[Mapbender-commits] r4213 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 07:02:11 EDT 2009
Author: vera
Date: 2009-06-25 07:02:11 -0400 (Thu, 25 Jun 2009)
New Revision: 4213
   trunk/mapbender/http/javascripts/mod_saveWmcKml.php
session var angepasst
Modified: trunk/mapbender/http/javascripts/mod_saveWmcKml.php
--- trunk/mapbender/http/javascripts/mod_saveWmcKml.php	2009-06-25 11:00:57 UTC (rev 4212)
+++ trunk/mapbender/http/javascripts/mod_saveWmcKml.php	2009-06-25 11:02:11 UTC (rev 4213)
@@ -1,108 +1,108 @@
-<?php
-# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
-# http://www.mapbender.org/index.php/mod_savewmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-echo "mod_savewmc_target = '".$e_target[0]."';";
-var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
-//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-function mod_saveWmcKml(obj){
-	current_user = "<?php echo $_SESSION["mb_user_id"]; ?>";
-	current_password = "<?php echo $_SESSION["mb_user_password"];?>";
-	current_gui = "<?php echo $gui_id;?>";
-	alert('Please set the meeting point by clicking the map.');
-	var ind = getMapObjIndexByName(mod_savewmc_target);
-	var el = frames[mod_savewmc_target].document;
-	el.onmousedown = mod_getMousePos;
-	el.onmouseup = null;
-	el.onmousemove = null;
-	el.onmouseover = null;
-function mod_getMousePos(e) {
-	mb_getMousePos(e,mod_savewmc_target);
-	var q = new Point(clickX,clickY);
-	var realWorldPos = mapToReal(mod_savewmc_target,q);
-	el.onmousedown = null;
-	//alert(realWorldPos);
-	//document.sendData.target = "_blank";
-	//document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
-	//document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
-	//document.sendData.submit();
-	saveWindow = open("", "save", "width=400, height=300, resizable, dependent=yes, scrollbars=yes");
-	saveWindow.document.open("text/html");
-	var cssLink = saveWindow.document.createElement("link");
-	cssLink.setAttribute("href", wfsCssUrl);
-	cssLink.setAttribute("type", "text/css");
-	cssLink.setAttribute("rel", "stylesheet");
-	var cssTmp = saveWindow.document.getElementsByTagName("head")[0];
-	cssTmp.appendChild(cssLink);
-	var wmc_title = "meetingpoint";
-	var icon = "http://wms1.ccgis.de/mapbender_dev/img/pin.png";
-	var str = "";
-	var onclick = "wmcid=window.opener.mod_savewmc('"+wmc_title+"');";
-	onclick += "document.sendData.action = '../javascripts/mod_insertKmlIntoDb.php?<?php echo SID;?>';";
-	onclick += "document.sendData.data.value = wmcid + '____" + realWorldPos.x + "____" + realWorldPos.y + "____"+ icon + "____<?php echo $gui_id;?>';";
-	onclick += "document.sendData.submit();"
-	str += "<form name='sendData' method='post'>\n";
-	str += "<table>\n";
-	str += "<tr>\n";
-	str += "<td>Name</td>\n";
-	str += "<td><input type='text' name='name'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Strasse</td>\n";
-	str += "<td><input type='text' name='street'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>PLZ</td>\n";
-	str += "<td><input type='text' name='postcode'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Ort</td>\n";
-	str += "<td><input type='text' name='city'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Webseite</td>\n";
-	str += "<td><input type='text' name='website'></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td>Beschreibung</td>\n";
-	str += "<td><textarea name='description'></textarea></td>\n";
-	str += "</tr>\n";
-	str += "<tr>\n";
-	str += "<td colspan=2><input type='button' value='URL generieren' name='generateUrl' onclick=\""+onclick+"\"></td>\n";
-	str += "</tr>\n";
-	str += "</table>\n";
-	str += "<input type=hidden name=data>\n";
-	str += "</form>";
-	saveWindow.document.write(str);
-	saveWindow.document.close();
+<?php
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+echo "mod_savewmc_target = '".$e_target[0]."';";
+var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
+//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+function mod_saveWmcKml(obj){
+	current_user = "<?php echo Mapbender::session()->get("mb_user_id"); ?>";
+	current_password = "<?php echo Mapbender::session()->get("mb_user_password");?>";
+	current_gui = "<?php echo $gui_id;?>";
+	alert('Please set the meeting point by clicking the map.');
+	var ind = getMapObjIndexByName(mod_savewmc_target);
+	var el = frames[mod_savewmc_target].document;
+	el.onmousedown = mod_getMousePos;
+	el.onmouseup = null;
+	el.onmousemove = null;
+	el.onmouseover = null;
+function mod_getMousePos(e) {
+	mb_getMousePos(e,mod_savewmc_target);
+	var q = new Point(clickX,clickY);
+	var realWorldPos = mapToReal(mod_savewmc_target,q);
+	el.onmousedown = null;
+	//alert(realWorldPos);
+	//document.sendData.target = "_blank";
+	//document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
+	//document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id;
+	//document.sendData.submit();
+	saveWindow = open("", "save", "width=400, height=300, resizable, dependent=yes, scrollbars=yes");
+	saveWindow.document.open("text/html");
+	var cssLink = saveWindow.document.createElement("link");
+	cssLink.setAttribute("href", wfsCssUrl);
+	cssLink.setAttribute("type", "text/css");
+	cssLink.setAttribute("rel", "stylesheet");
+	var cssTmp = saveWindow.document.getElementsByTagName("head")[0];
+	cssTmp.appendChild(cssLink);
+	var wmc_title = "meetingpoint";
+	var icon = "http://wms1.ccgis.de/mapbender_dev/img/pin.png";
+	var str = "";
+	var onclick = "wmcid=window.opener.mod_savewmc('"+wmc_title+"');";
+	onclick += "document.sendData.action = '../javascripts/mod_insertKmlIntoDb.php?<?php echo SID;?>';";
+	onclick += "document.sendData.data.value = wmcid + '____" + realWorldPos.x + "____" + realWorldPos.y + "____"+ icon + "____<?php echo $gui_id;?>';";
+	onclick += "document.sendData.submit();"
+	str += "<form name='sendData' method='post'>\n";
+	str += "<table>\n";
+	str += "<tr>\n";
+	str += "<td>Name</td>\n";
+	str += "<td><input type='text' name='name'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Strasse</td>\n";
+	str += "<td><input type='text' name='street'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>PLZ</td>\n";
+	str += "<td><input type='text' name='postcode'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Ort</td>\n";
+	str += "<td><input type='text' name='city'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Webseite</td>\n";
+	str += "<td><input type='text' name='website'></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td>Beschreibung</td>\n";
+	str += "<td><textarea name='description'></textarea></td>\n";
+	str += "</tr>\n";
+	str += "<tr>\n";
+	str += "<td colspan=2><input type='button' value='URL generieren' name='generateUrl' onclick=\""+onclick+"\"></td>\n";
+	str += "</tr>\n";
+	str += "</table>\n";
+	str += "<input type=hidden name=data>\n";
+	str += "</form>";
+	saveWindow.document.write(str);
+	saveWindow.document.close();
\ No newline at end of file
More information about the Mapbender_commits mailing list
