[Mapbender-commits] r4116 - in trunk/mapbender/documents: . api_js
svn_mapbender at osgeo.org
Wed Jun 24 08:59:33 EDT 2009
Author: christoph
Date: 2009-06-24 08:59:32 -0400 (Wed, 24 Jun 2009)
New Revision: 4116
Added:
trunk/mapbender/documents/api_js/
trunk/mapbender/documents/api_js/Menu.txt
Added: trunk/mapbender/documents/api_js/Menu.txt
--- trunk/mapbender/documents/api_js/Menu.txt (rev 0)
+++ trunk/mapbender/documents/api_js/Menu.txt 2009-06-24 12:59:32 UTC (rev 4116)
@@ -0,0 +1,75 @@
+Format: 1.4
+# You can add a title and sub-title to your menu like this:
+# Title: [project name]
+# SubTitle: [subtitle]
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+# m - One or two digit month. January is "1"
+# mm - Always two digit month. January is "01"
+# mon - Short month word. January is "Jan"
+# month - Long month word. January is "January"
+# d - One or two digit day. 1 is "1"
+# dd - Always two digit day. 1 is "01"
+# day - Day with letter extension. 1 is "1st"
+# yy - Two digit year. 2006 is "06"
+# yyyy - Four digit year. 2006 is "2006"
+# year - Four digit year. 2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu. Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries. Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file. Natural Docs will clean it up the next
+# time it is run. When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+Group: Mapbender {
+ File: Mapbender (http/javascripts/core.php)
+ File: Event (lib/event.js)
+ File: Map (http/javascripts/map_obj.js)
+ Group: modules {
+ File: mod_addWMSfromfilteredList.php (http/javascripts/mod_addWMSfromfilteredList.php)
+ File: Reload (http/javascripts/mod_reload.php)
+ File: Sandclock (http/javascripts/mod_sandclock.php)
+ File: ZoomIn1 (http/javascripts/mod_zoomIn1.php)
+ } # Group: modules
+ } # Group: Mapbender
+File: SearchPanel (docs/javascript/main.js)
+Group: Index {
+ Index: Everything
+ Class Index: Classes
+ File Index: Files
+ Function Index: Functions
+ Variable Index: Variables
+ } # Group: Index
More information about the Mapbender_commits
