[Mapbender-commits] r4013 - in trunk/mapbender: . conf
http/javascripts
svn_mapbender at osgeo.org
Tue Jun 9 07:59:02 EDT 2009
Author: beck
Date: 2009-06-09 07:59:01 -0400 (Tue, 09 Jun 2009)
New Revision: 4013
Added:
trunk/mapbender/.project
trunk/mapbender/conf/mapbender.conf
trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
trunk/mapbender/index.php
Added: trunk/mapbender/.project
--- trunk/mapbender/.project (rev 0)
+++ trunk/mapbender/.project 2009-06-09 11:59:01 UTC (rev 4013)
@@ -0,0 +1,12 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<projectDescription>
+ <name>mapbender_trunk</name>
+ <comment></comment>
+ <projects>
+ </projects>
+ <buildSpec>
+ </buildSpec>
+ <natures>
+ <nature>com.aptana.ide.editor.php.phpnature</nature>
+ </natures>
+</projectDescription>
Added: trunk/mapbender/conf/mapbender.conf
--- trunk/mapbender/conf/mapbender.conf (rev 0)
+++ trunk/mapbender/conf/mapbender.conf 2009-06-09 11:59:01 UTC (rev 4013)
@@ -0,0 +1,166 @@
+<?php
+# $Id: mapbender.conf-dist 3843 2009-03-30 07:24:14Z astrid_emde $
+# http://www.mapbender.org/index.php/Mapbender.conf
+# Copyright (C) 2002 CCGIS
+# type of mapbender database
+#define("SYS_DBTYPE", "mysql");
+define("SYS_DBTYPE", "pgsql");
+# database information
+if(SYS_DBTYPE=="mysql")
+ define("DBSERVER", "<HOST>");
+ define("PORT", "3306");
+ define("DB", "<database>");
+ define("OWNER", "<owner>");
+ define("PW", "<password>");
+ # database with geos functions
+ define("GEOS_DBSERVER", "<HOST>");
+ define("GEOS_PORT", "5432");
+ define("GEOS_DB", "<database with geos functions>");
+ define("GEOS_OWNER", "<owner>");
+ define("GEOS_PW", "<password>");
+else {
+ define("DBSERVER", "localhost");
+ define("PORT", "5432");
+ define("DB", "mapbender_trunk");
+ define("OWNER", "postgres");
+ define("PW", "postgres");
+# prepared statements (PHP > 5.1.x, PostgreSQL > 7.4)
+define("PREPAREDSTATEMENTS",true);
+# encoding - default characterset UTF-8 / ISO-8859-1
+define("CHARSET","UTF-8");
+# error_reporting
+//ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
+# directory for temporary files
+define("TMPDIR", "../tmp");
+# URL to login
+define("LOGIN", "http://localhost/aptana/mapbender_trunk/http/frames/login.php");
+define("MAXLOGIN", 100);
+$login = LOGIN;
+# URL to owsproxy
+# (no terminating slash)
+define("OWSPROXY", "http://<ip or name>/owsproxy");
+# type of server-connection
+# curl, socket, http
+#define("CONNECTION", "curl");
+define("CONNECTION", "http");
+#define("CONNECTION", "socket");
+define("CONNECTION_PROXY", "<ip>");
+define("CONNECTION_PORT", "<port>");
+define("CONNECTION_USER", "<user>");
+define("CONNECTION_PASSWORD", "<password>");
+# HOSTs not for Proxy (curl)
+define("NOT_PROXY_HOSTS", "<ip>,<ip>,<ip>");
+# security: path to modules
+define("CHECK", false);
+# enable/disable portal
+define("PORTAL", false);
+# mail settings for internal mapbender mails
+# smtp mailing
+# for further settings check 'class_administration.php'
+# please check phpmailer for more information
+define("USE_PHP_MAILING", "false");
+define("MAILHOST", "<host>");
+define("MAILUSERNAME", "<user>");
+define("MAILPASSWORD", "<password>");
+define("MAILADMIN", "<mailaddress of the mailadmin>");
+define("MAILADMINNAME", "<mailadminname>");
+$mailHost = MAILHOST;
+$mailUsername = MAILUSERNAME;
+$mailPassword = MAILPASSWORD;
+# wms monitoring
+define("AUTO_UPDATE", "0");
+define("TIME_LIMIT", "300");
+define("PHP_PATH", "/usr/local/bin/");
+# Mapbender error logging
+define("LOG_LEVEL", "error"); //"off","error","warning","notice" or "all"
+define("LOG_JS", "on"); // "on", "alert", "console" or "off"
+# Internationalization
+define("USE_I18N", false); // requires gettext for PHP.
+ // If "false", LANGUAGE is set to english
+define("LANGUAGE", "en"); // only available if USE_I18N is "true".
+ // "en", "de", "bg", "gr", "nl", "hu", "it", "es","fr","pt"
+###HACK for GLOBALS
+$DBSERVER=DBSERVER;
+ $DB=DB;
+ $OWNER=OWNER;
+ $PW=PW;
+ $GEOS_DBSERVER=GEOS_DBSERVER;
+ $GEOS_DB=GEOS_DB;
+ $GEOS_PORT =GEOS_PORT;
+ $GEOS_OWNER=GEOS_OWNER;
+ $GEOS_PW=GEOS_PW;
Added: trunk/mapbender/http/javascripts/mod_digitize_tab_category.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab_category.php (rev 0)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab_category.php 2009-06-09 11:59:01 UTC (rev 4013)
@@ -0,0 +1,2206 @@
+<?php
+# $Id: mod_digitize_tab.php 3939 2009-05-12 19:43:45Z marc $
+# http://www.mapbender.org/index.php/mod_digitize_tab.php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+$e_target = $_GET["e_target"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Digitize</title>
+<?php
+$digitize_conf_filename = "digitize_default.conf";
+include '../include/dyn_css.php';
+<script language='JavaScript'>
+// Returns a form with the elements of a selected WFS grouped in tabs
+// (if the original WFS is the selected WFS, the values are set too)
+var initialTab = false;
+function buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex) {
+ var featureTypeMismatch = false;
+ if (parseInt(d.get(memberIndex).wfs_conf) != parseInt(wfsConfIndex)) {featureTypeMismatch = true;}
+ var str = "";
+ var hasGeometryColumn = false;
+ var featureTypeArray = wfsConf[wfsConfIndex];
+ var memberElements;
+ var fid = false;
+ if (!featureTypeMismatch) {
+ memberElements = d.get(memberIndex).e;
+ fid = memberElements.getElementValueByName('fid');
+ if (typeof(featureTypeArray["element"]) !== "undefined") {
+ featureTypeElementArray = featureTypeArray["element"];
+ elementCategories.sort();
+ str += "<form id='"+featureTypeElementFormId+"'>\n\t\n";
+ initialTab = elementCategories[0];
+ for(var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
+ str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
+ // 2. add rows to form
+ for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
+ var featureTypeElement = featureTypeElementArray[i];
+ var elementName = featureTypeElement['element_name'];
+ var elementType = featureTypeElement['element_type'];
+ var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+ var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+ var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+ if(featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
+ continue;
+ str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
+ str += '<table>';
+ var elementLabelExists = (featureTypeElement['f_label'] != "");
+ var elementLabel = "";
+ if (elementLabelExists) {
+ elementLabel = featureTypeElement['f_label'];
+ var elementLabelStyle = featureTypeElement['f_label_id'];
+ if (!isGeomColumn) {
+ if (isEditable) {
+ str += "\t\t<tr>\n";
+ if(elementLabelExists) {
+ str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+ str += "\t\t\t<td>\n";
+ else {
+ str += '<td colspan="2">';
+ var elementValue = "";
+ for (var j = 0 ; j < memberElements.count() ; j ++) {
+ if (memberElements.getName(j) == featureTypeElement['element_name']) {
+ elementValue = memberElements.getValue(j);
+ var formElementHtml = featureTypeElement['f_form_element_html'];
+ if (!formElementHtml) {
+ mandatoryHint = '';
+ var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
+ str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+ str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+ str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+ else {
+ while (formElementHtml.match(/\\/)) {
+ formElementHtml = formElementHtml.replace(/\\/, "");
+ var patternString = "<select";
+ pattern = new RegExp(patternString);
+ if (pattern.test(formElementHtml)) {
+ formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ var patternString = "hasdatepicker";
+ formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ var patternString = "<textarea";
+ formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
+ str += formElementHtml;
+ if(featureTypeElement.f_helptext.length > 0) {
+ str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../x_geoportal/img/help.png" width="16" height="16" alt="?" /></a> ';
+ str += '<div id="helptext' +i+ '" class="helptext">';
+ str += '<p>';
+ str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+ str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
+ str += '</p>';
+ str += '</div>';
+ str += "\t\t\t</td>\n\t\t</tr>\n";
+ else {
+ hasGeometryColumn = true;
+ str += '</table>';
+ str += '</div>';
+ // 3. add buttons "save", "update", "delete"
+ str += "<table>";
+ var isTransactional = (featureTypeArray['wfs_transaction']);
+ if (isTransactional) {
+ var options = ["save", "update", "delete", "abort"];
+ for (var i = 0 ; i < options.length ; i++) {
+ var onClickText = "this.disabled=true;var result = window.opener.formCorrect(document, '"+featureTypeElementFormId+"');";
+ onClickText += "if (result.isCorrect) {";
+ onClickText += "window.opener.dbGeom('"+options[i]+"', "+memberIndex+"); ";
+// onClickText += "window.close();";
+ onClickText += "}";
+ onClickText += "else {";
+ onClickText += "alert(result.errorMessage);this.disabled=false;"
+ if (options[i] == "save" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
+ str += "\t\t\t<td><input type='button' name='saveButton' value='"+buttonLabelSaveGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\" /></td>\n";
+ if (!featureTypeMismatch && fid) {
+ if (options[i] == "update" && hasGeometryColumn) {
+ str += "\t\t\t<td><input type='button' name='updateButton' value='"+buttonLabelUpdateGeometry[selectedLanguage]+"' onclick=\""+onClickText+"\"/></td>\n";
+ if (options[i] == "delete"){
+ var deleteOnClickText = "var deltrans = confirm('"+messageConfirmDeleteGeomFromDb[selectedLanguage]+"');";
+ deleteOnClickText += "if (deltrans){";
+ deleteOnClickText += onClickText + "}";
+ str += "\t\t\t<td><input type='button' name='deleteButton' value='"+buttonLabelDeleteGeometry[selectedLanguage]+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
+ if (options[i] == "abort") {
+ str += "\t\t\t<td><input type='button' name='abortButton' value='"+buttonLabelAbort[selectedLanguage]+"' onclick=\"window.close();\" /></td>\n";
+ str += "\t\t</tr>\n";
+ str += "\t</table>\n";
+ str += "<input type='hidden' id='fid' value='"+fid+"'>";
+// str += "<input type='text' name='mb_wfs_conf'>";
+ str += "</form>\n";
+ return str;
+// Buttons
+function addButtonDig(id, isOn, src, titleOff, titleOn, x, y) {
+ buttonDig_id.push(id);
+ buttonDig_on.push(isOn);
+ buttonDig_src.push(src);
+ buttonDig_title_off.push(titleOff);
+ buttonDig_title_on.push(titleOn);
+ buttonDig_x.push(x);
+ buttonDig_y.push(y);
+function htmlspecialchars(p_string) {
+ p_string = p_string.replace(/&/g, '&');
+ p_string = p_string.replace(/</g, '<');
+ p_string = p_string.replace(/>/g, '>');
+ p_string = p_string.replace(/"/g, '"');
+ // p_string = p_string.replace(/'/g, ''');
+ return p_string;
+//default definition of image directory for digitize buttons, might
+//be overwritten with digitize conf data
+var buttonDig_imgdir = "../img/button_digitize/";
+var buttonDig_id = [];
+var buttonDig_on = [];
+var buttonDig_src = [];
+var buttonDig_title_off = [];
+var buttonDig_title_on = [];
+var buttonDig_x = [];
+var buttonDig_y = [];
+var mapWindow;
+var mapDomElement;
+var mapType = "";
+parent.eventInit.register(function () {
+ var mapIndex = parent.getMapObjIndexByName(mod_digitize_target);
+ mapDomElement = parent.mb_mapObj[mapIndex].getDomElement();
+ mapType = mapDomElement.tagName.toUpperCase();
+ if (mapType == "DIV") {
+ mapWindow = parent.window;
+ else if (mapType == "IFRAME") {
+ mapWindow = mapDomElement.window;
+ else {
+ new parent.Mb_warning("Could not set CSS for map in digitizing module.");
+<?php
+echo "var mod_digitize_target = '".$e_target."';";
+$digitizeConfFilenameAndPath = dirname(__FILE__) . "/../../conf/" . $digitize_conf_filename;
+if ($digitize_conf_filename && file_exists($digitizeConfFilenameAndPath)) {
+ include($digitizeConfFilenameAndPath);
+var wfsWindow;
+var wfsConf = [];
+var d;
+var mod_digitize_width;
+var mod_digitize_height;
+var mod_digitizeEvent = false;
+var nonTransactionalHighlight;
+var button_point = "Point";
+var button_line = "Line";
+var button_polygon = "Polygon";
+var button_move = "dragBasePoint";
+var button_insert = "setBasePoint";
+var button_delete = "delBasePoint";
+var button_clear = "clear";
+var button_split = "digitizeSplit";
+var button_merge = "digitizeMerge";
+var button_difference = "digitizeDifference";
+var digitizeDivTag;
+var GeometryArray;
+var MultiGeometry = parent.MultiGeometry;
+var Geometry;
+var Point;
+var geomType;
+var msgObj;
+var featureTypeElementFormId = "featureTypeElementForm";
+try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
+try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
+function toggleTabs(tabId) {
+ if(!initialTab) {
+ return;
+ var tabHeaders = wfsWindow.document.getElementsByTagName('a');
+ var tabs = wfsWindow.document.getElementsByTagName('div');
+ for(var i = 0; i < tabHeaders.length; i++) {
+ if(tabHeaders[i].id.indexOf('tabheader') != -1) {
+ tabHeaders[i].className = 'tabheader';
+ for(var i = 0; i < tabs.length; i++) {
+ if(tabs[i].className === 'tabcontent') {
+ tabs[i].style.visibility = 'hidden';
+ tabs[i].style.display = 'none';
+ wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
+ wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
+ wfsWindow.document.getElementById('tab_' + tabId).style.display = 'block';
+ return false;
+function showHelptext(helptextId) {
+ hideHelptext();
+ wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+ wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'block';
+ return false;
+function hideHelptext(helptextId) {
+ if(helptextId) {
+ wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+ wfsWindow.document.getElementById('helptext' + helptextId).style.display = 'none';
+ var helptext = wfsWindow.document.getElementsByTagName('div');
+ for(var i = 0; i < helptext.length; i++) {
+ if(helptext[i].className === 'helptext') {
+ helptext[i].style.visibility = 'hidden';
+ helptext[i].style.display = 'none';
+ return false;
+function getMousePosition(e) {
+ parent.mb_getMousePos(e, mod_digitize_target);
+ var currentPos = null;
+ currentPos = new parent.Point(
+ parent.clickX - parseInt(mapDomElement.style.left),
+ parent.clickY - parseInt(mapDomElement.style.top)
+ else {
+ parent.clickX,
+ parent.clickY
+ return currentPos;
+function initializeDigitize () {
+ d = new parent.GeometryArray();
+ GeometryArray = parent.GeometryArray;
+ Geometry = parent.Geometry;
+ Point = parent.Point;
+ geomType = parent.geomType;
+ * Append geometries from KML when KML has been loaded
+function appendGeometryArrayFromKML () {
+ try {
+ parent.kmlHasLoaded.register(function(properties){
+ d.importGeoJSON(properties);
+// d = parent.geoJsonToGeometryArray(properties);
+ executeDigitizeSubFunctions();
+ catch (e) {
+ var exc = new parent.Mb_warning(e);
+// --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
+function appendGeometryArray(obj) {
+ executeDigitizePreFunctions();
+ for (i=0; i<obj.count(); i++) {
+ d.addCopy(obj.get(i));
+function mod_digitize_go(e){
+ // ie workaround
+ if (e == undefined) {
+ e = mapWindow.event;
+ if (e) {
+ // track mouse position
+ var currentPos = getMousePosition(e);
+ s.check(currentPos);
+ else {
+// s.clean();
+ var el = mapDomElement;
+ el.onmousedown = mod_digitize_start;
+function mod_digitize_timeout(){
+ el.onmousedown = null;
+ el.onmouseup = null;
+ el.onmousemove = null;
+function mod_digitize_start(e){
+ // check if a proper geometry is selected
+ if (d.getGeometry(-1,-1).isComplete() || d.count() == 0){
+ if (mod_digitizeEvent != false) {
+ alert(msgObj.errorMessageNoGeometrySelected);
+ return false;
+ var realWorldPos;
+ if (s.isSnapped()) {
+ realWorldPos = s.getSnappedPoint();
+ s.clean();
+ else {
+ realWorldPos = parent.mapToReal(mod_digitize_target,currentPos);
+ if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(0).equals(realWorldPos)) {
+ // close the polygon
+ d.close();
+ parent.mb_disableThisButton(button_polygon);
+ return true;
+ else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() > 1 && d.getGeometry(-1,-1).get(-1).equals(realWorldPos)) {
+ // close the line
+ d.close();
+ parent.mb_disableThisButton(button_line);
+ return true;
+ else {
+ // set the calculated real world position as point of the geometry
+ d.getGeometry(-1,-1).addPoint(realWorldPos);
+ d.getGeometry(-1,-1).setEpsg(parent.mb_mapObj[mapIndex].epsg);
+ if(d.get(-1).geomType == parent.geomType.point){
+ d.close();
+ parent.mb_disableThisButton(button_point);
+ return true;
+ // add first point of polygon to snapping list (if three points have been inserted).
+ else if (d.get(-1).geomType == parent.geomType.polygon && d.getGeometry(-1,-1).count() == 3) {
+ s.add(d.getPoint(-1, -1, 0));
+ // add last point of line to snapping list (if at least two points have been inserted).
+ else if (d.get(-1).geomType == parent.geomType.line && d.getGeometry(-1,-1).count() >= 2) {
+ if (mod_digitizeEvent != button_move) {
+ s.store(d);
+ s.add(d.getPoint(-1, -1, -1));
+ return true;
+// --- basepoint handling (begin) -----------------------------------------------------------------------------------------
+var basepointObject = false;
+var basepointMemberIndex = null;
+var basepointGeometryIndex = null;
+var basepointRingIndex = null;
+var basepointPointIndex = null;
+var basepointDragActive = false;
+function handleBasepoint(obj,memberIndex, geometryIndex, ringIndex, pointIndex){
+ if (!(
+ mod_digitizeEvent == button_move ||
+ mod_digitizeEvent == button_insert ||
+ mod_digitizeEvent == button_delete)
+ return false;
+ basepointObject = obj;
+ basepointMemberIndex = memberIndex;
+ basepointGeometryIndex = geometryIndex;
+ if (pointIndex == undefined) {
+ pointIndex = ringIndex;
+ basepointRingIndex = undefined;
+ else {
+ basepointRingIndex = ringIndex;
+ basepointPointIndex = pointIndex;
+ if(mod_digitizeEvent == button_move){
+ mod_digitize_timeout();
+ basepointObject.style.cursor = 'move';
+ basepointObject.onmousedown = parent.frames[mod_digitize_elName].selectBasepoint;
+ if(mod_digitizeEvent == button_delete){
+ basepointObject.style.cursor = 'crosshair';
+ basepointObject.onmousedown = parent.frames[mod_digitize_elName].deleteBasepoint;
+function convertLinepointToBasepoint(obj, memberIndex, geomIndex, ringIndex, pointIndex){
+ if(!(mod_digitizeEvent == button_insert)){ return false; }
+ if(mod_digitizeEvent == button_insert){
+ obj.style.cursor = 'crosshair';
+ obj.onclick = insertBasepoint;
+ basepointGeometryIndex = geomIndex;
+function insertBasepoint(e){
+ var i = basepointMemberIndex;
+ var j = basepointGeometryIndex;
+ var k = basepointRingIndex;
+ var l = basepointPointIndex;
+ var ind = parent.getMapObjIndexByName(mod_digitize_target);
+ var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(currentPos.x, currentPos.y));
+ if (k == undefined) {
+ d.getGeometry(i,j).addPointAtIndex(p, l);
+ else {
+ d.getGeometry(i,j).innerRings.get(k).addPointAtIndex(p, l);
+function deleteBasepoint(){
+ if (k != undefined) {
+ d.delAllPointsLike(d.getPoint(i, j, k, l));
+ else {
+ d.delAllPointsLike(d.getPoint(i, j, l));
+function selectBasepoint(e){
+ if(!basepointDragActive && mod_digitizeEvent == button_move){
+ basepointDragActive = true;
+ s.store(d, d.getPoint(basepointMemberIndex, basepointGeometryIndex, basepointPointIndex));
+ // replace basepoint by transparent blob
+ basepointObject.style.width = mod_digitize_width;
+ basepointObject.style.height = mod_digitize_height;
+ basepointObject.style.left = 0;
+ basepointObject.style.top = 0;
+ if (parent.ie) {
+ // ie cannot handle backgroundColor = 'transparent'
+ basepointObject.style.background = "url(../img/transparent.gif)";
+ else{
+ basepointObject.style.backgroundColor = 'transparent';
+ basepointObject.onmouseup = releaseBasepoint;
+ basepointObject.onmousemove = dragBasepoint;
+function dragBasepoint(e){
+ if(basepointDragActive){
+ var res = s.check(currentPos);
+function updateAllPointsOfNonTransactionalLike(oldP, newP){
+ for (var i = 0; i < d.count(); i++) {
+ if (isTransactional(d.get(i))) {
+ d.get(i).updateAllPointsLike(oldP, newP);
+function releaseBasepoint(e){
+ basepointDragActive = false;
+ var basepointDragEnd = currentPos;
+ basepointObject.onmousedown = null;
+ var p = parent.mb_mapObj[ind].convertPixelToReal(new Point(basepointDragEnd.x, basepointDragEnd.y));
+ var oldPoint;
+ oldPoint = parent.cloneObject(d.getPoint(i,j,l));
+ else {
+ oldPoint = parent.cloneObject(d.getPoint(i,j,k,l));
+ var snappedPoint = parent.cloneObject(s.getSnappedPoint());
+ if (!nonTransactionalEditable) {
+ updateAllPointsOfNonTransactionalLike(oldPoint, snappedPoint);
+ else {
+ d.updateAllPointsLike(oldPoint, snappedPoint);
+ s.clean();
+ else {
+ updateAllPointsOfNonTransactionalLike(oldPoint, p);
+ else {
+ d.updateAllPointsLike(oldPoint, p);
+ basepointMemberIndex = null;
+ basepointGeometryIndex = null;
+ basepointPointIndex = null;
+// --- basepoint handling (end) -----------------------------------------------------------------------------------------
+// --- registered functions (begin) ---------------------------------------------------------------------------------------
+function registerDigitizePreFunctions(stringFunction){
+ mod_digitizePreFunctions[mod_digitizePreFunctions.length] = stringFunction;
+function registerDigitizeSubFunctions(stringFunction){
+ mod_digitizeSubFunctions[mod_digitizeSubFunctions.length] = stringFunction;
+function executeDigitizeSubFunctions(){
+ for(var i=0; i<mod_digitizeSubFunctions.length; i++){
+ eval(mod_digitizeSubFunctions[i]);
+function executeDigitizePreFunctions(){
+ for(var i=0; i<mod_digitizePreFunctions.length; i++){
+ eval(mod_digitizePreFunctions[i]);
+function registerFunctions(){
+ mod_digitizePreFunctions = [];
+ mod_digitizeSubFunctions = [];
+ registerDigitizePreFunctions("updateExtent()");
+ registerDigitizePreFunctions("drawDashedLine()");
+ registerDigitizeSubFunctions("updateListOfGeometries()");
+ registerDigitizeSubFunctions("drawDashedLine()");
+ parent.eventInit.register(function () {
+ initializeDigitize();
+ setStyleForTargetFrame();
+ checkDigitizeTag();
+ initialiseSnapping();
+// appendGeometryArrayFromKML();
+ initialiseHighlight();
+ initialiseMeasure();
+ getMessages();
+ parent.eventLocalize.register(function() {
+ getMessages();
+ parent.eventAfterMapRequest.register(function () {
+ updateExtent();
+ parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
+function checkDigitizeTag(){
+ var digitizeTagName = "digitizeDiv";
+ var digitizeTagStyle;
+ digitizeTagStyle = {"z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+ digitizeDivTag = new parent.DivTag(digitizeTagName, "", digitizeTagStyle, mapDomElement);
+ else {
+ digitizeTagStyle = {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeTransactionalZIndex, "font-size":"10px"};
+ digitizeDivTag = new parent.DivTag(digitizeTagName, mod_digitize_target, digitizeTagStyle);
+ parent.mb_registerPanSubElement(digitizeTagName);
+ parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].drawDashedLine()");
+function setStyleForTargetFrame(){
+ var cssLink = mapWindow.document.createElement("link");
+ var cssHead = mapWindow.document.getElementsByTagName("head")[0];
+ cssLink.setAttribute("href", cssUrl);
+ cssLink.setAttribute("type", "text/css");
+ cssLink.setAttribute("rel", "stylesheet");
+ cssHead.appendChild(cssLink);
+function initialiseSnapping(){
+ s = new parent.Snapping(mod_digitize_target, snappingTolerance, snappingColor, snappingHighlightZIndex);
+function initialiseHighlight(){
+ nonTransactionalHighlight = new parent.Highlight([mod_digitize_target], "nonTransactional", {"position":"absolute", "top":"0px", "left":"0px", "z-index":digitizeNonTransactionalZIndex}, nonTransactionalLineWidth);
+function initialiseMeasure(){
+ measureDivTag = new parent.DivTag(measureTagName, "", measureTagStyle);
+ else {
+ measureDivTag = new parent.DivTag(measureTagName, measureTagTarget, measureTagStyle);
+ parent.mb_registerSubFunctions("window.frames['"+ mod_digitize_elName + "'].updateMeasureTag()");
+// --- registered functions (end) -----------------------------------------------------------------------------------------
+function updateMeasureTag () {
+ if (d.count() > 0 ) {
+ if (d.get(-1).count() > 0) {
+ if (d.getGeometry(-1, -1).count() > 0) {
+ if (mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon) {
+ var measureString = "";
+ measureString += msgObj.measureTagLabelCurrent + d.getGeometry(-1, -1).getCurrentDist(measureNumberOfDigits) + "<br>";
+ measureString += msgObj.measureTagLabelTotal + d.getGeometry(-1, -1).getTotalDist(measureNumberOfDigits);
+ measureDivTag.write(measureString);
+ return true;
+ measureDivTag.clean();
+// --- button handling (begin) --------------------------------------------------------------------------------------------
+function displayButtons(){
+ for (var i = 0 ; i < buttonDig_id.length ; i ++) {
+ if (parseInt(buttonDig_on[i])==1) {
+ var divTag = document.createElement("div");
+ divTag.setAttribute("id", "div_" + buttonDig_id[i]);
+// FIREFOX
+ document.getElementById("digButtons").appendChild(divTag);
+//IE WORKAROUND, WORKS ALSO FOR FIREFOX
+ var tagContent = "<div style='position:absolute; top:"+buttonDig_y[i]+"px; left:"+buttonDig_x[i]+"px;'><img name=\""+buttonDig_id[i]+"\" onmouseover=\"parent.mb_regButton_frame('initDigButton', mod_digitize_elName, "+i+");\" id=\""+buttonDig_id[i]+"\" title=\""+buttonDig_title_off[i]+"\" src=\""+buttonDig_imgdir+buttonDig_src[i]+"\"></div>";
+ parent.writeTag(mod_digitize_elName,"div_" + buttonDig_id[i],tagContent);
+function updateButtons() {
+ var currentButton = document.getElementById(buttonDig_id[i]);
+ var currentStatus = buttonDig_id[i].status;
+ var currentTitle = "";
+ switch (buttonDig_id[i]) {
+ case "Point":
+ if (currentStatus == 1) {
+ currentTitle = msgObj.buttonLabelPointOn;
+ else {
+ currentTitle = msgObj.buttonLabelPointOff;
+ break;
+ case "Line":
+ currentTitle = msgObj.buttonLabelLineOn;
+ else {
+ currentTitle = msgObj.buttonLabelLineOff;
+ break;
+ case "Polygon":
+ currentTitle = msgObj.buttonLabelPolygonOn;
+ else {
+ currentTitle = msgObj.buttonLabelPolygonOff;
+ break;
+ case "dragBasePoint":
+ currentTitle = msgObj.buttonLabelMoveBasepointOn;
+ else {
+ currentTitle = msgObj.buttonLabelMoveBasepointOff;
+ break;
+ case "setBasePoint":
+ currentTitle = msgObj.buttonLabelInsertBasepointOn;
+ else {
+ currentTitle = msgObj.buttonLabelInsertBasepointOff;
+ break;
+ case "delBasePoint":
+ currentTitle = msgObj.buttonLabelDeleteBasepointOn;
+ else {
+ currentTitle = msgObj.buttonLabelDeleteBasepointOff;
+ break;
+ case "clear":
+ currentTitle = msgObj.buttonLabelClearListOn;
+ else {
+ currentTitle = msgObj.buttonLabelClearListOff;
+ break;
+ case "digitizeSplit":
+ currentTitle = msgObj.buttonLabelSplitOn;
+ else {
+ currentTitle = msgObj.buttonLabelSplitOff;
+ break;
+ case "digitizeMerge":
+ currentTitle = msgObj.buttonLabelMergeOn;
+ else {
+ currentTitle = msgObj.buttonLabelMergeOff;
+ break;
+ case "digitizeDifference":
+ currentTitle = msgObj.buttonLabelDifferenceOn;
+ else {
+ currentTitle = msgObj.buttonLabelDifferenceOff;
+ break;
+ currentButton.title = currentTitle;
+function initDigButton(ind, pos){
+ parent.mb_button[ind] = document.getElementById(buttonDig_id[pos]);
+ parent.mb_button[ind].img_over = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_over");
+ parent.mb_button[ind].img_on = buttonDig_imgdir + buttonDig_src[pos].replace(/_off/,"_on");
+ parent.mb_button[ind].img_off = buttonDig_imgdir + buttonDig_src[pos];
+ parent.mb_button[ind].title_on = buttonDig_title_on[pos];
+ parent.mb_button[ind].title_off = buttonDig_title_off[pos];
+ parent.mb_button[ind].status = 0;
+ parent.mb_button[ind].elName = buttonDig_id[pos];
+ parent.mb_button[ind].fName = "";
+ parent.mb_button[ind].go = new Function ("digitizeEnable(parent.mb_button["+ind+"])");
+ parent.mb_button[ind].stop = new Function ("digitizeDisable(parent.mb_button["+ind+"])");
+function digitizeEnable(obj) {
+ if (obj.id == button_move || obj.id == button_insert || obj.id == button_delete) {
+ mod_digitizeEvent = obj.id;
+ else if (obj.id == button_point || obj.id == button_line ||
+ obj.id == button_polygon || obj.id == button_clear ||
+ obj.id == button_split || obj.id == button_merge ||
+ obj.id == button_difference){
+ el.onmousemove = mod_digitize_go;
+ if (mod_digitizeEvent == button_point || mod_digitizeEvent == button_line || mod_digitizeEvent == button_polygon || mod_digitizeEvent == button_insert ) {
+ s.store(d);
+ obj.title = obj.title_on;
+ if (obj.id == button_point) {
+ if (d.count() > 0 && d.get(-1).count() > 0 && !d.get(-1).get(-1).isComplete()) {
+ if (d.get(-1).geomType != parent.geomType.point) {
+ d.close();
+ else {
+ if (d.count() == 0 || (d.count() > 0 && d.get(-1).count() > 0 && d.get(-1).get(-1).isComplete())) {
+ d.addMember(parent.geomType.point);
+ d.get(-1).addGeometry();
+ else {
+// delete existing line or polygon
+ d.del(-1);
+ else if (obj.id == button_polygon) {
+ if (d.get(-1).geomType != parent.geomType.polygon) {
+ d.close();
+ else {
+ // new geometry
+ d.addMember(parent.geomType.polygon);
+ else {
+// continue a line as a polygon
+ var geometryTemplate = parent.cloneObject(d.get(-1));
+ d.del(-1);
+ for (var i = 0; i < geometryTemplate.count(); i++) {
+ for (var j = 0; j < geometryTemplate.get(i).count(); j++) {
+ d.get(-1).get(-1).addPoint(geometryTemplate.get(i).get(j));
+ else if (obj.id == button_line) {
+ if (d.get(-1).geomType != parent.geomType.line) {
+ d.close();
+ else {
+ d.addMember(parent.geomType.line);
+ else {
+// continue a polygon as a line
+ d.del(-1);
+ else if (obj.id == button_clear) {
+ var clear = confirm(msgObj.messageConfirmDeleteAllGeomFromList);
+ if (clear) {
+ parent.mb_disableThisButton(button_clear);
+ else if (obj.id == button_merge) {
+ var applicable = (d.count() > 1);
+ var polygonTextArray = [];
+ if (d.get(i).geomType != parent.geomType.polygon) {
+ applicable = false;
+ polygonTextArray = [];
+ break;
+ polygonTextArray.push(d.get(i).toText());
+ if (!applicable) {
+ alert(msgObj.messageErrorMergeNotApplicable);
+ parent.mb_disableThisButton(button_merge);
+ return false;
+ parent.mb_ajax_post("../php/mod_digitize_mergePolygon.php", {polygons: polygonTextArray.join(";")}, function(json, status) {
+ var response = eval('(' + json + ')');
+ var polygon = response.polygon;
+ d.importGeometryFromText(polygon, parent.mb_mapObj[mapIndex].epsg);
+ // remove the original polygons
+ var len = d.count();
+ for (var i = 0; i < len-1; i++) {
+ d.del(0);
+ else if (obj.id == button_split) {
+ var applicable = (d.count() == 2) &&
+ (d.get(0).geomType == parent.geomType.polygon) &&
+ (d.get(1).geomType == parent.geomType.line);
+ alert(msgObj.messageErrorSplitNotApplicable);
+ parent.mb_disableThisButton(button_split);
+ return false;
+ var polygonText = d.get(0).toText();
+ var lineText = d.get(1).toText();
+ parent.mb_ajax_post("../php/mod_digitize_splitPolygon.php", {polygon: polygonText, line: lineText}, function(json, status) {
+ var polygonArray = response.polygons;
+ var wfsConfId = d.get(0).wfs_conf;
+ for (var i in polygonArray) {
+ d.importGeometryFromText(polygonArray[i], parent.mb_mapObj[mapIndex].epsg);
+ d.get(-1).wfs_conf = wfsConfId;
+ // remove the original polygon and the temporary line
+ d.del(0);
+ d.del(0);
+ else if (obj.id == button_difference) {
+ (d.get(1).geomType == parent.geomType.polygon);
+ alert(msgObj.messageErrorDifferenceNotApplicable);
+ parent.mb_disableThisButton(button_difference);
+ return false;
+ var polygon1Text = d.get(0).toText();
+ var polygon2Text = d.get(1).toText();
+ parent.mb_ajax_post("../php/mod_digitize_differencePolygon.php", {polygon1: polygon1Text, polygon2: polygon2Text}, function(json, status) {
+ var wfsProperties = d.get(0).e;
+ d.get(-1).e = wfsProperties;
+ // remove the original and the temporary polygon
+ d.del(0);
+ d.del(0);
+function digitizeDisable(obj) {
+ if (obj.id == button_point || obj.id == button_line || obj.id == button_polygon){
+ obj.title = obj.title_off;
+ if (d.get(-1).get(-1).count() == 0) {
+ d.delGeometry(-1,-1);
+ mod_digitizeEvent = false;
+// --- button handling (end) ----------------------------------------------------------------------------------------------
+// --- display (begin) -----------------------------------------------------------------------------------------
+function updateExtent() {
+ var anInd = parent.getMapObjIndexByName(mod_digitize_target);
+ var change = false;
+ if (typeof(mod_digitize_width) == 'undefined' || mod_digitize_width != parent.mb_mapObj[anInd].width) {
+ mod_digitize_width = parent.mb_mapObj[anInd].width;
+ change = true;
+ if (typeof(mod_digitize_height) == 'undefined' || mod_digitize_height != parent.mb_mapObj[anInd].height) {
+ mod_digitize_height = parent.mb_mapObj[anInd].height;
+ change = true;
+ if (typeof(mod_digitize_epsg) == 'undefined' || mod_digitize_epsg != parent.mb_mapObj[anInd].epsg) {
+ mod_digitize_epsg = parent.mb_mapObj[anInd].epsg;
+ change = true;
+// if (change) {
+// drawDashedLine();
+function drawDashedLine(){
+ nonTransactionalHighlight.clean();
+ var smP = "";
+ smP += "<div class='t_img'>";
+ smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
+ smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+ var smPArray = [];
+ smPArray[smPArray.length] = "<div class='t_img'>"
+ + "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
+ + "<div class='t_img'>"
+ + "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+ var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
+ var width = mapObj.width;
+ var height = mapObj.height;
+ var arrayBBox = mapObj.extent.split(",")
+ var minX = parseFloat(arrayBBox[0]);
+ var minY = parseFloat(arrayBBox[1]);
+ var maxX = parseFloat(arrayBBox[2]);
+ var maxY = parseFloat(arrayBBox[3]);
+ var cx = width/(maxX - minX);
+ var cy = height/(maxY - minY);
+ var isMoveOrInsertOrDelete = mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete;
+ var minDist = 6;
+ for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
+ var currentGeomArray = d.get(i);
+ if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
+ nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
+ else {
+ for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
+ var currentGeometry = d.getGeometry(i,j);
+ var isPolygon = currentGeomArray.geomType == parent.geomType.polygon;
+ var isLine = currentGeomArray.geomType == parent.geomType.line;
+ var isComplete = currentGeometry.isComplete();
+ var lastPaintedPoint = false;
+ for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
+ var currentPoint = currentGeometry.get(k);
+ var currentPointMap = new Point(Math.round((currentPoint.x - minX)*cx), Math.round((maxY - currentPoint.y)*cy));
+// var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
+// if (!isTooCloseToPrevious) {
+ var currentPointIsVisible = currentPointMap.x > 0 && currentPointMap.x < width && currentPointMap.y > 0 && currentPointMap.y < height;
+ if (currentPointIsVisible) {
+ if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint-1 && isLine))) {
+ smPArray[smPArray.length] = "<div class='bp' style='top:"+
+ (currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+
+ digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
+ else {
+ smPArray[smPArray.length] = "<div class='bp' style='top:"+(currentPointMap.y-2)+"px;left:"+(currentPointMap.x-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
+ if(k==0 && isPolygon && !isComplete){
+ smPArray[smPArray.length] = " title='"+msgObj.closePolygon_title+"' ";
+ if(isMoveOrInsertOrDelete) {
+ smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
+ smPArray[smPArray.length] = "></div>";
+ lastPaintedPoint = currentPointMap;
+ if (k > 0) {
+ points = parent.calculateVisibleDash(currentPointMap, previousPointMap, width, height);
+ if (points != false) {
+ smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
+ var previousPointMap = currentPointMap;
+ if (isPolygon && currentGeometry.innerRings.count() > 0) {
+ // draw inner rings
+ for (var l = 0, lenRings = currentGeometry.innerRings.count(); l < lenRings; l++) {
+ var currentRing = currentGeometry.innerRings.get(l);
+ for (var m = 0, lenPoint = currentRing.count(); m < lenPoint; m++) {
+ var currentPoint = currentRing.get(m);
+ var currentPointMap = new Point(Math.round((currentPoint.x - minX) * cx), Math.round((maxY - currentPoint.y) * cy));
+ // var isTooCloseToPrevious = lastPaintedPoint && (k > 0) && Math.abs(currentPointMap.x-lastPaintedPoint.x) <= minDist && Math.abs(currentPointMap.y-lastPaintedPoint.y) <= minDist;
+ // if (!isTooCloseToPrevious) {
+ if (!isComplete && ((k == 0 && isPolygon) || (k == lenPoint - 1 && isLine))) {
+ smPArray[smPArray.length] = "<div class='bp' style='top:" +
+ (currentPointMap.y - 2) +
+ "px;left:" +
+ (currentPointMap.x - 2) +
+ "px;z-index:" +
+ digitizeTransactionalZIndex +
+ ";background-color:" +
+ linepointColor +
+ else {
+ smPArray[smPArray.length] = "<div class='bp' style='top:" + (currentPointMap.y - 2) + "px;left:" + (currentPointMap.x - 2) + "px;z-index:" + digitizeTransactionalZIndex + ";'";
+ if (m == 0 && isPolygon && !isComplete) {
+ smPArray[smPArray.length] = " title='" + msgObj.closePolygon_title + "' ";
+ if (isMoveOrInsertOrDelete) {
+ smPArray[smPArray.length] = " onmouseover='parent.window.frames[\"" + mod_digitize_elName + "\"].handleBasepoint(this," + i + "," + j + "," + l + "," + m + ")' ;";
+ if (m > 0) {
+ smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, l, m);
+ digitizeDivTag.write(smPArray.join(""));
+function evaluateDashes(start, end, memberIndex, geomIndex, ringIndex, pointIndex){
+ ringIndex = undefined;
+ var strArray = [];
+ var delta = new parent.Point(end.x - start.x, end.y - start.y);
+ var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
+ var vecLength = start.dist(end);
+ var n = Math.round(vecLength/dotDistance);
+ if (n > 0) {
+ var step = delta.dividedBy(n);
+ for(var i=1; i < n; i++){
+ var x = Math.round(start.x + i * step.x) - 2;
+ var y = Math.round(start.y + i * step.y) - 2;
+ if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
+ if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
+ strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
+ else {
+ strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
+ if(mod_digitizeEvent == button_insert) {
+ strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+ringIndex+","+pointIndex+")'";
+ strArray[strArray.length] = "></div>";
+ return strArray.join("");
+function isTransactional(geom) {
+// alert(typeof(geom.wfs_conf) + " " + geom.wfs_conf + " " + wfsConf.length);
+ if (typeof(geom.wfs_conf) == 'number') {
+ if (geom.wfs_conf >= 0 && geom.wfs_conf < wfsConf.length) {
+ var isTransactionalGeom = (wfsConf[geom.wfs_conf]['wfs_transaction'] != "" && wfsConf[geom.wfs_conf]['fkey_featuretype_id'] != "");
+ if (isTransactionalGeom) {
+ return true;
+ else{
+ return false;
+ else if (typeof(geom.wfs_conf) == 'undefined') {
+ return true;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+ return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function getName (geom) {
+ wfsConfId = geom.wfs_conf;
+ wfsConf = parent.get_complete_wfs_conf();
+ if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+ var resultName = "";
+ for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+ if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1) {
+ resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+ if (resultName == "") {
+ resultName = wfsConf[wfsConfId]['g_label'];
+ return resultName;
+ else if (geom.e.getElementValueByName("name")) {
+ return geom.e.getElementValueByName("name");
+ else {
+ return msgObj.digitizeDefaultGeometryName;
+function updateListOfGeometries(){
+ var listOfGeom = "<ul>";
+ if (d.count() > 0) {
+ for (var i = 0 ; i < d.count(); i ++) {
+ if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
+ // for the geometries from a kml, there is another save dialogue
+ if (d.get(i).isFromKml()) {
+ // if the kml is in the db (id = id in database)
+ if (d.get(i).e.getElementValueByName("Mapbender:id")) {
+ // button: geometry information, update kml
+ listOfGeom += "<li>";
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>";
+ else {
+ // button: geometry information, save, update, delete
+ if (wfsExistsForGeom(d.get(i), wfsConf)) {
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>";
+ // button: remove this geometry
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>";
+ // button clone this geometry
+ if (addCloneGeometryButton === true) {
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_clone_src+"' title='"+msgObj.buttonDig_clone_title+"' onclick='d.addCopy(d.get("+i+"));d.get(-1).e.delElement(\"fid\");executeDigitizeSubFunctions();'>";
+ // button: remove geometry from database
+ if (d.get(i).e.getElementValueByName('fid')) {
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">";
+ listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
+ listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+"),\""+geomHighlightColour+"\")' ";
+ listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+"),\""+geomHighlightColour+"\");' ";
+ var geomName = getName(d.get(i));
+ var currentGeomType;
+ if (d.get(i).geomType == parent.geomType.polygon) {
+ currentGeomType = msgObj.messageDescriptionPolygon;
+ else if (d.get(i).geomType == parent.geomType.line) {
+ currentGeomType = msgObj.messageDescriptionLine;
+ else if (d.get(i).geomType == parent.geomType.point) {
+ currentGeomType = msgObj.messageDescriptionPoint;
+ var multi = "";
+ if (d.get(i).count() > 1) {
+ multi = "multi";
+ listOfGeom += ">" + htmlspecialchars(geomName) +" (" + multi + currentGeomType + ")</div>";
+ // multigeometries
+ listOfGeom += "<ul>";
+ for (var j = 0; j < d.get(i).count(); j++) {
+ var currentGeom = d.get(i).get(j);
+ if (d.get(i).count() > 1 || (d.get(i).geomType == geomType.polygon &&
+ d.get(i).get(j).innerRings &&
+ d.get(i).get(j).innerRings.count() > 0)) {
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").del(" + j + ");executeDigitizeSubFunctions();'>";
+ listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
+ listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\")' ";
+ listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.get("+i+").get("+j+"),\""+geomHighlightColour+"\");' ";
+ listOfGeom += ">" + currentGeomType + "#" + (j+1) +"</div></li>";
+ if (d.get(i).geomType == geomType.polygon &&
+ d.get(i).get(j).innerRings.count() > 0) {
+ for (var k = 0; k < d.get(i).get(j).innerRings.count(); k++) {
+ var currentRing = d.get(i).get(j).innerRings.get(k);
+ listOfGeom += "<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.get("+i+").get(" + j + ").innerRings.del(" + k + ");executeDigitizeSubFunctions();'>";
+ listOfGeom += "<div class='digitizeGeometryListItem' onmouseover='parent.mb_wfs_perform(\"over\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
+ listOfGeom += " onmouseout='parent.mb_wfs_perform(\"out\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\")' ";
+ listOfGeom += " onclick='parent.mb_wfs_perform(\"click\",d.getGeometry("+i+","+j+").innerRings.get(" + k + "),\""+geomHighlightColour+"\");' ";
+ listOfGeom += ">inner ring #" + (k+1) +"</div></li>";
+ listOfGeom += "</ul>";
+ listOfGeom += "</li>";
+ parent.writeTag(mod_digitize_elName,"listOfGeometries",listOfGeom);
+// --- display (end) -----------------------------------------------------------------------------------------
+// --- wfs window (begin) -----------------------------------------------------------------------------------------
+// --- wfs window form check (begin) -----------------------------------------------------------------------------------------
+function formCorrect(doc, formId) {
+ var isCorrect = true;
+ var errorMessage = "";
+ var result;
+ var form = doc.getElementById(formId);
+ result = mandatoryFieldsNotEmpty(doc, form);
+ isCorrect = isCorrect && result.isCorrect;
+ errorMessage += result.errorMessage;
+ //select box is now checked within function mandatoryFieldsNotEmpty
+ //result = validBoxEntrySelected(form);
+ //isCorrect = isCorrect && result.isCorrect;
+ //errorMessage += result.errorMessage;
+ result = dataTypeIsCorrect(doc, form);
+ return {"isCorrect":isCorrect, "errorMessage":errorMessage};
+function validBoxEntrySelected(form){
+ for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
+ if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
+ if (parseInt(form.childNodes[i].selectedIndex) == 0) {
+ return {"isCorrect":false, "errorMessage":errorMessage};
+ else if (form.childNodes[i].hasChildNodes()) {
+ isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
+ if (!isCorrect) {
+ errorMessage = msgObj.messageSelectAnOption + "\n";
+function mandatoryFieldsNotEmpty(doc, node){
+ nodeArray = doc.getElementsByName("mandatory");
+ for (var i = 0; i < nodeArray.length && isCorrect; i++) {
+ if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+ var nodeId = nodeArray[i].id.substr(10);
+ if (nodeArray[i].value == "true") {
+ if (doc.getElementById(nodeId).value == "") {
+ isCorrect = false;
+ errorMessage += "'"+ doc.getElementById(nodeId).name +"': "+ msgObj.messageErrorFieldIsEmpty +"\n";
+ if (nodeArray[i].nodeName.toUpperCase() == "SELECT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,10) == "mandatory_") {
+function isInteger(str) {
+ if (str.match(/^\d*$/)) {
+ return true;
+ return false;
+function isFloat(str) {
+ if (isInteger(str)) {
+ return true;
+ if (str.match(/^\d+\.\d+$/)) {
+ return true;
+ return false;
+function replaceCommaByDecimalPoint(str) {
+ var patternString = ",";
+ var pattern = new RegExp(patternString);
+ while (str.match(pattern)) {
+ str = str.replace(pattern, ".");
+ return str;
+function dataTypeIsCorrect(doc, node){
+ nodeArray = doc.getElementsByName("datatype");
+ for (var i = 0; i < nodeArray.length ; i++) {
+ if (nodeArray[i].nodeName.toUpperCase() == "INPUT" && nodeArray[i].type == "hidden" && nodeArray[i].id.substr(0,9) == "datatype_") {
+ var nodeId = nodeArray[i].id.substr(9);
+ var nodeValue = doc.getElementById(nodeId).value;
+ if (nodeArray[i].value == "int") {
+ if (!isInteger(nodeValue)) {
+ errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAnInteger + "\n";
+ else if (nodeArray[i].value == "double") {
+ nodeValue = replaceCommaByDecimalPoint(nodeValue);
+ if (!isFloat(nodeValue)) {
+ errorMessage += "'"+doc.getElementById(nodeId).name+"': "+ msgObj.messageErrorNotAFloat + "\n";
+ else {
+ doc.getElementById(nodeId).value = nodeValue;
+// --- wfs window form check (end) -----------------------------------------------------------------------------------------
+function getAvailableWfsForGeom(geom, wfsConf) {
+ var wfsConfIndices = [];
+ for (var attr in wfsConf) {
+ var isTrans = (wfsConf[attr]['wfs_transaction'] != "");
+ if (!isTrans) {
+ continue;
+ if (isValidWfsConfIndex(wfsConf, parseInt(geom.wfs_conf))) {
+ if (parseInt(geom.wfs_conf) == parseInt(attr)) {
+ wfsConfIndices.push(attr);
+ else {
+ for (var elementIndex = 0; elementIndex < wfsConf[attr]['element'].length ; elementIndex++) {
+ var isGeomColumn = (parseInt(wfsConf[attr]['element'][elementIndex]['f_geom']) == 1);
+ if (isGeomColumn) {
+ var isMultiPolygon = (
+ geom.geomType == parent.geomType.polygon &&
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiPolygonPropertyType' ||
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiSurfacePropertyType'
+ var isPolygon = (
+ geom.count() == 1 &&
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'PolygonPropertyType' ||
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'SurfacePropertyType'
+ var isMultiLine = (
+ geom.geomType == parent.geomType.line &&
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiLineStringPropertyType' ||
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'MultiCurvePropertyType'
+ var isLine = (
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'LineStringPropertyType' ||
+ wfsConf[attr]['element'][elementIndex]['element_type'] == 'CurvePropertyType'
+ var isPoint = (geom.geomType == parent.geomType.point && wfsConf[attr]['element'][elementIndex]['element_type'] == 'PointPropertyType');
+// alert(isMultiPolygon + " " + isPolygon + " " + isMultiLine + " " + isLine + " " + isPoint);
+ if (isMultiPolygon || isPolygon || isMultiLine || isLine || isPoint || wfsConf[attr]['element'][elementIndex]['element_type'] == 'GeometryAssociationType') {
+ return wfsConfIndices;
+function wfsExistsForGeom(geom, wfsConf) {
+ wfsConfIndices = getAvailableWfsForGeom(geom, wfsConf);
+// alert(wfsConfIndices.join(","));
+ if (wfsConfIndices.length > 0) {
+ return true;
+ return false;
+function showWfsKml (geometryIndex) {
+ wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+ wfsKmlWindow.document.open("text/html");
+ wfsKmlWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
+ wfsKmlWindow.document.close();
+ str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
+ var properties = d.get(geometryIndex).e;
+ var propertyCount = properties.count();
+ for (var i = 0; i < propertyCount; i++) {
+ var key = properties.getName(i);
+ var value = properties.getValue(i);
+ var expr = /Mapbender:/;
+ if (!key.match(expr)) {
+ str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
+ str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
+ var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
+ var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
+ deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
+ str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
+// delete button not yet implemented
+// str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
+ str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
+ wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
+// this method opens a new window and displays the attributes in wfs_conf
+function showWfs(geometryIndex) {
+ wfsWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+ wfsWindow.document.open("text/html");
+ var str = "";
+ var strStyle = "";
+ var defaultIndex = -1;
+ str += "<form id='wfs'>\n";
+ // 1. add select box
+ var onChangeText = "document.getElementById('elementForm').innerHTML = ";
+ onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
+ onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+ str += "\t<select name='wfs' size='" + wfsConf.length + "'";
+ str += " onChange=\""+ onChangeText +"\"";
+ str += ">\n\t\t";
+ var wfsConfIndices = getAvailableWfsForGeom(d.get(geometryIndex), wfsConf);
+ var selected = false;
+ for (var i = 0; i < wfsConfIndices.length ; i++) {
+ str += "<option value='" + wfsConfIndices[i] + "'";
+ if (!selected) {
+ str += " selected";
+ selected = true;
+ defaultIndex = parseInt(wfsConfIndices[i]);
+ str += ">" + wfsConf[wfsConfIndices[i]]['wfs_conf_abstract'];
+ str += "</option>\n\t\t";
+ str += "</select>\n\t\t</form>\n\t";
+ str += "<div id='elementForm'>\n</div>";
+ if (defaultIndex != -1) {
+ var htmlStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
+ htmlStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
+ htmlStr += '<style type="text/css">'
+ htmlStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
+ htmlStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
+ htmlStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
+ htmlStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
+ htmlStr += 'div.helptext p { margin: 0 ; }';
+ htmlStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
+ htmlStr += 'a img { vertical-align: middle;border: 0; }';
+ htmlStr += '</style>';
+ htmlStr += '</head><body></body></html>';
+// wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
+ wfsWindow.document.write(htmlStr);
+ wfsWindow.document.write(str);
+ wfsWindow.document.close();
+ wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
+ else {
+ wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
+function setWfsWindowStyle(wfsConfIndex) {
+ wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+// returns a form with the elements of a selected wfs
+// (if the original wfs is the selected wfs, the values are set too)
+function buildElementForm(wfsConfIndex, memberIndex){
+ var str = "";
+ var fid = false;
+ str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
+ // Check if there are categories given and
+ // build the form in tabs if necessary
+ var elementCategories = ['abc','def','123'];
+ for(var i = 0; i < featureTypeElementArray.length; i++){
+ var categoryName = featureTypeElementArray[i].f_category_name;
+ var categoryNameIsUnique = true;
+ if(categoryName.length === 0) { continue; }
+ for(var j = 0; j < elementCategories.length; j++) {
+ if(elementCategories[j] == categoryName) {
+ categoryNameIsUnique = false;
+ if(categoryNameIsUnique) {
+ elementCategories.push(categoryName);
+ if(elementCategories.length > 0) {
+ return buildTabbedElementForm(elementCategories,wfsConfIndex,memberIndex);
+ for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
+ if (isEditable) {
+ if (!formElementHtml || !formElementHtml.match(/<select/)) {
+ str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+ str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+ str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+ else {
+ // preselect the correct entry of the box
+ var patternString = "option value( )*=( )*'"+elementValue+"'";
+ var patternStringForReplace = "option value = '"+elementValue+"'";
+ formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
+ formElementHtml = formElementHtml.replace(/</g,'<');
+ formElementHtml = formElementHtml.replace(/>/g,'>');
+ formElementHtml = formElementHtml.replace(/'/g,'\'');
+ str += '<p>';
+ str += '</p>';
+ str += '</div>';
+ else {
+ str += "</table><table>";
+ var options = ["insert", "update", "delete", "abort"];
+ if (options[i] == "insert" && hasGeometryColumn && (!fid || showSaveButtonForExistingGeometries)) {
+ str += "\t\t\t<td><input type='button' name='saveButton' value='"+msgObj.buttonLabelSaveGeometry+"' onclick=\""+onClickText+"\" /></td>\n";
+ str += "\t\t\t<td><input type='button' name='updateButton' value='"+msgObj.buttonLabelUpdateGeometry+"' onclick=\""+onClickText+"\"/></td>\n";
+ var deleteOnClickText = "var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');";
+ str += "\t\t\t<td><input type='button' name='deleteButton' value='"+msgObj.buttonLabelDeleteGeometry+"' onclick=\""+deleteOnClickText+"\"/></td>\n";
+ str += "\t\t\t<td><input type='button' name='abortButton' value='"+msgObj.buttonLabelAbort+"' onclick=\"window.close();\" /></td>\n";
+ return str;
+function dbGeom(type,m) {
+ if (typeof(wfsWindow) != 'undefined' && !wfsWindow.closed) {
+ d.get(m).wfs_conf = parseInt(wfsWindow.document.forms[0].wfs.options[wfsWindow.document.forms[0].wfs.selectedIndex].value);
+ d.get(m).e = new parent.Wfs_element();
+ else {
+ var myconf = wfsConf[d.get(m).wfs_conf];
+ var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
+ var proceed = true;
+ if (myconf['featuretype_srs'] != parent.mb_mapObj[mapObjInd].epsg) {
+ proceed = confirm(msgObj.errorMessageEpsgMismatch + parent.mb_mapObj[mapObjInd].epsg + " / "+ myconf['featuretype_srs'] + ". Proceed?");
+ if (proceed) {
+ var fid = false;
+ myform = wfsWindow.document.getElementById(featureTypeElementFormId);
+ for (var i=0; i<myform.length; i++){
+ if (myform.elements[i].id == "fid") {
+ fid = myform.elements[i].value;
+ if (fid == "false") {
+ fid = false;
+ else {
+ d.get(m).e.setElement('fid', fid);
+ else if (myform.elements[i].type == 'text' ){
+ if (myform.elements[i].id) {
+ var elementId = String(myform.elements[i].id).replace(/mb_digitize_form_/, "");
+ d.get(m).e.setElement(elementId, myform.elements[i].value);
+ else {
+ errorMessage = msgObj.messageErrorFormEvaluation;
+ // selectbox
+ else if (typeof(myform.elements[i].selectedIndex) == 'number') {
+ d.get(m).e.setElement(elementId, myform.elements[i].options[myform.elements[i].selectedIndex].value);
+ else {
+ else {
+ fid = d.get(m).e.getElementValueByName('fid');
+// str = parent.get_wfs_str(myconf, d, m, type, fid);
+ var geoJson = d.featureToString(m);
+ "../extensions/geom2wfst.php",
+ 'geoJson' : geoJson,
+ 'method' : type,
+ 'wfs_conf_id' : wfsConf[d.get(m).wfs_conf]['wfs_conf_id']
+ function(json,status){
+ var result = eval('('+json+')');
+ var success = result.success;
+ var fid = result.fid;
+ wfsSubWrite(m, type, status, success, fid);
+function wfsSubWrite(m, type, status, success, fid) {
+ if (status == "success" && success) {
+ if (type == 'insert' && fid) {
+ d.get(m).e.setElement("fid", fid);
+ if (type == 'delete') {
+ parent.mb_disableThisButton(mod_digitizeEvent);
+ d.del(m);
+ var wfsWriteMessage = msgObj.messageSuccessWfsWrite;
+ else {
+ var wfsWriteMessage = msgObj.messageErrorWfsWrite;
+ parent.mb_execWfsWriteSubFunctions();
+ wfsWindow.alert(wfsWriteMessage);
+ window.setTimeout("wfsWindow.close()",0);
+ else {
+ alert(wfsWriteMessage);
+function getMultiGeometryIdsByPlacemarkId (placemarkId) {
+ var multiGeometryIdArray = [];
+ var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
+ if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
+ multiGeometryIdArray.push(i);
+ return multiGeometryIdArray;
+function updateKmlInDb (geometryIndex, command) {
+ var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
+ var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
+ if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
+ // update properties from form
+ myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
+ for (var i=0; i < myform.length; i++){
+ if (myform.elements[i].type == 'text' ){
+ var key = myform.elements[i].name;
+ var value = myform.elements[i].value;
+ // update all geometries with the same placemark id
+ for (var j = 0; j < multiGeometryIdArray.length; j++) {
+ var currentProperties = d.get(j).e;
+ currentProperties.setElement(key, value);
+ var kmlId = properties.getElementValueByName("Mapbender:id");
+ parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
+ if (obj === "1") {
+ wfsKmlWindow.alert("KML updated.");
+ var link = wfsKmlWindow.document.createElement("a");
+ link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
+ link.target = "_blank";
+ link.innerHTML = "KML";
+ wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
+ wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
+ else {
+ wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
+function getMessages() {
+ parent.mb_ajax_json("../php/mod_digitize_messages.php", function(obj, status) {
+ msgObj = obj;
+ applyMessages();
+function applyMessages() {
+ updateMeasureTag();
+ updateListOfGeometries();
+ updateButtons();
+ </script>
+ </head>
+ <body onload="registerFunctions();displayButtons();">
+ <div id='digButtons'></div>
+ <div id='listOfGeometries' class='digitizeGeometryList'></div>
+ </body>
+</html>
\ No newline at end of file
Added: trunk/mapbender/index.php
--- trunk/mapbender/index.php (rev 0)
+++ trunk/mapbender/index.php 2009-06-09 11:59:01 UTC (rev 4013)
@@ -0,0 +1,3 @@
+<?php
More information about the Mapbender_commits
