[Mapbender-commits] r3983 - branches/google_dev/http/javascripts
svn_mapbender at osgeo.org
Tue Jun 2 11:29:42 EDT 2009
Author: christoph
Date: 2009-06-02 11:29:42 -0400 (Tue, 02 Jun 2009)
New Revision: 3983
Added:
branches/google_dev/http/javascripts/mod_google.php
branches/google_dev/http/javascripts/mod_mapMirror.php
branches/google_dev/http/javascripts/mod_toggleLayers.php
branches/google_dev/http/javascripts/mod_wfs_gazetteer_parameterizedSearch.php
Added: branches/google_dev/http/javascripts/mod_google.php
--- branches/google_dev/http/javascripts/mod_google.php (rev 0)
+++ branches/google_dev/http/javascripts/mod_google.php 2009-06-02 15:29:42 UTC (rev 3983)
@@ -0,0 +1,179 @@
+<?php
+# $Id: mod_center1.php 3382 2009-01-02 10:53:53Z christoph $
+# http://www.mapbender.org/index.php/mod_center1.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+echo "var mod_google_target = '".$e_target[0]."';";
+$mapsApiUrl = "http://maps.google.com/maps/api/js?sensor=false&key=ABQIAAAAnSxy5UckGSKS1Wxnq6d10RRmYiuLful4T_-5_WDsqgKCFa5YaxSr2GxbtA92UOizu0iI4JvP_23jUw";
+readfile($mapsApiUrl);
+require(dirname(__FILE__)."/../include/dyn_js.php");
+if (typeof CENTER === "undefined") {
+ var CENTER = [50.7376701, 7.0714];
+if (typeof MAX_ZOOM_LEVEL === "undefined") {
+ var MAX_ZOOM_LEVEL = 19;
+if (typeof MIN_ZOOM_LEVEL === "undefined") {
+ var MIN_ZOOM_LEVEL = 2;
+if (typeof ZOOM_LEVEL === "undefined") {
+ var ZOOM_LEVEL = 10;
+if (typeof TYPE === "undefined") {
+ var TYPE = "SATELLITE";
+if (typeof KEY === "undefined") {
+ var e = new Mb_exception("No key for Google Maps. Please configure the element vars.");
+else {
+ mb_mapObj_const.prototype.zoomToLevel = function (currentZoomLevel) {
+ this.google.map.set_zoom(currentZoomLevel);
+ var that = this;
+ var zoomListener = google.maps.event.addListener(this.google.map, "bounds_changed", function () {
+ google.maps.event.removeListener(zoomListener);
+ var newBounds = that.google.map.get_bounds();
+ var newSw = newBounds.getSouthWest();
+ var newNe = newBounds.getNorthEast();
+ that.extent.set(new Point(newSw.lng(), newSw.lat()), new Point(newNe.lng(), newNe.lat()));
+ that.setMapRequest();
+ mb_mapObj_const.prototype.setGoogleMap = function (options) {
+ this.google = {
+ "id" : this.elementName + "-google",
+ "MIN_ZOOM_LEVEL" : MIN_ZOOM_LEVEL,
+ "MAX_ZOOM_LEVEL" : MAX_ZOOM_LEVEL,
+ "isInitialised" : false
+ var html = "<div id='" + this.google.id + "' " +
+ "style='position:absolute;top:0px;left:0px;" +
+ "width:" + this.width + "px;height:" + this.height + "px;" +
+ "'></div>";
+ $("#" + this.elementName).prepend(html);
+ var disableControlsOptions = {
+ keyboardShortcuts: false,
+ draggable: false,
+ navigationControl: false,
+ scaleControl: false,
+ mapTypeControl: false,
+ disableDefaultUI: true,
+ noResize: true
+ // get center
+// THIS IS THE CENTER OF WMS 0; MAY RESULT IN A ZOOM LEVEL LIKE 0 OR 1,
+// WHICH BREAKS THE WMS BBOX
+// var latLng = new google.maps.LatLng(this.extent.center.y, this.extent.center.x);
+ // USE THIS CENTER FOR TESTING!!!!!!!
+ var latLng = new google.maps.LatLng(CENTER[0], CENTER[1]);
+ // calculate zoom level from extent after initialization
+ var temporaryOptions = {
+ zoom : ZOOM_LEVEL,
+ center : latLng
+ var googleOptions = $.extend(disableControlsOptions, temporaryOptions, options);
+ this.google.map = new google.maps.Map(document.getElementById(this.google.id), googleOptions);
+ mb_registerPanSubElement(this.google.id);
+ var that = this;
+ var initListener = google.maps.event.addListener(this.google.map, "bounds_changed", function () {
+ google.maps.event.removeListener(initListener);
+ that.google.map.isInitialised = true;
+ // THIS MIGHT NOT BE THE BEST WAY TO RESIZE THE GOOGLE MAP
+ // HOWEVER, THERE IS NO API FUNCTION
+ this.eventResizeMap.register(function () {
+ $("#" + that.google.id).css({
+ "width" : that.width + "px",
+ "height" : that.height + "px"
+ (function () {
+ eventInitMap.register(function () {
+ var map = getMapObjByName(mod_google_target);
+ switch (TYPE) {
+ case "ROADMAP" :
+ mapTypeId = google.maps.MapTypeId.ROADMAP;
+ break;
+ case "SATELLITE" :
+ mapTypeId = google.maps.MapTypeId.SATELLITE;
+ break;
+ case "HYBRID" :
+ mapTypeId = google.maps.MapTypeId.HYBRID;
+ break;
+ case "TERRAIN" :
+ mapTypeId = google.maps.MapTypeId.TERRAIN;
+ break;
+ default:
+ break;
+ var googleOptions = {
+ mapTypeId: mapTypeId,
+ key: KEY
+ map.setGoogleMap(googleOptions);
\ No newline at end of file
Added: branches/google_dev/http/javascripts/mod_mapMirror.php
--- branches/google_dev/http/javascripts/mod_mapMirror.php (rev 0)
+++ branches/google_dev/http/javascripts/mod_mapMirror.php 2009-06-02 15:29:42 UTC (rev 3983)
@@ -0,0 +1,143 @@
+<?php
+# $Id: mod_selArea1.php 3391 2009-01-02 14:09:15Z nimix $
+# http://www.mapbender.org/index.php/mod_selArea1.php
+(function () {
+<?php
+include '../include/dyn_js.php';
+try {
+ if (wmsIdArray) {}
+catch (e) {
+ wmsIdArray = [];
+var mod_mapMirror_elName = "<?php echo $e_id;?>";
+var mod_mapMirror_target1 = "<?php echo $e_target[0]; ?>";
+var mod_mapMirror_target2 = "<?php echo $e_target[1]; ?>";
+var affectedItems = [
+ "#zoomIn2",
+ "#zoomOut2",
+ "#pan2",
+ "#selArea2",
+ "#arrow_n_navFrame2",
+ "#arrow_nw_navFrame2",
+ "#arrow_w_navFrame2",
+ "#arrow_sw_navFrame2",
+ "#arrow_s_navFrame2",
+ "#arrow_se_navFrame2",
+ "#arrow_e_navFrame2",
+ "#arrow_ne_navFrame2"
+var affectedItemsSelector = affectedItems.join(",");
+eventInit.register(function () {
+ var mapObj1 = getMapObjByName(mod_mapMirror_target1);
+ var mapObj2 = getMapObjByName(mod_mapMirror_target2);
+ var blockIn1 = [];
+ var blockIn2 = [];
+ // block these WMS in map 1
+ for (var i = 0; i < wmsIdArray.length; i++) {
+ var index = mapObj1.getWmsIndexById(wmsIdArray[i]);
+ if (index !== null && mapObj1.wms[index].gui_wms_visible !== 2) {
+ blockIn1.push(index);
+ // block other WMS in map 2
+ for (var i = 0; i < wms.length; i++) {
+ var found = false;
+ for (var j = 0; j < blockIn1.length; j++) {
+ if (blockIn1[j] === i) {
+ found = true;
+ break;
+ if (!found && mapObj2.wms[i].gui_wms_visible !== 2) {
+ blockIn2.push(i);
+ var blockUnwantedWms = function () {
+ mapObj1.afterMapRequest.register(function () {
+ var selectorArray = [];
+ for (var el in blockIn1) {
+ selectorArray.push("#" + mapObj1.elementName + "_div_" + blockIn1[el]);
+ var selector = selectorArray.join(",");
+ $(selector).remove();
+ mapObj2.afterMapRequest.register(function () {
+ for (var el in blockIn2) {
+ selectorArray.push("#" + mapObj2.elementName + "_div_" + blockIn2[el]);
+ blockUnwantedWms();
+ $("#" + mod_mapMirror_elName).html("<form><input id='mod_mapMirror_checkbox' type='checkbox' /></form>");
+ $("#mod_mapMirror_checkbox").change(function () {
+ if (this.checked === true) {
+ // disable controls
+ $(affectedItemsSelector).css({
+ "visibility":"hidden"
+ // mirror map extent of map 1 in map 2
+ var ext1 = mapObj1.extent;
+ mapObj2.extent = ext1;
+ mapObj2.setMapRequest();
+ // initial mirroring
+ mapObj1.afterMapRequest.trigger();
+ else {
+ // remove mirroring
+ mapObj1.afterMapRequest = new MapbenderEvent();
+ // re-add blocking
+ // enable controls
+ "visibility":"visible"
Added: branches/google_dev/http/javascripts/mod_toggleLayers.php
--- branches/google_dev/http/javascripts/mod_toggleLayers.php (rev 0)
+++ branches/google_dev/http/javascripts/mod_toggleLayers.php 2009-06-02 15:29:42 UTC (rev 3983)
@@ -0,0 +1,84 @@
+<?php
+(function () {
+<?php
+try {
+ if (layerData) {}
+catch (e) {
+ layerData = {};
+var mod_toggleLayers_elName = "<?php echo $e_id;?>";
+function findLayerInWmsAndSetVisibility (map, wmsArray, visibility) {
+ if (typeof(wmsArray) !== "object") {
+ return;
+ for (var wmsId in wmsArray) {
+ var index = map.getWmsIndexById(wmsId);
+ if (index === null) {
+ continue;
+ for (var i in wmsArray[wmsId]) {
+ var name = wmsArray[wmsId][i];
+ map.wms[index].handleLayer(name, "visible", visibility);
+ var checkBoxId = mod_toggleLayers_elName + "_checkbox";
+ $("#" + mod_toggleLayers_elName).html("<form><input id='" + checkBoxId + "' type='checkbox' /></form>");
+ $("#" + checkBoxId).change(function () {
+ for (var el in layerData) {
+ if (typeof(el) !== "string") {
+ continue;
+ var map = getMapObjByName(el);
+ if (map === false) {
+ continue;
+ var layerVisibility;
+ if (typeof(layerData[el].on) !== "undefined") {
+ layerVisibility = this.checked === true ? 1 : 0;
+ findLayerInWmsAndSetVisibility(map, layerData[el].on, layerVisibility);
+ if (typeof(layerData[el].off) !== "undefined") {
+ layerVisibility = this.checked === false ? 1 : 0;
+ findLayerInWmsAndSetVisibility(map, layerData[el].off, layerVisibility);
+ map.setMapRequest();
Added: branches/google_dev/http/javascripts/mod_wfs_gazetteer_parameterizedSearch.php
--- branches/google_dev/http/javascripts/mod_wfs_gazetteer_parameterizedSearch.php (rev 0)
+++ branches/google_dev/http/javascripts/mod_wfs_gazetteer_parameterizedSearch.php 2009-06-02 15:29:42 UTC (rev 3983)
@@ -0,0 +1,29 @@
+<?php
+# $Id: mod_wfs_gazetteer_client.php 3818 2009-03-27 08:25:43Z verenadiewald $
+# maintained by http://www.mapbender.org/index.php/User:Verena Diewald
+# http://www.mapbender.org/index.php/WFS_gazetteer
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+parameterizedSearch : function (value) {
+ var valueArray = value;
+ if (typeof value === "number" || typeof value === "string") {
+ valueArray = [value];
+ window.frames.gazetteerWFS.parameterizedSearch(20, "Verfahren", valueArray);
More information about the Mapbender_commits
