceWith:function(E){return this.after(E).remove()},eq:function(E){return this.slice(E,+E+1)},slice:function(){return this.pushStack(Array.prototype.slice.apply(this,arguments),"slice",Array.prototype.slice.call(arguments).join(","))},map:function(E){return this.pushStack(o.map(this,function(G,F){return E.call(G,F,G)}))},andSelf:function(){return this.add(this.prevObject)},domManip:function(J,M,L){if(this[0]){var I=(this[0].ownerDocument||this[0]).createDocumentFragment(),F=o.clean(J,(this[0].ownerDocument||this[0]),I),H=I.firstChild;if(H){for(var G=0,E=this.length;G<E;G++){L.call(K(this[G],H),this.length>1||G>0?I.cloneNode(true):I)}}if(F){o.each(F,z)}}return this;function K(N,O){return M&&o.nodeName(N,"table")&&o.nodeName(O,"tr")?(N.getElementsByTagName("tbody")[0]||N.appendChild(N.ownerDocument.createElement("tbody"))):N}}};o.fn.init.prototype=o.fn;function z(E,F){if(F.src){o.ajax({url:F.src,async:false,dataType:"script"})}else{o.globalEval(F.text||F.textContent||F.innerHTML||"")}if(F.parentNode){F.parentNode.removeChild(F)}}function e(){return +new Date}o.extend=o.fn.extend=function(){var J=arguments[0]||{},H=1,I=arguments.length,E=false,G;if(typeof J==="boolean"){E=J;J=arguments[1]||{};H=2}if(typeof J!=="object"&&!o.isFunction(J)){J={}}if(I==H){J=this;--H}for(;H<I;H++){if((G=arguments[H])!=null){for(var F in G){var K=J[F],L=G[F];if(J===L){continue}if(E&&L&&typeof L==="object"&&!L.nodeType){J[F]=o.extend(E,K||(L.length!=null?[]:{}),L)}else{if(L!==g){J[F]=L}}}}}return J};var b=/z-?index|font-?weight|opacity|zoom|line-?height/i,q=document.defaultView||{},s=Object.prototype.toString;o.extend({noConflict:function(E){l.$=p;if(E){l.jQuery=y}return o},isFunction:function(E){return s.call(E)==="[object Function]"},isArray:function(E){return s.call(E)==="[object Array]"},isXMLDoc:function(E){return E.nodeType===9&&E.documentElement.nodeName!=="HTML"||!!E.ownerDocument&&o.isXMLDoc(E.ownerDocument)},globalEval:function(G){if(G&&/\S/.test(G)){var F=document.getElementsByTagName("head")[0]||document.documentElement,E=document.createElement("script");E.type="text/javascript";if(o.support.scriptEval){E.appendChild(document.createTextNode(G))}else{E.text=G}F.insertBefore(E,F.firstChild);F.removeChild(E)}},nodeName:function(F,E){return F.nodeName&&F.nodeName.toUpperCase()==E.toUpperCase()},each:function(G,K,F){var E,H=0,I=G.length;if(F){if(I===g){for(E in G){if(K.apply(G[E],F)===false){break}}}else{for(;H<I;){if(K.apply(G[H++],F)===false){break}}}}else{if(I===g){for(E in G){if(K.call(G[E],E,G[E])===false){break}}}else{for(var J=G[0];H<I&&K.call(J,H,J)!==false;J=G[++H]){}}}return G},prop:function(H,I,G,F,E){if(o.isFunction(I)){I=I.call(H,F)}return typeof I==="number"&&G=="curCSS"&&!b.test(E)?I+"px":I},className:{add:function(E,F){o.each((F||"").split(/\s+/),function(G,H){if(E.nodeType==1&&!o.className.has(E.className,H)){E.className+=(E.className?" ":"")+H}})},remove:function(E,F){if(E.nodeType==1){E.className=F!==g?o.grep(E.className.split(/\s+/),function(G){return !o.className.has(F,G)}).join(" "):""}},has:function(F,E){return F&&o.inArray(E,(F.className||F).toString().split(/\s+/))>-1}},swap:function(H,G,I){var E={};for(var F in G){E[F]=H.style[F];H.style[F]=G[F]}I.call(H);for(var F in G){H.style[F]=E[F]}},css:function(H,F,J,E){if(F=="width"||F=="height"){var L,G={position:"absolute",visibility:"hidden",display:"block"},K=F=="width"?["Left","Right"]:["Top","Bottom"];function I(){L=F=="width"?H.offsetWidth:H.offsetHeight;if(E==="border"){return}o.each(K,function(){if(!E){L-=parseFloat(o.curCSS(H,"padding"+this,true))||0}if(E==="margin"){L+=parseFloat(o.curCSS(H,"margin"+this,true))||0}else{L-=parseFloat(o.curCSS(H,"border"+this+"Width",true))||0}})}if(H.offsetWidth!==0){I()}else{o.swap(H,G,I)}return Math.max(0,Math.round(L))}return o.curCSS(H,F,J)},curCSS:function(I,F,G){var L,E=I.style;if(F=="opacity"&&!o.support.opacity){L=o.attr(E,"opacity");return L==""?"1":L}if(F.match(/float/i)){F=w}if(!G&&E&&E[F]){L=E[F]}else{if(q.getComputedStyle){if(F.match(/float/i)){F="float"}F=F.replace(/([A-Z])/g,"-$1").toLowerCase();var M=q.getComputedStyle(I,null);if(M){L=M.getPropertyValue(F)}if(F=="opacity"&&L==""){L="1"}}else{if(I.currentStyle){var J=F.replace(/\-(\w)/g,function(N,O){return O.toUpperCase()});L=I.currentStyle[F]||I.currentStyle[J];if(!/^\d+(px)?$/i.test(L)&&/^\d/.test(L)){var H=E.left,K=I.runtimeStyle.left;I.runtimeStyle.left=I.currentStyle.left;E.left=L||0;L=E.pixelLeft+"px";E.left=H;I.runtimeStyle.left=K}}}}return L},clean:function(F,K,I){K=K||document;if(typeof K.createElement==="undefined"){K=K.ownerDocument||K[0]&&K[0].ownerDocument||document}if(!I&&F.length===1&&typeof F[0]==="string"){var H=/^<(\w+)\s*\/?>$/.exec(F[0]);if(H){return[K.createElement(H[1])]}}var G=[],E=[],L=K.createElement("div");o.each(F,function(P,S){if(typeof S==="number"){S+=""}if(!S){return}if(typeof S==="string"){S=S.replace(/(<(\w+)[^>]*?)\/>/g,function(U,V,T){return T.match(/^(abbr|br|col|img|input|link|meta|param|hr|area|embed)$/i)?U:V+"></"+T+">"});var O=S.replace(/^\s+/,"").substring(0,10).toLowerCase();var Q=!O.indexOf("<opt")&&[1,"<select multiple='multiple'>","</select>"]||!O.indexOf("<leg")&&[1,"<fieldset>","</fieldset>"]||O.match(/^<(thead|tbody|tfoot|colg|cap)/)&&[1,"<table>","</table>"]||!O.indexOf("<tr")&&[2,"<table><tbody>","</tbody></table>"]||(!O.indexOf("<td")||!O.indexOf("<th"))&&[3,"<table><tbody><tr>","</tr></tbody></table>"]||!O.indexOf("<col")&&[2,"<table><tbody></tbody><colgroup>","</colgroup></table>"]||!o.support.htmlSerialize&&[1,"div<div>","</div>"]||[0,"",""];L.innerHTML=Q[1]+S+Q[2];while(Q[0]--){L=L.lastChild}if(!o.support.tbody){var R=/<tbody/i.test(S),N=!O.indexOf("<table")&&!R?L.firstChild&&L.firstChild.childNodes:Q[1]=="<table>"&&!R?L.childNodes:[];for(var M=N.length-1;M>=0;--M){if(o.nodeName(N[M],"tbody")&&!N[M].childNodes.length){N[M].parentNode.removeChild(N[M])}}}if(!o.support.leadingWhitespace&&/^\s/.test(S)){L.insertBefore(K.createTextNode(S.match(/^\s*/)[0]),L.firstChild)}S=o.makeArray(L.childNodes)}if(S.nodeType){G.push(S)}else{G=o.merge(G,S)}});if(I){for(var J=0;G[J];J++){if(o.nodeName(G[J],"script")&&(!G[J].type||G[J].type.toLowerCase()==="text/javascript")){E.push(G[J].parentNode?G[J].parentNode.removeChild(G[J]):G[J])}else{if(G[J].nodeType===1){G.splice.apply(G,[J+1,0].concat(o.makeArray(G[J].getElementsByTagName("script"))))}I.appendChild(G[J])}}return E}return G},attr:function(J,G,K){if(!J||J.nodeType==3||J.nodeType==8){return g}var H=!o.isXMLDoc(J),L=K!==g;G=H&&o.props[G]||G;if(J.tagName){var F=/href|src|style/.test(G);if(G=="selected"&&J.parentNode){J.parentNode.selectedIndex}if(G in J&&H&&!F){if(L){if(G=="type"&&o.nodeName(J,"input")&&J.parentNode){throw"type property can't be changed"}J[G]=K}if(o.nodeName(J,"form")&&J.getAttributeNode(G)){return J.getAttributeNode(G).nodeValue}if(G=="tabIndex"){var I=J.getAttributeNode("tabIndex");return I&&I.specified?I.value:J.nodeName.match(/(button|input|object|select|textarea)/i)?0:J.nodeName.match(/^(a|area)$/i)&&J.href?0:g}return J[G]}if(!o.support.style&&H&&G=="style"){return o.attr(J.style,"cssText",K)}if(L){J.setAttribute(G,""+K)}var E=!o.support.hrefNormalized&&H&&F?J.getAttribute(G,2):J.getAttribute(G);return E===null?g:E}if(!o.support.opacity&&G=="opacity"){if(L){J.zoom=1;J.filter=(J.filter||"").replace(/alpha\([^)]*\)/,"")+(parseInt(K)+""=="NaN"?"":"alpha(opacity="+K*100+")")}return J.filter&&J.filter.indexOf("opacity=")>=0?(parseFloat(J.filter.match(/opacity=([^)]*)/)[1])/100)+"":""}G=G.replace(/-([a-z])/ig,function(M,N){return N.toUpperCase()});if(L){J[G]=K}return J[G]},trim:function(E){return(E||"").replace(/^\s+|\s+$/g,"")},makeArray:function(G){var E=[];if(G!=null){var F=G.length;if(F==null||typeof G==="string"||o.isFunction(G)||G.setInterval){E[0]=G}else{while(F){E[--F]=G[F]}}}return E},inArray:function(G,H){for(var E=0,F=H.length;E<F;E++){if(H[E]===G){return E}}return -1},merge:function(H,E){var F=0,G,I=H.length;if(!o.support.getAll){while((G=E[F++])!=null){if(G.nodeType!=8){H[I++]=G}}}else{while((G=E[F++])!=null){H[I++]=G}}return H},unique:function(K){var F=[],E={};try{for(var G=0,H=K.length;G<H;G++){var J=o.data(K[G]);if(!E[J]){E[J]=true;F.push(K[G])}}}catch(I){F=K}return F},grep:function(F,J,E){var G=[];for(var H=0,I=F.length;H<I;H++){if(!E!=!J(F[H],H)){G.push(F[H])}}return G},map:function(E,J){var F=[];for(var G=0,H=E.length;G<H;G++){var I=J(E[G],G);if(I!=null){F[F.length]=I}}return F.concat.apply([],F)}});var C=navigator.userAgent.toLowerCase();o.browser={version:(C.match(/.+(?:rv|it|ra|ie)[\/: ]([\d.]+)/)||[0,"0"])[1],safari:/webkit/.test(C),opera:/opera/.test(C),msie:/msie/.test(C)&&!/opera/.test(C),mozilla:/mozilla/.test(C)&&!/(compatible|webkit)/.test(C)};o.each({parent:function(E){return E.parentNode},parents:function(E){return o.dir(E,"parentNode")},next:function(E){return o.nth(E,2,"nextSibling")},prev:function(E){return o.nth(E,2,"previousSibling")},nextAll:function(E){return o.dir(E,"nextSibling")},prevAll:function(E){return o.dir(E,"previousSibling")},siblings:function(E){return o.sibling(E.parentNode.firstChild,E)},children:function(E){return o.sibling(E.firstChild)},contents:function(E){return o.nodeName(E,"iframe")?E.contentDocument||E.contentWindow.document:o.makeArray(E.childNodes)}},function(E,F){o.fn[E]=function(G){var H=o.map(this,F);if(G&&typeof G=="string"){H=o.multiFilter(G,H)}return this.pushStack(o.unique(H),E,G)}});o.each({appendTo:"append",prependTo:"prepend",insertBefore:"before",insertAfter:"after",replaceAll:"replaceWith"},function(E,F){o.fn[E]=function(G){var J=[],L=o(G);for(var K=0,H=L.length;K<H;K++){var I=(K>0?this.clone(true):this).get();o.fn[F].apply(o(L[K]),I);J=J.concat(I)}return this.pushStack(J,E,G)}});o.each({removeAttr:function(E){o.attr(this,E,"");if(this.nodeType==1){this.removeAttribute(E)}},addClass:function(E){o.className.add(this,E)},removeClass:function(E){o.className.remove(this,E)},toggleClass:function(F,E){if(typeof E!=="boolean"){E=!o.className.has(this,F)}o.className[E?"add":"remove"](this,F)},remove:function(E){if(!E||o.filter(E,[this]).length){o("*",this).add([this]).each(function(){o.event.remove(this);o.removeData(this)});if(this.parentNode){this.parentNode.removeChild(this)}}},empty:function(){o(this).children().remove();while(this.firstChild){this.removeChild(this.firstChild)}}},function(E,F){o.fn[E]=function(){return this.each(F,arguments)}});function j(E,F){return E[0]&&parseInt(o.curCSS(E[0],F,true),10)||0}var h="jQuery"+e(),v=0,A={};o.extend({cache:{},data:function(F,E,G){F=F==l?A:F;var H=F[h];if(!H){H=F[h]=++v}if(E&&!o.cache[H]){o.cache[H]={}}if(G!==g){o.cache[H][E]=G}return E?o.cache[H][E]:H},removeData:function(F,E){F=F==l?A:F;var H=F[h];if(E){if(o.cache[H]){delete o.cache[H][E];E="";for(E in o.cache[H]){break}if(!E){o.removeData(F)}}}else{try{delete F[h]}catch(G){if(F.removeAttribute){F.removeAttribute(h)}}delete o.cache[H]}},queue:function(F,E,H){if(F){E=(E||"fx")+"queue";var G=o.data(F,E);if(!G||o.isArray(H)){G=o.data(F,E,o.makeArray(H))}else{if(H){G.push(H)}}}return G},dequeue:function(H,G){var E=o.queue(H,G),F=E.shift();if(!G||G==="fx"){F=E[0]}if(F!==g){F.call(H)}}});o.fn.extend({data:function(E,G){var H=E.split(".");H[1]=H[1]?"."+H[1]:"";if(G===g){var F=this.triggerHandler("getData"+H[1]+"!",[H[0]]);if(F===g&&this.length){F=o.data(this[0],E)}return F===g&&H[1]?this.data(H[0]):F}else{return this.trigger("setData"+H[1]+"!",[H[0],G]).each(function(){o.data(this,E,G)})}},removeData:function(E){return this.each(function(){o.removeData(this,E)})},queue:function(E,F){if(typeof E!=="string"){F=E;E="fx"}if(F===g){return o.queue(this[0],E)}return this.each(function(){var G=o.queue(this,E,F);if(E=="fx"&&G.length==1){G[0].call(this)}})},dequeue:function(E){return this.each(function(){o.dequeue(this,E)})}});
+ * Sizzle CSS Selector Engine - v0.9.3
+ *  Copyright 2009, The Dojo Foundation
+ *  Released under the MIT, BSD, and GPL Licenses.
+ *  More information: http://sizzlejs.com/
+(function(){var R=/((?:\((?:\([^()]+\)|[^()]+)+\)|\[(?:\[[^[\]]*\]|['"][^'"]*['"]|[^[\]'"]+)+\]|\\.|[^ >+~,(\[\\]+)+|[>+~])(\s*,\s*)?/g,L=0,H=Object.prototype.toString;var F=function(Y,U,ab,ac){ab=ab||[];U=U||document;if(U.nodeType!==1&&U.nodeType!==9){return[]}if(!Y||typeof Y!=="string"){return ab}var Z=[],W,af,ai,T,ad,V,X=true;R.lastIndex=0;while((W=R.exec(Y))!==null){Z.push(W[1]);if(W[2]){V=RegExp.rightContext;break}}if(Z.length>1&&M.exec(Y)){if(Z.length===2&&I.relative[Z[0]]){af=J(Z[0]+Z[1],U)}else{af=I.relative[Z[0]]?[U]:F(Z.shift(),U);while(Z.length){Y=Z.shift();if(I.relative[Y]){Y+=Z.shift()}af=J(Y,af)}}}else{var ae=ac?{expr:Z.pop(),set:E(ac)}:F.find(Z.pop(),Z.length===1&&U.parentNode?U.parentNode:U,Q(U));af=F.filter(ae.expr,ae.set);if(Z.length>0){ai=E(af)}else{X=false}while(Z.length){var ah=Z.pop(),ag=ah;if(!I.relative[ah]){ah=""}else{ag=Z.pop()}if(ag==null){ag=U}I.relative[ah](ai,ag,Q(U))}}if(!ai){ai=af}if(!ai){throw"Syntax error, unrecognized expression: "+(ah||Y)}if(H.call(ai)==="[object Array]"){if(!X){ab.push.apply(ab,ai)}else{if(U.nodeType===1){for(var aa=0;ai[aa]!=null;aa++){if(ai[aa]&&(ai[aa]===true||ai[aa].nodeType===1&&K(U,ai[aa]))){ab.push(af[aa])}}}else{for(var aa=0;ai[aa]!=null;aa++){if(ai[aa]&&ai[aa].nodeType===1){ab.push(af[aa])}}}}}else{E(ai,ab)}if(V){F(V,U,ab,ac);if(G){hasDuplicate=false;ab.sort(G);if(hasDuplicate){for(var aa=1;aa<ab.length;aa++){if(ab[aa]===ab[aa-1]){ab.splice(aa--,1)}}}}}return ab};F.matches=function(T,U){return F(T,null,null,U)};F.find=function(aa,T,ab){var Z,X;if(!aa){return[]}for(var W=0,V=I.order.length;W<V;W++){var Y=I.order[W],X;if((X=I.match[Y].exec(aa))){var U=RegExp.leftContext;if(U.substr(U.length-1)!=="\\"){X[1]=(X[1]||"").replace(/\\/g,"");Z=I.find[Y](X,T,ab);if(Z!=null){aa=aa.replace(I.match[Y],"");break}}}}if(!Z){Z=T.getElementsByTagName("*")}return{set:Z,expr:aa}};F.filter=function(ad,ac,ag,W){var V=ad,ai=[],aa=ac,Y,T,Z=ac&&ac[0]&&Q(ac[0]);while(ad&&ac.length){for(var ab in I.filter){if((Y=I.match[ab].exec(ad))!=null){var U=I.filter[ab],ah,af;T=false;if(aa==ai){ai=[]}if(I.preFilter[ab]){Y=I.preFilter[ab](Y,aa,ag,ai,W,Z);if(!Y){T=ah=true}else{if(Y===true){continue}}}if(Y){for(var X=0;(af=aa[X])!=null;X++){if(af){ah=U(af,Y,X,aa);var ae=W^!!ah;if(ag&&ah!=null){if(ae){T=true}else{aa[X]=false}}else{if(ae){ai.push(af);T=true}}}}}if(ah!==g){if(!ag){aa=ai}ad=ad.replace(I.match[ab],"");if(!T){return[]}break}}}if(ad==V){if(T==null){throw"Syntax error, unrecognized expression: "+ad}else{break}}V=ad}return aa};var I=F.selectors={order:["ID","NAME","TAG"],match:{ID:/#((?:[\w\u00c0-\uFFFF_-]|\\.)+)/,CLASS:/\.((?:[\w\u00c0-\uFFFF_-]|\\.)+)/,NAME:/\[name=['"]*((?:[\w\u00c0-\uFFFF_-]|\\.)+)['"]*\]/,ATTR:/\[\s*((?:[\w\u00c0-\uFFFF_-]|\\.)+)\s*(?:(\S?=)\s*(['"]*)(.*?)\3|)\s*\]/,TAG:/^((?:[\w\u00c0-\uFFFF\*_-]|\\.)+)/,CHILD:/:(only|nth|last|first)-child(?:\((even|odd|[\dn+-]*)\))?/,POS:/:(nth|eq|gt|lt|first|last|even|odd)(?:\((\d*)\))?(?=[^-]|$)/,PSEUDO:/:((?:[\w\u00c0-\uFFFF_-]|\\.)+)(?:\((['"]*)((?:\([^\)]+\)|[^\2\(\)]*)+)\2\))?/},attrMap:{"class":"className","for":"htmlFor"},attrHandle:{href:function(T){return T.getAttribute("href")}},relative:{"+":function(aa,T,Z){var X=typeof T==="string",ab=X&&!/\W/.test(T),Y=X&&!ab;if(ab&&!Z){T=T.toUpperCase()}for(var W=0,V=aa.length,U;W<V;W++){if((U=aa[W])){while((U=U.previousSibling)&&U.nodeType!==1){}aa[W]=Y||U&&U.nodeName===T?U||false:U===T}}if(Y){F.filter(T,aa,true)}},">":function(Z,U,aa){var X=typeof U==="string";if(X&&!/\W/.test(U)){U=aa?U:U.toUpperCase();for(var V=0,T=Z.length;V<T;V++){var Y=Z[V];if(Y){var W=Y.parentNode;Z[V]=W.nodeName===U?W:false}}}else{for(var V=0,T=Z.length;V<T;V++){var Y=Z[V];if(Y){Z[V]=X?Y.parentNode:Y.parentNode===U}}if(X){F.filter(U,Z,true)}}},"":function(W,U,Y){var V=L++,T=S;if(!U.match(/\W/)){var X=U=Y?U:U.toUpperCase();T=P}T("parentNode",U,V,W,X,Y)},"~":function(W,U,Y){var V=L++,T=S;if(typeof U==="string"&&!U.match(/\W/)){var X=U=Y?U:U.toUpperCase();T=P}T("previousSibling",U,V,W,X,Y)}},find:{ID:function(U,V,W){if(typeof V.getElementById!=="undefined"&&!W){var T=V.getElementById(U[1]);return T?[T]:[]}},NAME:function(V,Y,Z){if(typeof Y.getElementsByName!=="undefined"){var U=[],X=Y.getElementsByName(V[1]);for(var W=0,T=X.length;W<T;W++){if(X[W].getAttribute("name")===V[1]){U.push(X[W])}}return U.length===0?null:U}},TAG:function(T,U){return U.getElementsByTagName(T[1])}},preFilter:{CLASS:function(W,U,V,T,Z,aa){W=" "+W[1].replace(/\\/g,"")+" ";if(aa){return W}for(var X=0,Y;(Y=U[X])!=null;X++){if(Y){if(Z^(Y.className&&(" "+Y.className+" ").indexOf(W)>=0)){if(!V){T.push(Y)}}else{if(V){U[X]=false}}}}return false},ID:function(T){return T[1].replace(/\\/g,"")},TAG:function(U,T){for(var V=0;T[V]===false;V++){}return T[V]&&Q(T[V])?U[1]:U[1].toUpperCase()},CHILD:function(T){if(T[1]=="nth"){var U=/(-?)(\d*)n((?:\+|-)?\d*)/.exec(T[2]=="even"&&"2n"||T[2]=="odd"&&"2n+1"||!/\D/.test(T[2])&&"0n+"+T[2]||T[2]);T[2]=(U[1]+(U[2]||1))-0;T[3]=U[3]-0}T[0]=L++;return T},ATTR:function(X,U,V,T,Y,Z){var W=X[1].replace(/\\/g,"");if(!Z&&I.attrMap[W]){X[1]=I.attrMap[W]}if(X[2]==="~="){X[4]=" "+X[4]+" "}return X},PSEUDO:function(X,U,V,T,Y){if(X[1]==="not"){if(X[3].match(R).length>1||/^\w/.test(X[3])){X[3]=F(X[3],null,null,U)}else{var W=F.filter(X[3],U,V,true^Y);if(!V){T.push.apply(T,W)}return false}}else{if(I.match.POS.test(X[0])||I.match.CHILD.test(X[0])){return true}}return X},POS:function(T){T.unshift(true);return T}},filters:{enabled:function(T){return T.disabled===false&&T.type!=="hidden"},disabled:function(T){return T.disabled===true},checked:function(T){return T.checked===true},selected:function(T){T.parentNode.selectedIndex;return T.selected===true},parent:function(T){return !!T.firstChild},empty:function(T){return !T.firstChild},has:function(V,U,T){return !!F(T[3],V).length},header:function(T){return/h\d/i.test(T.nodeName)},text:function(T){return"text"===T.type},radio:function(T){return"radio"===T.type},checkbox:function(T){return"checkbox"===T.type},file:function(T){return"file"===T.type},password:function(T){return"password"===T.type},submit:function(T){return"submit"===T.type},image:function(T){return"image"===T.type},reset:function(T){return"reset"===T.type},button:function(T){return"button"===T.type||T.nodeName.toUpperCase()==="BUTTON"},input:function(T){return/input|select|textarea|button/i.test(T.nodeName)}},setFilters:{first:function(U,T){return T===0},last:function(V,U,T,W){return U===W.length-1},even:function(U,T){return T%2===0},odd:function(U,T){return T%2===1},lt:function(V,U,T){return U<T[3]-0},gt:function(V,U,T){return U>T[3]-0},nth:function(V,U,T){return T[3]-0==U},eq:function(V,U,T){return T[3]-0==U}},filter:{PSEUDO:function(Z,V,W,aa){var U=V[1],X=I.filters[U];if(X){return X(Z,W,V,aa)}else{if(U==="contains"){return(Z.textContent||Z.innerText||"").indexOf(V[3])>=0}else{if(U==="not"){var Y=V[3];for(var W=0,T=Y.length;W<T;W++){if(Y[W]===Z){return false}}return true}}}},CHILD:function(T,W){var Z=W[1],U=T;switch(Z){case"only":case"first":while(U=U.previousSibling){if(U.nodeType===1){return false}}if(Z=="first"){return true}U=T;case"last":while(U=U.nextSibling){if(U.nodeType===1){return false}}return true;case"nth":var V=W[2],ac=W[3];if(V==1&&ac==0){return true}var Y=W[0],ab=T.parentNode;if(ab&&(ab.sizcache!==Y||!T.nodeIndex)){var X=0;for(U=ab.firstChild;U;U=U.nextSibling){if(U.nodeType===1){U.nodeIndex=++X}}ab.sizcache=Y}var aa=T.nodeIndex-ac;if(V==0){return aa==0}else{return(aa%V==0&&aa/V>=0)}}},ID:function(U,T){return U.nodeType===1&&U.getAttribute("id")===T},TAG:function(U,T){return(T==="*"&&U.nodeType===1)||U.nodeName===T},CLASS:function(U,T){return(" "+(U.className||U.getAttribute("class"))+" ").indexOf(T)>-1},ATTR:function(Y,W){var V=W[1],T=I.attrHandle[V]?I.attrHandle[V](Y):Y[V]!=null?Y[V]:Y.getAttribute(V),Z=T+"",X=W[2],U=W[4];return T==null?X==="!=":X==="="?Z===U:X==="*="?Z.indexOf(U)>=0:X==="~="?(" "+Z+" ").indexOf(U)>=0:!U?Z&&T!==false:X==="!="?Z!=U:X==="^="?Z.indexOf(U)===0:X==="$="?Z.substr(Z.length-U.length)===U:X==="|="?Z===U||Z.substr(0,U.length+1)===U+"-":false},POS:function(X,U,V,Y){var T=U[2],W=I.setFilters[T];if(W){return W(X,V,U,Y)}}}};var M=I.match.POS;for(var O in I.match){I.match[O]=RegExp(I.match[O].source+/(?![^\[]*\])(?![^\(]*\))/.source)}var E=function(U,T){U=Array.prototype.slice.call(U);if(T){T.push.apply(T,U);return T}return U};try{Array.prototype.slice.call(document.documentElement.childNodes)}catch(N){E=function(X,W){var U=W||[];if(H.call(X)==="[object Array]"){Array.prototype.push.apply(U,X)}else{if(typeof X.length==="number"){for(var V=0,T=X.length;V<T;V++){U.push(X[V])}}else{for(var V=0;X[V];V++){U.push(X[V])}}}return U}}var G;if(document.documentElement.compareDocumentPosition){G=function(U,T){var V=U.compareDocumentPosition(T)&4?-1:U===T?0:1;if(V===0){hasDuplicate=true}return V}}else{if("sourceIndex" in document.documentElement){G=function(U,T){var V=U.sourceIndex-T.sourceIndex;if(V===0){hasDuplicate=true}return V}}else{if(document.createRange){G=function(W,U){var V=W.ownerDocument.createRange(),T=U.ownerDocument.createRange();V.selectNode(W);V.collapse(true);T.selectNode(U);T.collapse(true);var X=V.compareBoundaryPoints(Range.START_TO_END,T);if(X===0){hasDuplicate=true}return X}}}}(function(){var U=document.createElement("form"),V="script"+(new Date).getTime();U.innerHTML="<input name='"+V+"'/>";var T=document.documentElement;T.insertBefore(U,T.firstChild);if(!!document.getElementById(V)){I.find.ID=function(X,Y,Z){if(typeof Y.getElementById!=="undefined"&&!Z){var W=Y.getElementById(X[1]);return W?W.id===X[1]||typeof W.getAttributeNode!=="undefined"&&W.getAttributeNode("id").nodeValue===X[1]?[W]:g:[]}};I.filter.ID=function(Y,W){var X=typeof Y.getAttributeNode!=="undefined"&&Y.getAttributeNode("id");return Y.nodeType===1&&X&&X.nodeValue===W}}T.removeChild(U)})();(function(){var T=document.createElement("div");T.appendChild(document.createComment(""));if(T.getElementsByTagName("*").length>0){I.find.TAG=function(U,Y){var X=Y.getElementsByTagName(U[1]);if(U[1]==="*"){var W=[];for(var V=0;X[V];V++){if(X[V].nodeType===1){W.push(X[V])}}X=W}return X}}T.innerHTML="<a href='#'></a>";if(T.firstChild&&typeof T.firstChild.getAttribute!=="undefined"&&T.firstChild.getAttribute("href")!=="#"){I.attrHandle.href=function(U){return U.getAttribute("href",2)}}})();if(document.querySelectorAll){(function(){var T=F,U=document.createElement("div");U.innerHTML="<p class='TEST'></p>";if(U.querySelectorAll&&U.querySelectorAll(".TEST").length===0){return}F=function(Y,X,V,W){X=X||document;if(!W&&X.nodeType===9&&!Q(X)){try{return E(X.querySelectorAll(Y),V)}catch(Z){}}return T(Y,X,V,W)};F.find=T.find;F.filter=T.filter;F.selectors=T.selectors;F.matches=T.matches})()}if(document.getElementsByClassName&&document.documentElement.getElementsByClassName){(function(){var T=document.createElement("div");T.innerHTML="<div class='test e'></div><div class='test'></div>";if(T.getElementsByClassName("e").length===0){return}T.lastChild.className="e";if(T.getElementsByClassName("e").length===1){return}I.order.splice(1,0,"CLASS");I.find.CLASS=function(U,V,W){if(typeof V.getElementsByClassName!=="undefined"&&!W){return V.getElementsByClassName(U[1])}}})()}function P(U,Z,Y,ad,aa,ac){var ab=U=="previousSibling"&&!ac;for(var W=0,V=ad.length;W<V;W++){var T=ad[W];if(T){if(ab&&T.nodeType===1){T.sizcache=Y;T.sizset=W}T=T[U];var X=false;while(T){if(T.sizcache===Y){X=ad[T.sizset];break}if(T.nodeType===1&&!ac){T.sizcache=Y;T.sizset=W}if(T.nodeName===Z){X=T;break}T=T[U]}ad[W]=X}}}function S(U,Z,Y,ad,aa,ac){var ab=U=="previousSibling"&&!ac;for(var W=0,V=ad.length;W<V;W++){var T=ad[W];if(T){if(ab&&T.nodeType===1){T.sizcache=Y;T.sizset=W}T=T[U];var X=false;while(T){if(T.sizcache===Y){X=ad[T.sizset];break}if(T.nodeType===1){if(!ac){T.sizcache=Y;T.sizset=W}if(typeof Z!=="string"){if(T===Z){X=true;break}}else{if(F.filter(Z,[T]).length>0){X=T;break}}}T=T[U]}ad[W]=X}}}var K=document.compareDocumentPosition?function(U,T){return U.compareDocumentPosition(T)&16}:function(U,T){return U!==T&&(U.contains?U.contains(T):true)};var Q=function(T){return T.nodeType===9&&T.documentElement.nodeName!=="HTML"||!!T.ownerDocument&&Q(T.ownerDocument)};var J=function(T,aa){var W=[],X="",Y,V=aa.nodeType?[aa]:aa;while((Y=I.match.PSEUDO.exec(T))){X+=Y[0];T=T.replace(I.match.PSEUDO,"")}T=I.relative[T]?T+"*":T;for(var Z=0,U=V.length;Z<U;Z++){F(T,V[Z],W)}return F.filter(X,W)};o.find=F;o.filter=F.filter;o.expr=F.selectors;o.expr[":"]=o.expr.filters;F.selectors.filters.hidden=function(T){return T.offsetWidth===0||T.offsetHeight===0};F.selectors.filters.visible=function(T){return T.offsetWidth>0||T.offsetHeight>0};F.selectors.filters.animated=function(T){return o.grep(o.timers,function(U){return T===U.elem}).length};o.multiFilter=function(V,T,U){if(U){V=":not("+V+")"}return F.matches(V,T)};o.dir=function(V,U){var T=[],W=V[U];while(W&&W!=document){if(W.nodeType==1){T.push(W)}W=W[U]}return T};o.nth=function(X,T,V,W){T=T||1;var U=0;for(;X;X=X[V]){if(X.nodeType==1&&++U==T){break}}return X};o.sibling=function(V,U){var T=[];for(;V;V=V.nextSibling){if(V.nodeType==1&&V!=U){T.push(V)}}return T};return;l.Sizzle=F})();o.event={add:function(I,F,H,K){if(I.nodeType==3||I.nodeType==8){return}if(I.setInterval&&I!=l){I=l}if(!H.guid){H.guid=this.guid++}if(K!==g){var G=H;H=this.proxy(G);H.data=K}var E=o.data(I,"events")||o.data(I,"events",{}),J=o.data(I,"handle")||o.data(I,"handle",function(){return typeof o!=="undefined"&&!o.event.triggered?o.event.handle.apply(arguments.callee.elem,arguments):g});J.elem=I;o.each(F.split(/\s+/),function(M,N){var O=N.split(".");N=O.shift();H.type=O.slice().sort().join(".");var L=E[N];if(o.event.specialAll[N]){o.event.specialAll[N].setup.call(I,K,O)}if(!L){L=E[N]={};if(!o.event.special[N]||o.event.special[N].setup.call(I,K,O)===false){if(I.addEventListener){I.addEventListener(N,J,false)}else{if(I.attachEvent){I.attachEvent("on"+N,J)}}}}L[H.guid]=H;o.event.global[N]=true});I=null},guid:1,global:{},remove:function(K,H,J){if(K.nodeType==3||K.nodeType==8){return}var G=o.data(K,"events"),F,E;if(G){if(H===g||(typeof H==="string"&&H.charAt(0)==".")){for(var I in G){this.remove(K,I+(H||""))}}else{if(H.type){J=H.handler;H=H.type}o.each(H.split(/\s+/),function(M,O){var Q=O.split(".");O=Q.shift();var N=RegExp("(^|\\.)"+Q.slice().sort().join(".*\\.")+"(\\.|$)");if(G[O]){if(J){delete G[O][J.guid]}else{for(var P in G[O]){if(N.test(G[O][P].type)){delete G[O][P]}}}if(o.event.specialAll[O]){o.event.specialAll[O].teardown.call(K,Q)}for(F in G[O]){break}if(!F){if(!o.event.special[O]||o.event.special[O].teardown.call(K,Q)===false){if(K.removeEventListener){K.removeEventListener(O,o.data(K,"handle"),false)}else{if(K.detachEvent){K.detachEvent("on"+O,o.data(K,"handle"))}}}F=null;delete G[O]}}})}for(F in G){break}if(!F){var L=o.data(K,"handle");if(L){L.elem=null}o.removeData(K,"events");o.removeData(K,"handle")}}},trigger:function(I,K,H,E){var G=I.type||I;if(!E){I=typeof I==="object"?I[h]?I:o.extend(o.Event(G),I):o.Event(G);if(G.indexOf("!")>=0){I.type=G=G.slice(0,-1);I.exclusive=true}if(!H){I.stopPropagation();if(this.global[G]){o.each(o.cache,function(){if(this.events&&this.events[G]){o.event.trigger(I,K,this.handle.elem)}})}}if(!H||H.nodeType==3||H.nodeType==8){return g}I.result=g;I.target=H;K=o.makeArray(K);K.unshift(I)}I.currentTarget=H;var J=o.data(H,"handle");if(J){J.apply(H,K)}if((!H[G]||(o.nodeName(H,"a")&&G=="click"))&&H["on"+G]&&H["on"+G].apply(H,K)===false){I.result=false}if(!E&&H[G]&&!I.isDefaultPrevented()&&!(o.nodeName(H,"a")&&G=="click")){this.triggered=true;try{H[G]()}catch(L){}}this.triggered=false;if(!I.isPropagationStopped()){var F=H.parentNode||H.ownerDocument;if(F){o.event.trigger(I,K,F,true)}}},handle:function(K){var J,E;K=arguments[0]=o.event.fix(K||l.event);K.currentTarget=this;var L=K.type.split(".");K.type=L.shift();J=!L.length&&!K.exclusive;var I=RegExp("(^|\\.)"+L.slice().sort().join(".*\\.")+"(\\.|$)");E=(o.data(this,"events")||{})[K.type];for(var G in E){var H=E[G];if(J||I.test(H.type)){K.handler=H;K.data=H.data;var F=H.apply(this,arguments);if(F!==g){K.result=F;if(F===false){K.preventDefault();K.stopPropagation()}}if(K.isImmediatePropagationStopped()){break}}}},props:"altKey attrChange attrName bubbles button cancelable charCode clientX clientY ctrlKey currentTarget data detail eventPhase fromElement handler keyCode metaKey newValue originalTarget pageX pageY prevValue relatedNode relatedTarget screenX screenY shiftKey srcElement target toElement view wheelDelta which".split(" "),fix:function(H){if(H[h]){return H}var F=H;H=o.Event(F);for(var G=this.props.length,J;G;){J=this.props[--G];H[J]=F[J]}if(!H.target){H.target=H.srcElement||document}if(H.target.nodeType==3){H.target=H.target.parentNode}if(!H.relatedTarget&&H.fromElement){H.relatedTarget=H.fromElement==H.target?H.toElement:H.fromElement}if(H.pageX==null&&H.clientX!=null){var I=document.documentElement,E=document.body;H.pageX=H.clientX+(I&&I.scrollLeft||E&&E.scrollLeft||0)-(I.clientLeft||0);H.pageY=H.clientY+(I&&I.scrollTop||E&&E.scrollTop||0)-(I.clientTop||0)}if(!H.which&&((H.charCode||H.charCode===0)?H.charCode:H.keyCode)){H.which=H.charCode||H.keyCode}if(!H.metaKey&&H.ctrlKey){H.metaKey=H.ctrlKey}if(!H.which&&H.button){H.which=(H.button&1?1:(H.button&2?3:(H.button&4?2:0)))}return H},proxy:function(F,E){E=E||function(){return F.apply(this,arguments)};E.guid=F.guid=F.guid||E.guid||this.guid++;return E},special:{ready:{setup:B,teardown:function(){}}},specialAll:{live:{setup:function(E,F){o.event.add(this,F[0],c)},teardown:function(G){if(G.length){var E=0,F=RegExp("(^|\\.)"+G[0]+"(\\.|$)");o.each((o.data(this,"events").live||{}),function(){if(F.test(this.type)){E++}});if(E<1){o.event.remove(this,G[0],c)}}}}}};o.Event=function(E){if(!this.preventDefault){return new o.Event(E)}if(E&&E.type){this.originalEvent=E;this.type=E.type}else{this.type=E}this.timeStamp=e();this[h]=true};function k(){return false}function u(){return true}o.Event.prototype={preventDefault:function(){this.isDefaultPrevented=u;var E=this.originalEvent;if(!E){return}if(E.preventDefault){E.preventDefault()}E.returnValue=false},stopPropagation:function(){this.isPropagationStopped=u;var E=this.originalEvent;if(!E){return}if(E.stopPropagation){E.stopPropagation()}E.cancelBubble=true},stopImmediatePropagation:function(){this.isImmediatePropagationStopped=u;this.stopPropagation()},isDefaultPrevented:k,isPropagationStopped:k,isImmediatePropagationStopped:k};var a=function(F){var E=F.relatedTarget;while(E&&E!=this){try{E=E.parentNode}catch(G){E=this}}if(E!=this){F.type=F.data;o.event.handle.apply(this,arguments)}};o.each({mouseover:"mouseenter",mouseout:"mouseleave"},function(F,E){o.event.special[E]={setup:function(){o.event.add(this,F,a,E)},teardown:function(){o.event.remove(this,F,a)}}});o.fn.extend({bind:function(F,G,E){return F=="unload"?this.one(F,G,E):this.each(function(){o.event.add(this,F,E||G,E&&G)})},one:function(G,H,F){var E=o.event.proxy(F||H,function(I){o(this).unbind(I,E);return(F||H).apply(this,arguments)});return this.each(function(){o.event.add(this,G,E,F&&H)})},unbind:function(F,E){return this.each(function(){o.event.remove(this,F,E)})},trigger:function(E,F){return this.each(function(){o.event.trigger(E,F,this)})},triggerHandler:function(E,G){if(this[0]){var F=o.Event(E);F.preventDefault();F.stopPropagation();o.event.trigger(F,G,this[0]);return F.result}},toggle:function(G){var E=arguments,F=1;while(F<E.length){o.event.proxy(G,E[F++])}return this.click(o.event.proxy(G,function(H){this.lastToggle=(this.lastToggle||0)%F;H.preventDefault();return E[this.lastToggle++].apply(this,arguments)||false}))},hover:function(E,F){return this.mouseenter(E).mouseleave(F)},ready:function(E){B();if(o.isReady){E.call(document,o)}else{o.readyList.push(E)}return this},live:function(G,F){var E=o.event.proxy(F);E.guid+=this.selector+G;o(document).bind(i(G,this.selector),this.selector,E);return this},die:function(F,E){o(document).unbind(i(F,this.selector),E?{guid:E.guid+this.selector+F}:null);return this}});function c(H){var E=RegExp("(^|\\.)"+H.type+"(\\.|$)"),G=true,F=[];o.each(o.data(this,"events").live||[],function(I,J){if(E.test(J.type)){var K=o(H.target).closest(J.data)[0];if(K){F.push({elem:K,fn:J})}}});F.sort(function(J,I){return o.data(J.elem,"closest")-o.data(I.elem,"closest")});o.each(F,function(){if(this.fn.call(this.elem,H,this.fn.data)===false){return(G=false)}});return G}function i(F,E){return["live",F,E.replace(/\./g,"`").replace(/ /g,"|")].join(".")}o.extend({isReady:false,readyList:[],ready:function(){if(!o.isReady){o.isReady=true;if(o.readyList){o.each(o.readyList,function(){this.call(document,o)});o.readyList=null}o(document).triggerHandler("ready")}}});var x=false;function B(){if(x){return}x=true;if(document.addEventListener){document.addEventListener("DOMContentLoaded",function(){document.removeEventListener("DOMContentLoaded",arguments.callee,false);o.ready()},false)}else{if(document.attachEvent){document.attachEvent("onreadystatechange",function(){if(document.readyState==="complete"){document.detachEvent("onreadystatechange",arguments.callee);o.ready()}});if(document.documentElement.doScroll&&l==l.top){(function(){if(o.isReady){return}try{document.documentElement.doScroll("left")}catch(E){setTimeout(arguments.callee,0);return}o.ready()})()}}}o.event.add(l,"load",o.ready)}o.each(("blur,focus,load,resize,scroll,unload,click,dblclick,mousedown,mouseup,mousemove,mouseover,mouseout,mouseenter,mouseleave,change,select,submit,keydown,keypress,keyup,error").split(","),function(F,E){o.fn[E]=function(G){return G?this.bind(E,G):this.trigger(E)}});o(l).bind("unload",function(){for(var E in o.cache){if(E!=1&&o.cache[E].handle){o.event.remove(o.cache[E].handle.elem)}}});(function(){o.support={};var F=document.documentElement,G=document.createElement("script"),K=document.createElement("div"),J="script"+(new Date).getTime();K.style.display="none";K.innerHTML='   <link/><table></table><a href="/a" style="color:red;float:left;opacity:.5;">a</a><select><option>text</option></select><object><param/></object>';var H=K.getElementsByTagName("*"),E=K.getElementsByTagName("a")[0];if(!H||!H.length||!E){return}o.support={leadingWhitespace:K.firstChild.nodeType==3,tbody:!K.getElementsByTagName("tbody").length,objectAll:!!K.getElementsByTagName("object")[0].getElementsByTagName("*").length,htmlSerialize:!!K.getElementsByTagName("link").length,style:/red/.test(E.getAttribute("style")),hrefNormalized:E.getAttribute("href")==="/a",opacity:E.style.opacity==="0.5",cssFloat:!!E.style.cssFloat,scriptEval:false,noCloneEvent:true,boxModel:null};G.type="text/javascript";try{G.appendChild(document.createTextNode("window."+J+"=1;"))}catch(I){}F.insertBefore(G,F.firstChild);if(l[J]){o.support.scriptEval=true;delete l[J]}F.removeChild(G);if(K.attachEvent&&K.fireEvent){K.attachEvent("onclick",function(){o.support.noCloneEvent=false;K.detachEvent("onclick",arguments.callee)});K.cloneNode(true).fireEvent("onclick")}o(function(){var L=document.createElement("div");L.style.width=L.style.paddingLeft="1px";document.body.appendChild(L);o.boxModel=o.support.boxModel=L.offsetWidth===2;document.body.removeChild(L).style.display="none"})})();var w=o.support.cssFloat?"cssFloat":"styleFloat";o.props={"for":"htmlFor","class":"className","float":w,cssFloat:w,styleFloat:w,readonly:"readOnly",maxlength:"maxLength",cellspacing:"cellSpacing",rowspan:"rowSpan",tabindex:"tabIndex"};o.fn.extend({_load:o.fn.load,load:function(G,J,K){if(typeof G!=="string"){return this._load(G)}var I=G.indexOf(" ");if(I>=0){var E=G.slice(I,G.length);G=G.slice(0,I)}var H="GET";if(J){if(o.isFunction(J)){K=J;J=null}else{if(typeof J==="object"){J=o.param(J);H="POST"}}}var F=this;o.ajax({url:G,type:H,dataType:"html",data:J,complete:function(M,L){if(L=="success"||L=="notmodified"){F.html(E?o("<div/>").append(M.responseText.replace(/<script(.|\s)*?\/script>/g,"")).find(E):M.responseText)}if(K){F.each(K,[M.responseText,L,M])}}});return this},serialize:function(){return o.param(this.serializeArray())},serializeArray:function(){return this.map(function(){return this.elements?o.makeArray(this.elements):this}).filter(function(){return this.name&&!this.disabled&&(this.checked||/select|textarea/i.test(this.nodeName)||/text|hidden|password|search/i.test(this.type))}).map(function(E,F){var G=o(this).val();return G==null?null:o.isArray(G)?o.map(G,function(I,H){return{name:F.name,value:I}}):{name:F.name,value:G}}).get()}});o.each("ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","),function(E,F){o.fn[F]=function(G){return this.bind(F,G)}});var r=e();o.extend({get:function(E,G,H,F){if(o.isFunction(G)){H=G;G=null}return o.ajax({type:"GET",url:E,data:G,success:H,dataType:F})},getScript:function(E,F){return o.get(E,null,F,"script")},getJSON:function(E,F,G){return o.get(E,F,G,"json")},post:function(E,G,H,F){if(o.isFunction(G)){H=G;G={}}return o.ajax({type:"POST",url:E,data:G,success:H,dataType:F})},ajaxSetup:function(E){o.extend(o.ajaxSettings,E)},ajaxSettings:{url:location.href,global:true,type:"GET",contentType:"application/x-www-form-urlencoded",processData:true,async:true,xhr:function(){return l.ActiveXObject?new ActiveXObject("Microsoft.XMLHTTP"):new XMLHttpRequest()},accepts:{xml:"application/xml, text/xml",html:"text/html",script:"text/javascript, application/javascript",json:"application/json, text/javascript",text:"text/plain",_default:"*/*"}},lastModified:{},ajax:function(M){M=o.extend(true,M,o.extend(true,{},o.ajaxSettings,M));var W,F=/=\?(&|$)/g,R,V,G=M.type.toUpperCase();if(M.data&&M.processData&&typeof M.data!=="string"){M.data=o.param(M.data)}if(M.dataType=="jsonp"){if(G=="GET"){if(!M.url.match(F)){M.url+=(M.url.match(/\?/)?"&":"?")+(M.jsonp||"callback")+"=?"}}else{if(!M.data||!M.data.match(F)){M.data=(M.data?M.data+"&":"")+(M.jsonp||"callback")+"=?"}}M.dataType="json"}if(M.dataType=="json"&&(M.data&&M.data.match(F)||M.url.match(F))){W="jsonp"+r++;if(M.data){M.data=(M.data+"").replace(F,"="+W+"$1")}M.url=M.url.replace(F,"="+W+"$1");M.dataType="script";l[W]=function(X){V=X;I();L();l[W]=g;try{delete l[W]}catch(Y){}if(H){H.removeChild(T)}}}if(M.dataType=="script"&&M.cache==null){M.cache=false}if(M.cache===false&&G=="GET"){var E=e();var U=M.url.replace(/(\?|&)_=.*?(&|$)/,"$1_="+E+"$2");M.url=U+((U==M.url)?(M.url.match(/\?/)?"&":"?")+"_="+E:"")}if(M.data&&G=="GET"){M.url+=(M.url.match(/\?/)?"&":"?")+M.data;M.data=null}if(M.global&&!o.active++){o.event.trigger("ajaxStart")}var Q=/^(\w+:)?\/\/([^\/?#]+)/.exec(M.url);if(M.dataType=="script"&&G=="GET"&&Q&&(Q[1]&&Q[1]!=location.protocol||Q[2]!=location.host)){var H=document.getElementsByTagName("head")[0];var T=document.createElement("script");T.src=M.url;if(M.scriptCharset){T.charset=M.scriptCharset}if(!W){var O=false;T.onload=T.onreadystatechange=function(){if(!O&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){O=true;I();L();T.onload=T.onreadystatechange=null;H.removeChild(T)}}}H.appendChild(T);return g}var K=false;var J=M.xhr();if(M.username){J.open(G,M.url,M.async,M.username,M.password)}else{J.open(G,M.url,M.async)}try{if(M.data){J.setRequestHeader("Content-Type",M.contentType)}if(M.ifModified){J.setRequestHeader("If-Modified-Since",o.lastModified[M.url]||"Thu, 01 Jan 1970 00:00:00 GMT")}J.setRequestHeader("X-Requested-With","XMLHttpRequest");J.setRequestHeader("Accept",M.dataType&&M.accepts[M.dataType]?M.accepts[M.dataType]+", */*":M.accepts._default)}catch(S){}if(M.beforeSend&&M.beforeSend(J,M)===false){if(M.global&&!--o.active){o.event.trigger("ajaxStop")}J.abort();return false}if(M.global){o.event.trigger("ajaxSend",[J,M])}var N=function(X){if(J.readyState==0){if(P){clearInterval(P);P=null;if(M.global&&!--o.active){o.event.trigger("ajaxStop")}}}else{if(!K&&J&&(J.readyState==4||X=="timeout")){K=true;if(P){clearInterval(P);P=null}R=X=="timeout"?"timeout":!o.httpSuccess(J)?"error":M.ifModified&&o.httpNotModified(J,M.url)?"notmodified":"success";if(R=="success"){try{V=o.httpData(J,M.dataType,M)}catch(Z){R="parsererror"}}if(R=="success"){var Y;try{Y=J.getResponseHeader("Last-Modified")}catch(Z){}if(M.ifModified&&Y){o.lastModified[M.url]=Y}if(!W){I()}}else{o.handleError(M,J,R)}L();if(X){J.abort()}if(M.async){J=null}}}};if(M.async){var P=setInterval(N,13);if(M.timeout>0){setTimeout(function(){if(J&&!K){N("timeout")}},M.timeout)}}try{J.send(M.data)}catch(S){o.handleError(M,J,null,S)}if(!M.async){N()}function I(){if(M.success){M.success(V,R)}if(M.global){o.event.trigger("ajaxSuccess",[J,M])}}function L(){if(M.complete){M.complete(J,R)}if(M.global){o.event.trigger("ajaxComplete",[J,M])}if(M.global&&!--o.active){o.event.trigger("ajaxStop")}}return J},handleError:function(F,H,E,G){if(F.error){F.error(H,E,G)}if(F.global){o.event.trigger("ajaxError",[H,F,G])}},active:0,httpSuccess:function(F){try{return !F.status&&location.protocol=="file:"||(F.status>=200&&F.status<300)||F.status==304||F.status==1223}catch(E){}return false},httpNotModified:function(G,E){try{var H=G.getResponseHeader("Last-Modified");return G.status==304||H==o.lastModified[E]}catch(F){}return false},httpData:function(J,H,G){var F=J.getResponseHeader("content-type"),E=H=="xml"||!H&&F&&F.indexOf("xml")>=0,I=E?J.responseXML:J.responseText;if(E&&I.documentElement.tagName=="parsererror"){throw"parsererror"}if(G&&G.dataFilter){I=G.dataFilter(I,H)}if(typeof I==="string"){if(H=="script"){o.globalEval(I)}if(H=="json"){I=l["eval"]("("+I+")")}}return I},param:function(E){var G=[];function H(I,J){G[G.length]=encodeURIComponent(I)+"="+encodeURIComponent(J)}if(o.isArray(E)||E.jquery){o.each(E,function(){H(this.name,this.value)})}else{for(var F in E){if(o.isArray(E[F])){o.each(E[F],function(){H(F,this)})}else{H(F,o.isFunction(E[F])?E[F]():E[F])}}}return G.join("&").replace(/%20/g,"+")}});var m={},n,d=[["height","marginTop","marginBottom","paddingTop","paddingBottom"],["width","marginLeft","marginRight","paddingLeft","paddingRight"],["opacity"]];function t(F,E){var G={};o.each(d.concat.apply([],d.slice(0,E)),function(){G[this]=F});return G}o.fn.extend({show:function(J,L){if(J){return this.animate(t("show",3),J,L)}else{for(var H=0,F=this.length;H<F;H++){var E=o.data(this[H],"olddisplay");this[H].style.display=E||"";if(o.css(this[H],"display")==="none"){var G=this[H].tagName,K;if(m[G]){K=m[G]}else{var I=o("<"+G+" />").appendTo("body");K=I.css("display");if(K==="none"){K="block"}I.remove();m[G]=K}o.data(this[H],"olddisplay",K)}}for(var H=0,F=this.length;H<F;H++){this[H].style.display=o.data(this[H],"olddisplay")||""}return this}},hide:function(H,I){if(H){return this.animate(t("hide",3),H,I)}else{for(var G=0,F=this.length;G<F;G++){var E=o.data(this[G],"olddisplay");if(!E&&E!=="none"){o.data(this[G],"olddisplay",o.css(this[G],"display"))}}for(var G=0,F=this.length;G<F;G++){this[G].style.display="none"}return this}},_toggle:o.fn.toggle,toggle:function(G,F){var E=typeof G==="boolean";return o.isFunction(G)&&o.isFunction(F)?this._toggle.apply(this,arguments):G==null||E?this.each(function(){var H=E?G:o(this).is(":hidden");o(this)[H?"show":"hide"]()}):this.animate(t("toggle",3),G,F)},fadeTo:function(E,G,F){return this.animate({opacity:G},E,F)},animate:function(I,F,H,G){var E=o.speed(F,H,G);return this[E.queue===false?"each":"queue"](function(){var K=o.extend({},E),M,L=this.nodeType==1&&o(this).is(":hidden"),J=this;for(M in I){if(I[M]=="hide"&&L||I[M]=="show"&&!L){return K.complete.call(this)}if((M=="height"||M=="width")&&this.style){K.display=o.css(this,"display");K.overflow=this.style.overflow}}if(K.overflow!=null){this.style.overflow="hidden"}K.curAnim=o.extend({},I);o.each(I,function(O,S){var R=new o.fx(J,K,O);if(/toggle|show|hide/.test(S)){R[S=="toggle"?L?"show":"hide":S](I)}else{var Q=S.toString().match(/^([+-]=)?([\d+-.]+)(.*)$/),T=R.cur(true)||0;if(Q){var N=parseFloat(Q[2]),P=Q[3]||"px";if(P!="px"){J.style[O]=(N||1)+P;T=((N||1)/R.cur(true))*T;J.style[O]=T+P}if(Q[1]){N=((Q[1]=="-="?-1:1)*N)+T}R.custom(T,N,P)}else{R.custom(T,S,"")}}});return true})},stop:function(F,E){var G=o.timers;if(F){this.queue([])}this.each(function(){for(var H=G.length-1;H>=0;H--){if(G[H].elem==this){if(E){G[H](true)}G.splice(H,1)}}});if(!E){this.dequeue()}return this}});o.each({slideDown:t("show",1),slideUp:t("hide",1),slideToggle:t("toggle",1),fadeIn:{opacity:"show"},fadeOut:{opacity:"hide"}},function(E,F){o.fn[E]=function(G,H){return this.animate(F,G,H)}});o.extend({speed:function(G,H,F){var E=typeof G==="object"?G:{complete:F||!F&&H||o.isFunction(G)&&G,duration:G,easing:F&&H||H&&!o.isFunction(H)&&H};E.duration=o.fx.off?0:typeof E.duration==="number"?E.duration:o.fx.speeds[E.duration]||o.fx.speeds._default;E.old=E.complete;E.complete=function(){if(E.queue!==false){o(this).dequeue()}if(o.isFunction(E.old)){E.old.call(this)}};return E},easing:{linear:function(G,H,E,F){return E+F*G},swing:function(G,H,E,F){return((-Math.cos(G*Math.PI)/2)+0.5)*F+E}},timers:[],fx:function(F,E,G){this.options=E;this.elem=F;this.prop=G;if(!E.orig){E.orig={}}}});o.fx.prototype={update:function(){if(this.options.step){this.options.step.call(this.elem,this.now,this)}(o.fx.step[this.prop]||o.fx.step._default)(this);if((this.prop=="height"||this.prop=="width")&&this.elem.style){this.elem.style.display="block"}},cur:function(F){if(this.elem[this.prop]!=null&&(!this.elem.style||this.elem.style[this.prop]==null)){return this.elem[this.prop]}var E=parseFloat(o.css(this.elem,this.prop,F));return E&&E>-10000?E:parseFloat(o.curCSS(this.elem,this.prop))||0},custom:function(I,H,G){this.startTime=e();this.start=I;this.end=H;this.unit=G||this.unit||"px";this.now=this.start;this.pos=this.state=0;var E=this;function F(J){return E.step(J)}F.elem=this.elem;if(F()&&o.timers.push(F)&&!n){n=setInterval(function(){var K=o.timers;for(var J=0;J<K.length;J++){if(!K[J]()){K.splice(J--,1)}}if(!K.length){clearInterval(n);n=g}},13)}},show:function(){this.options.orig[this.prop]=o.attr(this.elem.style,this.prop);this.options.show=true;this.custom(this.prop=="width"||this.prop=="height"?1:0,this.cur());o(this.elem).show()},hide:function(){this.options.orig[this.prop]=o.attr(this.elem.style,this.prop);this.options.hide=true;this.custom(this.cur(),0)},step:function(H){var G=e();if(H||G>=this.options.duration+this.startTime){this.now=this.end;this.pos=this.state=1;this.update();this.options.curAnim[this.prop]=true;var E=true;for(var F in this.options.curAnim){if(this.options.curAnim[F]!==true){E=false}}if(E){if(this.options.display!=null){this.elem.style.overflow=this.options.overflow;this.elem.style.display=this.options.display;if(o.css(this.elem,"display")=="none"){this.elem.style.display="block"}}if(this.options.hide){o(this.elem).hide()}if(this.options.hide||this.options.show){for(var I in this.options.curAnim){o.attr(this.elem.style,I,this.options.orig[I])}}this.options.complete.call(this.elem)}return false}else{var J=G-this.startTime;this.state=J/this.options.duration;this.pos=o.easing[this.options.easing||(o.easing.swing?"swing":"linear")](this.state,J,0,1,this.options.duration);this.now=this.start+((this.end-this.start)*this.pos);this.update()}return true}};o.extend(o.fx,{speeds:{slow:600,fast:200,_default:400},step:{opacity:function(E){o.attr(E.elem.style,"opacity",E.now)},_default:function(E){if(E.elem.style&&E.elem.style[E.prop]!=null){E.elem.style[E.prop]=E.now+E.unit}else{E.elem[E.prop]=E.now}}}});if(document.documentElement.getBoundingClientRect){o.fn.offset=function(){if(!this[0]){return{top:0,left:0}}if(this[0]===this[0].ownerDocument.body){return o.offset.bodyOffset(this[0])}var G=this[0].getBoundingClientRect(),J=this[0].ownerDocument,F=J.body,E=J.documentElement,L=E.clientTop||F.clientTop||0,K=E.clientLeft||F.clientLeft||0,I=G.top+(self.pageYOffset||o.boxModel&&E.scrollTop||F.scrollTop)-L,H=G.left+(self.pageXOffset||o.boxModel&&E.scrollLeft||F.scrollLeft)-K;return{top:I,left:H}}}else{o.fn.offset=function(){if(!this[0]){return{top:0,left:0}}if(this[0]===this[0].ownerDocument.body){return o.offset.bodyOffset(this[0])}o.offset.initialized||o.offset.initialize();var J=this[0],G=J.offsetParent,F=J,O=J.ownerDocument,M,H=O.documentElement,K=O.body,L=O.defaultView,E=L.getComputedStyle(J,null),N=J.offsetTop,I=J.offsetLeft;while((J=J.parentNode)&&J!==K&&J!==H){M=L.getComputedStyle(J,null);N-=J.scrollTop,I-=J.scrollLeft;if(J===G){N+=J.offsetTop,I+=J.offsetLeft;if(o.offset.doesNotAddBorder&&!(o.offset.doesAddBorderForTableAndCells&&/^t(able|d|h)$/i.test(J.tagName))){N+=parseInt(M.borderTopWidth,10)||0,I+=parseInt(M.borderLeftWidth,10)||0}F=G,G=J.offsetParent}if(o.offset.subtractsBorderForOverflowNotVisible&&M.overflow!=="visible"){N+=parseInt(M.borderTopWidth,10)||0,I+=parseInt(M.borderLeftWidth,10)||0}E=M}if(E.position==="relative"||E.position==="static"){N+=K.offsetTop,I+=K.offsetLeft}if(E.position==="fixed"){N+=Math.max(H.scrollTop,K.scrollTop),I+=Math.max(H.scrollLeft,K.scrollLeft)}return{top:N,left:I}}}o.offset={initialize:function(){if(this.initialized){return}var L=document.body,F=document.createElement("div"),H,G,N,I,M,E,J=L.style.marginTop,K='<div style="position:absolute;top:0;left:0;margin:0;border:5px solid #000;padding:0;width:1px;height:1px;"><div></div></div><table style="position:absolute;top:0;left:0;margin:0;border:5px solid #000;padding:0;width:1px;height:1px;" cellpadding="0" cellspacing="0"><tr><td></td></tr></table>';M={position:"absolute",top:0,left:0,margin:0,border:0,width:"1px",height:"1px",visibility:"hidden"};for(E in M){F.style[E]=M[E]}F.innerHTML=K;L.insertBefore(F,L.firstChild);H=F.firstChild,G=H.firstChild,I=H.nextSibling.firstChild.firstChild;this.doesNotAddBorder=(G.offsetTop!==5);this.doesAddBorderForTableAndCells=(I.offsetTop===5);H.style.overflow="hidden",H.style.position="relative";this.subtractsBorderForOverflowNotVisible=(G.offsetTop===-5);L.style.marginTop="1px";this.doesNotIncludeMarginInBodyOffset=(L.offsetTop===0);L.style.marginTop=J;L.removeChild(F);this.initialized=true},bodyOffset:function(E){o.offset.initialized||o.offset.initialize();var G=E.offsetTop,F=E.offsetLeft;if(o.offset.doesNotIncludeMarginInBodyOffset){G+=parseInt(o.curCSS(E,"marginTop",true),10)||0,F+=parseInt(o.curCSS(E,"marginLeft",true),10)||0}return{top:G,left:F}}};o.fn.extend({position:function(){var I=0,H=0,F;if(this[0]){var G=this.offsetParent(),J=this.offset(),E=/^body|html$/i.test(G[0].tagName)?{top:0,left:0}:G.offset();J.top-=j(this,"marginTop");J.left-=j(this,"marginLeft");E.top+=j(G,"borderTopWidth");E.left+=j(G,"borderLeftWidth");F={top:J.top-E.top,left:J.left-E.left}}return F},offsetParent:function(){var E=this[0].offsetParent||document.body;while(E&&(!/^body|html$/i.test(E.tagName)&&o.css(E,"position")=="static")){E=E.offsetParent}return o(E)}});o.each(["Left","Top"],function(F,E){var G="scroll"+E;o.fn[G]=function(H){if(!this[0]){return null}return H!==g?this.each(function(){this==l||this==document?l.scrollTo(!F?H:o(l).scrollLeft(),F?H:o(l).scrollTop()):this[G]=H}):this[0]==l||this[0]==document?self[F?"pageYOffset":"pageXOffset"]||o.boxModel&&document.documentElement[G]||document.body[G]:this[0][G]}});o.each(["Height","Width"],function(I,G){var E=I?"Left":"Top",H=I?"Right":"Bottom",F=G.toLowerCase();o.fn["inner"+G]=function(){return this[0]?o.css(this[0],F,false,"padding"):null};o.fn["outer"+G]=function(K){return this[0]?o.css(this[0],F,false,K?"margin":"border"):null};var J=G.toLowerCase();o.fn[J]=function(K){return this[0]==l?document.compatMode=="CSS1Compat"&&document.documentElement["client"+G]||document.body["client"+G]:this[0]==document?Math.max(document.documentElement["client"+G],document.body["scroll"+G],document.documentElement["scroll"+G],document.body["offset"+G],document.documentElement["offset"+G]):K===g?(this.length?o.css(this[0],J):null):this.css(J,typeof K==="string"?K:K+"px")}})})();
\ No newline at end of file
Added: branches/google_dev/http/extensions/jquery-ui-1.7.1.custom.min.js
--- branches/google_dev/http/extensions/jquery-ui-1.7.1.custom.min.js	                        (rev 0)
+++ branches/google_dev/http/extensions/jquery-ui-1.7.1.custom.min.js	2009-06-02 15:29:26 UTC (rev 3982)
@@ -0,0 +1,34 @@
+ * jQuery UI 1.7.1
+ * Copyright (c) 2009 AUTHORS.txt (http://jqueryui.com/about)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * http://docs.jquery.com/UI
+jQuery.ui||(function(c){var i=c.fn.remove,d=c.browser.mozilla&&(parseFloat(c.browser.version)<1.9);c.ui={version:"1.7.1",plugin:{add:function(k,l,n){var m=c.ui[k].prototype;for(var j in n){m.plugins[j]=m.plugins[j]||[];m.plugins[j].push([l,n[j]])}},call:function(j,l,k){var n=j.plugins[l];if(!n||!j.element[0].parentNode){return}for(var m=0;m<n.length;m++){if(j.options[n[m][0]]){n[m][1].apply(j.element,k)}}}},contains:function(k,j){return document.compareDocumentPosition?k.compareDocumentPosition(j)&16:k!==j&&k.contains(j)},hasScroll:function(m,k){if(c(m).css("overflow")=="hidden"){return false}var j=(k&&k=="left")?"scrollLeft":"scrollTop",l=false;if(m[j]>0){return true}m[j]=1;l=(m[j]>0);m[j]=0;return l},isOverAxis:function(k,j,l){return(k>j)&&(k<(j+l))},isOver:function(o,k,n,m,j,l){return c.ui.isOverAxis(o,n,j)&&c.ui.isOverAxis(k,m,l)},keyCode:{BACKSPACE:8,CAPS_LOCK:20,COMMA:188,CONTROL:17,DELETE:46,DOWN:40,END:35,ENTER:13,ESCAPE:27,HOME:36,INSERT:45,LEFT:37,NUMPAD_ADD:107,NUMPAD_DECIMAL:110,NUMPAD_DIVIDE:111,NUMPAD_ENTER:108,NUMPAD_MULTIPLY:106,NUMPAD_SUBTRACT:109,PAGE_DOWN:34,PAGE_UP:33,PERIOD:190,RIGHT:39,SHIFT:16,SPACE:32,TAB:9,UP:38}};if(d){var f=c.attr,e=c.fn.removeAttr,h="http://www.w3.org/2005/07/aaa",a=/^aria-/,b=/^wairole:/;c.attr=function(k,j,l){var m=l!==undefined;return(j=="role"?(m?f.call(this,k,j,"wairole:"+l):(f.apply(this,arguments)||"").replace(b,"")):(a.test(j)?(m?k.setAttributeNS(h,j.replace(a,"aaa:"),l):f.call(this,k,j.replace(a,"aaa:"))):f.apply(this,arguments)))};c.fn.removeAttr=function(j){return(a.test(j)?this.each(function(){this.removeAttributeNS(h,j.replace(a,""))}):e.call(this,j))}}c.fn.extend({remove:function(){c("*",this).add(this).each(function(){c(this).triggerHandler("remove")});return i.apply(this,arguments)},enableSelection:function(){return this.attr("unselectable","off").css("MozUserSelect","").unbind("selectstart.ui")},disableSelection:function(){return this.attr("unselectable","on").css("MozUserSelect","none").bind("selectstart.ui",function(){return false})},scrollParent:function(){var j;if((c.browser.msie&&(/(static|relative)/).test(this.css("position")))||(/absolute/).test(this.css("position"))){j=this.parents().filter(function(){return(/(relative|absolute|fixed)/).test(c.curCSS(this,"position",1))&&(/(auto|scroll)/).test(c.curCSS(this,"overflow",1)+c.curCSS(this,"overflow-y",1)+c.curCSS(this,"overflow-x",1))}).eq(0)}else{j=this.parents().filter(function(){return(/(auto|scroll)/).test(c.curCSS(this,"overflow",1)+c.curCSS(this,"overflow-y",1)+c.curCSS(this,"overflow-x",1))}).eq(0)}return(/fixed/).test(this.css("position"))||!j.length?c(document):j}});c.extend(c.expr[":"],{data:function(l,k,j){return !!c.data(l,j[3])},focusable:function(k){var l=k.nodeName.toLowerCase(),j=c.attr(k,"tabindex");return(/input|select|textarea|button|object/.test(l)?!k.disabled:"a"==l||"area"==l?k.href||!isNaN(j):!isNaN(j))&&!c(k)["area"==l?"parents":"closest"](":hidden").length},tabbable:function(k){var j=c.attr(k,"tabindex");return(isNaN(j)||j>=0)&&c(k).is(":focusable")}});function g(m,n,o,l){function k(q){var p=c[m][n][q]||[];return(typeof p=="string"?p.split(/,?\s+/):p)}var j=k("getter");if(l.length==1&&typeof l[0]=="string"){j=j.concat(k("getterSetter"))}return(c.inArray(o,j)!=-1)}c.widget=function(k,j){var l=k.split(".")[0];k=k.split(".")[1];c.fn[k]=function(p){var n=(typeof p=="string"),o=Array.prototype.slice.call(arguments,1);if(n&&p.substring(0,1)=="_"){return this}if(n&&g(l,k,p,o)){var m=c.data(this[0],k);return(m?m[p].apply(m,o):undefined)}return this.each(function(){var q=c.data(this,k);(!q&&!n&&c.data(this,k,new c[l][k](this,p))._init());(q&&n&&c.isFunction(q[p])&&q[p].apply(q,o))})};c[l]=c[l]||{};c[l][k]=function(o,n){var m=this;this.namespace=l;this.widgetName=k;this.widgetEventPrefix=c[l][k].eventPrefix||k;this.widgetBaseClass=l+"-"+k;this.options=c.extend({},c.widget.defaults,c[l][k].defaults,c.metadata&&c.metadata.get(o)[k],n);this.element=c(o).bind("setData."+k,function(q,p,r){if(q.target==o){return m._setData(p,r)}}).bind("getData."+k,function(q,p){if(q.target==o){return m._getData(p)}}).bind("remove",function(){return m.destroy()})};c[l][k].prototype=c.extend({},c.widget.prototype,j);c[l][k].getterSetter="option"};c.widget.prototype={_init:function(){},destroy:function(){this.element.removeData(this.widgetName).removeClass(this.widgetBaseClass+"-disabled "+this.namespace+"-state-disabled").removeAttr("aria-disabled")},option:function(l,m){var k=l,j=this;if(typeof l=="string"){if(m===undefined){return this._getData(l)}k={};k[l]=m}c.each(k,function(n,o){j._setData(n,o)})},_getData:function(j){return this.options[j]},_setData:function(j,k){this.options[j]=k;if(j=="disabled"){this.element[k?"addClass":"removeClass"](this.widgetBaseClass+"-disabled "+this.namespace+"-state-disabled").attr("aria-disabled",k)}},enable:function(){this._setData("disabled",false)},disable:function(){this._setData("disabled",true)},_trigger:function(l,m,n){var p=this.options[l],j=(l==this.widgetEventPrefix?l:this.widgetEventPrefix+l);m=c.Event(m);m.type=j;if(m.originalEvent){for(var k=c.event.props.length,o;k;){o=c.event.props[--k];m[o]=m.originalEvent[o]}}this.element.trigger(m,n);return !(c.isFunction(p)&&p.call(this.element[0],m,n)===false||m.isDefaultPrevented())}};c.widget.defaults={disabled:false};c.ui.mouse={_mouseInit:function(){var j=this;this.element.bind("mousedown."+this.widgetName,function(k){return j._mouseDown(k)}).bind("click."+this.widgetName,function(k){if(j._preventClickEvent){j._preventClickEvent=false;k.stopImmediatePropagation();return false}});if(c.browser.msie){this._mouseUnselectable=this.element.attr("unselectable");this.element.attr("unselectable","on")}this.started=false},_mouseDestroy:function(){this.element.unbind("."+this.widgetName);(c.browser.msie&&this.element.attr("unselectable",this._mouseUnselectable))},_mouseDown:function(l){l.originalEvent=l.originalEvent||{};if(l.originalEvent.mouseHandled){return}(this._mouseStarted&&this._mouseUp(l));this._mouseDownEvent=l;var k=this,m=(l.which==1),j=(typeof this.options.cancel=="string"?c(l.target).parents().add(l.target).filter(this.options.cancel).length:false);if(!m||j||!this._mouseCapture(l)){return true}this.mouseDelayMet=!this.options.delay;if(!this.mouseDelayMet){this._mouseDelayTimer=setTimeout(function(){k.mouseDelayMet=true},this.options.delay)}if(this._mouseDistanceMet(l)&&this._mouseDelayMet(l)){this._mouseStarted=(this._mouseStart(l)!==false);if(!this._mouseStarted){l.preventDefault();return true}}this._mouseMoveDelegate=function(n){return k._mouseMove(n)};this._mouseUpDelegate=function(n){return k._mouseUp(n)};c(document).bind("mousemove."+this.widgetName,this._mouseMoveDelegate).bind("mouseup."+this.widgetName,this._mouseUpDelegate);(c.browser.safari||l.preventDefault());l.originalEvent.mouseHandled=true;return true},_mouseMove:function(j){if(c.browser.msie&&!j.button){return this._mouseUp(j)}if(this._mouseStarted){this._mouseDrag(j);return j.preventDefault()}if(this._mouseDistanceMet(j)&&this._mouseDelayMet(j)){this._mouseStarted=(this._mouseStart(this._mouseDownEvent,j)!==false);(this._mouseStarted?this._mouseDrag(j):this._mouseUp(j))}return !this._mouseStarted},_mouseUp:function(j){c(document).unbind("mousemove."+this.widgetName,this._mouseMoveDelegate).unbind("mouseup."+this.widgetName,this._mouseUpDelegate);if(this._mouseStarted){this._mouseStarted=false;this._preventClickEvent=(j.target==this._mouseDownEvent.target);this._mouseStop(j)}return false},_mouseDistanceMet:function(j){return(Math.max(Math.abs(this._mouseDownEvent.pageX-j.pageX),Math.abs(this._mouseDownEvent.pageY-j.pageY))>=this.options.distance)},_mouseDelayMet:function(j){return this.mouseDelayMet},_mouseStart:function(j){},_mouseDrag:function(j){},_mouseStop:function(j){},_mouseCapture:function(j){return true}};c.ui.mouse.defaults={cancel:null,distance:1,delay:0}})(jQuery);;/*
+ * jQuery UI Draggable 1.7.1
+ * http://docs.jquery.com/UI/Draggables
+ * Depends:
+ *	ui.core.js
+(function(a){a.widget("ui.draggable",a.extend({},a.ui.mouse,{_init:function(){if(this.options.helper=="original"&&!(/^(?:r|a|f)/).test(this.element.css("position"))){this.element[0].style.position="relative"}(this.options.addClasses&&this.element.addClass("ui-draggable"));(this.options.disabled&&this.element.addClass("ui-draggable-disabled"));this._mouseInit()},destroy:function(){if(!this.element.data("draggable")){return}this.element.removeData("draggable").unbind(".draggable").removeClass("ui-draggable ui-draggable-dragging ui-draggable-disabled");this._mouseDestroy()},_mouseCapture:function(b){var c=this.options;if(this.helper||c.disabled||a(b.target).is(".ui-resizable-handle")){return false}this.handle=this._getHandle(b);if(!this.handle){return false}return true},_mouseStart:function(b){var c=this.options;this.helper=this._createHelper(b);this._cacheHelperProportions();if(a.ui.ddmanager){a.ui.ddmanager.current=this}this._cacheMargins();this.cssPosition=this.helper.css("position");this.scrollParent=this.helper.scrollParent();this.offset=this.element.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};a.extend(this.offset,{click:{left:b.pageX-this.offset.left,top:b.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(b);this.originalPageX=b.pageX;this.originalPageY=b.pageY;if(c.cursorAt){this._adjustOffsetFromHelper(c.cursorAt)}if(c.containment){this._setContainment()}this._trigger("start",b);this._cacheHelperProportions();if(a.ui.ddmanager&&!c.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,b)}this.helper.addClass("ui-draggable-dragging");this._mouseDrag(b,true);return true},_mouseDrag:function(b,d){this.position=this._generatePosition(b);this.positionAbs=this._convertPositionTo("absolute");if(!d){var c=this._uiHash();this._trigger("drag",b,c);this.position=c.position}if(!this.options.axis||this.options.axis!="y"){this.helper[0].style.left=this.position.left+"px"}if(!this.options.axis||this.options.axis!="x"){this.helper[0].style.top=this.position.top+"px"}if(a.ui.ddmanager){a.ui.ddmanager.drag(this,b)}return false},_mouseStop:function(c){var d=false;if(a.ui.ddmanager&&!this.options.dropBehaviour){d=a.ui.ddmanager.drop(this,c)}if(this.dropped){d=this.dropped;this.dropped=false}if((this.options.revert=="invalid"&&!d)||(this.options.revert=="valid"&&d)||this.options.revert===true||(a.isFunction(this.options.revert)&&this.options.revert.call(this.element,d))){var b=this;a(this.helper).animate(this.originalPosition,parseInt(this.options.revertDuration,10),function(){b._trigger("stop",c);b._clear()})}else{this._trigger("stop",c);this._clear()}return false},_getHandle:function(b){var c=!this.options.handle||!a(this.options.handle,this.element).length?true:false;a(this.options.handle,this.element).find("*").andSelf().each(function(){if(this==b.target){c=true}});return c},_createHelper:function(c){var d=this.options;var b=a.isFunction(d.helper)?a(d.helper.apply(this.element[0],[c])):(d.helper=="clone"?this.element.clone():this.element);if(!b.parents("body").length){b.appendTo((d.appendTo=="parent"?this.element[0].parentNode:d.appendTo))}if(b[0]!=this.element[0]&&!(/(fixed|absolute)/).test(b.css("position"))){b.css("position","absolute")}return b},_adjustOffsetFromHelper:function(b){if(b.left!=undefined){this.offset.click.left=b.left+this.margins.left}if(b.right!=undefined){this.offset.click.left=this.helperProportions.width-b.right+this.margins.left}if(b.top!=undefined){this.offset.click.top=b.top+this.margins.top}if(b.bottom!=undefined){this.offset.click.top=this.helperProportions.height-b.bottom+this.margins.top}},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var b=this.offsetParent.offset();if(this.cssPosition=="absolute"&&this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0])){b.left+=this.scrollParent.scrollLeft();b.top+=this.scrollParent.scrollTop()}if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=="html"&&a.browser.msie)){b={top:0,left:0}}return{top:b.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:b.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)}},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var b=this.element.position();return{top:b.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:b.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()}}else{return{top:0,left:0}}},_cacheMargins:function(){this.margins={left:(parseInt(this.element.css("marginLeft"),10)||0),top:(parseInt(this.element.css("marginTop"),10)||0)}},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()}},_setContainment:function(){var e=this.options;if(e.containment=="parent"){e.containment=this.helper[0].parentNode}if(e.containment=="document"||e.containment=="window"){this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,a(e.containment=="document"?document:window).width()-this.helperProportions.width-this.margins.left,(a(e.containment=="document"?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top]}if(!(/^(document|window|parent)$/).test(e.containment)&&e.containment.constructor!=Array){var c=a(e.containment)[0];if(!c){return}var d=a(e.containment).offset();var b=(a(c).css("overflow")!="hidden");this.containment=[d.left+(parseInt(a(c).css("borderLeftWidth"),10)||0)+(parseInt(a(c).css("paddingLeft"),10)||0)-this.margins.left,d.top+(parseInt(a(c).css("borderTopWidth"),10)||0)+(parseInt(a(c).css("paddingTop"),10)||0)-this.margins.top,d.left+(b?Math.max(c.scrollWidth,c.offsetWidth):c.offsetWidth)-(parseInt(a(c).css("borderLeftWidth"),10)||0)-(parseInt(a(c).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,d.top+(b?Math.max(c.scrollHeight,c.offsetHeight):c.offsetHeight)-(parseInt(a(c).css("borderTopWidth"),10)||0)-(parseInt(a(c).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top]}else{if(e.containment.constructor==Array){this.containment=e.containment}}},_convertPositionTo:function(f,h){if(!h){h=this.position}var c=f=="absolute"?1:-1;var e=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,g=(/(html|body)/i).test(b[0].tagName);return{top:(h.top+this.offset.relative.top*c+this.offset.parent.top*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(g?0:b.scrollTop()))*c)),left:(h.left+this.offset.relative.left*c+this.offset.parent.left*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():g?0:b.scrollLeft())*c))}},_generatePosition:function(e){var h=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,i=(/(html|body)/i).test(b[0].tagName);if(this.cssPosition=="relative"&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset()}var d=e.pageX;var c=e.pageY;if(this.originalPosition){if(this.containment){if(e.pageX-this.offset.click.left<this.containment[0]){d=this.containment[0]+this.offset.click.left}if(e.pageY-this.offset.click.top<this.containment[1]){c=this.containment[1]+this.offset.click.top}if(e.pageX-this.offset.click.left>this.containment[2]){d=this.containment[2]+this.offset.click.left}if(e.pageY-this.offset.click.top>this.containment[3]){c=this.containment[3]+this.offset.click.top}}if(h.grid){var g=this.originalPageY+Math.round((c-this.originalPageY)/h.grid[1])*h.grid[1];c=this.containment?(!(g-this.offset.click.top<this.containment[1]||g-this.offset.click.top>this.containment[3])?g:(!(g-this.offset.click.top<this.containment[1])?g-h.grid[1]:g+h.grid[1])):g;var f=this.originalPageX+Math.round((d-this.originalPageX)/h.grid[0])*h.grid[0];d=this.containment?(!(f-this.offset.click.left<this.containment[0]||f-this.offset.click.left>this.containment[2])?f:(!(f-this.offset.click.left<this.containment[0])?f-h.grid[0]:f+h.grid[0])):f}}return{top:(c-this.offset.click.top-this.offset.relative.top-this.offset.parent.top+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(i?0:b.scrollTop())))),left:(d-this.offset.click.left-this.offset.relative.left-this.offset.parent.left+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():i?0:b.scrollLeft())))}},_clear:function(){this.helper.removeClass("ui-draggable-dragging");if(this.helper[0]!=this.element[0]&&!this.cancelHelperRemoval){this.helper.remove()}this.helper=null;this.cancelHelperRemoval=false},_trigger:function(b,c,d){d=d||this._uiHash();a.ui.plugin.call(this,b,[c,d]);if(b=="drag"){this.positionAbs=this._convertPositionTo("absolute")}return a.widget.prototype._trigger.call(this,b,c,d)},plugins:{},_uiHash:function(b){return{helper:this.helper,position:this.position,absolutePosition:this.positionAbs,offset:this.positionAbs}}}));a.extend(a.ui.draggable,{version:"1.7.1",eventPrefix:"drag",defaults:{addClasses:true,appendTo:"parent",axis:false,cancel:":input,option",connectToSortable:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,grid:false,handle:false,helper:"original",iframeFix:false,opacity:false,refreshPositions:false,revert:false,revertDuration:500,scope:"default",scroll:true,scrollSensitivity:20,scrollSpeed:20,snap:false,snapMode:"both",snapTolerance:20,stack:false,zIndex:false}});a.ui.plugin.add("draggable","connectToSortable",{start:function(c,e){var d=a(this).data("draggable"),f=d.options,b=a.extend({},e,{item:d.element});d.sortables=[];a(f.connectToSortable).each(function(){var g=a.data(this,"sortable");if(g&&!g.options.disabled){d.sortables.push({instance:g,shouldRevert:g.options.revert});g._refreshItems();g._trigger("activate",c,b)}})},stop:function(c,e){var d=a(this).data("draggable"),b=a.extend({},e,{item:d.element});a.each(d.sortables,function(){if(this.instance.isOver){this.instance.isOver=0;d.cancelHelperRemoval=true;this.instance.cancelHelperRemoval=false;if(this.shouldRevert){this.instance.options.revert=true}this.instance._mouseStop(c);this.instance.options.helper=this.instance.options._helper;if(d.options.helper=="original"){this.instance.currentItem.css({top:"auto",left:"auto"})}}else{this.instance.cancelHelperRemoval=false;this.instance._trigger("deactivate",c,b)}})},drag:function(c,f){var e=a(this).data("draggable"),b=this;var d=function(i){var n=this.offset.click.top,m=this.offset.click.left;var g=this.positionAbs.top,k=this.positionAbs.left;var j=i.height,l=i.width;var p=i.top,h=i.left;return a.ui.isOver(g+n,k+m,p,h,j,l)};a.each(e.sortables,function(g){this.instance.positionAbs=e.positionAbs;this.instance.helperProportions=e.helperProportions;this.instance.offset.click=e.offset.click;if(this.instance._intersectsWith(this.instance.containerCache)){if(!this.instance.isOver){this.instance.isOver=1;this.instance.currentItem=a(b).clone().appendTo(this.instance.element).data("sortable-item",true);this.instance.options._helper=this.instance.options.helper;this.instance.options.helper=function(){return f.helper[0]};c.target=this.instance.currentItem[0];this.instance._mouseCapture(c,true);this.instance._mouseStart(c,true,true);this.instance.offset.click.top=e.offset.click.top;this.instance.offset.click.left=e.offset.click.left;this.instance.offset.parent.left-=e.offset.parent.left-this.instance.offset.parent.left;this.instance.offset.parent.top-=e.offset.parent.top-this.instance.offset.parent.top;e._trigger("toSortable",c);e.dropped=this.instance.element;e.currentItem=e.element;this.instance.fromOutside=e}if(this.instance.currentItem){this.instance._mouseDrag(c)}}else{if(this.instance.isOver){this.instance.isOver=0;this.instance.cancelHelperRemoval=true;this.instance.options.revert=false;this.instance._trigger("out",c,this.instance._uiHash(this.instance));this.instance._mouseStop(c,true);this.instance.options.helper=this.instance.options._helper;this.instance.currentItem.remove();if(this.instance.placeholder){this.instance.placeholder.remove()}e._trigger("fromSortable",c);e.dropped=false}}})}});a.ui.plugin.add("draggable","cursor",{start:function(c,d){var b=a("body"),e=a(this).data("draggable").options;if(b.css("cursor")){e._cursor=b.css("cursor")}b.css("cursor",e.cursor)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._cursor){a("body").css("cursor",d._cursor)}}});a.ui.plugin.add("draggable","iframeFix",{start:function(b,c){var d=a(this).data("draggable").options;a(d.iframeFix===true?"iframe":d.iframeFix).each(function(){a('<div class="ui-draggable-iframeFix" style="background: #fff;"></div>').css({width:this.offsetWidth+"px",height:this.offsetHeight+"px",position:"absolute",opacity:"0.001",zIndex:1000}).css(a(this).offset()).appendTo("body")})},stop:function(b,c){a("div.ui-draggable-iframeFix").each(function(){this.parentNode.removeChild(this)})}});a.ui.plugin.add("draggable","opacity",{start:function(c,d){var b=a(d.helper),e=a(this).data("draggable").options;if(b.css("opacity")){e._opacity=b.css("opacity")}b.css("opacity",e.opacity)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._opacity){a(c.helper).css("opacity",d._opacity)}}});a.ui.plugin.add("draggable","scroll",{start:function(c,d){var b=a(this).data("draggable");if(b.scrollParent[0]!=document&&b.scrollParent[0].tagName!="HTML"){b.overflowOffset=b.scrollParent.offset()}},drag:function(d,e){var c=a(this).data("draggable"),f=c.options,b=false;if(c.scrollParent[0]!=document&&c.scrollParent[0].tagName!="HTML"){if(!f.axis||f.axis!="x"){if((c.overflowOffset.top+c.scrollParent[0].offsetHeight)-d.pageY<f.scrollSensitivity){c.scrollParent[0].scrollTop=b=c.scrollParent[0].scrollTop+f.scrollSpeed}else{if(d.pageY-c.overflowOffset.top<f.scrollSensitivity){c.scrollParent[0].scrollTop=b=c.scrollParent[0].scrollTop-f.scrollSpeed}}}if(!f.axis||f.axis!="y"){if((c.overflowOffset.left+c.scrollParent[0].offsetWidth)-d.pageX<f.scrollSensitivity){c.scrollParent[0].scrollLeft=b=c.scrollParent[0].scrollLeft+f.scrollSpeed}else{if(d.pageX-c.overflowOffset.left<f.scrollSensitivity){c.scrollParent[0].scrollLeft=b=c.scrollParent[0].scrollLeft-f.scrollSpeed}}}}else{if(!f.axis||f.axis!="x"){if(d.pageY-a(document).scrollTop()<f.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()-f.scrollSpeed)}else{if(a(window).height()-(d.pageY-a(document).scrollTop())<f.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()+f.scrollSpeed)}}}if(!f.axis||f.axis!="y"){if(d.pageX-a(document).scrollLeft()<f.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()-f.scrollSpeed)}else{if(a(window).width()-(d.pageX-a(document).scrollLeft())<f.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()+f.scrollSpeed)}}}}if(b!==false&&a.ui.ddmanager&&!f.dropBehaviour){a.ui.ddmanager.prepareOffsets(c,d)}}});a.ui.plugin.add("draggable","snap",{start:function(c,d){var b=a(this).data("draggable"),e=b.options;b.snapElements=[];a(e.snap.constructor!=String?(e.snap.items||":data(draggable)"):e.snap).each(function(){var g=a(this);var f=g.offset();if(this!=b.element[0]){b.snapElements.push({item:this,width:g.outerWidth(),height:g.outerHeight(),top:f.top,left:f.left})}})},drag:function(u,p){var g=a(this).data("draggable"),q=g.options;var y=q.snapTolerance;var x=p.offset.left,w=x+g.helperProportions.width,f=p.offset.top,e=f+g.helperProportions.height;for(var v=g.snapElements.length-1;v>=0;v--){var s=g.snapElements[v].left,n=s+g.snapElements[v].width,m=g.snapElements[v].top,A=m+g.snapElements[v].height;if(!((s-y<x&&x<n+y&&m-y<f&&f<A+y)||(s-y<x&&x<n+y&&m-y<e&&e<A+y)||(s-y<w&&w<n+y&&m-y<f&&f<A+y)||(s-y<w&&w<n+y&&m-y<e&&e<A+y))){if(g.snapElements[v].snapping){(g.options.snap.release&&g.options.snap.release.call(g.element,u,a.extend(g._uiHash(),{snapItem:g.snapElements[v].item})))}g.snapElements[v].snapping=false;continue}if(q.snapMode!="inner"){var c=Math.abs(m-e)<=y;var z=Math.abs(A-f)<=y;var j=Math.abs(s-w)<=y;var k=Math.abs(n-x)<=y;if(c){p.position.top=g._convertPositionTo("relative",{top:m-g.helperProportions.height,left:0}).top-g.margins.top}if(z){p.position.top=g._convertPositionTo("relative",{top:A,left:0}).top-g.margins.top}if(j){p.position.left=g._convertPositionTo("relative",{top:0,left:s-g.helperProportions.width}).left-g.margins.left}if(k){p.position.left=g._convertPositionTo("relative",{top:0,left:n}).left-g.margins.left}}var h=(c||z||j||k);if(q.snapMode!="outer"){var c=Math.abs(m-f)<=y;var z=Math.abs(A-e)<=y;var j=Math.abs(s-x)<=y;var k=Math.abs(n-w)<=y;if(c){p.position.top=g._convertPositionTo("relative",{top:m,left:0}).top-g.margins.top}if(z){p.position.top=g._convertPositionTo("relative",{top:A-g.helperProportions.height,left:0}).top-g.margins.top}if(j){p.position.left=g._convertPositionTo("relative",{top:0,left:s}).left-g.margins.left}if(k){p.position.left=g._convertPositionTo("relative",{top:0,left:n-g.helperProportions.width}).left-g.margins.left}}if(!g.snapElements[v].snapping&&(c||z||j||k||h)){(g.options.snap.snap&&g.options.snap.snap.call(g.element,u,a.extend(g._uiHash(),{snapItem:g.snapElements[v].item})))}g.snapElements[v].snapping=(c||z||j||k||h)}}});a.ui.plugin.add("draggable","stack",{start:function(b,c){var e=a(this).data("draggable").options;var d=a.makeArray(a(e.stack.group)).sort(function(g,f){return(parseInt(a(g).css("zIndex"),10)||e.stack.min)-(parseInt(a(f).css("zIndex"),10)||e.stack.min)});a(d).each(function(f){this.style.zIndex=e.stack.min+f});this[0].style.zIndex=e.stack.min+d.length}});a.ui.plugin.add("draggable","zIndex",{start:function(c,d){var b=a(d.helper),e=a(this).data("draggable").options;if(b.css("zIndex")){e._zIndex=b.css("zIndex")}b.css("zIndex",e.zIndex)},stop:function(b,c){var d=a(this).data("draggable").options;if(d._zIndex){a(c.helper).css("zIndex",d._zIndex)}}})})(jQuery);;/*
+ * jQuery UI Sortable 1.7.1
+ * http://docs.jquery.com/UI/Sortables
+ * Depends:
+ *	ui.core.js
+(function(a){a.widget("ui.sortable",a.extend({},a.ui.mouse,{_init:function(){var b=this.options;this.containerCache={};this.element.addClass("ui-sortable");this.refresh();this.floating=this.items.length?(/left|right/).test(this.items[0].item.css("float")):false;this.offset=this.element.offset();this._mouseInit()},destroy:function(){this.element.removeClass("ui-sortable ui-sortable-disabled").removeData("sortable").unbind(".sortable");this._mouseDestroy();for(var b=this.items.length-1;b>=0;b--){this.items[b].item.removeData("sortable-item")}},_mouseCapture:function(e,f){if(this.reverting){return false}if(this.options.disabled||this.options.type=="static"){return false}this._refreshItems(e);var d=null,c=this,b=a(e.target).parents().each(function(){if(a.data(this,"sortable-item")==c){d=a(this);return false}});if(a.data(e.target,"sortable-item")==c){d=a(e.target)}if(!d){return false}if(this.options.handle&&!f){var g=false;a(this.options.handle,d).find("*").andSelf().each(function(){if(this==e.target){g=true}});if(!g){return false}}this.currentItem=d;this._removeCurrentsFromItems();return true},_mouseStart:function(e,f,b){var g=this.options,c=this;this.currentContainer=this;this.refreshPositions();this.helper=this._createHelper(e);this._cacheHelperProportions();this._cacheMargins();this.scrollParent=this.helper.scrollParent();this.offset=this.currentItem.offset();this.offset={top:this.offset.top-this.margins.top,left:this.offset.left-this.margins.left};this.helper.css("position","absolute");this.cssPosition=this.helper.css("position");a.extend(this.offset,{click:{left:e.pageX-this.offset.left,top:e.pageY-this.offset.top},parent:this._getParentOffset(),relative:this._getRelativeOffset()});this.originalPosition=this._generatePosition(e);this.originalPageX=e.pageX;this.originalPageY=e.pageY;if(g.cursorAt){this._adjustOffsetFromHelper(g.cursorAt)}this.domPosition={prev:this.currentItem.prev()[0],parent:this.currentItem.parent()[0]};if(this.helper[0]!=this.currentItem[0]){this.currentItem.hide()}this._createPlaceholder();if(g.containment){this._setContainment()}if(g.cursor){if(a("body").css("cursor")){this._storedCursor=a("body").css("cursor")}a("body").css("cursor",g.cursor)}if(g.opacity){if(this.helper.css("opacity")){this._storedOpacity=this.helper.css("opacity")}this.helper.css("opacity",g.opacity)}if(g.zIndex){if(this.helper.css("zIndex")){this._storedZIndex=this.helper.css("zIndex")}this.helper.css("zIndex",g.zIndex)}if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!="HTML"){this.overflowOffset=this.scrollParent.offset()}this._trigger("start",e,this._uiHash());if(!this._preserveHelperProportions){this._cacheHelperProportions()}if(!b){for(var d=this.containers.length-1;d>=0;d--){this.containers[d]._trigger("activate",e,c._uiHash(this))}}if(a.ui.ddmanager){a.ui.ddmanager.current=this}if(a.ui.ddmanager&&!g.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,e)}this.dragging=true;this.helper.addClass("ui-sortable-helper");this._mouseDrag(e);return true},_mouseDrag:function(f){this.position=this._generatePosition(f);this.positionAbs=this._convertPositionTo("absolute");if(!this.lastPositionAbs){this.lastPositionAbs=this.positionAbs}if(this.options.scroll){var g=this.options,b=false;if(this.scrollParent[0]!=document&&this.scrollParent[0].tagName!="HTML"){if((this.overflowOffset.top+this.scrollParent[0].offsetHeight)-f.pageY<g.scrollSensitivity){this.scrollParent[0].scrollTop=b=this.scrollParent[0].scrollTop+g.scrollSpeed}else{if(f.pageY-this.overflowOffset.top<g.scrollSensitivity){this.scrollParent[0].scrollTop=b=this.scrollParent[0].scrollTop-g.scrollSpeed}}if((this.overflowOffset.left+this.scrollParent[0].offsetWidth)-f.pageX<g.scrollSensitivity){this.scrollParent[0].scrollLeft=b=this.scrollParent[0].scrollLeft+g.scrollSpeed}else{if(f.pageX-this.overflowOffset.left<g.scrollSensitivity){this.scrollParent[0].scrollLeft=b=this.scrollParent[0].scrollLeft-g.scrollSpeed}}}else{if(f.pageY-a(document).scrollTop()<g.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()-g.scrollSpeed)}else{if(a(window).height()-(f.pageY-a(document).scrollTop())<g.scrollSensitivity){b=a(document).scrollTop(a(document).scrollTop()+g.scrollSpeed)}}if(f.pageX-a(document).scrollLeft()<g.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()-g.scrollSpeed)}else{if(a(window).width()-(f.pageX-a(document).scrollLeft())<g.scrollSensitivity){b=a(document).scrollLeft(a(document).scrollLeft()+g.scrollSpeed)}}}if(b!==false&&a.ui.ddmanager&&!g.dropBehaviour){a.ui.ddmanager.prepareOffsets(this,f)}}this.positionAbs=this._convertPositionTo("absolute");if(!this.options.axis||this.options.axis!="y"){this.helper[0].style.left=this.position.left+"px"}if(!this.options.axis||this.options.axis!="x"){this.helper[0].style.top=this.position.top+"px"}for(var d=this.items.length-1;d>=0;d--){var e=this.items[d],c=e.item[0],h=this._intersectsWithPointer(e);if(!h){continue}if(c!=this.currentItem[0]&&this.placeholder[h==1?"next":"prev"]()[0]!=c&&!a.ui.contains(this.placeholder[0],c)&&(this.options.type=="semi-dynamic"?!a.ui.contains(this.element[0],c):true)){this.direction=h==1?"down":"up";if(this.options.tolerance=="pointer"||this._intersectsWithSides(e)){this._rearrange(f,e)}else{break}this._trigger("change",f,this._uiHash());break}}this._contactContainers(f);if(a.ui.ddmanager){a.ui.ddmanager.drag(this,f)}this._trigger("sort",f,this._uiHash());this.lastPositionAbs=this.positionAbs;return false},_mouseStop:function(c,d){if(!c){return}if(a.ui.ddmanager&&!this.options.dropBehaviour){a.ui.ddmanager.drop(this,c)}if(this.options.revert){var b=this;var e=b.placeholder.offset();b.reverting=true;a(this.helper).animate({left:e.left-this.offset.parent.left-b.margins.left+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollLeft),top:e.top-this.offset.parent.top-b.margins.top+(this.offsetParent[0]==document.body?0:this.offsetParent[0].scrollTop)},parseInt(this.options.revert,10)||500,function(){b._clear(c)})}else{this._clear(c,d)}return false},cancel:function(){var b=this;if(this.dragging){this._mouseUp();if(this.options.helper=="original"){this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper")}else{this.currentItem.show()}for(var c=this.containers.length-1;c>=0;c--){this.containers[c]._trigger("deactivate",null,b._uiHash(this));if(this.containers[c].containerCache.over){this.containers[c]._trigger("out",null,b._uiHash(this));this.containers[c].containerCache.over=0}}}if(this.placeholder[0].parentNode){this.placeholder[0].parentNode.removeChild(this.placeholder[0])}if(this.options.helper!="original"&&this.helper&&this.helper[0].parentNode){this.helper.remove()}a.extend(this,{helper:null,dragging:false,reverting:false,_noFinalSort:null});if(this.domPosition.prev){a(this.domPosition.prev).after(this.currentItem)}else{a(this.domPosition.parent).prepend(this.currentItem)}return true},serialize:function(d){var b=this._getItemsAsjQuery(d&&d.connected);var c=[];d=d||{};a(b).each(function(){var e=(a(d.item||this).attr(d.attribute||"id")||"").match(d.expression||(/(.+)[-=_](.+)/));if(e){c.push((d.key||e[1]+"[]")+"="+(d.key&&d.expression?e[1]:e[2]))}});return c.join("&")},toArray:function(d){var b=this._getItemsAsjQuery(d&&d.connected);var c=[];d=d||{};b.each(function(){c.push(a(d.item||this).attr(d.attribute||"id")||"")});return c},_intersectsWith:function(m){var e=this.positionAbs.left,d=e+this.helperProportions.width,k=this.positionAbs.top,j=k+this.helperProportions.height;var f=m.left,c=f+m.width,n=m.top,i=n+m.height;var o=this.offset.click.top,h=this.offset.click.left;var g=(k+o)>n&&(k+o)<i&&(e+h)>f&&(e+h)<c;if(this.options.tolerance=="pointer"||this.options.forcePointerForContainers||(this.options.tolerance!="pointer"&&this.helperProportions[this.floating?"width":"height"]>m[this.floating?"width":"height"])){return g}else{return(f<e+(this.helperProportions.width/2)&&d-(this.helperProportions.width/2)<c&&n<k+(this.helperProportions.height/2)&&j-(this.helperProportions.height/2)<i)}},_intersectsWithPointer:function(d){var e=a.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,d.top,d.height),c=a.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,d.left,d.width),g=e&&c,b=this._getDragVerticalDirection(),f=this._getDragHorizontalDirection();if(!g){return false}return this.floating?(((f&&f=="right")||b=="down")?2:1):(b&&(b=="down"?2:1))},_intersectsWithSides:function(e){var c=a.ui.isOverAxis(this.positionAbs.top+this.offset.click.top,e.top+(e.height/2),e.height),d=a.ui.isOverAxis(this.positionAbs.left+this.offset.click.left,e.left+(e.width/2),e.width),b=this._getDragVerticalDirection(),f=this._getDragHorizontalDirection();if(this.floating&&f){return((f=="right"&&d)||(f=="left"&&!d))}else{return b&&((b=="down"&&c)||(b=="up"&&!c))}},_getDragVerticalDirection:function(){var b=this.positionAbs.top-this.lastPositionAbs.top;return b!=0&&(b>0?"down":"up")},_getDragHorizontalDirection:function(){var b=this.positionAbs.left-this.lastPositionAbs.left;return b!=0&&(b>0?"right":"left")},refresh:function(b){this._refreshItems(b);this.refreshPositions()},_connectWith:function(){var b=this.options;return b.connectWith.constructor==String?[b.connectWith]:b.connectWith},_getItemsAsjQuery:function(b){var l=this;var g=[];var e=[];var h=this._connectWith();if(h&&b){for(var d=h.length-1;d>=0;d--){var k=a(h[d]);for(var c=k.length-1;c>=0;c--){var f=a.data(k[c],"sortable");if(f&&f!=this&&!f.options.disabled){e.push([a.isFunction(f.options.items)?f.options.items.call(f.element):a(f.options.items,f.element).not(".ui-sortable-helper"),f])}}}}e.push([a.isFunction(this.options.items)?this.options.items.call(this.element,null,{options:this.options,item:this.currentItem}):a(this.options.items,this.element).not(".ui-sortable-helper"),this]);for(var d=e.length-1;d>=0;d--){e[d][0].each(function(){g.push(this)})}return a(g)},_removeCurrentsFromItems:function(){var d=this.currentItem.find(":data(sortable-item)");for(var c=0;c<this.items.length;c++){for(var b=0;b<d.length;b++){if(d[b]==this.items[c].item[0]){this.items.splice(c,1)}}}},_refreshItems:function(b){this.items=[];this.containers=[this];var h=this.items;var p=this;var f=[[a.isFunction(this.options.items)?this.options.items.call(this.element[0],b,{item:this.currentItem}):a(this.options.items,this.element),this]];var l=this._connectWith();if(l){for(var e=l.length-1;e>=0;e--){var m=a(l[e]);for(var d=m.length-1;d>=0;d--){var g=a.data(m[d],"sortable");if(g&&g!=this&&!g.options.disabled){f.push([a.isFunction(g.options.items)?g.options.items.call(g.element[0],b,{item:this.currentItem}):a(g.options.items,g.element),g]);this.containers.push(g)}}}}for(var e=f.length-1;e>=0;e--){var k=f[e][1];var c=f[e][0];for(var d=0,n=c.length;d<n;d++){var o=a(c[d]);o.data("sortable-item",k);h.push({item:o,instance:k,width:0,height:0,left:0,top:0})}}},refreshPositions:function(b){if(this.offsetParent&&this.helper){this.offset.parent=this._getParentOffset()}for(var d=this.items.length-1;d>=0;d--){var e=this.items[d];if(e.instance!=this.currentContainer&&this.currentContainer&&e.item[0]!=this.currentItem[0]){continue}var c=this.options.toleranceElement?a(this.options.toleranceElement,e.item):e.item;if(!b){e.width=c.outerWidth();e.height=c.outerHeight()}var f=c.offset();e.left=f.left;e.top=f.top}if(this.options.custom&&this.options.custom.refreshContainers){this.options.custom.refreshContainers.call(this)}else{for(var d=this.containers.length-1;d>=0;d--){var f=this.containers[d].element.offset();this.containers[d].containerCache.left=f.left;this.containers[d].containerCache.top=f.top;this.containers[d].containerCache.width=this.containers[d].element.outerWidth();this.containers[d].containerCache.height=this.containers[d].element.outerHeight()}}},_createPlaceholder:function(d){var b=d||this,e=b.options;if(!e.placeholder||e.placeholder.constructor==String){var c=e.placeholder;e.placeholder={element:function(){var f=a(document.createElement(b.currentItem[0].nodeName)).addClass(c||b.currentItem[0].className+" ui-sortable-placeholder").removeClass("ui-sortable-helper")[0];if(!c){f.style.visibility="hidden"}return f},update:function(f,g){if(c&&!e.forcePlaceholderSize){return}if(!g.height()){g.height(b.currentItem.innerHeight()-parseInt(b.currentItem.css("paddingTop")||0,10)-parseInt(b.currentItem.css("paddingBottom")||0,10))}if(!g.width()){g.width(b.currentItem.innerWidth()-parseInt(b.currentItem.css("paddingLeft")||0,10)-parseInt(b.currentItem.css("paddingRight")||0,10))}}}}b.placeholder=a(e.placeholder.element.call(b.element,b.currentItem));b.currentItem.after(b.placeholder);e.placeholder.update(b,b.placeholder)},_contactContainers:function(d){for(var c=this.containers.length-1;c>=0;c--){if(this._intersectsWith(this.containers[c].containerCache)){if(!this.containers[c].containerCache.over){if(this.currentContainer!=this.containers[c]){var h=10000;var g=null;var e=this.positionAbs[this.containers[c].floating?"left":"top"];for(var b=this.items.length-1;b>=0;b--){if(!a.ui.contains(this.containers[c].element[0],this.items[b].item[0])){continue}var f=this.items[b][this.containers[c].floating?"left":"top"];if(Math.abs(f-e)<h){h=Math.abs(f-e);g=this.items[b]}}if(!g&&!this.options.dropOnEmpty){continue}this.currentContainer=this.containers[c];g?this._rearrange(d,g,null,true):this._rearrange(d,null,this.containers[c].element,true);this._trigger("change",d,this._uiHash());this.containers[c]._trigger("change",d,this._uiHash(this));this.options.placeholder.update(this.currentContainer,this.placeholder)}this.containers[c]._trigger("over",d,this._uiHash(this));this.containers[c].containerCache.over=1}}else{if(this.containers[c].containerCache.over){this.containers[c]._trigger("out",d,this._uiHash(this));this.containers[c].containerCache.over=0}}}},_createHelper:function(c){var d=this.options;var b=a.isFunction(d.helper)?a(d.helper.apply(this.element[0],[c,this.currentItem])):(d.helper=="clone"?this.currentItem.clone():this.currentItem);if(!b.parents("body").length){a(d.appendTo!="parent"?d.appendTo:this.currentItem[0].parentNode)[0].appendChild(b[0])}if(b[0]==this.currentItem[0]){this._storedCSS={width:this.currentItem[0].style.width,height:this.currentItem[0].style.height,position:this.currentItem.css("position"),top:this.currentItem.css("top"),left:this.currentItem.css("left")}}if(b[0].style.width==""||d.forceHelperSize){b.width(this.currentItem.width())}if(b[0].style.height==""||d.forceHelperSize){b.height(this.currentItem.height())}return b},_adjustOffsetFromHelper:function(b){if(b.left!=undefined){this.offset.click.left=b.left+this.margins.left}if(b.right!=undefined){this.offset.click.left=this.helperProportions.width-b.right+this.margins.left}if(b.top!=undefined){this.offset.click.top=b.top+this.margins.top}if(b.bottom!=undefined){this.offset.click.top=this.helperProportions.height-b.bottom+this.margins.top}},_getParentOffset:function(){this.offsetParent=this.helper.offsetParent();var b=this.offsetParent.offset();if(this.cssPosition=="absolute"&&this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0])){b.left+=this.scrollParent.scrollLeft();b.top+=this.scrollParent.scrollTop()}if((this.offsetParent[0]==document.body)||(this.offsetParent[0].tagName&&this.offsetParent[0].tagName.toLowerCase()=="html"&&a.browser.msie)){b={top:0,left:0}}return{top:b.top+(parseInt(this.offsetParent.css("borderTopWidth"),10)||0),left:b.left+(parseInt(this.offsetParent.css("borderLeftWidth"),10)||0)}},_getRelativeOffset:function(){if(this.cssPosition=="relative"){var b=this.currentItem.position();return{top:b.top-(parseInt(this.helper.css("top"),10)||0)+this.scrollParent.scrollTop(),left:b.left-(parseInt(this.helper.css("left"),10)||0)+this.scrollParent.scrollLeft()}}else{return{top:0,left:0}}},_cacheMargins:function(){this.margins={left:(parseInt(this.currentItem.css("marginLeft"),10)||0),top:(parseInt(this.currentItem.css("marginTop"),10)||0)}},_cacheHelperProportions:function(){this.helperProportions={width:this.helper.outerWidth(),height:this.helper.outerHeight()}},_setContainment:function(){var e=this.options;if(e.containment=="parent"){e.containment=this.helper[0].parentNode}if(e.containment=="document"||e.containment=="window"){this.containment=[0-this.offset.relative.left-this.offset.parent.left,0-this.offset.relative.top-this.offset.parent.top,a(e.containment=="document"?document:window).width()-this.helperProportions.width-this.margins.left,(a(e.containment=="document"?document:window).height()||document.body.parentNode.scrollHeight)-this.helperProportions.height-this.margins.top]}if(!(/^(document|window|parent)$/).test(e.containment)){var c=a(e.containment)[0];var d=a(e.containment).offset();var b=(a(c).css("overflow")!="hidden");this.containment=[d.left+(parseInt(a(c).css("borderLeftWidth"),10)||0)+(parseInt(a(c).css("paddingLeft"),10)||0)-this.margins.left,d.top+(parseInt(a(c).css("borderTopWidth"),10)||0)+(parseInt(a(c).css("paddingTop"),10)||0)-this.margins.top,d.left+(b?Math.max(c.scrollWidth,c.offsetWidth):c.offsetWidth)-(parseInt(a(c).css("borderLeftWidth"),10)||0)-(parseInt(a(c).css("paddingRight"),10)||0)-this.helperProportions.width-this.margins.left,d.top+(b?Math.max(c.scrollHeight,c.offsetHeight):c.offsetHeight)-(parseInt(a(c).css("borderTopWidth"),10)||0)-(parseInt(a(c).css("paddingBottom"),10)||0)-this.helperProportions.height-this.margins.top]}},_convertPositionTo:function(f,h){if(!h){h=this.position}var c=f=="absolute"?1:-1;var e=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,g=(/(html|body)/i).test(b[0].tagName);return{top:(h.top+this.offset.relative.top*c+this.offset.parent.top*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(g?0:b.scrollTop()))*c)),left:(h.left+this.offset.relative.left*c+this.offset.parent.left*c-(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():g?0:b.scrollLeft())*c))}},_generatePosition:function(e){var h=this.options,b=this.cssPosition=="absolute"&&!(this.scrollParent[0]!=document&&a.ui.contains(this.scrollParent[0],this.offsetParent[0]))?this.offsetParent:this.scrollParent,i=(/(html|body)/i).test(b[0].tagName);if(this.cssPosition=="relative"&&!(this.scrollParent[0]!=document&&this.scrollParent[0]!=this.offsetParent[0])){this.offset.relative=this._getRelativeOffset()}var d=e.pageX;var c=e.pageY;if(this.originalPosition){if(this.containment){if(e.pageX-this.offset.click.left<this.containment[0]){d=this.containment[0]+this.offset.click.left}if(e.pageY-this.offset.click.top<this.containment[1]){c=this.containment[1]+this.offset.click.top}if(e.pageX-this.offset.click.left>this.containment[2]){d=this.containment[2]+this.offset.click.left}if(e.pageY-this.offset.click.top>this.containment[3]){c=this.containment[3]+this.offset.click.top}}if(h.grid){var g=this.originalPageY+Math.round((c-this.originalPageY)/h.grid[1])*h.grid[1];c=this.containment?(!(g-this.offset.click.top<this.containment[1]||g-this.offset.click.top>this.containment[3])?g:(!(g-this.offset.click.top<this.containment[1])?g-h.grid[1]:g+h.grid[1])):g;var f=this.originalPageX+Math.round((d-this.originalPageX)/h.grid[0])*h.grid[0];d=this.containment?(!(f-this.offset.click.left<this.containment[0]||f-this.offset.click.left>this.containment[2])?f:(!(f-this.offset.click.left<this.containment[0])?f-h.grid[0]:f+h.grid[0])):f}}return{top:(c-this.offset.click.top-this.offset.relative.top-this.offset.parent.top+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollTop():(i?0:b.scrollTop())))),left:(d-this.offset.click.left-this.offset.relative.left-this.offset.parent.left+(a.browser.safari&&this.cssPosition=="fixed"?0:(this.cssPosition=="fixed"?-this.scrollParent.scrollLeft():i?0:b.scrollLeft())))}},_rearrange:function(g,f,c,e){c?c[0].appendChild(this.placeholder[0]):f.item[0].parentNode.insertBefore(this.placeholder[0],(this.direction=="down"?f.item[0]:f.item[0].nextSibling));this.counter=this.counter?++this.counter:1;var d=this,b=this.counter;window.setTimeout(function(){if(b==d.counter){d.refreshPositions(!e)}},0)},_clear:function(d,e){this.reverting=false;var f=[],b=this;if(!this._noFinalSort&&this.currentItem[0].parentNode){this.placeholder.before(this.currentItem)}this._noFinalSort=null;if(this.helper[0]==this.currentItem[0]){for(var c in this._storedCSS){if(this._storedCSS[c]=="auto"||this._storedCSS[c]=="static"){this._storedCSS[c]=""}}this.currentItem.css(this._storedCSS).removeClass("ui-sortable-helper")}else{this.currentItem.show()}if(this.fromOutside&&!e){f.push(function(g){this._trigger("receive",g,this._uiHash(this.fromOutside))})}if((this.fromOutside||this.domPosition.prev!=this.currentItem.prev().not(".ui-sortable-helper")[0]||this.domPosition.parent!=this.currentItem.parent()[0])&&!e){f.push(function(g){this._trigger("update",g,this._uiHash())})}if(!a.ui.contains(this.element[0],this.currentItem[0])){if(!e){f.push(function(g){this._trigger("remove",g,this._uiHash())})}for(var c=this.containers.length-1;c>=0;c--){if(a.ui.contains(this.containers[c].element[0],this.currentItem[0])&&!e){f.push((function(g){return function(h){g._trigger("receive",h,this._uiHash(this))}}).call(this,this.containers[c]));f.push((function(g){return function(h){g._trigger("update",h,this._uiHash(this))}}).call(this,this.containers[c]))}}}for(var c=this.containers.length-1;c>=0;c--){if(!e){f.push((function(g){return function(h){g._trigger("deactivate",h,this._uiHash(this))}}).call(this,this.containers[c]))}if(this.containers[c].containerCache.over){f.push((function(g){return function(h){g._trigger("out",h,this._uiHash(this))}}).call(this,this.containers[c]));this.containers[c].containerCache.over=0}}if(this._storedCursor){a("body").css("cursor",this._storedCursor)}if(this._storedOpacity){this.helper.css("opacity",this._storedOpacity)}if(this._storedZIndex){this.helper.css("zIndex",this._storedZIndex=="auto"?"":this._storedZIndex)}this.dragging=false;if(this.cancelHelperRemoval){if(!e){this._trigger("beforeStop",d,this._uiHash());for(var c=0;c<f.length;c++){f[c].call(this,d)}this._trigger("stop",d,this._uiHash())}return false}if(!e){this._trigger("beforeStop",d,this._uiHash())}this.placeholder[0].parentNode.removeChild(this.placeholder[0]);if(this.helper[0]!=this.currentItem[0]){this.helper.remove()}this.helper=null;if(!e){for(var c=0;c<f.length;c++){f[c].call(this,d)}this._trigger("stop",d,this._uiHash())}this.fromOutside=false;return true},_trigger:function(){if(a.widget.prototype._trigger.apply(this,arguments)===false){this.cancel()}},_uiHash:function(c){var b=c||this;return{helper:b.helper,placeholder:b.placeholder||a([]),position:b.position,absolutePosition:b.positionAbs,offset:b.positionAbs,item:b.currentItem,sender:c?c.element:null}}}));a.extend(a.ui.sortable,{getter:"serialize toArray",version:"1.7.1",eventPrefix:"sort",defaults:{appendTo:"parent",axis:false,cancel:":input,option",connectWith:false,containment:false,cursor:"auto",cursorAt:false,delay:0,distance:1,dropOnEmpty:true,forcePlaceholderSize:false,forceHelperSize:false,grid:false,handle:false,helper:"original",items:"> *",opacity:false,placeholder:false,revert:false,scroll:true,scrollSensitivity:20,scrollSpeed:20,scope:"default",tolerance:"intersect",zIndex:1000}})})(jQuery);;
Added: branches/google_dev/http/extensions/jquery-ui-selectable.min.js
--- branches/google_dev/http/extensions/jquery-ui-selectable.min.js	                        (rev 0)
+++ branches/google_dev/http/extensions/jquery-ui-selectable.min.js	2009-06-02 15:29:26 UTC (rev 3982)
@@ -0,0 +1,22 @@
+ * jQuery UI 1.7.1
+ * jQuery UI Selectable 1.7.1
+ * http://docs.jquery.com/UI/Selectables
+ * Depends:
+ *	ui.core.js
+(function(a){a.widget("ui.selectable",a.extend({},a.ui.mouse,{_init:function(){var b=this;this.element.addClass("ui-selectable");this.dragged=false;var c;this.refresh=function(){c=a(b.options.filter,b.element[0]);c.each(function(){var d=a(this);var e=d.offset();a.data(this,"selectable-item",{element:this,$element:d,left:e.left,top:e.top,right:e.left+d.outerWidth(),bottom:e.top+d.outerHeight(),startselected:false,selected:d.hasClass("ui-selected"),selecting:d.hasClass("ui-selecting"),unselecting:d.hasClass("ui-unselecting")})})};this.refresh();this.selectees=c.addClass("ui-selectee");this._mouseInit();this.helper=a(document.createElement("div")).css({border:"1px dotted black"}).addClass("ui-selectable-helper")},destroy:function(){this.element.removeClass("ui-selectable ui-selectable-disabled").removeData("selectable").unbind(".selectable");this._mouseDestroy()},_mouseStart:function(d){var b=this;this.opos=[d.pageX,d.pageY];if(this.options.disabled){return}var c=this.options;this.selectees=a(c.filter,this.element[0]);this._trigger("start",d);a(c.appendTo).append(this.helper);this.helper.css({"z-index":100,position:"absolute",left:d.clientX,top:d.clientY,width:0,height:0});if(c.autoRefresh){this.refresh()}this.selectees.filter(".ui-selected").each(function(){var e=a.data(this,"selectable-item");e.startselected=true;if(!d.metaKey){e.$element.removeClass("ui-selected");e.selected=false;e.$element.addClass("ui-unselecting");e.unselecting=true;b._trigger("unselecting",d,{unselecting:e.element})}});a(d.target).parents().andSelf().each(function(){var e=a.data(this,"selectable-item");if(e){e.$element.removeClass("ui-unselecting").addClass("ui-selecting");e.unselecting=false;e.selecting=true;e.selected=true;b._trigger("selecting",d,{selecting:e.element});return false}})},_mouseDrag:function(i){var c=this;this.dragged=true;if(this.options.disabled){return}var e=this.options;var d=this.opos[0],h=this.opos[1],b=i.pageX,g=i.pageY;if(d>b){var f=b;b=d;d=f}if(h>g){var f=g;g=h;h=f}this.helper.css({left:d,top:h,width:b-d,height:g-h});this.selectees.each(function(){var j=a.data(this,"selectable-item");if(!j||j.element==c.element[0]){return}var k=false;if(e.tolerance=="touch"){k=(!(j.left>b||j.right<d||j.top>g||j.bottom<h))}else{if(e.tolerance=="fit"){k=(j.left>d&&j.right<b&&j.top>h&&j.bottom<g)}}if(k){if(j.selected){j.$element.removeClass("ui-selected");j.selected=false}if(j.unselecting){j.$element.removeClass("ui-unselecting");j.unselecting=false}if(!j.selecting){j.$element.addClass("ui-selecting");j.selecting=true;c._trigger("selecting",i,{selecting:j.element})}}else{if(j.selecting){if(i.metaKey&&j.startselected){j.$element.removeClass("ui-selecting");j.selecting=false;j.$element.addClass("ui-selected");j.selected=true}else{j.$element.removeClass("ui-selecting");j.selecting=false;if(j.startselected){j.$element.addClass("ui-unselecting");j.unselecting=true}c._trigger("unselecting",i,{unselecting:j.element})}}if(j.selected){if(!i.metaKey&&!j.startselected){j.$element.removeClass("ui-selected");j.selected=false;j.$element.addClass("ui-unselecting");j.unselecting=true;c._trigger("unselecting",i,{unselecting:j.element})}}}});return false},_mouseStop:function(d){var b=this;this.dragged=false;var c=this.options;a(".ui-unselecting",this.element[0]).each(function(){var e=a.data(this,"selectable-item");e.$element.removeClass("ui-unselecting");e.unselecting=false;e.startselected=false;b._trigger("unselected",d,{unselected:e.element})});a(".ui-selecting",this.element[0]).each(function(){var e=a.data(this,"selectable-item");e.$element.removeClass("ui-selecting").addClass("ui-selected");e.selecting=false;e.selected=true;e.startselected=true;b._trigger("selected",d,{selected:e.element})});this._trigger("stop",d);this.helper.remove();return false}}));a.extend(a.ui.selectable,{version:"1.7.1",defaults:{appendTo:"body",autoRefresh:true,cancel:":input,option",delay:0,distance:0,filter:"*",tolerance:"touch"}})})(jQuery);;
Added: branches/google_dev/http/extensions/ui.core.js
--- branches/google_dev/http/extensions/ui.core.js	                        (rev 0)
+++ branches/google_dev/http/extensions/ui.core.js	2009-06-02 15:29:26 UTC (rev 3982)
@@ -0,0 +1,534 @@
+ * jQuery UI @VERSION
+ * Copyright (c) 2008 AUTHORS.txt (http://ui.jquery.com/about)
+;(function($) {
+/** jQuery core modifications and additions **/
+$.keyCode = {
+	BACKSPACE: 8,
+	CAPS_LOCK: 20,
+	COMMA: 188,
+	CONTROL: 17,
+	DELETE: 46,
+	DOWN: 40,
+	END: 35,
+	ENTER: 13,
+	ESCAPE: 27,
+	HOME: 36,
+	INSERT: 45,
+	LEFT: 37,
+	NUMPAD_ADD: 107,
+	NUMPAD_DECIMAL: 110,
+	NUMPAD_DIVIDE: 111,
+	NUMPAD_ENTER: 108,
+	NUMPAD_MULTIPLY: 106,
+	NUMPAD_SUBTRACT: 109,
+	PAGE_DOWN: 34,
+	PAGE_UP: 33,
+	PERIOD: 190,
+	RIGHT: 39,
+	SHIFT: 16,
+	SPACE: 32,
+	TAB: 9,
+	UP: 38
+var _remove = $.fn.remove,
+	isFF2 = $.browser.mozilla && (parseFloat($.browser.version) < 1.9);
+//Helper functions and ui object
+$.ui = {
+	version: "@VERSION",
+	// $.ui.plugin is deprecated.  Use the proxy pattern instead.
+	plugin: {
+		add: function(module, option, set) {
+			var proto = $.ui[module].prototype;
+			for(var i in set) {
+				proto.plugins[i] = proto.plugins[i] || [];
+				proto.plugins[i].push([option, set[i]]);
+		call: function(instance, name, args) {
+			var set = instance.plugins[name];
+			if(!set) { return; }
+			for (var i = 0; i < set.length; i++) {
+				if (instance.options[set[i][0]]) {
+					set[i][1].apply(instance.element, args);
+	contains: function(a, b) {
+		var safari2 = $.browser.safari && $.browser.version < 522;
+	    if (a.contains && !safari2) {
+	        return a.contains(b);
+	    if (a.compareDocumentPosition)
+	        return !!(a.compareDocumentPosition(b) & 16);
+	    while (b = b.parentNode)
+	          if (b == a) return true;
+	    return false;
+	cssCache: {},
+	css: function(name) {
+		if ($.ui.cssCache[name]) { return $.ui.cssCache[name]; }
+		var tmp = $('<div class="ui-gen">').addClass(name).css({position:'absolute', top:'-5000px', left:'-5000px', display:'block'}).appendTo('body');
+		//if (!$.browser.safari)
+			//tmp.appendTo('body');
+		//Opera and Safari set width and height to 0px instead of auto
+		//Safari returns rgba(0,0,0,0) when bgcolor is not set
+		$.ui.cssCache[name] = !!(
+			(!(/auto|default/).test(tmp.css('cursor')) || (/^[1-9]/).test(tmp.css('height')) || (/^[1-9]/).test(tmp.css('width')) ||
+			!(/none/).test(tmp.css('backgroundImage')) || !(/transparent|rgba\(0, 0, 0, 0\)/).test(tmp.css('backgroundColor')))
+		try { $('body').get(0).removeChild(tmp.get(0));	} catch(e){}
+		return $.ui.cssCache[name];
+	hasScroll: function(el, a) {
+		//If overflow is hidden, the element might have extra content, but the user wants to hide it
+		if ($(el).css('overflow') == 'hidden') { return false; }
+		var scroll = (a && a == 'left') ? 'scrollLeft' : 'scrollTop',
+			has = false;
+		if (el[scroll] > 0) { return true; }
+		// TODO: determine which cases actually cause this to happen
+		// if the element doesn't have the scroll set, see if it's possible to
+		// set the scroll
+		el[scroll] = 1;
+		has = (el[scroll] > 0);
+		el[scroll] = 0;
+		return has;
+	isOverAxis: function(x, reference, size) {
+		//Determines when x coordinate is over "b" element axis
+		return (x > reference) && (x < (reference + size));
+	isOver: function(y, x, top, left, height, width) {
+		//Determines when x, y coordinates is over "b" element
+		return $.ui.isOverAxis(y, top, height) && $.ui.isOverAxis(x, left, width);
+// WAI-ARIA normalization
+if (isFF2) {
+	var attr = $.attr,
+		removeAttr = $.fn.removeAttr,
+		ariaNS = "http://www.w3.org/2005/07/aaa",
+		ariaState = /^aria-/,
+		ariaRole = /^wairole:/;
+	$.attr = function(elem, name, value) {
+		var set = value !== undefined;
+		return (name == 'role'
+			? (set
+				? attr.call(this, elem, name, "wairole:" + value)
+				: (attr.apply(this, arguments) || "").replace(ariaRole, ""))
+			: (ariaState.test(name)
+				? (set
+					? elem.setAttributeNS(ariaNS,
+						name.replace(ariaState, "aaa:"), value)
+					: attr.call(this, elem, name.replace(ariaState, "aaa:")))
+				: attr.apply(this, arguments)));
+	$.fn.removeAttr = function(name) {
+		return (ariaState.test(name)
+			? this.each(function() {
+				this.removeAttributeNS(ariaNS, name.replace(ariaState, ""));
+			}) : removeAttr.call(this, name));
+//jQuery plugins
+$.fn.extend({
+	remove: function() {
+		// Safari has a native remove event which actually removes DOM elements,
+		// so we have to use triggerHandler instead of trigger (#3037).
+		$("*", this).add(this).each(function() {
+			$(this).triggerHandler("remove");
+		return _remove.apply(this, arguments );
+	enableSelection: function() {
+		return this
+			.attr('unselectable', 'off')
+			.css('MozUserSelect', '')
+			.unbind('selectstart.ui');
+	disableSelection: function() {
+		return this
+			.attr('unselectable', 'on')
+			.css('MozUserSelect', 'none')
+			.bind('selectstart.ui', function() { return false; });
+	scrollParent: function() {
+		var scrollParent;
+		if(($.browser.msie && (/(static|relative)/).test(this.css('position'))) || (/absolute/).test(this.css('position'))) {
+			scrollParent = this.parents().filter(function() {
+				return (/(relative|absolute|fixed)/).test($.curCSS(this,'position',1)) && (/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));
+			}).eq(0);
+		} else {
+				return (/(auto|scroll)/).test($.curCSS(this,'overflow',1)+$.curCSS(this,'overflow-y',1)+$.curCSS(this,'overflow-x',1));
+			}).eq(0);
+		return (/fixed/).test(this.css('position')) || !scrollParent.length ? $(document) : scrollParent;
+//Additional selectors
+$.extend($.expr[':'], {
+	data: function(a, i, m) {
+		return $.data(a, m[3]);
+	// TODO: add support for object, area
+	tabbable: function(a, i, m) {
+		var nodeName = a.nodeName.toLowerCase();
+		function isVisible(element) {
+			return !($(element).is(':hidden') || $(element).parents(':hidden').length);
+		return (
+			// in tab order
+			a.tabIndex >= 0 &&
+			( // filter node types that participate in the tab order
+				// anchor tag
+				('a' == nodeName && a.href) ||
+				// enabled form element
+				(/input|select|textarea|button/.test(nodeName) &&
+					'hidden' != a.type && !a.disabled)
+			// visible on page
+			isVisible(a)
+// $.widget is a factory to create jQuery plugins
+// taking some boilerplate code out of the plugin code
+function getter(namespace, plugin, method, args) {
+	function getMethods(type) {
+		var methods = $[namespace][plugin][type] || [];
+		return (typeof methods == 'string' ? methods.split(/,?\s+/) : methods);
+	var methods = getMethods('getter');
+	if (args.length == 1 && typeof args[0] == 'string') {
+		methods = methods.concat(getMethods('getterSetter'));
+	return ($.inArray(method, methods) != -1);
+$.widget = function(name, prototype) {
+	var namespace = name.split(".")[0];
+	name = name.split(".")[1];
+	// create plugin method
+	$.fn[name] = function(options) {
+		var isMethodCall = (typeof options == 'string'),
+			args = Array.prototype.slice.call(arguments, 1);
+		// prevent calls to internal methods
+		if (isMethodCall && options.substring(0, 1) == '_') {
+			return this;
+		// handle getter methods
+		if (isMethodCall && getter(namespace, name, options, args)) {
+			var instance = $.data(this[0], name);
+			return (instance ? instance[options].apply(instance, args)
+				: undefined);
+		// handle initialization and non-getter methods
+		return this.each(function() {
+			var instance = $.data(this, name);
+			// constructor
+			(!instance && !isMethodCall &&
+				$.data(this, name, new $[namespace][name](this, options)));
+			// method call
+			(instance && isMethodCall && $.isFunction(instance[options]) &&
+				instance[options].apply(instance, args));
+	// create widget constructor
+	$[namespace] = $[namespace] || {};
+	$[namespace][name] = function(element, options) {
+		var self = this;
+		this.namespace = namespace;
+		this.widgetName = name;
+		this.widgetEventPrefix = $[namespace][name].eventPrefix || name;
+		this.widgetBaseClass = namespace + '-' + name;
+		this.options = $.extend({},
+			$.widget.defaults,
+			$[namespace][name].defaults,
+			$.metadata && $.metadata.get(element)[name],
+			options);
+		this.element = $(element)
+			.bind('setData.' + name, function(event, key, value) {
+				return self._setData(key, value);
+			.bind('getData.' + name, function(event, key) {
+				return self._getData(key);
+			.bind('remove', function() {
+				return self.destroy();
+		this._init();
+	// add widget prototype
+	$[namespace][name].prototype = $.extend({}, $.widget.prototype, prototype);
+	// TODO: merge getter and getterSetter properties from widget prototype
+	// and plugin prototype
+	$[namespace][name].getterSetter = 'option';
+$.widget.prototype = {
+	_init: function() {},
+	destroy: function() {
+		this.element.removeData(this.widgetName)
+			.removeClass(this.widgetBaseClass + '-disabled' + ' ' + this.namespace + '-state-disabled')
+			.removeAttr('aria-disabled');
+	option: function(key, value) {
+		var options = key,
+			self = this;
+		if (typeof key == "string") {
+			if (value === undefined) {
+				return this._getData(key);
+			options = {};
+			options[key] = value;
+		$.each(options, function(key, value) {
+			self._setData(key, value);
+	_getData: function(key) {
+		return this.options[key];
+	_setData: function(key, value) {
+		this.options[key] = value;
+		if (key == 'disabled') {
+			this.element[value ? 'addClass' : 'removeClass'](
+				this.widgetBaseClass + '-disabled' + ' ' + this.namespace + '-state-disabled')
+				.attr("aria-disabled", value);
+	enable: function() {
+		this._setData('disabled', false);
+	disable: function() {
+		this._setData('disabled', true);
+	_trigger: function(type, event, data) {
+		var eventName = (type == this.widgetEventPrefix
+			? type : this.widgetEventPrefix + type);
+		event = event || $.event.fix({ type: eventName, target: this.element[0] });
+		return this.element.triggerHandler(eventName, [event, data], this.options[type]);
+$.widget.defaults = {
+	disabled: false
+/** Mouse Interaction Plugin **/
+$.ui.mouse = {
+	_mouseInit: function() {
+		var self = this;
+		this.element
+			.bind('mousedown.'+this.widgetName, function(event) {
+				return self._mouseDown(event);
+			.bind('click.'+this.widgetName, function(event) {
+				if(self._preventClickEvent) {
+					self._preventClickEvent = false;
+					return false;
+		// Prevent text selection in IE
+		if ($.browser.msie) {
+			this._mouseUnselectable = this.element.attr('unselectable');
+			this.element.attr('unselectable', 'on');
+		this.started = false;
+	// TODO: make sure destroying one instance of mouse doesn't mess with
+	// other instances of mouse
+	_mouseDestroy: function() {
+		this.element.unbind('.'+this.widgetName);
+		// Restore text selection in IE
+		($.browser.msie
+			&& this.element.attr('unselectable', this._mouseUnselectable));
+	_mouseDown: function(event) {
+		// we may have missed mouseup (out of window)
+		(this._mouseStarted && this._mouseUp(event));
+		this._mouseDownEvent = event;
+		var self = this,
+			btnIsLeft = (event.which == 1),
+			elIsCancel = (typeof this.options.cancel == "string" ? $(event.target).parents().add(event.target).filter(this.options.cancel).length : false);
+		if (!btnIsLeft || elIsCancel || !this._mouseCapture(event)) {
+			return true;
+		this.mouseDelayMet = !this.options.delay;
+		if (!this.mouseDelayMet) {
+			this._mouseDelayTimer = setTimeout(function() {
+				self.mouseDelayMet = true;
+			}, this.options.delay);
+		if (this._mouseDistanceMet(event) && this._mouseDelayMet(event)) {
+			this._mouseStarted = (this._mouseStart(event) !== false);
+			if (!this._mouseStarted) {
+				event.preventDefault();
+				return true;
+		// these delegates are required to keep context
+		this._mouseMoveDelegate = function(event) {
+			return self._mouseMove(event);
+		this._mouseUpDelegate = function(event) {
+			return self._mouseUp(event);
+		$(document)
+			.bind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+			.bind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+		// preventDefault() is used to prevent the selection of text here -
+		// however, in Safari, this causes select boxes not to be selectable
+		// anymore, so this fix is needed
+		if(!$.browser.safari) event.preventDefault();
+		return true;
+	_mouseMove: function(event) {
+		// IE mouseup check - mouseup happened when mouse was out of window
+		if ($.browser.msie && !event.button) {
+			return this._mouseUp(event);
+		if (this._mouseStarted) {
+			this._mouseDrag(event);
+			return event.preventDefault();
+				(this._mouseStart(this._mouseDownEvent, event) !== false);
+			(this._mouseStarted ? this._mouseDrag(event) : this._mouseUp(event));
+		return !this._mouseStarted;
+	_mouseUp: function(event) {
+		$(document)
+			.unbind('mousemove.'+this.widgetName, this._mouseMoveDelegate)
+			.unbind('mouseup.'+this.widgetName, this._mouseUpDelegate);
+			this._mouseStarted = false;
+			this._preventClickEvent = true;
+			this._mouseStop(event);
+		return false;
+	_mouseDistanceMet: function(event) {
+		return (Math.max(
+				Math.abs(this._mouseDownEvent.pageX - event.pageX),
+				Math.abs(this._mouseDownEvent.pageY - event.pageY)
+			) >= this.options.distance
+	_mouseDelayMet: function(event) {
+		return this.mouseDelayMet;
+	// These are placeholder methods, to be overriden by extending plugin
+	_mouseStart: function(event) {},
+	_mouseDrag: function(event) {},
+	_mouseStop: function(event) {},
+	_mouseCapture: function(event) { return true; }
+$.ui.mouse.defaults = {
+	cancel: null,
+	distance: 1,
+	delay: 0
+})(jQuery);
Added: branches/google_dev/http/extensions/ui.selectable.js
--- branches/google_dev/http/extensions/ui.selectable.js	                        (rev 0)
+++ branches/google_dev/http/extensions/ui.selectable.js	2009-06-02 15:29:26 UTC (rev 3982)
@@ -0,0 +1,397 @@
+ * jQuery UI Selectable @VERSION
+ * Copyright (c) 2009 AUTHORS.txt (http://ui.jquery.com/about)
+ * Dual licensed under the MIT (MIT-LICENSE.txt)
+ * and GPL (GPL-LICENSE.txt) licenses.
+ * Depends:
+ *	ui.core.js
+(function($) {
+	$.widget('ui.selectable', $.extend({}, $.ui.mouse, {
+			var self = this;
+			this.element.addClass("ui-selectable");
+			//Set the currentFocus to the first item
+			this.currentFocus = $($(this.options.filter, this.element)[0]);
+			//Refresh item positions
+			this.refresh();
+			//Disable text selection
+			this.element.disableSelection();
+			//Prepare caret selection
+			if(this.options.lasso) this._mouseInit();
+			this.element
+				.bind('mousedown', function(event) {
+					var item = self._targetIsItem(event.target);
+					if (!item) return;
+					self._select(event, item);
+					self.element[0].focus();
+				.bind('focus.selectable', function() {
+					self.currentFocus.addClass('ui-focused');
+				.bind('blur.selectable', function() {
+					self.currentFocus.removeClass('ui-focused');
+				.bind('keydown.selectable', function(event) {
+					if(!self.options.keyboard)
+						return;
+					if (event.keyCode == $.ui.keyCode.DOWN || event.keyCode == $.ui.keyCode.RIGHT) {
+						self.selectNext(event);
+					if (event.keyCode == $.ui.keyCode.UP || event.keyCode == $.ui.keyCode.LEFT) {
+						self.selectPrevious(event);
+					if ((event.ctrlKey || event.metaKey) && event.keyCode == $.ui.keyCode.SPACE) {
+						self._toggleSelection(self.currentFocus, event);
+			this.helper = $(document.createElement('div'))
+				.css({border:'1px dotted black'})
+				.addClass("ui-selectable-helper");
+			this.element
+				.removeClass("ui-selectable ui-selectable-disabled")
+				.removeData("selectable")
+				.unbind(".selectable");
+			this._mouseDestroy();
+			//If the item we start dragging on is a selectable, we bail (if keyboard is used)
+			this.clickedOnItem = this._targetIsItem(event.target);
+			return !this.options.keyboard || !this.clickedOnItem;
+			var self = this, o = this.options;
+			this.opos = [event.pageX, event.pageY];
+			if (o.disabled)
+				return;
+			//Cache positions
+			this.refresh();
+			//Trigger start event
+			this._trigger("start", event, this._uiHash());
+			// append and position helper (lasso)
+			$('body').append(this.helper);
+			this.helper.css({
+				zIndex: 100,
+				position: "absolute",
+				left: event.clientX,
+				top: event.clientY,
+				width: 0,
+				height: 0
+			//Tell the intersection that some start selected
+			$(this.options.filter, this.element).filter('.ui-selected').each(function() {
+				if(event.metaKey) {
+					if(this != self.clickedOnItem) $.data(this, "selectable-item").startSelected = true;
+				} else self._removeFromSelection($(this), event);
+			if (o.disabled)
+				return;
+			//Do the lasso magic
+			var x1 = this.opos[0], y1 = this.opos[1], x2 = event.pageX, y2 = event.pageY;
+			if (x1 > x2) { var tmp = x2; x2 = x1; x1 = tmp; }
+			if (y1 > y2) { var tmp = y2; y2 = y1; y1 = tmp; }
+			this.helper.css({left: x1, top: y1, width: x2-x1, height: y2-y1});
+			//Loop through all items and check overlaps
+			$(this.options.filter, this.element).each(function() {
+				var item = $.data(this, "selectable-item");
+				//prevent helper from being selected if appendTo: selectable
+				if (!item || item.element == self.element[0])
+					return;
+				var hit = false;
+				if (o.tolerance == 'touch') {
+					hit = ( !(item.left > x2 || item.right < x1 || item.top > y2 || item.bottom < y1) );
+				} else if (o.tolerance == 'fit') {
+					hit = (item.left > x1 && item.right < x2 && item.top > y1 && item.bottom < y2);
+				hit ?
+					item.startSelected ? self._removeFromSelection($(this), event) : self._addToSelection($(this), event)
+				:  !item.startSelected ? self._removeFromSelection($(this), event) : self._addToSelection($(this), event);
+			return false;
+			this._trigger("stop", event, this._uiHash());
+			this.helper.remove();
+			return false;
+		_targetIsItem: function(item) {
+			var test = false, self = this;
+			$(item).parents().andSelf().each(function() {
+				if ($(self.options.filter, self.element).index(this) != -1) test = this;
+			return test;
+		_selection: [],
+		_clearSelection: function(triggerEvent) {
+			var triggerItems = [];
+			for (var i = this._selection.length - 1; i >= 0; i--){
+				if(triggerEvent && this._selection[i].data('selectable-item').selected) triggerItems.push(this._selection[i]);
+				this._selection[i].removeClass('ui-selected');
+				this._selection[i].data('selectable-item').selected = false;
+			this._selection = [];
+			if(triggerEvent) this._trigger('unselect', triggerEvent, this._uiHash($($.map(triggerItems, function(i) { return i[0]; })), 'removed'));
+		_toggleSelection: function(item, event) {
+				item.data('selectable-item').selected ? this._removeFromSelection(item, event) : this._addToSelection(item);
+		_addToSelection: function(item, triggerEvent) {
+			if (item.data('selectable-item').selected)
+				return null;
+			this._selection.push(item);
+			this.latestSelection = item;
+			item.addClass('ui-selected');
+			item.data('selectable-item').selected = true;
+			if(triggerEvent) {
+				this._trigger('select', triggerEvent, $.extend({ lasso: true }, this._uiHash(item)));
+			return item;
+		_removeFromSelection: function(item, triggerEvent) {
+			for (var i=0; i < this._selection.length; i++) {
+				if (this._selection[i][0] == item[0]) {
+					this._selection.splice(i,1);
+					if(triggerEvent) this._trigger('unselect', triggerEvent, this._uiHash($(item), 'remove'));
+					break;
+		_updateSelectionMouse: function(event) {
+			var newlySelected = [];
+			if (event.shiftKey && this.options.multiple) {
+				//Clear the previous selection to make room for a shift selection
+				this._clearSelection(event);
+				var dir = $(this.options.filter, this.element).index(this.latestWithoutModifier[0]) > $(this.options.filter, this.element).index(this.currentFocus[0]) ? 'prev' : 'next';
+				var i = this.latestWithoutModifier.data('selectable-item').selected ? this.latestWithoutModifier[dir]() : this.latestWithoutModifier;
+				while(i.length && i[0] != this.currentFocus[0]) {
+					i[0] == this.previousFocus[0] ? this._addToSelection(i) : newlySelected.push(this._addToSelection(i));
+					i = i[dir]();
+				//Readd the item with the current focus
+				newlySelected.push(this._addToSelection(this.currentFocus));
+			} else {
+				if (event.metaKey) {
+					this._toggleSelection(this.currentFocus, event);
+				} else {
+					this.latestWithoutModifier = this.currentFocus;
+			return $($.map(newlySelected, function(i) { return i[0]; }));
+		_updateSelection: function(event, dir) {
+				if (this.currentFocus.data('selectable-item').selected) {
+					this._removeFromSelection(this.previousFocus, event);
+				} else {
+					var dir2 = $(this.options.filter, this.element).index(this.latestSelection[0]) > $(this.options.filter, this.element).index(this.currentFocus[0]) ? 'next' : 'prev';
+					if (!this.previousFocus.data('selectable-item').selected) {
+						var i = dir == dir2 ? this.previousFocus[dir2]() : this.previousFocus;
+						while(i.length && !i.data('selectable-item').selected) {
+							newlySelected.push(this._addToSelection(i));
+							i = i[dir2]();
+			} else {
+				//If the CTRL or Apple/Win key is pressed, only set focus
+					return;
+		_select: function(event, item) {
+			//Set the current selection to the previous/next item
+			this.previousFocus = this.currentFocus;
+			this.currentFocus = $(item);
+			this.previousFocus.removeClass('ui-focused');
+			this.currentFocus.addClass('ui-focused');
+			//Set and update the selection
+			var newlySelected = this._updateSelectionMouse(event);
+			//Trigger select event
+			if(newlySelected && newlySelected.length) this._trigger('select', event, this._uiHash(newlySelected, 'added'));
+		_selectAdjacent: function(event, dir) {
+			//Bail if there's no previous/next item
+			if (!this.currentFocus[dir]().length)
+				return;
+			this.currentFocus = this.currentFocus[dir]();
+			var newlySelected = this._updateSelection(event, dir);
+		selectPrevious: function(event) {
+			this._selectAdjacent(event, 'prev');
+		selectNext: function(event) {
+			this._selectAdjacent(event, 'next');
+		refresh: function() {
+				var $this = $(this);
+				var pos = $this.offset();
+				$.data(this, "selectable-item", {
+					left: pos.left,
+					top: pos.top,
+					right: pos.left + $this.width(),
+					bottom: pos.top + $this.height(),
+					startSelected: false,
+					selected: $this.hasClass('ui-selected')
+		_uiHash: function(items, specialKey) {
+			var uiHash =  {
+				previousFocus: this.previousFocus,
+				currentFocus: this.currentFocus,
+				selection: $($.map(this._selection, function(i) { return i[0]; }))
+			if(specialKey) uiHash[specialKey] = items;
+			return uiHash;
+	$.extend($.ui.selectable, {
+		defaults: {
+			appendTo: 'body',
+			cancel: ":input,option",
+			delay: 0,
+			distance: 1,
+			tolerance: 'touch',
+			multiple: true,
+			filter: '> *',
+			keyboard: true,
+			lasso: true
+})(jQuery);
More information about the Mapbender_commits mailing list
