[Mapbender-commits] r4227 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 25 07:52:01 EDT 2009
Author: vera
Date: 2009-06-25 07:52:00 -0400 (Thu, 25 Jun 2009)
New Revision: 4227
   trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
session var angepasst
Modified: trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php
--- trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php	2009-06-25 11:50:57 UTC (rev 4226)
+++ trunk/mapbender/http/javascripts/mod_insertLayerPreviewIntoDb.php	2009-06-25 11:52:00 UTC (rev 4227)
@@ -1,163 +1,163 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-#include(dirname(__FILE__)."/../../conf/geoportal.conf");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-require_once(dirname(__FILE__)."/../classes/class_connector.php");
-function savePreview($fileName, $fileContent) {
-	if (strlen($fileContent) > 0) {
-		$fileMapImg = fopen("..".LAYER_PREVIEW_URL."/".$fileName, 'w+');
-		if ($fileMapImg) {
-			rewind($fileMapImg);
-			$bytesWritten = fwrite($fileMapImg, $fileContent);
-			if ($bytesWritten) {
-				fflush($fileMapImg);
-				ftruncate($fileMapImg, ftell($fileMapImg));
-				fclose($fileMapImg);
-				return true;
-			$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": 0 bytes written.");
-			return false;
-		$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": could not open.");
-		return false;
-	$e = new mb_exception($fileName.": no file content.");
-	return false;
-if ($_POST["data"]) {
-	$d = explode("____", $_POST["data"]);
-	$mapurl = $d[0];
-	$legendurl = $d[1];
-	$mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_WIDTH."\\2", $mapurl);
-	$mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_HEIGHT."\\2", $mapurl);
-	$adm = new administration();
-	$layer_id = $_SESSION['layer_preview'];
-	if (!$layer_id) {
-		 echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
-	else {
-		session_write_close();
-		$con1 = new connector($mapurl);
-		$fileNameMap = $layer_id."_layer_map_preview.png";
-		$fileContentMap = $con1->file;
-		$success = savePreview($fileNameMap, $fileContentMap);
-		if (!$success) $fileNameMap = "";
-		$con2 = new	connector($legendurl);
-		$fileNameLegend = $layer_id."_layer_legend_preview.png";
-		$fileContentLegend = $con2->file;
-		$success = savePreview($fileNameLegend, $fileContentLegend);
-		if (!$success) $fileNameLegend = "";
-//		$rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
-		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
-		$sql = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'";
-		$v = array($layer_id);
-		$t = array('i');
-		$res = db_prep_query($sql, $v, $t);
-		$row = db_fetch_array($res);
-		if ($row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
-			$extent_layer_id = $layer_id;
-			$layer_4326_box = array($row['minx'], $row['miny'], $row['maxx'], $row['maxy']);
-		else {
-			$sql = "SELECT * FROM (SELECT fkey_wms_id FROM layer WHERE layer_id = $1 LIMIT 1) AS w, layer_epsg AS e, layer AS l WHERE l.fkey_wms_id = w.fkey_wms_id AND l.layer_pos = 0 AND l.layer_id = e.fkey_layer_id AND e.epsg = 'EPSG:4326'";
-			$t = array('i');
-			if ($row['epsg'] && $row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
-				$extent_layer_id = $row['layer_id'];
-			else {
-				$layer_4326_box = $rlp_4326_box;
-		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
-			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
-				$rlp_4326_box[0] = $layer_4326_box[0];
-			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
-				$rlp_4326_box[2] = $layer_4326_box[2];
-			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
-				$rlp_4326_box[1] = $layer_4326_box[1];
-			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
-				$rlp_4326_box[3] = $layer_4326_box[3];
-			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
-			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
-			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
-			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
-			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
-			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
-			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
-			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
-			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
-			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
-		$con3 = new connector(LAYER_EXTENT_URL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
-		$fileNameExtent = $layer_id."_layer_extent_preview.png";
-		$fileContentExtent = $con3->file;
-		$success = savePreview($fileNameExtent, $fileContentExtent);
-		if (!$success) $fileNameExtent = "";
-		$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
-		$t = array('i');
-		if ($row['fkey_layer_id'] == $layer_id) {
-			$sql = "UPDATE layer_preview SET layer_map_preview_filename = $1, layer_extent_preview_filename = $2, layer_legend_preview_filename = $3 WHERE fkey_layer_id = $4";
-			$v = array($fileNameMap, $fileNameExtent, $fileNameLegend, $layer_id);
-			$t = array('s', 's', 's', 'i');
-		else {
-			$sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview_filename, layer_extent_preview_filename, layer_legend_preview_filename) VALUES ($1, $2, $3, $4)";
-			$v = array($layer_id, $fileNameMap, $fileNameExtent, $fileNameLegend);
-			$t = array('i', 's', 's', 's');
-		if (db_error()) {
-			 echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
-		else {
-			 echo "<script>try{parent.opener.document.getElementById('".$layer_id."_dp').style.display='';}catch(e){};alert(\"Layer preview has been saved!\")</script>";
-</body>
-<html>
+<?php
+#$Id$
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+#include(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+function savePreview($fileName, $fileContent) {
+	if (strlen($fileContent) > 0) {
+		$fileMapImg = fopen("..".LAYER_PREVIEW_URL."/".$fileName, 'w+');
+		if ($fileMapImg) {
+			rewind($fileMapImg);
+			$bytesWritten = fwrite($fileMapImg, $fileContent);
+			if ($bytesWritten) {
+				fflush($fileMapImg);
+				ftruncate($fileMapImg, ftell($fileMapImg));
+				fclose($fileMapImg);
+				return true;
+			$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": 0 bytes written.");
+			return false;
+		$e = new mb_exception("..".LAYER_PREVIEW_URL."/".$fileName.": could not open.");
+		return false;
+	$e = new mb_exception($fileName.": no file content.");
+	return false;
+if ($_POST["data"]) {
+	$d = explode("____", $_POST["data"]);
+	$mapurl = $d[0];
+	$legendurl = $d[1];
+	$mapurl = eregi_replace("(&width=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_WIDTH."\\2", $mapurl);
+	$mapurl = eregi_replace("(&height=)[0-9]+($|[^0-9])", "\\1".LAYER_PREVIEW_HEIGHT."\\2", $mapurl);
+	$adm = new administration();
+	$layer_id = Mapbender::session()->get("layer_preview");
+	if (!$layer_id) {
+		 echo "<script>alert('Could not find wms: ".$wms_getmap."');</script>";
+	else {
+		session_write_close();
+		$con1 = new connector($mapurl);
+		$fileNameMap = $layer_id."_layer_map_preview.png";
+		$fileContentMap = $con1->file;
+		$success = savePreview($fileNameMap, $fileContentMap);
+		if (!$success) $fileNameMap = "";
+		$con2 = new	connector($legendurl);
+		$fileNameLegend = $layer_id."_layer_legend_preview.png";
+		$fileContentLegend = $con2->file;
+		$success = savePreview($fileNameLegend, $fileContentLegend);
+		if (!$success) $fileNameLegend = "";
+//		$rlp_4326_box = array(6.10988942079081,48.987785376052,8.58790010810365,50.9273496139233);
+		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
+		$sql = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = 'EPSG:4326'";
+		$v = array($layer_id);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		if ($row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+			$extent_layer_id = $layer_id;
+			$layer_4326_box = array($row['minx'], $row['miny'], $row['maxx'], $row['maxy']);
+		else {
+			$sql = "SELECT * FROM (SELECT fkey_wms_id FROM layer WHERE layer_id = $1 LIMIT 1) AS w, layer_epsg AS e, layer AS l WHERE l.fkey_wms_id = w.fkey_wms_id AND l.layer_pos = 0 AND l.layer_id = e.fkey_layer_id AND e.epsg = 'EPSG:4326'";
+			$t = array('i');
+			if ($row['epsg'] && $row['minx'] && $row['miny'] && $row['maxx'] && $row['maxy']) {
+				$extent_layer_id = $row['layer_id'];
+			else {
+				$layer_4326_box = $rlp_4326_box;
+		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
+			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
+				$rlp_4326_box[0] = $layer_4326_box[0];
+			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
+				$rlp_4326_box[2] = $layer_4326_box[2];
+			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
+				$rlp_4326_box[1] = $layer_4326_box[1];
+			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
+				$rlp_4326_box[3] = $layer_4326_box[3];
+			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
+			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
+			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
+			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
+			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
+			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
+			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
+			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
+			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
+			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
+		$con3 = new connector(LAYER_EXTENT_URL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=rlp,ows_layer&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&layer_id=".$extent_layer_id);
+		$fileNameExtent = $layer_id."_layer_extent_preview.png";
+		$fileContentExtent = $con3->file;
+		$success = savePreview($fileNameExtent, $fileContentExtent);
+		if (!$success) $fileNameExtent = "";
+		$sql = "SELECT * FROM layer_preview WHERE fkey_layer_id = $1";
+		$t = array('i');
+		if ($row['fkey_layer_id'] == $layer_id) {
+			$sql = "UPDATE layer_preview SET layer_map_preview_filename = $1, layer_extent_preview_filename = $2, layer_legend_preview_filename = $3 WHERE fkey_layer_id = $4";
+			$v = array($fileNameMap, $fileNameExtent, $fileNameLegend, $layer_id);
+			$t = array('s', 's', 's', 'i');
+		else {
+			$sql = "INSERT INTO layer_preview (fkey_layer_id, layer_map_preview_filename, layer_extent_preview_filename, layer_legend_preview_filename) VALUES ($1, $2, $3, $4)";
+			$v = array($layer_id, $fileNameMap, $fileNameExtent, $fileNameLegend);
+			$t = array('i', 's', 's', 's');
+		if (db_error()) {
+			 echo "<script>alert(\"Error while saving layer preview: ".addslashes(db_error())."\");</script>";
+		else {
+			 echo "<script>try{parent.opener.document.getElementById('".$layer_id."_dp').style.display='';}catch(e){};alert(\"Layer preview has been saved!\")</script>";
+</body>
+<html>
More information about the Mapbender_commits mailing list
