[Mapbender-commits] r4065 - branches/mifan_dev/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Jun 20 03:06:17 EDT 2009
Author: mifan
Date: 2009-06-20 03:06:16 -0400 (Sat, 20 Jun 2009)
New Revision: 4065
   branches/mifan_dev/mapbender/http/classes/class_csw.php
more methods to class
Modified: branches/mifan_dev/mapbender/http/classes/class_csw.php
--- branches/mifan_dev/mapbender/http/classes/class_csw.php	2009-06-19 21:19:01 UTC (rev 4064)
+++ branches/mifan_dev/mapbender/http/classes/class_csw.php	2009-06-20 07:06:16 UTC (rev 4065)
@@ -28,9 +28,17 @@
 class csw{
-	var $title;
-	var $abstract;
+	var $cat_id;
+	var $cat_title;
+	var $cat_abstract;
+	var $cat_version;
+	var $cat_op_getcapabilities;
+	var $cat_op_getrecords;
+	var $cat_op_getrecordbyid;
+	var $cat_op_describerecord;
+	var $cat_getcapabilities_doc;
 	var $fees;
 	var $accessconstraints;
 	var $contactperson;
@@ -45,6 +53,8 @@
 	var $contactfacsimiletelephone;
 	var $contactelectronicmailaddress;
+	var $keywords = array();
 	var $catowner;
 	var $cattimestamp;
@@ -52,17 +62,42 @@
-	public function createCatObjFromXML()
+	//Getters of common items
+	function getCatVersion(){
+		return $this->cat_version;
+	//XML to Persistance
+	 * Called by admin function when adding catalog
+	 * Create Catalog object from Getcapabilities XML
+	 * @return unknown_type
+	 * @param $url URL of getcapabilities request
+	public function createCatObjFromXML($url)
+		//import connector
+		$x = new connector($url);
+		$data = $x->file;
-	public function createCatObjFromDB()
+	 * Get catalog object from DB
+	 * @param $cat_id
+	public function getCatObjFromDB($cat_id)
-	public function setCatObjToDB()
+	 * Write catalog object to persistent storage
+	 * @param $gui
+	public function setCatObjToDB($gui)
More information about the Mapbender_commits mailing list
