[Mapbender-commits] r4066 - in trunk/mapbender/http: include
javascripts
svn_mapbender at osgeo.org
Mon Jun 22 06:49:13 EDT 2009
Author: christoph
Date: 2009-06-22 06:49:13 -0400 (Mon, 22 Jun 2009)
New Revision: 4066
Added:
trunk/mapbender/http/include/dyn_js_object.php
trunk/mapbender/http/javascripts/map.php
trunk/mapbender/http/javascripts/mod_zoomIn1.php
Mapbender elements as jquery plugins
http://baudson.cute-ice.de/serendipity/index.php?/archives/30-Mapbender-a-set-of-jQuery-plugins.html
Added: trunk/mapbender/http/include/dyn_js_object.php
--- trunk/mapbender/http/include/dyn_js_object.php (rev 0)
+++ trunk/mapbender/http/include/dyn_js_object.php 2009-06-22 10:49:13 UTC (rev 4066)
@@ -0,0 +1,62 @@
+<?php
+# $Id: dyn_js.php 3850 2009-04-03 09:02:12Z christoph $
+# $Header: /cvsroot/mapbender/mapbender/http/classes/class_wfs.php,v 1.15 2006/03/09 13:55:46 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+if (isset($gui_id)) {
+ $sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 and var_type='var'";
+ $v = array($e_id, $gui_id);
+ $t = array('s', 's');
+ $res = db_prep_query($sql, $v, $t);
+ $arrays = array();
+ $varArray = array();
+ while ($row = db_fetch_array($res)) {
+ if (mb_strpos($row["var_name"], "[")) {
+ $arrayname = mb_substr($row["var_name"], 0, mb_strpos($row["var_name"], "["));
+ if (!in_array($arrayname, $arrays)) {
+ $i++;
+ $arrays[$i] = $arrayname;
+ $varArray[]= $arrayname . ": []";
+ if (is_numeric(stripslashes($row["var_value"]))) {
+ $varArray[]= $row["var_name"].": ".stripslashes($row["var_value"]);
+ elseif (strpos(stripslashes($row["var_value"]), "[") === 0 ||
+ strpos(stripslashes($row["var_value"]), "{") === 0) {
+ else {
+ $varArray[]= $row["var_name"].": '" .
+ str_replace(
+ array('"',"'", "\r", "\n", "\0"),
+ array('\"','\\\'','\r', '\n', '\0'),
+ stripslashes($row["var_value"])
+ echo "$.extend(options, {";
+ echo implode(",\n", $varArray);
+ echo "});";
+else {
+ $e = new mb_exception("Application ID not set while retrieving element vars of module " . $e_id);
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2009-06-20 07:06:16 UTC (rev 4065)
+++ trunk/mapbender/http/javascripts/map.php 2009-06-22 10:49:13 UTC (rev 4066)
@@ -148,8 +148,16 @@
$modulesNotRelyingOnGlobalsArray = explode(",", MODULES_NOT_RELYING_ON_GLOBALS);
-echo "\nMapbender.Modules = {};\n";
+Mapbender.Modules = {};
+Mapbender.addModule = function (name, obj) {
+ if (name && !Mapbender.Modules[name]) {
+ Mapbender.Modules[name] = obj;
+ return true;
+ return false;
+<?php
$mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos, " .
"e_url, e_left, e_top, e_width, e_height, e_requires FROM gui_element WHERE e_public = 1 AND " .
"fkey_gui_id = $1 ORDER BY e_pos";
@@ -160,14 +168,51 @@
if($row_js["e_js_file"] != ""){
$jsArray = explode(",", $row_js["e_js_file"]);
for ($i = 0; $i < count($jsArray); $i++) {
- $e_id = $row_js["e_id"];
+ $e_id = isset($row_js["e_id"]) ? $row_js["e_id"] : "";
$e_src = $row_js["e_src"];
$e_require = $row_js["e_requires"];
$e_target = explode(",",$row_js["e_target"]);
$e_width = intval($row_js["e_width"]);
$e_height = intval($row_js["e_height"]);
+ $e_top = intval($row_js["e_top"]);
+ $e_left = intval($row_js["e_left"]);
$currentFile = trim($jsArray[$i]);
- if (file_exists($currentFile)) {
+ if (!file_exists($currentFile)) {
+ $e = new mb_exception("Javascript not found: " . $currentFile);
+ echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
+ die;
+ if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
+ echo <<<JS
+var options = {
+ id:"$e_id",
+ target:"$e_target",
+ top:$e_top,
+ left:$e_left,
+ width:$e_width,
+ height:$e_height,
+ src:"$e_src"
+JS;
+ include "../include/dyn_js_object.php";
+ echo <<<JS
+$.fn.$e_id = function (options) {
+ return this.each(function () {
+JS;
+ require($currentFile);
+ echo <<<JS
+$("#$e_id").$e_id(options);
+JS;
+ else {
echo "Mapbender.Modules." . $e_id . " = {\n";
echo "id:'".$row_js["e_id"]."',";
echo "url:'".$row_js["e_url"]."',";
@@ -175,31 +220,10 @@
echo "left:'".$row_js["e_left"]."',";
echo "width:'".$row_js["e_width"]."',";
echo "height:'".$row_js["e_height"]."'";
- if (in_array($e_id, $modulesNotRelyingOnGlobalsArray)) {
- echo ",\ninit : function () {\n";
- require($currentFile);
- echo "}\n";
- echo "};\n";
- else {
- echo "};\n";
+ echo "};\n";
- else {
- $e = new mb_exception("Javascript not found: " . $currentFile);
- echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
- die;
-eventBeforeInit.register(function () {
- for (var module in Mapbender.Modules) {
- var initFunction = Mapbender.Modules[module].init;
- if (typeof(initFunction) == "function") {
- Mapbender.Modules[module].init();
Modified: trunk/mapbender/http/javascripts/mod_zoomIn1.php
--- trunk/mapbender/http/javascripts/mod_zoomIn1.php 2009-06-20 07:06:16 UTC (rev 4065)
+++ trunk/mapbender/http/javascripts/mod_zoomIn1.php 2009-06-22 10:49:13 UTC (rev 4066)
@@ -16,30 +16,21 @@
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-var zoomin1Id = '<?php echo $e_id; ?>';
-var mod_zoom1_img = new Image();
-mod_zoom1_img.src = "<?php echo $e_src; ?>";
-var mod_zoom1_img_over = new Image();
-mod_zoom1_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-var $zoomin1Button = $("#"+zoomin1Id);
-$zoomin1Button.click(function () {
- zoom("<?php echo $e_target[0]; ?>", true, 2.0);
-function mod_zoomIn1_init(obj){
- document.getElementById("zoomIn1").src = mod_zoom1_img_over.src;
- obj.onmouseover = new Function("mod_zoomIn1_over()");
- obj.onmouseout = new Function("mod_zoomIn1_out()");
-function mod_zoomIn1_over(){
-function mod_zoomIn1_out(){
- document.getElementById("zoomIn1").src = mod_zoom1_img.src;
+$(this).click(function () {
+ if (!options.target) {
+ return;
+ if (!Mapbender.Modules[options.target]) {
+ return;
+ Mapbender.Modules[options.target].zoom(true, 2.0);
+}).mouseover(function () {
+ if (options.src) {
+ this.src = options.src.replace(/_off/, "_over");
+}).mouseout(function () {
+ this.src = options.src;
More information about the Mapbender_commits
