[Mapbender-commits] r4202 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 06:27:19 EDT 2009
Author: vera
Date: 2009-06-25 06:27:19 -0400 (Thu, 25 Jun 2009)
New Revision: 4202
   trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_wfs_gazetteer_server.php
--- trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2009-06-25 10:26:09 UTC (rev 4201)
+++ trunk/mapbender/http/php/mod_wfs_gazetteer_server.php	2009-06-25 10:27:19 UTC (rev 4202)
@@ -1,139 +1,139 @@
-<?php
-# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
-$command = $_REQUEST["command"];
- * checks if a variable name is valid.
- * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
- * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
-function isValidVarName ($varname) {
-	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
-		return true;
-	return false;
- * If access to the WFS conf is restricted, modify the filter.
- function checkAccessConstraint($filter, $wfs_conf_id) {
-	/* wfs_conf_element */
-	$sql = "SELECT * FROM wfs_conf_element ";
-	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-	$sql .= "ORDER BY wfs_conf_element.f_respos";
-	$v = array($wfs_conf_id);
-	$t = array('i');
-	$res = db_prep_query($sql,$v,$t);
-	while($row = db_fetch_array($res)){
-		if (!empty($row["f_auth_varname"])) {
-			$auth_varname = $row["f_auth_varname"];
-			$element_name = $row["element_name"];
-	if (!empty($auth_varname)) {
-		if (isValidVarName($auth_varname)) {
-			$user = eval("return " . $auth_varname . ";");
-			if ($user) {
-				$pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
-				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
-				$filter = mb_eregi_replace($pattern, $replacement, $filter);
-			else {
-				$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
-		else {
-			$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
-	return $filter;
-if ($command == "getWfsConf") {
-	$wfsConfIdString = $_GET["wfsConfIdString"];
-	if ($wfsConfIdString != "") {
-		//array_keys(array_flip()) produces an array with unique entries
-		$wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
-	else {
-		echo "please specify wfs conf id.";
-		die();
-	$obj = new WfsConf();
-	$obj->load($wfsConfIdArray);
-	$json = new Mapbender_JSON();
-	$output = $json->encode($obj->confArray);
-	echo $output;
-else if ($command == "getSearchResults") {
-	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
-	$backlink = $_REQUEST["backlink"];
-	$frame = $_REQUEST["frame"];
-	$filter = $_REQUEST["filter"];
-	$url = $_REQUEST["url"];
-	$typename = $_REQUEST["typename"];
-	$wfsConf = WfsConfiguration::createFromDb($wfs_conf_id);
-	if (is_null($wfsConf)) {
-		sendErrorMessage("Invalid WFS conf: " . $wfs_conf_id);
-	$admin = new administration();
-	$filter = $admin->char_decode(stripslashes($filter));
-	$wfsId = $wfsConf->wfsId;
-	$myWfsFactory = new UniversalWfsFactory();
-	$myWfs = $myWfsFactory->createFromDb($wfsId);
-	$data = $myWfs->getFeature($typename, $filter);
-	if ($data === null) die('{}');
-//	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
-	$gmlFactory = new UniversalGmlFactory();
-	$myGml = $gmlFactory->createFromXml($data, $wfsConf);
-	$geoJson = $myGml->toGeoJSON();
-	header("Content-type:application/x-json; charset=utf-8");
-	echo $geoJson;
-else {
-	echo "please enter a valid command.";
+<?php
+# $Id: mod_wfs_gazetteer_server.php 1190 2007-10-18 10:38:38Z baudson $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
+$command = $_REQUEST["command"];
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like Mapbender::session()->get("mb_user_id")
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+	if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+		return true;
+	return false;
+ * If access to the WFS conf is restricted, modify the filter.
+ function checkAccessConstraint($filter, $wfs_conf_id) {
+	/* wfs_conf_element */
+	$sql = "SELECT * FROM wfs_conf_element ";
+	$sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+	$sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+	$sql .= "ORDER BY wfs_conf_element.f_respos";
+	$v = array($wfs_conf_id);
+	$t = array('i');
+	$res = db_prep_query($sql,$v,$t);
+	while($row = db_fetch_array($res)){
+		if (!empty($row["f_auth_varname"])) {
+			$auth_varname = $row["f_auth_varname"];
+			$element_name = $row["element_name"];
+	if (!empty($auth_varname)) {
+		if (isValidVarName($auth_varname)) {
+			$user = eval("return " . $auth_varname . ";");
+			if ($user) {
+				$pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+				$replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+				$filter = mb_eregi_replace($pattern, $replacement, $filter);
+			else {
+				$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: invalid value of variable containing user information!");
+		else {
+			$e = new mb_exception("mod_wfs_gazetteer_server: checkAccessConstraint: var name is not valid! (" . $auth_varname . ")");
+	return $filter;
+if ($command == "getWfsConf") {
+	$wfsConfIdString = $_GET["wfsConfIdString"];
+	if ($wfsConfIdString != "") {
+		//array_keys(array_flip()) produces an array with unique entries
+		$wfsConfIdArray = array_keys(array_flip(mb_split(",", $wfsConfIdString)));
+	else {
+		echo "please specify wfs conf id.";
+		die();
+	$obj = new WfsConf();
+	$obj->load($wfsConfIdArray);
+	$json = new Mapbender_JSON();
+	$output = $json->encode($obj->confArray);
+	echo $output;
+else if ($command == "getSearchResults") {
+	$wfs_conf_id = $_REQUEST["wfs_conf_id"];
+	$backlink = $_REQUEST["backlink"];
+	$frame = $_REQUEST["frame"];
+	$filter = $_REQUEST["filter"];
+	$url = $_REQUEST["url"];
+	$typename = $_REQUEST["typename"];
+	$wfsConf = WfsConfiguration::createFromDb($wfs_conf_id);
+	if (is_null($wfsConf)) {
+		sendErrorMessage("Invalid WFS conf: " . $wfs_conf_id);
+	$admin = new administration();
+	$filter = $admin->char_decode(stripslashes($filter));
+	$wfsId = $wfsConf->wfsId;
+	$myWfsFactory = new UniversalWfsFactory();
+	$myWfs = $myWfsFactory->createFromDb($wfsId);
+	$data = $myWfs->getFeature($typename, $filter);
+	if ($data === null) die('{}');
+//	$geomColumn = WfsConf::getGeomColumnNameByConfId($wfs_conf_id);
+	$gmlFactory = new UniversalGmlFactory();
+	$myGml = $gmlFactory->createFromXml($data, $wfsConf);
+	$geoJson = $myGml->toGeoJSON();
+	header("Content-type:application/x-json; charset=utf-8");
+	echo $geoJson;
+else {
+	echo "please enter a valid command.";
\ No newline at end of file
More information about the Mapbender_commits mailing list
