[Mapbender-commits] r4028 - in trunk/mapbender/http: img javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jun 17 05:56:19 EDT 2009
Author: christoph
Date: 2009-06-17 05:56:19 -0400 (Wed, 17 Jun 2009)
New Revision: 4028
Added:
   trunk/mapbender/http/img/help.png
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
category tabs
Added: trunk/mapbender/http/img/help.png
(Binary files differ)
Property changes on: trunk/mapbender/http/img/help.png
___________________________________________________________________
   + application/octet-stream
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-06-17 09:09:26 UTC (rev 4027)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2009-06-17 09:56:19 UTC (rev 4028)
@@ -131,7 +131,60 @@
 try {if(nonTransactionalEditable){}}catch(e) {nonTransactionalEditable = false;}
 try {if(addCloneGeometryButton){}}catch(e) {addCloneGeometryButton = false;}
+function toggleTabs(tabId) {
+	if(!initialTab) {
+		return;
+	var tabHeaders = wfsWindow.document.getElementsByTagName('a');
+	var tabs       = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < tabHeaders.length; i++) {
+		if(tabHeaders[i].id.indexOf('tabheader') != -1) {
+			tabHeaders[i].className = 'tabheader';
+	for(var i = 0; i < tabs.length; i++) {
+		if(tabs[i].className === 'tabcontent') {
+			tabs[i].style.visibility = 'hidden';
+			tabs[i].style.display    = 'none';
+	wfsWindow.document.getElementById('tabheader_' + tabId).className += ' active';
+	wfsWindow.document.getElementById('tab_' + tabId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('tab_' + tabId).style.display    = 'block';
+	return false;
+function showHelptext(helptextId) {
+	hideHelptext();
+	wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'visible';
+	wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'block';
+	return false;
+function hideHelptext(helptextId) {
+	if(helptextId) {
+		wfsWindow.document.getElementById('helptext' + helptextId).style.visibility = 'hidden';
+		wfsWindow.document.getElementById('helptext' + helptextId).style.display    = 'none';
+	var helptext = wfsWindow.document.getElementsByTagName('div');
+	for(var i = 0; i < helptext.length; i++) {
+		if(helptext[i].className === 'helptext') {
+			helptext[i].style.visibility = 'hidden';
+			helptext[i].style.display    = 'none';
+	return false;
 function getMousePosition(e) {
 	parent.mb_getMousePos(e, mod_digitize_target);
 	var currentPos = null;
@@ -1321,19 +1374,26 @@
 function validBoxEntrySelected(form){
 	var isCorrect = true;
 	var errorMessage = "";
+	var name = "";
 	for (var i = 0; i < form.childNodes.length && isCorrect; i++) {
 		if (form.childNodes[i].nodeName.toUpperCase() == "SELECT") {
-			if (parseInt(form.childNodes[i].selectedIndex) == 0) {
-				return {"isCorrect":false, "errorMessage":errorMessage};
+			name += form.childNodes[i].name;
+			if (parseInt(form.childNodes[i].selectedIndex) == 0 && form.childNodes[i].getAttribute("mandatory") == "true") {
+				var msg = name + ": " + msgObj.messageSelectAnOption + "\n"
+				var categ = form.childNodes[i].getAttribute("category");
+				if (typeof(categ) != "undefined") {
+					msg = categ + " => " + msg;
+				return {"isCorrect":false, "errorMessage":msg};
 		else if (form.childNodes[i].hasChildNodes()) {
-			isCorrect = validBoxEntrySelected(form.childNodes[i]).isCorrect;
+			var res = validBoxEntrySelected(form.childNodes[i]);
+			errorMessage = res.errorMessage + errorMessage;
+			isCorrect = res.isCorrect;
-	if (!isCorrect) {
-		errorMessage = msgObj.messageSelectAnOption + "\n";
 	return {"isCorrect":isCorrect, "errorMessage":errorMessage};
@@ -1554,8 +1614,9 @@
 	var onChangeText = "document.getElementById('elementForm').innerHTML = ";
-	onChangeText += "window.opener.buildElementForm(this.value , " + geometryIndex + ");";
+	onChangeText += "window.opener.buildElementForm(this.value, " + geometryIndex + ");";
 	onChangeText += "window.opener.setWfsWindowStyle(this.value);";
+	onChangeText += "$('.hasDatepicker').datepicker();";
 	str += "\t<select name='wfs' size='" + wfsConf.length + "'";
 	str += " onChange=\""+ onChangeText +"\"";
@@ -1577,25 +1638,155 @@
 	str += "</select>\n\t\t</form>\n\t";
-	str += "<div id='elementForm'>\n</div>";
+	var elForm = "";
 	if (defaultIndex != -1) {
-		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'>"+wfsConf[defaultIndex]['g_style']+"</style></head><body></body></html>");
-		wfsWindow.document.write(str);
-		wfsWindow.document.close();
-		wfsWindow.document.getElementById("elementForm").innerHTML = buildElementForm(defaultIndex, geometryIndex);
+		elForm = buildElementForm(defaultIndex, geometryIndex);
+		var headStr = "<html><head><style type='text/css'>" + wfsConf[defaultIndex]['g_style'] + "</style>";
+		headStr += '<link rel="stylesheet" type="text/css" href="../extensions/theme/ui.all.css" />';
+		headStr += '<style type="text/css">'
+		headStr += 'a.tabheader { margin: 0 3px 0 0;padding: 1px 5px;text-decoration: none;color: #999;background-color: #F5F5F5;border: 1px solid #999;border-bottom: 0; }';
+		headStr += 'a.tabheader.active { color: #666;background-color: transparent;border-color: #666;border-bottom: 1px solid #FFF;cursor: default; }';
+		headStr += 'div.tabcontent { visibility: hidden;display: none;margin: -3px 0 5px 0;padding: 5px;border: 1px solid #666; }';
+		headStr += 'div.helptext { visibility: hidden;display: none;position: absolute;top: 5%;left: 5%;width: 85%;padding: 5px;color: #000;background-color: #CCC;border: 1px solid #000; }';
+		headStr += 'div.helptext p { margin: 0 ; }';
+		headStr += 'div.helptext p a.close { display: block;margin: 5px auto;text-align: center; }';
+		headStr += 'a img { vertical-align: middle;border: 0; }';
+		headStr += '</style>';
+		headStr += '</head><body onload="window.opener.toggleTabs(\''+initialTab+'\'); var $dp = $(\'.hasdatepicker\');$dp.datepicker();">';
+		wfsWindow.document.write(headStr);
 	else {
-		wfsWindow.document.writeln("<html><head><meta http-equiv='Content-Type' content='text/html; charset=<?php echo CHARSET;?>'><style type='text/css'></style></head><body></body></html>");
+		var headStr = "<html><head><style type='text/css'></style></head><body>";
+	str += "<div id='elementForm'>\n" + elForm + "</div>";
+	str += "<script type='text/javascript' src='../extensions/jquery-1.3.2.min.js'><\/script>";
+	str += "<script type='text/javascript' src='../extensions/jquery-ui-1.7.1.w.o.effects.min.js'><\/script>";
+	str += "</body></html>";
+	wfsWindow.document.write(str);
+	wfsWindow.document.close();
+//	toggleTabs(initialTab);
 function setWfsWindowStyle(wfsConfIndex) {
 	wfsWindow.document.getElementsByTagName("style")[0].innerHTML = wfsConf[wfsConfIndex]['g_style'];
+function prepareSelectBox (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+	if (categoryName) {
+		var patternString = "<select";
+		var pattern = new RegExp(patternString);
+		formElementHtml = formElementHtml.replace(pattern, patternString + " category='" + categoryName + "' ");
+	if (isMandatory) {
+		// set border if mandatory
+		patternString = "<select";
+		pattern = new RegExp(patternString);
+		formElementHtml = formElementHtml.replace(pattern, patternString + " mandatory='true' style='border:1px solid red' ");
+	// set name of select box to elementlabel
+	patternString = "name\s*=\s*\\*'\w+\\*'";
+	if (pattern.test(formElementHtml)) {
+		formElementHtml = formElementHtml.replace(pattern, "name='" + elementLabel + "'");
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<select name='" + elementLabel + "'");
+	// preselect the correct entry of the box
+	patternString = "option value='"+elementValue+"'";
+	formElementHtml = formElementHtml.replace(pattern, patternString+" selected");
+	return formElementHtml;
+function prepareDatepicker (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+		var patternString = "<input";
+		patternString = "<input";
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<input name='" + elementLabel + "'");
+	formElementHtml = formElementHtml.replace(pattern, patternString + " value='"+elementValue+"'");
+function prepareTextArea (formElementHtml, categoryName, isMandatory, elementLabel, elementValue) {
+	// set category
+		var patternString = "<textarea";
+		patternString = "<textarea";
+	else {
+		formElementHtml = formElementHtml.replace(pattern, "<textarea name='" + elementLabel + "'");
+	patternString = "<\/textarea>";
+	formElementHtml = formElementHtml.replace(pattern, elementValue + patternString);
+// Returns a form with the elements of a selected WFS grouped in tabs
+// (if the original WFS is the selected WFS, the values are set too)
+var initialTab = false;
 // returns a form with the elements of a selected wfs
 // (if the original wfs is the selected wfs, the values are set too)
 function buildElementForm(wfsConfIndex, memberIndex){
@@ -1613,78 +1804,161 @@
 	if (typeof(featureTypeArray["element"]) !== "undefined") {
-		str += "<form id='"+featureTypeElementFormId+"'>\n\t<table>\n";
 		featureTypeElementArray = featureTypeArray["element"];
-		// 2. add rows to form
-		for (var i = 0 ; i < featureTypeElementArray.length ; i ++) {
-			var featureTypeElement = featureTypeElementArray[i];
-			var elementName = featureTypeElement['element_name'];
-			var elementType = featureTypeElement['element_type'];
-			var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
-			var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
-			var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
-			var elementLabelExists = (featureTypeElement['f_label'] != "");
-			var elementLabel = "";
-			if (elementLabelExists) {
-				elementLabel = featureTypeElement['f_label'];
+		// Check if there are categories given and
+		// build the form in tabs if necessary
+		var elementCategories = [];
+		for(var i = 0; i < featureTypeElementArray.length; i++){
+			var categoryName         = featureTypeElementArray[i].f_category_name;
+			var categoryNameIsUnique = true;
+			if(categoryName.length === 0) { continue; }
+			for(var j = 0; j < elementCategories.length; j++) {
+				if(elementCategories[j] == categoryName) {
+					categoryNameIsUnique = false;
-			var elementLabelStyle = featureTypeElement['f_label_id'];
+			if(categoryNameIsUnique) {
+				elementCategories.push(categoryName);
-			if (!isGeomColumn) {
-				if (isEditable) {
-					str += "\t\t<tr>\n";
-					str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
-					str += "\t\t\t<td>\n";
+		str += "<form id='"+featureTypeElementFormId+"'>\n\t";
+		var hasCategories = (elementCategories.length > 0);
+		if (hasCategories) {
+			elementCategories.sort();
+			initialTab = elementCategories[0];
+			for (var currentCategory = 0; currentCategory < elementCategories.length; currentCategory++) {
+				str += '<a href="#" id="tabheader_' + elementCategories[currentCategory] + '" class="tabheader" onclick="return window.opener.toggleTabs(\'' + elementCategories[currentCategory] + '\')">' + elementCategories[currentCategory] + '</a>';
+		for (var currentCategory = 0; currentCategory < elementCategories.length || !hasCategories; currentCategory++) {
+				str += '<div id="tab_' + elementCategories[currentCategory] + '" class="tabcontent">';
+			str += '<table>';
-					var elementValue = "";
-					if (!featureTypeMismatch) {
-						for (var j = 0 ; j < memberElements.count() ; j ++) {
-							if (memberElements.getName(j) == featureTypeElement['element_name']) {
-								elementValue = memberElements.getValue(j);
+			// 2. add rows to form
+			for (var i = 0 ; i < featureTypeElementArray.length ; i++) {
+				var featureTypeElement = featureTypeElementArray[i];
+				var elementName = featureTypeElement['element_name'];
+				var elementType = featureTypeElement['element_type'];
+				var isEditable = (parseInt(featureTypeElement['f_edit']) == 1);
+				var isMandatory = (parseInt(featureTypeElement['f_mandatory']) == 1);
+				var isGeomColumn = (parseInt(featureTypeElement['f_geom']) == 1);
+				if(hasCategories && featureTypeElement.f_category_name != elementCategories[currentCategory] && !isGeomColumn) {
+					continue;
+				var elementLabelExists = (featureTypeElement['f_label'] != "");
+				var elementLabel = "";
+				if (elementLabelExists) {
+					elementLabel = featureTypeElement['f_label'];
+				var elementLabelStyle = featureTypeElement['f_label_id'];
+				if (!isGeomColumn) {
+					if (isEditable) {
+						str += "\t\t<tr>\n";
+						if(elementLabelExists) {
+							str += "\t\t\t<td>\n\t\t\t\t<div class = '"+elementLabelStyle+"''>" + elementLabel + "</div>\n\t\t\t</td>\n";
+							str += "\t\t\t<td>\n";
+						else {
+							str += '<td colspan="2">';
+						var elementValue = "";
+						if (!featureTypeMismatch) {
+							for (var j = 0 ; j < memberElements.count() ; j ++) {
+								if (memberElements.getName(j) == featureTypeElement['element_name']) {
+									elementValue = memberElements.getValue(j);
-					var formElementHtml = featureTypeElement['f_form_element_html'];
-					if (!formElementHtml || !formElementHtml.match(/&lt;select/)) {
-						str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
-						str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
-						str += "\t\t\t\t<input id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
-					else {
+						var formElementHtml = featureTypeElement['f_form_element_html'];
+						if (!formElementHtml) {
+							mandatoryHint = '';
+							var mandatoryHint = (parseInt(featureTypeElement['f_mandatory']) == 1) ? ' style="border:1px solid red;"' : '';
+							str += "\t\t\t\t<input id = 'datatype_mb_digitize_form_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
+							str += "\t\t\t\t<input id = 'mandatory_mb_digitize_form_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
+							if (!hasCategories) {
+								str += "\t\t\t\t<input id = '" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+							else {
+								str += "\t\t\t\t<input category='"+elementCategories[currentCategory]+"' id = 'mb_digitize_form_" + elementName + "' name='" + elementLabel + "' type='text' " + mandatoryHint + " class = '"+featureTypeElement['f_style_id']+"' size=20 value = '" + elementValue + "'>\n";
+						else {
 							while (formElementHtml.match(/\\/)) {
 								formElementHtml = formElementHtml.replace(/\\/, "");
-							str += "\t\t\t\t<input id = 'datatype_" + elementName + "' name='datatype' type='hidden' value = '" + elementType + "'>\n";
-							str += "\t\t\t\t<input id = 'mandatory_" + elementName + "' name='mandatory' type='hidden' value = '" + isMandatory + "'>\n";
-							// preselect the correct entry of the box
-							var patternString = "option value( )*=( )*'"+elementValue+"'";
-							var pattern = new RegExp(patternString);
-							var patternStringForReplace = "option value = '"+elementValue+"'";
-							formElementHtml = formElementHtml.replace(pattern, patternStringForReplace+" selected");
-							formElementHtml = formElementHtml.replace(/&lt;/g,'<');
-							formElementHtml = formElementHtml.replace(/&gt;/g,'>');
-							formElementHtml = formElementHtml.replace(/&#039;/g,'\'');
+								formElementHtml = prepareSelectBox(formElementHtml, "", isMandatory, elementLabel, elementValue);
+							var patternString = "hasdatepicker";
+								formElementHtml = prepareDatepicker(formElementHtml, "", isMandatory, elementLabel, elementValue);
+								formElementHtml = prepareTextArea(formElementHtml, "", isMandatory, elementLabel, elementValue);
 							str += formElementHtml;
+						if(featureTypeElement.f_helptext.length > 0) {
+							str += ' <a href="#" onclick="return window.opener.showHelptext(' + i + ')"><img src="../img/help.png" width="16" height="16" alt="?" /></a> ';
+							str += '<div id="helptext' +i+ '" class="helptext">';
+							str += '<p>';
+							str += featureTypeElement.f_helptext.replace(/(http:\/\/\S*)/g,'<a href="$1" target="blank">$1<\/a>');
+							str += '<a href="#" class="close" onclick="return window.opener.hideHelptext(' + i + ')">close</a>';
+							str += '</p>';
+							str += '</div>';
+						str += "\t\t\t</td>\n\t\t</tr>\n";
-					str += "\t\t\t</td>\n\t\t</tr>\n";
+				else {
+					hasGeometryColumn = true;
-			else {
-				hasGeometryColumn = true;
+			str += '</table>';
+			str += '</div>';
+			// if no categories exist, the for loop would be
+			// infinite without this break
+				break;
 		// 3. add buttons "save", "update", "delete"
-		str += "</table><table>";
+		str += "<table>";
 		var isTransactional = (featureTypeArray['wfs_transaction']);
 		if (isTransactional) {
More information about the Mapbender_commits mailing list
