[Mapbender-commits] r4117 - trunk/mapbender/http/php
    svn_mapbender at osgeo.org
    Wed Jun 24 10:36:43 EDT 2009
Author: vera
Date: 2009-06-24 10:36:43 -0400 (Wed, 24 Jun 2009)
New Revision: 4117
   trunk/mapbender/http/php/mod_addWMSfromfilteredList_server.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_addWMSfromfilteredList_server.php
--- trunk/mapbender/http/php/mod_addWMSfromfilteredList_server.php	2009-06-24 12:59:32 UTC (rev 4116)
+++ trunk/mapbender/http/php/mod_addWMSfromfilteredList_server.php	2009-06-24 14:36:43 UTC (rev 4117)
@@ -1,135 +1,138 @@
-<?php
-# $Id: mod_addWMSfromfilteredList.php 830 2006-11-20 13:39:10Z christoph $
-# http://www.mapbender.org/index.php/mod_addWMSfromfilteredList.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$userId = $_SESSION["mb_user_id"];
-$command = $_GET["command"];
-$guiId = $_GET["guiId"];
-$groupId = $_GET["groupId"];
-$admin = new administration();
-$guiIdArray = $admin->getGuisByPermission($userId, false);
-$resultObj = array();
-if ($command == "getGroups") {
-	$resultObj["group"] = array();
-	$sql = "SELECT mb_group_id, mb_group_name, gettext($1, mb_group_description) as mb_group_description ";
-	$sql .= "FROM mb_group, mb_user_mb_group ";
-	$sql .= "WHERE fkey_mb_group_id = mb_group_id AND fkey_mb_user_id = $2 ";
-	$sql .= "ORDER BY mb_group_name";
-	$v = array($_SESSION["mb_lang"], $userId);
-	$t = array("s", "i");
-	$res = db_prep_query($sql, $v, $t);
-	while($row = db_fetch_array($res)){
-		$resultArray = array("description" => $row["mb_group_description"], "name" => $row["mb_group_name"], "id" => $row["mb_group_id"]);
-		array_push($resultObj["group"], $resultArray);
-else if ($command == "getGUIs") {
-	$resultObj["gui"] = array();
-	$sql = "SELECT gui_id, gui_name, gettext($1, gui_description) as gui_description FROM gui WHERE gui_id IN (";
-	$v = array($_SESSION["mb_lang"]);
-	$t = array("s");
-	for ($i = 0; $i < count($guiIdArray); $i++) {
-		if ($i > 0) {
-			$sql .= ",";
-		$sql .= "$" . strval($i + 2);
-		array_push($v, $guiIdArray[$i]);
-		array_push($t, "s");
-	$sql .= ") ORDER BY gui_name";
-	$res = db_prep_query($sql,$v,$t);
-	while ($row = db_fetch_array($res)) {
-		$resultArray = array("description" => $row["gui_description"], "name" => $row["gui_name"], "id" => $row["gui_id"]);
-		array_push($resultObj["gui"], $resultArray);
-else if ($command == "getAllWMS") {
-	$resultObj["wms"] = array();
-	$sql = "SELECT DISTINCT wms.wms_id, wms.wms_title, gettext($1, wms.wms_abstract) as wms_abstract, wms.wms_getcapabilities, wms.wms_version ";
-	$sql .= "FROM wms, gui_wms ";
-	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id IN (";
-	$t = array("s");
-		if ($i > 0) {
-			$sql .= ",";
-	$sql .= ") ORDER BY wms_title";
-		$resultArray = array("id" => $row["wms_id"], "title" => $row["wms_title"], "abstract" => $row["wms_abstract"], "getCapabilitiesUrl" => $row["wms_getcapabilities"], "version" => $row["wms_version"]);
-		array_push($resultObj["wms"], $resultArray);
-else if ($command == "getWMSByGroup") {
-	$sql = "SELECT DISTINCT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version ";
-	$sql .= "FROM wms, gui_wms, gui_mb_group ";
-	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id = gui_mb_group.fkey_gui_id AND gui_mb_group.fkey_mb_group_id = $2";
-	$v = array($_SESSION["mb_lang"], $groupId);
-else if ($command == "getWMSByGUI") {
-	$sql .= "FROM wms, gui_wms WHERE wms.wms_id = gui_wms.fkey_wms_id AND fkey_gui_id = $2";
-	$v = array($_SESSION["mb_lang"], $guiId);
-	$t = array("s", "s");
-$json = new Mapbender_JSON();
-$output = $json->encode($resultObj);
-echo $output;
+<?php
+# $Id: mod_addWMSfromfilteredList.php 830 2006-11-20 13:39:10Z christoph $
+# http://www.mapbender.org/index.php/mod_addWMSfromfilteredList.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$userId = Mapbender::session()->get("mb_user_id");
+$command = $_GET["command"];
+$guiId = $_GET["guiId"];
+$groupId = $_GET["groupId"];
+$admin = new administration();
+$guiIdArray = $admin->getGuisByPermission($userId, false);
+$resultObj = array();
+if ($command == "getGroups") {
+	$resultObj["group"] = array();
+	$sql = "SELECT mb_group_id, mb_group_name, gettext($1, mb_group_description) as mb_group_description ";
+	$sql .= "FROM mb_group, mb_user_mb_group ";
+	$sql .= "WHERE fkey_mb_group_id = mb_group_id AND fkey_mb_user_id = $2 ";
+	$sql .= "ORDER BY mb_group_name";
+	$v = array($_SESSION["mb_lang"], $userId);
+	$v = array(Mapbender::session()->get("mb_lang"), $userId);
+	$t = array("s", "i");
+	$res = db_prep_query($sql, $v, $t);
+	while($row = db_fetch_array($res)){
+		$resultArray = array("description" => $row["mb_group_description"], "name" => $row["mb_group_name"], "id" => $row["mb_group_id"]);
+		array_push($resultObj["group"], $resultArray);
+else if ($command == "getGUIs") {
+	$resultObj["gui"] = array();
+	$sql = "SELECT gui_id, gui_name, gettext($1, gui_description) as gui_description FROM gui WHERE gui_id IN (";
+	$v = array(Mapbender::session()->get("mb_lang"));
+	$t = array("s");
+	for ($i = 0; $i < count($guiIdArray); $i++) {
+		if ($i > 0) {
+			$sql .= ",";
+		$sql .= "$" . strval($i + 2);
+		array_push($v, $guiIdArray[$i]);
+		array_push($t, "s");
+	$sql .= ") ORDER BY gui_name";
+	$res = db_prep_query($sql,$v,$t);
+	while ($row = db_fetch_array($res)) {
+		$resultArray = array("description" => $row["gui_description"], "name" => $row["gui_name"], "id" => $row["gui_id"]);
+		array_push($resultObj["gui"], $resultArray);
+else if ($command == "getAllWMS") {
+	$resultObj["wms"] = array();
+	$sql = "SELECT DISTINCT wms.wms_id, wms.wms_title, gettext($1, wms.wms_abstract) as wms_abstract, wms.wms_getcapabilities, wms.wms_version ";
+	$sql .= "FROM wms, gui_wms ";
+	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id IN (";
+	$t = array("s");
+		if ($i > 0) {
+			$sql .= ",";
+	$sql .= ") ORDER BY wms_title";
+		$resultArray = array("id" => $row["wms_id"], "title" => $row["wms_title"], "abstract" => $row["wms_abstract"], "getCapabilitiesUrl" => $row["wms_getcapabilities"], "version" => $row["wms_version"]);
+		array_push($resultObj["wms"], $resultArray);
+else if ($command == "getWMSByGroup") {
+	$sql = "SELECT DISTINCT wms_id, wms_title, gettext($1, wms_abstract) as wms_abstract, wms_getcapabilities, wms_version ";
+	$sql .= "FROM wms, gui_wms, gui_mb_group ";
+	$sql .= "WHERE wms.wms_id = gui_wms.fkey_wms_id AND gui_wms.fkey_gui_id = gui_mb_group.fkey_gui_id AND gui_mb_group.fkey_mb_group_id = $2";
+	$v = array(Mapbender::session()->get("mb_lang"), $groupId);
+else if ($command == "getWMSByGUI") {
+	$sql .= "FROM wms, gui_wms WHERE wms.wms_id = gui_wms.fkey_wms_id AND fkey_gui_id = $2";
+	$v = array(Mapbender::session()->get("mb_lang"), $guiId);
+	$t = array("s", "s");
+$json = new Mapbender_JSON();
+$output = $json->encode($resultObj);
+echo $output;
\ No newline at end of file
More information about the Mapbender_commits
