[Mapbender-commits] r4226 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 07:50:57 EDT 2009
Author: vera
Date: 2009-06-25 07:50:57 -0400 (Thu, 25 Jun 2009)
New Revision: 4226
   trunk/mapbender/http/javascripts/mod_insertKmlIntoDb.php
session var angepasst
Modified: trunk/mapbender/http/javascripts/mod_insertKmlIntoDb.php
--- trunk/mapbender/http/javascripts/mod_insertKmlIntoDb.php	2009-06-25 11:49:32 UTC (rev 4225)
+++ trunk/mapbender/http/javascripts/mod_insertKmlIntoDb.php	2009-06-25 11:50:57 UTC (rev 4226)
@@ -1,98 +1,98 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-include(dirname(__FILE__) . "/../classes/class_kml.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-Licensing: See the GNU General Public License for more details.
-http://www.gnu.org/copyleft/gpl.html
-or:
-mapbender/licence/
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>MB2 - <?php  echo  $gui_id;?></title>
-</head>
-<body>
-<?php
-if ($_POST["data"]) {
-	$d = explode("____", $_POST["data"]);
-	$wmc_id = $d[0];
-	$x = $d[1];
-	$y = $d[2];
-	$icon = $d[3];
-	$gui_id = $d[4];
-	$title_array = array();
-	if ($_POST['name']) $title_array[count($title_array)] = $_POST['name'];
-	if ($_POST['street']) $title_array[count($title_array)] = $_POST['street'];
-	if ($_POST['postcode']) {
-		if ($_POST['city']) {
-			$title_array[count($title_array)] = $_POST['postcode'] . " " . $_POST['city'];
-		else {
-			$title_array[count($title_array)] = $_POST['postcode'];
-	elseif ($_POST['city']) {
-		$title_array[count($title_array)] = $_POST['city'];
-	if ($_POST['website']) $title_array[count($title_array)] = $_POST['website'];
-	$title = implode(", ", $title_array);
-	$description = $_POST['description'];
-	$kml = new kml($title, $description, $x, $y, $icon);
-	$kml->createKMLFromObj();
-	$sql = "INSERT INTO mb_meetingpoint VALUES ($1, $2, $3, $4, $5, $6)";
-	$v = array($kml->kml_id, $wmc_id, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)), $_SESSION["mb_user_id"], $_SESSION["mb_user_password"], $gui_id);
-	$t = array('s', 's', 's', 'i', 's', 's');
-	$res = db_prep_query($sql, $v, $t);
-	if (db_error()) {
-		echo "<script>var title = \"" . $title . "\";alert(\"Error while saving KML document \" + title + \"! ".db_error()."\");</script>";
-	else {
-		if ($alert) {
-			 echo "<script>var title = \"" . $title . "\";alert(\"KML document \" + title + \"has been saved!\")</script>";
-	$filename = "../tmp/".$kml->kml_id.'.kml';
-	$handle = fopen($filename, "w");
-	fputs($handle, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)));
-	fclose($handle);
-	echo "Please feel free to add the <a href = 'http://".$_SERVER['HTTP_HOST']."/mburl/".$kml->kml_id."'>link</a> to your meeting point to your website.<br><br>";
-	echo "<a href='".$filename."'>kml</a>";
-</body>
-</html>
+<?php
+#$Id$
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include(dirname(__FILE__) . "/../classes/class_kml.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+Licensing: See the GNU General Public License for more details.
+http://www.gnu.org/copyleft/gpl.html
+or:
+mapbender/licence/
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>MB2 - <?php  echo  $gui_id;?></title>
+</head>
+<body>
+<?php
+if ($_POST["data"]) {
+	$d = explode("____", $_POST["data"]);
+	$wmc_id = $d[0];
+	$x = $d[1];
+	$y = $d[2];
+	$icon = $d[3];
+	$gui_id = $d[4];
+	$title_array = array();
+	if ($_POST['name']) $title_array[count($title_array)] = $_POST['name'];
+	if ($_POST['street']) $title_array[count($title_array)] = $_POST['street'];
+	if ($_POST['postcode']) {
+		if ($_POST['city']) {
+			$title_array[count($title_array)] = $_POST['postcode'] . " " . $_POST['city'];
+		else {
+			$title_array[count($title_array)] = $_POST['postcode'];
+	elseif ($_POST['city']) {
+		$title_array[count($title_array)] = $_POST['city'];
+	if ($_POST['website']) $title_array[count($title_array)] = $_POST['website'];
+	$title = implode(", ", $title_array);
+	$description = $_POST['description'];
+	$kml = new kml($title, $description, $x, $y, $icon);
+	$kml->createKMLFromObj();
+	$sql = "INSERT INTO mb_meetingpoint VALUES ($1, $2, $3, $4, $5, $6)";
+	$v = array($kml->kml_id, $wmc_id, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)), Mapbender::session()->get("mb_user_id"), Mapbender::session()->get("mb_user_password"), $gui_id);
+	$t = array('s', 's', 's', 'i', 's', 's');
+	$res = db_prep_query($sql, $v, $t);
+	if (db_error()) {
+		echo "<script>var title = \"" . $title . "\";alert(\"Error while saving KML document \" + title + \"! ".db_error()."\");</script>";
+	else {
+		if ($alert) {
+			 echo "<script>var title = \"" . $title . "\";alert(\"KML document \" + title + \"has been saved!\")</script>";
+	$filename = "../tmp/".$kml->kml_id.'.kml';
+	$handle = fopen($filename, "w");
+	fputs($handle, preg_replace("/&/", "&#38;" , html_entity_decode($kml->kml)));
+	fclose($handle);
+	echo "Please feel free to add the <a href = 'http://".$_SERVER['HTTP_HOST']."/mburl/".$kml->kml_id."'>link</a> to your meeting point to your website.<br><br>";
+	echo "<a href='".$filename."'>kml</a>";
+</body>
+</html>
More information about the Mapbender_commits mailing list
