[Mapbender-commits] r4026 -
branches/dynamic_printframe_dev/print_dynamic
svn_mapbender at osgeo.org
Wed Jun 17 03:43:29 EDT 2009
Author: christoph
Date: 2009-06-17 03:43:29 -0400 (Wed, 17 Jun 2009)
New Revision: 4026
branches/dynamic_printframe_dev/print_dynamic/mod_printPDF_pdf.php
branches/dynamic_printframe_dev/print_dynamic/printbox.js
bug fix by nimix
Modified: branches/dynamic_printframe_dev/print_dynamic/mod_printPDF_pdf.php
--- branches/dynamic_printframe_dev/print_dynamic/mod_printPDF_pdf.php 2009-06-16 08:05:45 UTC (rev 4025)
+++ branches/dynamic_printframe_dev/print_dynamic/mod_printPDF_pdf.php 2009-06-17 07:43:29 UTC (rev 4026)
@@ -383,12 +383,17 @@
$coordPattern = "\d+(\.\d+)?";
$pattern = "/BBOX=$coordPattern,$coordPattern,$coordPattern,$coordPattern&/";
$url = preg_replace($pattern, "BBOX=" . $_REQUEST["coordinates"] . "&", $url);
+ // if highquality is choosed multiplicate width and height with mapFactor =4
+ $mapFactor = 1 ;
+ if($factor > 1){
+ $mapFactor = 4 ;
$pattern = "/WIDTH=\d+&/";
- $url = preg_replace($pattern, "WIDTH=" . $_REQUEST["mapwidth"] . "&", $url);
+ $url = preg_replace($pattern, "WIDTH=" . ($_REQUEST["mapwidth"]*$mapFactor) . "&", $url);
$pattern = "/HEIGHT=\d+&/";
- $url = preg_replace($pattern, "HEIGHT=" . $_REQUEST["mapheight"] . "&", $url);
+ $url = preg_replace($pattern, "HEIGHT=" . ($_REQUEST["mapheight"]*$mapFactor) . "&", $url);
$i = new weldMaps2PNG_rotate(implode("___",$array_urls),$filename, $_REQUEST["angle"]);
Modified: branches/dynamic_printframe_dev/print_dynamic/printbox.js
--- branches/dynamic_printframe_dev/print_dynamic/printbox.js 2009-06-16 08:05:45 UTC (rev 4025)
+++ branches/dynamic_printframe_dev/print_dynamic/printbox.js 2009-06-17 07:43:29 UTC (rev 4026)
@@ -620,6 +620,9 @@
boxCanvas.setColor(boxColour);
boxCanvas.paint();
+ //Hack to apply opacity also to IE
+ $("#" + canvasName[0]+" div").css({"opacity":opacity});
@@ -630,6 +633,7 @@
boxCanvas.clear();
activeCanvas.clear();
passiveCanvas.clear();
+ $superContainer.remove();
var switchActiveCanvas = function () {
@@ -674,10 +678,13 @@
$circleCanvas = $("#" + canvasName[3]);
$pointCanvas = $("#" + canvasName[1] + ", #" + canvasName[2]);
$boxCanvas = $("#" + canvasName[0]);
- $boxCanvas.css({
- "opacity" : opacity,
- "filter" : "alpha(opacity=" + (opacity * 100) + ")"
+ //this won't work because IE does not apply opacity to absolute positioned child divs
+ //see paintBox for workaround
+// $boxCanvas.css({
+// "opacity" : opacity,
+// "filter" : "alpha(opacity=" + (opacity * 100) + ")"
More information about the Mapbender_commits
