[Mapbender-commits] r4203 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Jun 25 06:28:00 EDT 2009
Author: vera
Date: 2009-06-25 06:28:00 -0400 (Thu, 25 Jun 2009)
New Revision: 4203
trunk/mapbender/http/php/mod_wfs_result.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_wfs_result.php
--- trunk/mapbender/http/php/mod_wfs_result.php 2009-06-25 10:27:19 UTC (rev 4202)
+++ trunk/mapbender/http/php/mod_wfs_result.php 2009-06-25 10:28:00 UTC (rev 4203)
@@ -1,105 +1,105 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
-require_once(dirname(__FILE__) . "/../classes/class_connector.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
-$filter = stripslashes($_REQUEST["filter"]);
-$db_wfs_conf_id = $_REQUEST["db_wfs_conf_id"];
-$typename = $_REQUEST["typename"];
- * checks if a variable name is valid.
- * Currently a valid name would be sth. like $_SESSION["mb_user_id"]
- * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
-function isValidVarName ($varname) {
- if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
- return true;
- return false;
- * If access to the WFS conf is restricted, modify the filter.
-function checkAccessConstraint($filter, $wfs_conf_id) {
- /* wfs_conf_element */
- $sql = "SELECT * FROM wfs_conf_element ";
- $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
- $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
- $sql .= "ORDER BY wfs_conf_element.f_respos";
- $v = array($wfs_conf_id);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- while($row = db_fetch_array($res)){
- if (!empty($row["f_auth_varname"])) {
- $auth_varname = $row["f_auth_varname"];
- $element_name = $row["element_name"];
- $e = new mb_exception($auth_varname . " " . $element_name);
- if (!empty($auth_varname)) {
- if (isValidVarName($auth_varname)) {
- $user = eval("return " . $auth_varname . ";");
- $pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
- $replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
- $filter = eregi_replace($pattern, $replacement, $filter);
- return $filter;
-$filter = checkAccessConstraint($filter, $db_wfs_conf_id);
-$sql = "SELECT fkey_wfs_id FROM wfs_conf WHERE wfs_conf_id = $1";
-$v = array($db_wfs_conf_id);
-$t = array('i');
-$res = db_prep_query($sql, $v, $t);
-$row = db_fetch_array($res);
-$wfsId = $row["fkey_wfs_id"];
-$myWfsFactory = new UniversalWfsFactory();
-$myWfs = $myWfsFactory->createFromDb($wfsId);
-$data = $myWfs->getFeature($typename, $filter);
-if ($data === null) die('{}');
-$myWfsConf = WfsConfiguration::createFromDb($db_wfs_conf_id);
-if (is_null($myWfsConf)) {
- die("{}");
-$gmlFactory = new UniversalGmlFactory();
-$myGml = $gmlFactory->createFromXml($data, $myWfsConf);
-$geoJson = $myGml->toGeoJSON();
-header('Content-type: text/html');
-echo $geoJson;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_stripRequest.php");
+require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs_configuration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_gml_factory.php");
+$filter = stripslashes($_REQUEST["filter"]);
+$db_wfs_conf_id = $_REQUEST["db_wfs_conf_id"];
+$typename = $_REQUEST["typename"];
+ * checks if a variable name is valid.
+ * Currently a valid name would be sth. like Mapbender::session()->get("mb_user_id")
+ * TODO: this function is also in mod_wfs_result!! Maybe merge someday.
+function isValidVarName ($varname) {
+ if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
+ return true;
+ return false;
+ * If access to the WFS conf is restricted, modify the filter.
+function checkAccessConstraint($filter, $wfs_conf_id) {
+ /* wfs_conf_element */
+ $sql = "SELECT * FROM wfs_conf_element ";
+ $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+ $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+ $sql .= "ORDER BY wfs_conf_element.f_respos";
+ $v = array($wfs_conf_id);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ while($row = db_fetch_array($res)){
+ if (!empty($row["f_auth_varname"])) {
+ $auth_varname = $row["f_auth_varname"];
+ $element_name = $row["element_name"];
+ $e = new mb_exception($auth_varname . " " . $element_name);
+ if (!empty($auth_varname)) {
+ if (isValidVarName($auth_varname)) {
+ $user = eval("return " . $auth_varname . ";");
+ $pattern = "(<ogc:Filter[^>]*>)(.*)(</ogc:Filter>)";
+ $replacement = "\\1<And>\\2<ogc:PropertyIsEqualTo><ogc:PropertyName>" . $element_name . "</ogc:PropertyName><ogc:Literal>" . $user . "</ogc:Literal></ogc:PropertyIsEqualTo></And>\\3";
+ $filter = eregi_replace($pattern, $replacement, $filter);
+ return $filter;
+$filter = checkAccessConstraint($filter, $db_wfs_conf_id);
+$sql = "SELECT fkey_wfs_id FROM wfs_conf WHERE wfs_conf_id = $1";
+$v = array($db_wfs_conf_id);
+$t = array('i');
+$res = db_prep_query($sql, $v, $t);
+$row = db_fetch_array($res);
+$wfsId = $row["fkey_wfs_id"];
+$myWfsFactory = new UniversalWfsFactory();
+$myWfs = $myWfsFactory->createFromDb($wfsId);
+$data = $myWfs->getFeature($typename, $filter);
+if ($data === null) die('{}');
+$myWfsConf = WfsConfiguration::createFromDb($db_wfs_conf_id);
+if (is_null($myWfsConf)) {
+ die("{}");
+$gmlFactory = new UniversalGmlFactory();
+$myGml = $gmlFactory->createFromXml($data, $myWfsConf);
+$geoJson = $myGml->toGeoJSON();
+header('Content-type: text/html');
+echo $geoJson;
\ No newline at end of file
More information about the Mapbender_commits
