[Mapbender-commits] r4204 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Jun 25 06:29:37 EDT 2009
Author: vera
Date: 2009-06-25 06:29:36 -0400 (Thu, 25 Jun 2009)
New Revision: 4204
trunk/mapbender/http/php/mod_wfs_server.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_wfs_server.php
--- trunk/mapbender/http/php/mod_wfs_server.php 2009-06-25 10:28:00 UTC (rev 4203)
+++ trunk/mapbender/http/php/mod_wfs_server.php 2009-06-25 10:29:36 UTC (rev 4204)
@@ -1,326 +1,326 @@
-<?php
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_wfs.php");
-require_once(dirname(__FILE__) . "/../classes/class_json.php");
-require_once(dirname(__FILE__) . "/../classes/class_universal_wfs_factory.php");
-$json = new Mapbender_JSON();
-$obj = $json->decode(stripslashes($_REQUEST['obj']));
-//workflow:
-switch($obj->action){
- case 'getServices':
- $obj->services = getServices($obj);
- sendOutput($obj);
- break;
- case 'getWfsConfData':
- $obj->wfsConf = getWfsConfData($obj->wfs);
- sendOutput($obj);
- break;
- case 'getGuis':
- $obj->id = getGuis($obj);
- sendOutput($obj);
- break;
- case 'getAssignedConfs':
- $obj->assignedConfs = getAssignedConfs($obj);
- sendOutput($obj);
- break;
- case 'getUpdateUrl':
- $obj->url = getUpdateUrl($obj);
- sendOutput($obj);
- break;
- case 'add':
- addConfsToGui($obj);
- sendOutput($obj);
- break;
- case 'remove':
- removeConfsFromGui($obj);
- sendOutput($obj);
- break;
- case 'updateWfs':
- updateWfs($obj);
- sendOutput($obj);
- break;
- case 'deleteWfs':
- deleteWfs($obj);
- sendOutput($obj);
- break;
- case 'setOwsproxy':
- $ows = array();
- $ows['string'] = setOwsproxy($obj);
- $ows['action'] = "owsproxy";
- sendOutput($ows);
- break;
- case 'removeOwsproxy':
- $ows = array();
- $ows['string'] = removeOwsproxy($obj);
- sendOutput($ows);
- break;
- case 'getOwsproxy':
- $ows = array();
- $ows['string'] = getOwsproxy($obj);
- sendOutput($ows);
- break;
- default:
- sendOutput("no action specified...");
- * Get all services (ids and titles) where the current user is owner
- * @return mixed[] services the ids and titles of the services
-function getServices(){
- global $con;
- $services = array();
- $services['id'] = array();
- $services['title'] = array();
- $adm = new administration();
- $serviceList = $adm->getWfsByOwner($_SESSION['mb_user_id']);
- if(count($serviceList) == 0){
- return false;
- $sql = "SELECT * FROM wfs WHERE wfs_id IN (";
- $v = $serviceList;
- $t = array();
- for ($i = 1; $i <= count($serviceList); $i++) {
- if ($i > 1) {
- $sql .= ", ";
- $sql .= "$" . $i;
- array_push($t, "i");
- $sql .= ") ORDER BY wfs_title";
- $res = db_prep_query($sql, $v, $t);
- while($row = db_fetch_array($res)){
- array_push($services['id'], $row['wfs_id']);
- array_push($services['title'], $row['wfs_title']);
- return $services;
- * Get all configurations of the selcted wfs if the current user is owner
- * @return mixed[]
-function getWfsConfData($wfsID){
- global $con;
- // re-check permission
- if(in_array($wfsID, $serviceList)){
- $wfsConf = array();
- $wfsConf['id'] = array();
- $wfsConf['abstract'] = array();
- $sql = "SELECT * FROM wfs_conf WHERE fkey_wfs_id = $1 ORDER BY wfs_conf_abstract";
- $v = array($wfsID);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- $cnt = 0;
- array_push($wfsConf['id'], $row['wfs_conf_id']);
- array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
- $cnt++;
- if($cnt == 0){
- return false;
- else{
- return $wfsConf;
- else if($wfsID==="gui_confs"){
- $wfsConf['id'] = $adm->getWfsConfByPermission($_SESSION['mb_user_id']);
- $cnt = 0;
- foreach($wfsConf['id'] as $wfscid){
- $sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
- $v = array($wfscid);
- $t = array('i');
- $cnt++;
- if($cnt == 0){
- return false;
- else{
- return $wfsConf;
- * Get all GUIs where the current user is owner. This are the GUIs where the user could publish his
- * wfs configurations
- * @return mixed[]
-function getGuis(){
- $guiList = $adm->getGuisByOwner($_SESSION['mb_user_id'],1);
- if(count($guiList) > 0){
- return $guiList;
- return false;
- * get all wfs_confs of the selected WFS which are assigned to the selected gui
- * @param
- * @return mixed[]
-function getAssignedConfs($obj){
- global $con;
- $assignedConfs = array();
- $confs = getWfsConfData($obj->selectedWfs);
- if($confs === false){
- return false;
- $sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id IN (".join(",",$confs['id']).")";
- $v = array($obj->selectedGui);
- $t = array('s');
- if(!$res){
- $e = new mb_exception("Error: SQL: " . $sql . " -> Gui: " .$obj->selectedGui);
- array_push($assignedConfs, $row['fkey_wfs_conf_id']);
- return $assignedConfs;
-function addConfsToGui($obj){
- global $con;
- for($i=0; $i<count($obj->confs); $i++){
- $sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
- $v = array($obj->gui,$obj->confs->$i);
- $t = array('s','i');
- if(!$row = db_fetch_array($res)){
- $sql1 = "INSERT INTO gui_wfs_conf (fkey_gui_id,fkey_wfs_conf_id) VALUES ($1,$2)";
- $v1 = array($obj->gui, $obj->confs->$i);
- $t1 = array('s', 'i');
- $res1 = db_prep_query($sql1,$v1,$t1);
-function removeConfsFromGui($obj){
- global $con;
- $sql = "DELETE FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
- $v = array($obj->gui, $obj->confs->$i);
- $t = array('s', 'i');
- * updates an WFS
- * @param object the un-encoded object
- * @return boolean success
-function updateWfs($obj){
- $id = $obj->wfs;
- $url = $obj->url;
- $wfsFactory = new UniversalWfsFactory();
- $myWfs = $wfsFactory->createFromUrl($url);
- $myWfs->id = $id;
- if(is_null($myWfs) || !$myWfs->update()){
- $obj->success = false;
- else {
- $obj->success = true;
- return true;
- * deletes an WFS
-function deleteWfs($obj){
- $id = $obj->wfs;
- $myWfs = $wfsFactory->createFromDb($id);
- if (is_null($myWfs) || !$myWfs->delete()) {
- else {
- return true;
- * gets the specified url column from db
- * @return string requested url
-function getUpdateUrl($obj){
- global $con;
- $sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
- $v = array($obj->wfs);
- $t = array('i');
- $ContentOfColumn = $row[$obj->column];
- if($obj->column == 'wfs_getcapabilities'){
- $n = new administration();
- $updateUrl = $n->checkURL($ContentOfColumn)."Version=".$row['wfs_version']."&Request=getCapabilities&SERVICE=WFS";
- }else{
- $updateUrl = $ContentOfColumn;
- return $updateUrl;
- return "";
-function getOwsproxy($obj){
- if($obj->wfs=="gui_confs")
- return false;
- return $n->getWfsOwsproxyString($obj->wfs);
-function setOwsproxy($obj){
- return false;
- return $n->setWfsOwsproxyString($obj->wfs,true);
-function removeOwsproxy($obj){
- return false;
- return $n->setWfsOwsproxyString($obj->wfs,false);
- * encodes and delivers the data
-function sendOutput($out){
- global $json;
- $output = $json->encode($out);
- header("Content-Type: text/x-json");
- echo $output;
+<?php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
+require_once(dirname(__FILE__) . "/../classes/class_universal_wfs_factory.php");
+$json = new Mapbender_JSON();
+$obj = $json->decode(stripslashes($_REQUEST['obj']));
+//workflow:
+switch($obj->action){
+ case 'getServices':
+ $obj->services = getServices($obj);
+ sendOutput($obj);
+ break;
+ case 'getWfsConfData':
+ $obj->wfsConf = getWfsConfData($obj->wfs);
+ sendOutput($obj);
+ break;
+ case 'getGuis':
+ $obj->id = getGuis($obj);
+ sendOutput($obj);
+ break;
+ case 'getAssignedConfs':
+ $obj->assignedConfs = getAssignedConfs($obj);
+ sendOutput($obj);
+ break;
+ case 'getUpdateUrl':
+ $obj->url = getUpdateUrl($obj);
+ sendOutput($obj);
+ break;
+ case 'add':
+ addConfsToGui($obj);
+ sendOutput($obj);
+ break;
+ case 'remove':
+ removeConfsFromGui($obj);
+ sendOutput($obj);
+ break;
+ case 'updateWfs':
+ updateWfs($obj);
+ sendOutput($obj);
+ break;
+ case 'deleteWfs':
+ deleteWfs($obj);
+ sendOutput($obj);
+ break;
+ case 'setOwsproxy':
+ $ows = array();
+ $ows['string'] = setOwsproxy($obj);
+ $ows['action'] = "owsproxy";
+ sendOutput($ows);
+ break;
+ case 'removeOwsproxy':
+ $ows = array();
+ $ows['string'] = removeOwsproxy($obj);
+ sendOutput($ows);
+ break;
+ case 'getOwsproxy':
+ $ows = array();
+ $ows['string'] = getOwsproxy($obj);
+ sendOutput($ows);
+ break;
+ default:
+ sendOutput("no action specified...");
+ * Get all services (ids and titles) where the current user is owner
+ * @return mixed[] services the ids and titles of the services
+function getServices(){
+ global $con;
+ $services = array();
+ $services['id'] = array();
+ $services['title'] = array();
+ $adm = new administration();
+ $serviceList = $adm->getWfsByOwner(Mapbender::session()->get("mb_user_id"));
+ if(count($serviceList) == 0){
+ return false;
+ $sql = "SELECT * FROM wfs WHERE wfs_id IN (";
+ $v = $serviceList;
+ $t = array();
+ for ($i = 1; $i <= count($serviceList); $i++) {
+ if ($i > 1) {
+ $sql .= ", ";
+ $sql .= "$" . $i;
+ array_push($t, "i");
+ $sql .= ") ORDER BY wfs_title";
+ $res = db_prep_query($sql, $v, $t);
+ while($row = db_fetch_array($res)){
+ array_push($services['id'], $row['wfs_id']);
+ array_push($services['title'], $row['wfs_title']);
+ return $services;
+ * Get all configurations of the selcted wfs if the current user is owner
+ * @return mixed[]
+function getWfsConfData($wfsID){
+ global $con;
+ // re-check permission
+ if(in_array($wfsID, $serviceList)){
+ $wfsConf = array();
+ $wfsConf['id'] = array();
+ $wfsConf['abstract'] = array();
+ $sql = "SELECT * FROM wfs_conf WHERE fkey_wfs_id = $1 ORDER BY wfs_conf_abstract";
+ $v = array($wfsID);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $cnt = 0;
+ array_push($wfsConf['id'], $row['wfs_conf_id']);
+ array_push($wfsConf['abstract'], $row['wfs_conf_abstract']);
+ $cnt++;
+ if($cnt == 0){
+ return false;
+ else{
+ return $wfsConf;
+ else if($wfsID==="gui_confs"){
+ $wfsConf['id'] = $adm->getWfsConfByPermission(Mapbender::session()->get("mb_user_id"));
+ $cnt = 0;
+ foreach($wfsConf['id'] as $wfscid){
+ $sql = "SELECT wfs_conf_abstract FROM wfs_conf WHERE wfs_conf_id = $1";
+ $v = array($wfscid);
+ $t = array('i');
+ $cnt++;
+ if($cnt == 0){
+ return false;
+ else{
+ return $wfsConf;
+ * Get all GUIs where the current user is owner. This are the GUIs where the user could publish his
+ * wfs configurations
+ * @return mixed[]
+function getGuis(){
+ $guiList = $adm->getGuisByOwner(Mapbender::session()->get("mb_user_id"),1);
+ if(count($guiList) > 0){
+ return $guiList;
+ return false;
+ * get all wfs_confs of the selected WFS which are assigned to the selected gui
+ * @param
+ * @return mixed[]
+function getAssignedConfs($obj){
+ global $con;
+ $assignedConfs = array();
+ $confs = getWfsConfData($obj->selectedWfs);
+ if($confs === false){
+ return false;
+ $sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id IN (".join(",",$confs['id']).")";
+ $v = array($obj->selectedGui);
+ $t = array('s');
+ if(!$res){
+ $e = new mb_exception("Error: SQL: " . $sql . " -> Gui: " .$obj->selectedGui);
+ array_push($assignedConfs, $row['fkey_wfs_conf_id']);
+ return $assignedConfs;
+function addConfsToGui($obj){
+ global $con;
+ for($i=0; $i<count($obj->confs); $i++){
+ $sql = "SELECT * FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
+ $v = array($obj->gui,$obj->confs->$i);
+ $t = array('s','i');
+ if(!$row = db_fetch_array($res)){
+ $sql1 = "INSERT INTO gui_wfs_conf (fkey_gui_id,fkey_wfs_conf_id) VALUES ($1,$2)";
+ $v1 = array($obj->gui, $obj->confs->$i);
+ $t1 = array('s', 'i');
+ $res1 = db_prep_query($sql1,$v1,$t1);
+function removeConfsFromGui($obj){
+ global $con;
+ $sql = "DELETE FROM gui_wfs_conf WHERE fkey_gui_id = $1 AND fkey_wfs_conf_id = $2";
+ $v = array($obj->gui, $obj->confs->$i);
+ $t = array('s', 'i');
+ * updates an WFS
+ * @param object the un-encoded object
+ * @return boolean success
+function updateWfs($obj){
+ $id = $obj->wfs;
+ $url = $obj->url;
+ $wfsFactory = new UniversalWfsFactory();
+ $myWfs = $wfsFactory->createFromUrl($url);
+ $myWfs->id = $id;
+ if(is_null($myWfs) || !$myWfs->update()){
+ $obj->success = false;
+ else {
+ $obj->success = true;
+ return true;
+ * deletes an WFS
+function deleteWfs($obj){
+ $id = $obj->wfs;
+ $myWfs = $wfsFactory->createFromDb($id);
+ if (is_null($myWfs) || !$myWfs->delete()) {
+ else {
+ return true;
+ * gets the specified url column from db
+ * @return string requested url
+function getUpdateUrl($obj){
+ global $con;
+ $sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
+ $v = array($obj->wfs);
+ $t = array('i');
+ $ContentOfColumn = $row[$obj->column];
+ if($obj->column == 'wfs_getcapabilities'){
+ $n = new administration();
+ $updateUrl = $n->checkURL($ContentOfColumn)."Version=".$row['wfs_version']."&Request=getCapabilities&SERVICE=WFS";
+ }else{
+ $updateUrl = $ContentOfColumn;
+ return $updateUrl;
+ return "";
+function getOwsproxy($obj){
+ if($obj->wfs=="gui_confs")
+ return false;
+ return $n->getWfsOwsproxyString($obj->wfs);
+function setOwsproxy($obj){
+ return false;
+ return $n->setWfsOwsproxyString($obj->wfs,true);
+function removeOwsproxy($obj){
+ return false;
+ return $n->setWfsOwsproxyString($obj->wfs,false);
+ * encodes and delivers the data
+function sendOutput($out){
+ global $json;
+ $output = $json->encode($out);
+ header("Content-Type: text/x-json");
+ echo $output;
More information about the Mapbender_commits
