[Mapbender-commits] r4212 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 07:00:58 EDT 2009
Author: vera
Date: 2009-06-25 07:00:57 -0400 (Thu, 25 Jun 2009)
New Revision: 4212
   trunk/mapbender/http/javascripts/mod_savewmc.php
session var angepasst
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2009-06-25 10:57:25 UTC (rev 4211)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2009-06-25 11:00:57 UTC (rev 4212)
@@ -1,82 +1,82 @@
-<?php
-# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
-# http://www.mapbender.org/index.php/mod_savewmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-include(dirname(__FILE__) . "/../include/dyn_js.php");
-echo "mod_savewmc_target = '".$e_target[0]."';";
-function setOnUnload() {
-	if (ie) {
-		document.getElementsByTagName('body')[0].onunload = function() {
-			var x = new Function ("", "mod_savewmc_session()"); x();
-	else {
-		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
-try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
-if (saveInSession == 1) {
-	eventAfterMapRequest.register(function () {
-		mod_savewmc_session();
-//	mb_registerInitFunctions('setOnUnload()');
-<?php
-if ($e_src) {
-	sprintf("var mod_savewmc_img = new Image();
-			mod_savewmc_img.src = '%s';", $e_src);
-//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function mod_savewmc_session(){
-	sendMapDataToServer("session", 1, function(result, status) {});
-function mod_savewmc(title){
-	var generalTitle = title ? title : prompt("Save WMC as...");
-	if (generalTitle != "" && generalTitle != null) {
-		sendMapDataToServer(generalTitle, 0, function(result, status) {alert(status + ": " + result);});
-function sendMapDataToServer(generalTitle, storeInSession, callbackFunction) {
-	var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
-	var ind = getMapObjIndexByName(mod_savewmc_target);
-	var	extensionDataString = "";
-	if (currentWmcExtensionData != null) {
-		extensionDataString = $.toJSON(currentWmcExtensionData);
-	if (storeInSession) {
-		$.ajaxSetup({async:false});
-	$.post("../php/mod_savewmc_server.php", {
-		"saveInSession":storeInSession,
-		"generalTitle":generalTitle,
-		"extensionData":extensionDataString,
-		"mapObject":$.toJSON(mb_mapObj)
-	}, callbackFunction);
+<?php
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+include(dirname(__FILE__) . "/../include/dyn_js.php");
+echo "mod_savewmc_target = '".$e_target[0]."';";
+function setOnUnload() {
+	if (ie) {
+		document.getElementsByTagName('body')[0].onunload = function() {
+			var x = new Function ("", "mod_savewmc_session()"); x();
+	else {
+		document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc_session();");
+try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
+if (saveInSession == 1) {
+	eventAfterMapRequest.register(function () {
+		mod_savewmc_session();
+//	mb_registerInitFunctions('setOnUnload()');
+<?php
+if ($e_src) {
+	sprintf("var mod_savewmc_img = new Image();
+			mod_savewmc_img.src = '%s';", $e_src);
+//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+function mod_savewmc_session(){
+	sendMapDataToServer("session", 1, function(result, status) {});
+function mod_savewmc(title){
+	var generalTitle = title ? title : prompt("Save WMC as...");
+	if (generalTitle != "" && generalTitle != null) {
+		sendMapDataToServer(generalTitle, 0, function(result, status) {alert(status + ": " + result);});
+function sendMapDataToServer(generalTitle, storeInSession, callbackFunction) {
+	var user = "<?php echo Mapbender::session()->get("mb_user_id"); ?>";
+	var ind = getMapObjIndexByName(mod_savewmc_target);
+	var	extensionDataString = "";
+	if (currentWmcExtensionData != null) {
+		extensionDataString = $.toJSON(currentWmcExtensionData);
+	if (storeInSession) {
+		$.ajaxSetup({async:false});
+	$.post("../php/mod_savewmc_server.php", {
+		"saveInSession":storeInSession,
+		"generalTitle":generalTitle,
+		"extensionData":extensionDataString,
+		"mapObject":$.toJSON(mb_mapObj)
+	}, callbackFunction);
More information about the Mapbender_commits mailing list
