[Mapbender-commits] r4027 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Wed Jun 17 05:09:26 EDT 2009
Author: christoph
Date: 2009-06-17 05:09:26 -0400 (Wed, 17 Jun 2009)
New Revision: 4027
trunk/mapbender/http/classes/class_wfs_configuration.php
trunk/mapbender/http/php/mod_wfs.php
trunk/mapbender/http/php/mod_wfs_conf_featuretype_elements.html
trunk/mapbender/http/php/mod_wfs_conf_interface.js
bug fixes
Modified: trunk/mapbender/http/classes/class_wfs_configuration.php
--- trunk/mapbender/http/classes/class_wfs_configuration.php 2009-06-17 07:43:29 UTC (rev 4026)
+++ trunk/mapbender/http/classes/class_wfs_configuration.php 2009-06-17 09:09:26 UTC (rev 4027)
@@ -246,22 +246,22 @@
// TO DO: check if access is allowed!
// (use the new WFS classes for this)
$wfsConf->wfsId = intval($obj->wfsId);
- $wfsConf->featureTypeId = intval($obj->wfsFeaturetypeId);
+ $wfsConf->featureTypeId = intval($obj->featuretypeId);
$wfsConf->type = intval($obj->type);
$wfsConf->label = $obj->label;
- $wfsConf->labelId = $obj->label_id;
+ $wfsConf->labelId = $obj->labelId;
$wfsConf->button = $obj->button;
- $wfsConf->buttonId = $obj->button_id;
+ $wfsConf->buttonId = $obj->buttonId;
$wfsConf->style = $obj->style;
$wfsConf->buffer = floatval($obj->buffer);
- $wfsConf->resStyle = $obj->result_style;
- $wfsConf->abstr = $obj->title;
+ $wfsConf->resStyle = $obj->resStyle;
+ $wfsConf->abstr = $obj->abstr;
$wfsConf->description = $obj->description;
- for ($i = 0; $i < count($obj->elements); $i++) {
- $element = WfsConfigurationElement::createFromObject($obj->elements[$i]);
+ for ($i = 0; $i < count($obj->elementArray); $i++) {
+ $element = WfsConfigurationElement::createFromObject($obj->elementArray[$i]);
$wfsConf->elementArray[]= $element;
return $wfsConf;
@@ -437,6 +437,7 @@
$element->type = $row["element_type"];
$element->search = intval($row["f_search"]);
$element->pos = intval($row["f_pos"]);
+ $element->edit = intval($row["f_edit"]);
$element->styleId = $row["f_style_id"];
$element->toUpper = intval($row["f_toupper"]);
$element->label = $row["f_label"];
@@ -446,7 +447,7 @@
$element->mandatory = intval($row["f_mandatory"]);
$element->respos = $row["f_respos"];
$element->minInput = $row["f_min_input"];
- $element->formElementHtmlTemplate = $row["f_html_template"];
+// $element->formElementHtmlTemplate = $row["f_html_template"];
$element->formElementHtml = stripslashes($row["f_form_element_html"]);
$element->authVarname = stripslashes($row["f_auth_varname"]);
$element->detailPos = $row["f_detailpos"];
Modified: trunk/mapbender/http/php/mod_wfs.php
--- trunk/mapbender/http/php/mod_wfs.php 2009-06-17 07:43:29 UTC (rev 4026)
+++ trunk/mapbender/http/php/mod_wfs.php 2009-06-17 09:09:26 UTC (rev 4027)
@@ -66,6 +66,11 @@
var iamready = false;
</script>
<?php
+function myNl2br ($str) {
+ return preg_replace('#\r?\n#', '\\n', $str);
echo "<script language='JavaScript' type='text/javascript'>";
if(isset($_REQUEST['id']) && $_REQUEST['id']!=""){
$wfs = mb_split(",",$_REQUEST['id']);
@@ -160,12 +165,14 @@
echo "wfs_conf[".$i."]['element'][".$cnt."]['element_type'] = '".htmlentities($row["element_type"], ENT_QUOTES, "UTF-8")."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_geom'] = '".$row["f_geom"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_gid'] = '".$row["f_gid"]."';";
- echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"".(preg_replace("/\n/", "", preg_replace("/\r/", "", htmlentities($row["f_form_element_html"], ENT_QUOTES, "UTF-8"))))."\";";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"".(preg_replace("/\n/", "", preg_replace("/\r/", "", $row["f_form_element_html"])))."\";";
// echo "wfs_conf[".$i."]['element'][".$cnt."]['f_form_element_html'] = \"\";";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_edit'] = '".$row["f_edit"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_mandatory'] = '".$row["f_mandatory"]."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_auth_varname'] = '".htmlentities($row["f_auth_varname"], ENT_QUOTES, "UTF-8")."';";
echo "wfs_conf[".$i."]['element'][".$cnt."]['f_operator'] = '".$row["f_operator"]."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['f_helptext'] = '".myNl2br(htmlentities($row["f_helptext"], ENT_QUOTES, "UTF-8"))."';";
+ echo "wfs_conf[".$i."]['element'][".$cnt."]['f_category_name'] = '".htmlentities($row["f_category_name"], ENT_QUOTES, "UTF-8")."';";
$cnt++;
if($cnt == 0){die("wfs_conf data not available");}
Modified: trunk/mapbender/http/php/mod_wfs_conf_featuretype_elements.html
--- trunk/mapbender/http/php/mod_wfs_conf_featuretype_elements.html 2009-06-17 07:43:29 UTC (rev 4026)
+++ trunk/mapbender/http/php/mod_wfs_conf_featuretype_elements.html 2009-06-17 09:09:26 UTC (rev 4027)
@@ -46,18 +46,19 @@
<th class='wfs_conf_geom'>geom</th>
<th class='wfs_conf_search'>search</th>
<th class='wfs_conf_pos'>pos</th>
- <th class='wfs_conf_mininput'>minimum_input</th>
- <th class='wfs_conf_styleid'>style_id</th>
- <th class='wfs_conf_toupper'>upper</th>
+ <th class='wfs_conf_minInput'>minimum_input</th>
+ <th class='wfs_conf_styleId'>style_id</th>
+ <th class='wfs_conf_toUpper'>upper</th>
<th class='wfs_conf_label'>label</th>
- <th class='wfs_conf_labelid'>label_id</th>
+ <th class='wfs_conf_labelId'>label_id</th>
<th class='wfs_conf_show'>show</th>
- <th class='wfs_conf_showdetail'>show_detail</th>
+ <th class='wfs_conf_showDetail'>show_detail</th>
+ <th class='wfs_conf_detailPos'>show_detail</th>
<th class='wfs_conf_respos'>position</th>
<th class='wfs_conf_mandatory'>mandatory</th>
<th class='wfs_conf_edit'>edit</th>
- <th class='wfs_conf_formelementhtml'>html</th>
- <th class='wfs_conf_authvarname'>auth</th>
+ <th class='wfs_conf_formElementHtml'>html</th>
+ <th class='wfs_conf_authVarname'>auth</th>
<th class='wfs_conf_operator'>operator</th>
<th class='wfs_conf_helptext'>helptext</th>
<th class='wfs_conf_category'>category</th>
Modified: trunk/mapbender/http/php/mod_wfs_conf_interface.js
--- trunk/mapbender/http/php/mod_wfs_conf_interface.js 2009-06-17 07:43:29 UTC (rev 4026)
+++ trunk/mapbender/http/php/mod_wfs_conf_interface.js 2009-06-17 09:09:26 UTC (rev 4027)
@@ -12,7 +12,7 @@
"def" : 0,
"size" : 1
- "mininput" : {
+ "minInput" : {
"type" : "select",
"def" : {
"0" : "...",
@@ -23,19 +23,19 @@
"5" : "5"
- "styleid" : {
+ "styleId" : {
"type" : "text",
"def" : 0,
"size" : 1
- "toupper" : {
+ "toUpper" : {
"type" : "checkbox"
"label" : {
"type" : "text",
"size" : 2
- "labelid" : {
+ "labelId" : {
"type" : "text",
"def" : 0,
"size" : 1
@@ -43,9 +43,14 @@
"show" : {
"type" : "checkbox"
- "showdetail" : {
+ "showDetail" : {
"type" : "checkbox"
+ "detailPos" : {
+ "type" : "text",
+ "def" : 0,
+ "size" : 1
"respos" : {
"type" : "text",
"def" : 0,
@@ -57,10 +62,10 @@
"edit" : {
"type" : "checkbox"
- "formelementhtml" : {
+ "formElementHtml" : {
"type" : "htmlTemplate"
- "authvarname" : {
+ "authVarname" : {
"type" : "text",
"size" : 8
@@ -125,7 +130,7 @@
"title" : "Download",
"icon" : "someicon.png",
"columns" : [
- "geom", "pos", "show", "showdetail", "respos", "helptext"
+ "geom", "pos", "show", "showDetail", "respos", "helptext"
@@ -134,9 +139,9 @@
"title" : "Search",
"columns" : [
- "geom", "search", "pos", "mininput", "styleid", "toupper",
- "label", "labelid", "show", "showdetail", "respos",
- "authvarname", "operator", "helptext"
+ "geom", "search", "pos", "minInput", "styleId", "toUpper",
+ "label", "labelId", "show", "showDetail", "detailPos", "respos",
+ "authVarname", "operator", "helptext"
@@ -145,9 +150,9 @@
"title" : "Digitize",
"columns" : [
- "geom", "pos", "styleid", "label", "labelid", "show",
- "showdetail", "respos", "mandatory", "edit", "formelementhtml",
- "authvarname", "helptext", "category"
+ "geom", "pos", "styleId", "label", "labelId", "show",
+ "showDetail", "respos", "mandatory", "edit", "formElementHtml",
+ "authVarname", "helptext", "category"
@@ -260,6 +265,16 @@
return null;
+ var getWfsConfIndex = function (id) {
+ // find WFS Conf in WFS Conf array
+ for (var i = 0; i < wfsConfArray.length; i++) {
+ if (wfsConfArray[i].id === id) {
+ return i;
+ return null;
// FORMS
@@ -622,18 +637,18 @@
return {
"id": wfsConfId,
"wfsId" : wfsId,
- "wfsFeaturetypeId" : wfsFeaturetypeId,
+ "featuretypeId" : wfsFeaturetypeId,
"type" : wfsConfType,
- "title": $('#wfs_conf_title').val(),
+ "abstr": $('#wfs_conf_title').val(),
"description": $('#wfs_conf_description').val(),
"label": $('#wfs_conf_label').val(),
- "label_id": $('#wfs_conf_label_id').val(),
+ "labelId": $('#wfs_conf_label_id').val(),
"button": $('#wfs_conf_button').val(),
- "button_id": $('#wfs_conf_button_id').val(),
+ "buttonId": $('#wfs_conf_button_id').val(),
"style": $('#wfs_conf_style').val(),
"buffer": $('#wfs_conf_buffer').val(),
- "result_style": $('#wfs_conf_resultstyle').val(),
- "elements": ftElements
+ "resStyle": $('#wfs_conf_resultstyle').val(),
+ "elementArray": ftElements
@@ -718,7 +733,7 @@
var $tr = $("#" + prefix + "wfs_conf_form_tr_" + el.id);
for (var attr in el) {
for (var column in ALL_WFS_CONF_ATTRIBUTES) {
- if (attr.toLowerCase() === column) {
+ if (attr === column) {
var $td = $tr.children("TD.wfs_conf_" + column);
fillWfsConfFormElement(column, $td, el[attr]);
break;
@@ -884,6 +899,12 @@
var wfsConf = getWfsConfFromHtml(prefix);
if (wfsConf.id !== null) {
updateWfsConfInDb(wfsConf);
+ var index = getWfsConfIndex(wfsConf.id);
+ if (index !== null) {
+ console.log(index);
+ wfsConfArray[index] = wfsConf;
+ console.log(wfsConf);
else {
insertWfsConfIntoDb(wfsConf);
@@ -964,6 +985,7 @@
var onSelectWfsConf = function (wfsConf) {
isBusy.trigger();
setTimeout(function () {
for (var i in WFS_CONF_TYPES) {
More information about the Mapbender_commits
