[Mapbender-commits] r4206 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 06:34:39 EDT 2009
Author: vera
Date: 2009-06-25 06:34:39 -0400 (Thu, 25 Jun 2009)
New Revision: 4206
   trunk/mapbender/http/php/mod_WMSpreferences.php
session var angepasst
Modified: trunk/mapbender/http/php/mod_WMSpreferences.php
--- trunk/mapbender/http/php/mod_WMSpreferences.php	2009-06-25 10:33:00 UTC (rev 4205)
+++ trunk/mapbender/http/php/mod_WMSpreferences.php	2009-06-25 10:34:39 UTC (rev 4206)
@@ -1,66 +1,66 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>WMS Preferences</title>
-<?php
-include '../include/dyn_css.php';
-<STYLE TYPE="text/css">
-   body{
-   	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
-   	color:#0066cc;
-      font-size:10pt
-   table{
-   	color:#808080;;
-      font-size:9pt
-   th{
-   	background-color:#F0F0F0;
-   select{
-		width:240px;
-</STYLE>
-<?php
-echo '<script type="text/javascript">';
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>WMS Preferences</title>
+<?php
+include '../include/dyn_css.php';
+<STYLE TYPE="text/css">
+   body{
+   	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+   	color:#0066cc;
+      font-size:10pt
+   table{
+   	color:#808080;;
+      font-size:9pt
+   th{
+   	background-color:#F0F0F0;
+   select{
+		width:240px;
+</STYLE>
+<?php
+echo '<script type="text/javascript">';
 $sql = "SELECT * FROM gui_element WHERE e_id = 'WMS_preferences' AND fkey_gui_id = $1";
-$v = array($_SESSION["mb_user_gui"]);
+$v = array(Mapbender::session()->get("mb_user_gui"));
 $t = array("s");
 $res = db_prep_query($sql, $v, $t);
 $cnt = 0;
@@ -73,215 +73,215 @@
 if($cnt > 1){ echo "alert('WMS_preferences: ID not unique!');";}
 $e_target = explode(",", $e_target);
-echo "var mod_WMSpreferences_target1 = '".trim($e_target[0])."';";
-echo "var mod_WMSpreferences_target2 = '".trim($e_target[1])."';";
-echo "</script>";
-$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
-$t = array("s");
-$res_visible = db_prep_query($sql_visible, $v, $t);
-$cnt_visible = 0;
-while($row = db_fetch_array($res_visible)){
-	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
-	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
-	if($cnt_visible>0){
-		$vis .= ",";
-		$wmsid .= ",";
-	$vis .= $gui_wms_visible[$cnt_visible];
-	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
-	$cnt_visible++;
-echo "var mod_gui_wms_visible = '".$vis."';";
-echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
-echo "</script>";
-<script type="text/javascript">
-var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
-var my = window.opener.mb_mapObj[ind];
+echo "var mod_WMSpreferences_target1 = '".trim($e_target[0])."';";
+echo "var mod_WMSpreferences_target2 = '".trim($e_target[1])."';";
+echo "</script>";
+$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
+$t = array("s");
+$res_visible = db_prep_query($sql_visible, $v, $t);
+$cnt_visible = 0;
+while($row = db_fetch_array($res_visible)){
+	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
+	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
+	if($cnt_visible>0){
+		$vis .= ",";
+		$wmsid .= ",";
+	$vis .= $gui_wms_visible[$cnt_visible];
+	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
+	$cnt_visible++;
+echo "var mod_gui_wms_visible = '".$vis."';";
+echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
+echo "</script>";
+<script type="text/javascript">
+var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
+var my = window.opener.mb_mapObj[ind];
  function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
- 	var myMapObj = window.opener.mb_mapObj[mapObj_ind];
-	if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
-		upper = myMapObj.wms[indexA];
-		myMapObj.wms[indexA] = myMapObj.wms[indexB];
-		myMapObj.wms[indexB] = upper;
-		var upperLayers = myMapObj.layers[indexA];
-		var upperStyles = myMapObj.styles[indexA];
-		var upperQuerylayers = myMapObj.querylayers[indexA];
-		myMapObj.layers[indexA] = myMapObj.layers[indexB];
-		myMapObj.styles[indexA] = myMapObj.styles[indexB];
-		myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
-		myMapObj.layers[indexB] = upperLayers;
-		myMapObj.styles[indexB] = upperStyles;
-		myMapObj.querylayers[indexB] = upperQuerylayers;
-		return true;
-	else {
-		return false;
-// Opacity version
+ 	var myMapObj = window.opener.mb_mapObj[mapObj_ind];
+	if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
+		upper = myMapObj.wms[indexA];
+		myMapObj.wms[indexA] = myMapObj.wms[indexB];
+		myMapObj.wms[indexB] = upper;
+		var upperLayers = myMapObj.layers[indexA];
+		var upperStyles = myMapObj.styles[indexA];
+		var upperQuerylayers = myMapObj.querylayers[indexA];
+		myMapObj.layers[indexA] = myMapObj.layers[indexB];
+		myMapObj.styles[indexA] = myMapObj.styles[indexB];
+		myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
+		myMapObj.layers[indexB] = upperLayers;
+		myMapObj.styles[indexB] = upperStyles;
+		myMapObj.querylayers[indexB] = upperQuerylayers;
+		return true;
+	else {
+		return false;
+// Opacity version
 function cambia_opacity(id,incremento){
 	opacity = my.wms[id].gui_wms_mapopacity*100 + parseInt(incremento);
 	my.wms[id].setOpacity(opacity);
 	loadWMS();
-function setMapformat(val){
-	var tmp = val.split(",");
-	my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
-	loadWMS();
-function setFeatureformat(val){
-	my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
-	loadWMS();
-function setExceptionformat(val){
-	my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
-	loadWMS();
-function swap(index1, index2){
-	if (mb_swapWmsByIndex(ind, index1, index2) == true) {
-		loadWMS();
-		window.opener.zoom(mod_WMSpreferences_target1, true, 1.0);
-		window.opener.mb_execloadWmsSubFunctions();
-function remove_wms(num){
-	var cnt_vis=0;
-	var wms_visible_down = mod_gui_wms_visible.split(",");
-	var wms_vis_down = wms_visible_down.length;
-	//check if there are more than two visible wms's
-	for(var i=0; i < wms_visible_down.length; i++){
-		var my_wms_visible = wms_visible_down[i];
-		if(my_wms_visible == 0){
-  			var cnt_vis = cnt_vis+1;
-	if(my.wms.length - cnt_vis>1){
-	  	var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
-  		window.opener.mb_mapObjremoveWMS(ind,num)
-//  	window.opener.frames[mod_WMSpreferences_target2].document.location.reload();
-  		window.location.reload();
-	else{
-		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
-function loadWMS(){
-	var str = "";
-	var wms_visible = mod_gui_wms_visible.split(",");
-	var wms_id_visible = mod_fkey_wms_id_visible.split(",");
-	var visibleWmsIndexArray = new Array();
-	for(var i=0; i < my.wms.length; i++){
-		var found = false;
-		for(var j=0; j < wms_id_visible.length; j++){
-			if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
-				visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
-				found = true;
-		if (found == false && my.wms[i].gui_wms_visible == 1) {
-	for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
-		z = visibleWmsIndexArray[i];
-		var mapString = "";
-		var featureinfoString = "";
-		var exceptionString = "";
-		for(var j=0; j<my.wms[z].data_type.length; j++){
-			if(my.wms[z].data_type[j] == 'map'){
-				mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
-					mapString += "selected";
-				mapString += ">"+my.wms[z].data_format[j]+"</option>";
-			else if(my.wms[z].data_type[j] == 'featureinfo'){
-				featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
-					featureinfoString += "selected";
-				featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
-			else if(my.wms[z].data_type[j] == 'exception'){
-				exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
-				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
-					exceptionString += "selected";
-				exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
-		str += "<table border='1' rules='rows'>";
-		str += "<tr><th>";
-		str += "<img src='../img/button_gray/up.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+visibleWmsIndexArray[i-1]+","+z+")' value='up' title='move WMS up'>&nbsp;";
-		str += "<img src='../img/button_gray/down.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+z+", "+visibleWmsIndexArray[i+1]+")'value='down'title='move WMS down'>&nbsp;</td>";
-		str += "<img src='../img/button_gray/del.png' onclick='remove_wms("+z+")' value='remove' title='remove WMS from GUI'>&nbsp;";
-		str += "</th><th  width='300'><div id ='id_"+my.wms[z].wms_id+"' style='cursor:pointer' onmouseover = 'title=\""+"id:"+my.wms[z].wms_id+" "+my.wms[z].wms_abstract+"\"'><b>"+my.wms[z].wms_title+"</b>";
-		str += "</div></th></tr>";
-		//str += "<tr><td>ID:</td><td>"+my.wms[z].wms_id+"</td></tr>";
-		str += "<tr><td>MapImageFormat: </td><td>";
-		str += "<select onchange='setMapformat(this.value)'>"
-		str += mapString;
-		str += "</select></td></tr>";
-		str += "<tr><td>FeatureInfoFormat: </td><td>";
-		str += "<select onchange='setFeatureformat(this.value)'>";
-		str += featureinfoString;
-		str += "<tr><td>ExceptionFormat: </td><td>";
-		str += "<select onchange='setExceptionformat(this.value)'>"
-		str += exceptionString;
-		str += "</select></td></tr></table>";
-		str += "<table><tr>";
-		//opacity version
-		str += "<tr><td>Opacity:</td><td><input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','-10')\" value=\"-\">";
-		str += "<input id=\"valor_opacity_"+visibleWmsIndexArray[i]+"\" type=\"text\" disabled=\"disabled\" size=\"3\" value=\""+my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100+" %\">";
-		str += "<input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','+10')\" value=\"+\">";
-		str += "</td></tr>";
-		str += "</tr></table><br>";
-	document.getElementById('data').innerHTML = str;
-</script>
-</head>
-<body onload='loadWMS()'>
-<div id='data'><div>
-<form>
-<input type='hidden' name='visibility' value=''>
-</form>
-</body>
-</html>
+function setMapformat(val){
+	var tmp = val.split(",");
+	my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
+	loadWMS();
+function setFeatureformat(val){
+	my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
+	loadWMS();
+function setExceptionformat(val){
+	my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
+	loadWMS();
+function swap(index1, index2){
+	if (mb_swapWmsByIndex(ind, index1, index2) == true) {
+		loadWMS();
+		window.opener.zoom(mod_WMSpreferences_target1, true, 1.0);
+		window.opener.mb_execloadWmsSubFunctions();
+function remove_wms(num){
+	var cnt_vis=0;
+	var wms_visible_down = mod_gui_wms_visible.split(",");
+	var wms_vis_down = wms_visible_down.length;
+	//check if there are more than two visible wms's
+	for(var i=0; i < wms_visible_down.length; i++){
+		var my_wms_visible = wms_visible_down[i];
+		if(my_wms_visible == 0){
+  			var cnt_vis = cnt_vis+1;
+	if(my.wms.length - cnt_vis>1){
+	  	var ind = window.opener.getMapObjIndexByName(mod_WMSpreferences_target1);
+  		window.opener.mb_mapObjremoveWMS(ind,num)
+//  	window.opener.frames[mod_WMSpreferences_target2].document.location.reload();
+  		window.location.reload();
+	else{
+		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+function loadWMS(){
+	var str = "";
+	var wms_visible = mod_gui_wms_visible.split(",");
+	var wms_id_visible = mod_fkey_wms_id_visible.split(",");
+	var visibleWmsIndexArray = new Array();
+	for(var i=0; i < my.wms.length; i++){
+		var found = false;
+		for(var j=0; j < wms_id_visible.length; j++){
+			if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
+				visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
+				found = true;
+		if (found == false && my.wms[i].gui_wms_visible == 1) {
+	for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
+		z = visibleWmsIndexArray[i];
+		var mapString = "";
+		var featureinfoString = "";
+		var exceptionString = "";
+		for(var j=0; j<my.wms[z].data_type.length; j++){
+			if(my.wms[z].data_type[j] == 'map'){
+				mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
+					mapString += "selected";
+				mapString += ">"+my.wms[z].data_format[j]+"</option>";
+			else if(my.wms[z].data_type[j] == 'featureinfo'){
+				featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
+					featureinfoString += "selected";
+				featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
+			else if(my.wms[z].data_type[j] == 'exception'){
+				exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+				if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
+					exceptionString += "selected";
+				exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
+		str += "<table border='1' rules='rows'>";
+		str += "<tr><th>";
+		str += "<img src='../img/button_gray/up.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+visibleWmsIndexArray[i-1]+","+z+")' value='up' title='move WMS up'>&nbsp;";
+		str += "<img src='../img/button_gray/down.png' style='filter:Chroma(color=#C2CBCF);' onclick='swap("+z+", "+visibleWmsIndexArray[i+1]+")'value='down'title='move WMS down'>&nbsp;</td>";
+		str += "<img src='../img/button_gray/del.png' onclick='remove_wms("+z+")' value='remove' title='remove WMS from GUI'>&nbsp;";
+		str += "</th><th  width='300'><div id ='id_"+my.wms[z].wms_id+"' style='cursor:pointer' onmouseover = 'title=\""+"id:"+my.wms[z].wms_id+" "+my.wms[z].wms_abstract+"\"'><b>"+my.wms[z].wms_title+"</b>";
+		str += "</div></th></tr>";
+		//str += "<tr><td>ID:</td><td>"+my.wms[z].wms_id+"</td></tr>";
+		str += "<tr><td>MapImageFormat: </td><td>";
+		str += "<select onchange='setMapformat(this.value)'>"
+		str += mapString;
+		str += "</select></td></tr>";
+		str += "<tr><td>FeatureInfoFormat: </td><td>";
+		str += "<select onchange='setFeatureformat(this.value)'>";
+		str += featureinfoString;
+		str += "<tr><td>ExceptionFormat: </td><td>";
+		str += "<select onchange='setExceptionformat(this.value)'>"
+		str += exceptionString;
+		str += "</select></td></tr></table>";
+		str += "<table><tr>";
+		//opacity version
+		str += "<tr><td>Opacity:</td><td><input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','-10')\" value=\"-\">";
+		str += "<input id=\"valor_opacity_"+visibleWmsIndexArray[i]+"\" type=\"text\" disabled=\"disabled\" size=\"3\" value=\""+my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100+" %\">";
+		str += "<input type=\"button\" onclick=\"cambia_opacity('"+visibleWmsIndexArray[i]+"','+10')\" value=\"+\">";
+		str += "</td></tr>";
+		str += "</tr></table><br>";
+	document.getElementById('data').innerHTML = str;
+</script>
+</head>
+<body onload='loadWMS()'>
+<div id='data'><div>
+<form>
+<input type='hidden' name='visibility' value=''>
+</form>
+</body>
+</html>
More information about the Mapbender_commits mailing list
