[Mapbender-commits] r4205 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 06:33:00 EDT 2009
Author: vera
Date: 2009-06-25 06:33:00 -0400 (Thu, 25 Jun 2009)
New Revision: 4205
   trunk/mapbender/http/php/mod_wfsSpatialRequest_messages.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_wfsSpatialRequest_messages.php
--- trunk/mapbender/http/php/mod_wfsSpatialRequest_messages.php	2009-06-25 10:29:36 UTC (rev 4204)
+++ trunk/mapbender/http/php/mod_wfsSpatialRequest_messages.php	2009-06-25 10:33:00 UTC (rev 4205)
@@ -1,42 +1,42 @@
-<?php
-#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_json.php");
-$e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
-setlocale(LC_ALL, $_SESSION["mb_locale"]);
-// Messages
-$msg_obj = array();
-$msg_obj["buttonLabelRectangle"] = _mb("select by rectangle");
-$msg_obj["buttonLabelPolygon"] = _mb("select by polygon");
-$msg_obj["buttonLabelPoint"] = _mb("select by point");
-$msg_obj["buttonLabelExtent"] = _mb("select by extent");
-$msg_obj["buttonLabelDialogue"] = _mb("open dialogue form");
-$msg_obj["errorMessageInvalidExtent"] = _mb("Invalid box!");
-$json = new Mapbender_JSON();
-$output = $json->encode($msg_obj);
-header("Content-type:application/x-json; charset=utf-8");
-echo $output;
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
+$e = new mb_notice("locale: " . Mapbender::session()->get("mb_locale") . "; lang: " . Mapbender::session()->get("mb_lang"));
+setlocale(LC_ALL, Mapbender::session()->get("mb_locale"));
+// Messages
+$msg_obj = array();
+$msg_obj["buttonLabelRectangle"] = _mb("select by rectangle");
+$msg_obj["buttonLabelPolygon"] = _mb("select by polygon");
+$msg_obj["buttonLabelPoint"] = _mb("select by point");
+$msg_obj["buttonLabelExtent"] = _mb("select by extent");
+$msg_obj["buttonLabelDialogue"] = _mb("open dialogue form");
+$msg_obj["errorMessageInvalidExtent"] = _mb("Invalid box!");
+$json = new Mapbender_JSON();
+$output = $json->encode($msg_obj);
+header("Content-type:application/x-json; charset=utf-8");
+echo $output;
\ No newline at end of file
More information about the Mapbender_commits mailing list
