[Mapbender-commits] r4014 - trunk/mapbender/http/html
svn_mapbender at osgeo.org
Tue Jun 9 08:47:19 EDT 2009
Author: beck
Date: 2009-06-09 08:47:19 -0400 (Tue, 09 Jun 2009)
New Revision: 4014
Added:
trunk/mapbender/http/html/mod_treefolder2_multiple.php
Added: trunk/mapbender/http/html/mod_treefolder2_multiple.php
--- trunk/mapbender/http/html/mod_treefolder2_multiple.php (rev 0)
+++ trunk/mapbender/http/html/mod_treefolder2_multiple.php 2009-06-09 12:47:19 UTC (rev 4014)
@@ -0,0 +1,810 @@
+<?php
+# $Id: mod_treefolder2.php 2206 2008-03-07 12:49:17Z nimix $
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+About the Statistikportal category hack:
+For this application two or more trees of WMS services are desired, whereas
+each has to come with a different list of services. The IDs of the services
+are configured at the variable "wms_ids" in the administration GUI.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$gui_id = $_SESSION["mb_user_gui"];
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
+<HTML>
+<HEAD>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<TITLE>Treefolder</TITLE>
+<?php
+ include '../include/dyn_css.php';
+<script language='JavaScript'>
+function openwindow(Adresse) {
+Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+Fenster1.focus();
+</script>
+<script src="../javascripts/jsTree.js" type="text/javascript" language="JavaScript"></script>
+<?php
+echo "<script language='JavaScript'>";
+ $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $v = array($_REQUEST['e_id_css'],$_SESSION["mb_user_gui"]);
+ $t = array('s','s');
+ $res = db_prep_query($sql,$v,$t);
+ $e_target = db_result($res,0,"e_target");
+ echo "var mod_treeGDE_map = '".$e_target."';";
+echo "</script>";
+session_write_close();
+<SCRIPT language="JavaScript" type="text/javascript">
+var msgObj = {};
+msgObj.tooltipHandleWms = '<?php echo _mb("(De)activate this service");?>';
+msgObj.tooltipLayerVisible = '<?php echo _mb("Toggles the visibility of this service");?>';
+msgObj.tooltipLayerQuerylayer = '<?php echo _mb("Toggles the queryability of this service");?>';
+msgObj.tooltipLayerContextMenu = '<?php echo _mb("Opens the layer context menu");?>';
+msgObj.tooltipWmsContextMenu = '<?php echo _mb("Opens the WMS context menu");?>';
+msgObj.tooltipRemoveWms = '<?php echo _mb("Removes the selected WMS");?>';
+msgObj.tooltipMoveSelectionUp = '<?php echo _mb("Moves the selection up");?>';
+msgObj.tooltipMoveSelectionDown = '<?php echo _mb("Moves the selection down");?>';
+var jst_container = "document.getElementById('treeContainer')";
+var jst_image_folder = imagedir;
+var jst_display_root = false;
+var defaultTarget = 'examplemain';
+var lock=false;
+var lock_update=false;
+var lock_check=false;
+var selectedMap=-1;
+var selectedWMS=-1;
+var selectedLayer=-1;
+var init=false;
+var errors = 0;
+var state=Array();
+var treeState = "";
+<?php
+/* Category hack (begin) */
+if(isset($wms_ids) && !empty($wms_ids)) {
+ echo "var wmsIDs = [" . $wms_ids . "];";
+ $wms_ids = explode(",",$wms_ids);
+else {
+ echo "var wmsIDs = false;";
+ $wms_ids = array();
+/* Category hack (end) */
+//load structure
+$sql = "SELECT * FROM gui_treegde WHERE fkey_gui_id = $1 AND NOT lft = 1 ORDER BY lft;";
+$v = array($_SESSION["mb_user_gui"]);
+$t = array("s");
+$res = db_prep_query($sql, $v, $t);
+//init tree converting arrays
+$nr = array(); //array for nested sets numbers
+$str = array(); //array for js array elements
+$categories = array(); //array for wms folders
+$path = array(); //stack for actual path elements
+$rights = array(); //stack for rights of open elements
+//build javascript data array for jsTree
+while($row = db_fetch_array($res)){
+ /* Category hack (begin) */
+ $wms_ids_db = explode(",",$row["wms_id"]);
+ if(count($wms_ids_db) != count(array_intersect($wms_ids_db,$wms_ids))){
+ continue;
+ /* Category hack (end) */
+ //push javascript array elements to a single array with lefts and rights
+ $left = "['folder_".$row['id']."', ['".$row['my_layer_title']."', 'javascript:_foo()'],[";
+ $right = "]],";
+ array_push($nr, $row['lft']);
+ array_push($str, $left);
+ array_push($nr, $row['rgt']);
+ array_push($str, $right);
+ //finish all nodes that have no further childs
+ while(count($rights) > 0 && $rights[count($rights)-1]<$row['lft']){
+ array_pop($rights);
+ array_pop($path);
+ //set path for each wms that is referenced in this folder
+ array_push($rights, $row['rgt']);
+ array_push($path, "folder_".$row['id']);
+ if($row['wms_id']!=""){
+ foreach(explode(",",$row['wms_id']) as $wms){
+ array_push($categories, "'wms_".$wms."':\"root_id|".implode("|", $path)."\"");
+//if we have a configured structure output it
+if(count($str)>0){
+ //order js array elements
+ array_multisort($nr, $str);
+ //output javascript vars
+ $arrNodesStr = "[['root_id', ['Layer','javascript:_foo()'],[".implode("",$str)."]]];";
+ $arrNodesStr = str_replace(array("[]", ",]"),array("","]"),$arrNodesStr);
+ echo "var arrNodesStr = \"".$arrNodesStr."\";\n";
+ echo "var categories = {".implode(",", $categories)."};\n";
+else{
+//if there is no structure take default
+var arrNodesStr = "[['root_id', ['Layer','javascript:_foo()']]];";
+var categories = {};
+<?php
+/*var arrNodesStr = "[['root_id', ['Layer','javascript:_foo()'], [['test1',['Einfach so','javascript:_foo()']],['test2',['Schönes Wetter','javascript:_foo()']],['test3',['Sonstiges','javascript:_foo()']]]]];"
+var categories = {"wms_407":arrNodes[0][0]+"|test1","wms_911":arrNodes[0][0]+"|test2", "wms_914":arrNodes[0][0]+"|test2"};
+var arrNodes = [
+ String: node id,
+ String: title,
+ String: href,
+ String: target,
+ String: image,
+ String: tooltip,
+ Folder definition: node context menu,
+ String: controls
+ Folder definition: sub folder
+var arrNodes = eval(arrNodesStr);
+function _foo(){selectedMap=-1;selectedWMS=-1;selectedLayer=-1}
+// some defaults
+try{if (reverse){}}catch(e){reverse = 'false';}
+try{if (switchwms){}}catch(e){switchwms = 'true';}
+try{if (ficheckbox){}}catch(e){ficheckbox = 'false';}
+try{if (metadatalink){}}catch(e){metadatalink = 'false';}
+try{if (wmsbuttons){}}catch(e){wmsbuttons = 'false';}
+try{if (showstatus){}}catch(e){showstatus = 'false';}
+try{if (alerterror){}}catch(e){alerterror = 'false';}
+try{if (openfolder){}}catch(e){openfolder = 'false';}
+try{if (handlesublayer){}}catch(e){handlesublayer = 'false';}
+try{if (menu){}}catch(e){menu = '';}
+//menu elements
+var menu_move_up = ['menu_move_up', ['Nach oben ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_move_down = ['menu_move_down', ['Nach unten ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];move_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_delete = ['menu_delete', ['Enfernen ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];remove_wms(ids[0],ids[1],ids[2]);',,'delete_wms.png']];
+var menu_opacity_up = ['menu_opacity_up', ['Opacity up ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_up(ids[0],ids[1],ids[2]);',,'move_up.png']];
+var menu_opacity_down = ['menu_opacity_down', ['Opacity down ','javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];opacity_down(ids[0],ids[1],ids[2]);',,'move_down.png']];
+var menu_metalink = ['menu_metalink', ['Information ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[ids[0]].wms[ids[1]].objLayer[ids[2]].layer_uid);',,'info.png']];
+var menu_zoom = ['menu_zoom', ['Hin zoomen ', 'javascript:var sd = "{@strData}";var ids=eval(sd.substr(0, sd.length-6))[1][7];zoomToLayer(ids[0],ids[1],ids[2]);',,'zoom.png']];
+var menu_hide = ['menu_hide', ['Layermenü ausblenden ', 'javascript:hideMenu()',,'hide.png']];
+//var menu_wms_switch = ['menu_zoom', ['Zoom ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_layer_switch = ['menu_zoom', ['Zjjj ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+//var menu_info_switch = ['menu_zoom', ['Zmn ', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
+parent.eventAfterLoadWMS.register(reloadTree);
+parent.eventInit.register(loadTree);
+if(showstatus=='true'||alerterror=='true'){
+ parent.eventAfterMapRequest.register(init_mapcheck);
+ init_mapcheck();
+parent.eventAfterMapRequest.register(updateScale);
+parent.eventAfterMapRequest.register(updateCheckState);
+if(wmsbuttons != "true")
+ jst_highlight = false;
+function select(i,ii,iii){
+ //ignore if selected
+ if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
+ if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
+ selectedMap=i;
+ selectedWMS=ii;
+ selectedLayer=iii;
+ return;
+ //scalehints
+ var scale = parseInt(parent.mb_mapObj[selectedMap].getScale());
+ if(scale < parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_minscale) != 0){
+ if(selectedLayer==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '#999999');
+ else if(scale > parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) && parseInt(parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].gui_layer_maxscale) != 0){
+ else
+ else{
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[selectedMap].wms[selectedWMS].wms_id+"|"+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_id, '');
+ selectedMap=i;
+ selectedWMS=ii;
+function updateScale(){
+ if(!init)return;
+ for(var i=0; i<parent.mb_mapObj.length; i++){
+ if(parent.mb_mapObj[i].frameName == mod_treeGDE_map){
+ var scale = parent.mb_mapObj[i].getScale();
+ for(var ii=0; ii<parent.mb_mapObj[i].wms.length; ii++){
+ for(var iii=1; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ if(scale < parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_minscale) != 0){
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id, '#999999');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '#999999');
+ else if(scale > parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) && parseInt(parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_maxscale) != 0){
+ if(iii==0)
+ else
+ else{
+ if(iii==0)
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id, '');
+ else
+ setNodeColor(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id, '');
+function updateCheckState(){
+ if(!init||lock_check)return;
+ lock_check=true;
+ if(!parent.mb_mapObj[i].wms[ii].objLayer[iii].has_childs){
+ path = arrNodes[0][0]+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"|"+parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_id;
+ checkNode(path, 0, parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_visible=='1', false);
+ if(ficheckbox == 'true')
+ checkNode(path, 1, parent.mb_mapObj[i].wms[ii].objLayer[iii].gui_layer_querylayer=='1', false);
+ lock_check=false;
+function operaLoad(){
+ initArray();
+ renderTree();
+ setTimeout('initWmsCheckboxen();updateScale();',100);
+function loadTree(){
+ if(window.opera){
+ setTimeout('operaLoad()',200);
+ return;
+ initArray();
+ renderTree();
+ initWmsCheckboxen();
+ updateScale();
+function reloadTree(){
+ if(!init) return;
+ selectedMap=-1;
+ selectedWMS=-1;
+ selectedLayer=-1;
+ init=false;
+ arrNodes = eval(arrNodesStr)
+ initArray();
+ if(showstatus=='true'||alerterror=='true')
+ init_mapcheck();
+ renderTree();
+ if(window.opera)
+ else{
+ updateScale();
+function imgerror(){
+ var map=parent.getMapObjIndexByName(mod_treeGDE_map);
+ var wms=Number(this.id.substr(4));
+ this.onerror=null;
+ this.onabort=null;
+ if(state[wms]!=-1 && alerterror=='true'){
+ state[wms]=-1;
+ if(confirm('Failed to Load WMS "'+parent.mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+parent.mb_mapObj[map].wms[wms].wms_getmap.substr(0,parent.mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?')){
+ window.open(this.src,"");
+ state[wms]=-1;
+ errors++;
+ if(showstatus=='true')
+ setNodeImage(arrNodes[0][0]+"|wms_"+parent.mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
+function checkComplete(wms, map, img, first){
+ var ind=parent.getMapObjIndexByName(mod_treeGDE_map);
+ if(parent.mb_mapObj[ind].wms[wms].mapURL == false || parent.frames[mod_treeGDE_map].document.getElementById(map).complete){
+ if(state[wms]!=-1){
+ for(var i=1;i<parent.mb_mapObj[ind].wms[wms].objLayer.length;i++){
+ if(parent.mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
+ state[wms]=1;
+ setNodeImage(img);
+ break;
+ else{
+ if(first){
+ state[wms]=0;
+ parent.frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
+ parent.frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
+ setNodeImage(img, "loading_folder.gif");
+ setTimeout('checkComplete('+wms+', "'+map+'", "'+img+'");',100);
+//parent.mb_registerWmsLoadErrorFunctions("window.frames['treeGDE'].imgerror();");
+function init_mapcheck(){
+ if(!init)return;
+ errors = 0;
+ var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
+ if(!parent.mb_mapObj[ind]||!init){
+ setTimeout("init_mapcheck();",100);
+ return;
+ for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++){
+ var wmsimgid="map_"+wms;
+ if(parent.frames[mod_treeGDE_map].document.getElementById(wmsimgid)){
+ checkComplete(wms, wmsimgid, arrNodes[0][0]+'|wms_'+parent.mb_mapObj[ind].wms[wms].wms_id, true);
+function handleSelectedLayer(mapObj,wms_id,layername,type,status){
+ if(lock_update||lock_check)return;
+ var ind = parent.getMapObjIndexByName(mapObj);
+ for(var i=0; i<parent.mb_mapObj[ind].wms.length; i++){
+ if(parent.mb_mapObj[ind].wms[i].wms_id == wms_id){
+ parent.mb_mapObj[ind].wms[i].handleLayer(layername, type, status);
+ break;
+function zoomToLayer(j,k,l){
+ if(!j&&!k&&!l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ var my=parent.mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
+ for (var i=0;i<my.length;i++){
+ if(my[i]["epsg"]==parent.mb_mapObj[j].epsg){
+ parent.mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
+ var arrayExt = parent.mb_mapObj[j].extent.split(",");
+ parent.mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
+ break;
+//---begin------------- opacity --------------------
+var opacityIncrement = 20;
+function opacity_up(j, k, l) {
+ handleOpacity(j, k, opacityIncrement);
+function opacity_down(j, k, l) {
+ handleOpacity(j, k, -opacityIncrement);
+function handleOpacity(mapObj_id, wms_id, increment) {
+ var opacity = parent.mb_mapObj[mapObj_id].wms[wms_id].gui_wms_mapopacity*100 + increment;
+ parent.mb_mapObj[mapObj_id].wms[wms_id].setOpacity(opacity);
+ reloadTree();
+//---end------------- opacity --------------------
+function move_up(j,k,l){
+ if(isNaN(j)&&isNaN(k)&&isNaN(l)){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ if(j==-1||k==-1||l==-1){
+ alert("You have to select the WMS you want to move up!")
+ return;
+ var lid=parent.mb_mapObj[j].wms[k].objLayer[l].layer_id;
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?false:true)){
+ alert("Illegal move operation");
+ return;
+ treeState = getState();
+ parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
+ parent.mb_execloadWmsSubFunctions();
+ //find layer and select
+ for(k=0;k<parent.mb_mapObj[j].wms.length;k++){
+ for(l=0;l<parent.mb_mapObj[j].wms[k].objLayer.length;l++){
+ if(parent.mb_mapObj[j].wms[k].objLayer[l].layer_id==lid){
+ select(j,k,l);
+ if(l!=0)
+ selectNode(String(lid));
+ else
+ selectNode("wms_"+String(parent.mb_mapObj[j].wms[k].wms_id));
+function move_down(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("You have to select the WMS you want to move down!")
+ return;
+ if(!parent.mb_mapObj[j].move(parent.mb_mapObj[j].wms[k].wms_id,lid,(reverse=="true")?true:false)){
+ return;
+ select(j,k,l);
+ if(l!=0)
+ else
+function remove_wms(j,k,l){
+ j=selectedMap;
+ k=selectedWMS;
+ l=selectedLayer;
+ alert("You have to select the WMS you want to delete!")
+ return;
+ if(l!=0){
+ alert("It is not possible to delete a single layer, please select a WMS!")
+ return;
+ var visibleWMS=0;
+ for(var i=0;i<parent.mb_mapObj[j].wms.length;i++)
+ if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1)
+ visibleWMS++;
+ if(visibleWMS<=1){
+ alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+ return;
+ if(confirm('Are you sure you want to remove "'+parent.mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
+ parent.mb_mapObjremoveWMS(j,k);
+function updateParent(path){
+ if(lock_check)return;
+ var reset_lock=!lock_update;
+ lock_update=true;
+ var state=getChildrenCheckState(path, 0);
+ //enableCheckbox(path, (state!=-1)); //3rd state
+ checkNode(path, 0, (state==1));
+ if(state==0 && showstatus=='true' && path.split(jst_delimiter[0]).length == 2){
+ setTimeout('setNodeImage("'+path+'", "error_folder.png");', 100);
+ if(reset_lock)
+ lock_update=false;
+function handleSelectedWMS(path){
+ if(lock_update)return;
+ var t = path.split("|");
+ var wms_id = t[t.length-1].substr(4);
+ var reset_lock=!lock_check;
+ var wms = parent.getWMSIndexById(mod_treeGDE_map,wms_id);
+ var layername = parent.mb_mapObj[ind].wms[wms].objLayer[0].layer_name;
+ var bChk = IsChecked(path, 0);
+ parent.mb_mapObj[ind].wms[wms].handleLayer(layername,"visible",bChk?"1":"0");
+ parent.mb_mapObj[ind].wms[wms].handleLayer(layername,"querylayer",bChk?"1":"0");
+ lock_check=true;
+ checkChildren(path, 0, bChk);
+ if(ficheckbox)checkChildren(path, 1, bChk);
+ if(bChk==false && showstatus=='true')
+ if(reset_lock)
+ parent.mb_restateLayers(mod_treeGDE_map,wms_id);
+ parent.setSingleMapRequest(mod_treeGDE_map,wms_id);
+ lock_check=false;
+function handleSelection(path, box){
+ lock_check=true;
+ var bChk = IsChecked(path, box);
+// enableCheckbox(path, 0, true);
+ checkChildren(path, box, bChk);
+ if(reset_lock){
+ //find wms id from path
+ for(var i=1;t[i].indexOf("wms_")!=0;i++){}
+ var wms_id = t[i].substr(4);
+ //set maprequest
+ if(box==0)
+ lock_check=false;
+function layerHasQueryableChild (layerArray, index) {
+ var parentIdArray = [index];
+ for (var i = 0; i < layerArray.length; i++) {
+ var currentLayer = layerArray[i];
+ for (var j = 0; j < parentIdArray.length; j++) {
+ if (currentLayer.layer_parent && parseInt(currentLayer.layer_parent, 10) === parentIdArray[j]) {
+ if (currentLayer.gui_layer_queryable == "1") {
+ return true;
+ parentIdArray.push(i);
+ return false;
+function checkID(wmsID) {
+ if(!wmsIDs) {
+ return true;
+ for(var i = 0; i < wmsIDs.length; i++) {
+ if(wmsID == wmsIDs[i]) {
+ return true;
+ return false;
+function initArray(){
+ var parentObj = "";
+ var controls="";
+ if(parent.mb_mapObj.length > 0){
+ if(
+ (parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1) &&
+ checkID(parent.mb_mapObj[i].wms[ii].wms_id)
+ for(var iii=0; iii<parent.mb_mapObj[i].wms[ii].objLayer.length; iii++){
+ var temp = parent.mb_mapObj[i].wms[ii].objLayer[iii];
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent == ""){
+ if(!temp.gui_layer_selectable == '1' && !temp.gui_layer_queryable == '1')
+ continue;
+ parentNode = arrNodes[0][0];
+ if(eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id) !== undefined)
+ parentNode = eval("categories.wms_"+parent.mb_mapObj[i].wms[ii].wms_id);
+ else
+ eval("categories['wms_"+parent.mb_mapObj[i].wms[ii].wms_id+"'] = parentNode");
+ var c_menu="[";
+ if(reverse=="true"){
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("wms_up")!=-1 && parentObj!="")c_menu+="menu_move_up,";
+ if(menu.indexOf("wms_down")!=-1 && ii!=parent.mb_mapObj[i].wms.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("remove")!=-1)c_menu+="menu_delete,";
+// if(menu.indexOf("wms_switch")!=-1)c_menu+="menu_wms_switch,";
+ if(menu.indexOf("opacity_up")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)c_menu+="menu_opacity_up,";
+ if(menu.indexOf("opacity_down")!=-1 && parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) > 0)c_menu+="menu_opacity_down,";
+ if(menu.indexOf("hide")!=-1)c_menu+="menu_hide";
+ c_menu+="]";
+ controls='';
+ if(switchwms=='true')controls='<INPUT type="checkbox" title="' + msgObj.tooltipHandleWms + '" checked onclick="handleSelectedWMS(\''+parentNode+'|wms_'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
+ if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\''+ defaultMetadataUrl + '&id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
+ addNode(parentNode,["wms_"+parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"'+ defaultMetadataUrl + '&id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+ parentObj = parentNode+"|wms_"+parent.mb_mapObj[i].wms[ii].wms_id;
+ if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"||parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
+ var parentLayer = "";
+ var j = iii;
+ while(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent!="0"){
+ //find parent
+ for(var jj=0; jj < parent.mb_mapObj[i].wms[ii].objLayer.length; jj++){
+ if(parent.mb_mapObj[i].wms[ii].objLayer[jj].layer_pos==parseInt(parent.mb_mapObj[i].wms[ii].objLayer[j].layer_parent)){
+ j=jj;
+ break;
+ parentLayer = "|" + parent.mb_mapObj[i].wms[ii].objLayer[j].layer_id + parentLayer;
+ if(temp.gui_layer_selectable == '1' || temp.gui_layer_queryable == '1'){
+ var c_menu="[";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_down,";
+ else{
+ if(menu.indexOf("layer_up")!=-1 && iii!=1)c_menu+="menu_move_up,";
+ if(menu.indexOf("layer_down")!=-1 && iii!=parent.mb_mapObj[i].wms[ii].objLayer.length-1)c_menu+="menu_move_down,";
+ if(menu.indexOf("metainfo")!=-1)c_menu+="menu_metalink,";
+ if(menu.indexOf("zoom")!=-1 && temp.layer_epsg.length>0)c_menu+="menu_zoom,";
+// if(menu.indexOf("layer_switch")!=-1)c_menu+="menu_layer_switch,";
+// if(menu.indexOf("info_switch")!=-1)c_menu+="menu_info_switch,";
+ c_menu+="]";
+ controls = [];
+ controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerVisible + '" ');
+ if(temp.layer_name=="")
+ controls.push('style="display:none;" ');
+ if(temp.gui_layer_visible=='1')
+ controls.push('checked ');
+ if(temp.gui_layer_selectable!='1')
+ controls.push('disabled ');
+ controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);");
+ if(ficheckbox == 'false')
+ controls.push("handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+ controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 0);");
+ controls.push("updateParent('"+parentObj+parentLayer+"');\" />");
+ if(ficheckbox == 'true'){
+ controls.push('<input type="checkbox" title="' + msgObj.tooltipLayerQuerylayer + '" ');
+ if(temp.gui_layer_querylayer=='1')
+ if(temp.gui_layer_queryable!='1' && !layerHasQueryableChild(parent.mb_mapObj[i].wms[ii].objLayer, iii))
+ controls.push("onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);");
+ controls.push("handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1);\" />");
+ if(wmsbuttons == 'true'&&metadatalink == 'true'){
+ controls.push('<a href="javascript:openwindow(\'../php/mod_layerMetadata.php?id='+temp.layer_uid+'\');"><img src="'+imagedir+'/info.png" /></a>');
+ //////////////special for Statistikportal with window.open for SLD Editor//////////
+ if(temp.layer_name.match(/bevoelkerungdichte_/)){
+ controls.push('<a style="cursor:pointer;" ');
+ var sldUrl = '../x_kosis/sldEditor.php?wms_id='+parent.mb_mapObj[i].wms[ii].wms_id+'&layer_id='+temp.layer_id+'&layer_name='+temp.layer_name+'&layer_title='+temp.layer_title;
+ controls.push('href="javascript:var sldEditorWindow = window.open(\''+sldUrl+'\', \'SLDEditor\', \'width=600, height=400, status=no, scrollbars=no, resizable=no, screenX=100, screenY=50\');');
+ controls.push('sldEditorWindow.focus();">');
+ controls.push('<img src="'+imagedir+'/openSldEditor.png" /> </a>');
+ addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls.join(""),[i,ii,iii]]],false,false,reverse=="true");
+ continue;
+ ////////////end of special//////////////////////////////////////////
+ init=true;
+function initWmsCheckboxen(){
+ var hidden=0;
+ if(parent.mb_mapObj[i].wms[ii].gui_wms_visible == '1' || parent.mb_mapObj[i].wms[ii].gui_wms_visible == 1){
+ updateParent(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id);
+ else if(ii<=parent.parseInt(openfolder)+hidden)
+ hidden++;
+ closeAll()
+ if(treeState!='')
+ setState(treeState);
+ else if(openfolder!='false')
+ setState(arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[parent.parseInt(openfolder)+hidden].wms_id);
+ </SCRIPT>
+</HEAD>
+<BODY VLINK="#000000" ALINK="#000000" LINK="#000000" TEXT="#000000"
+ MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
+if(wmsbuttons=='true'){
+ document.writeln("<div>");
+ document.writeln('<a href="javascript:move_up()"><img title="'+msgObj.tooltipMoveSelectionUp+'" src="'+imagedir+'/move_up.png" alt="move up" style="position:relative;top:0px;left:0px;"/></a>');
+ document.writeln('<a href="javascript:move_down()"><img title="'+msgObj.tooltipMoveSelectionDown+'" src="'+imagedir+'/move_down.png" alt="move down" style="position:relative;top:0px;left:-3px"/></a>');
+ document.writeln('<a href="javascript:remove_wms()"><img title="'+msgObj.tooltipRemoveWms+'" src="'+imagedir+'/delete_wms.png" alt="remove wms" style="position:relative;top:0px;left:-6px"/></a>');
+ document.writeln("</div>");
+</SCRIPT>
+<DIV id="treeContainer"></DIV>
+</BODY>
+</HTML>
More information about the Mapbender_commits
